This backports the following upstream commits all as one patch:
54f5de709984bae0d31d823ff03de755f9dcac54
ecc1a8993751de4e82eb18640d631dae1f626bd6
1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f
f106af4e90eadd76cfc0b5325f659619e08fb762
097eed103862f9c6a97f2e415e21d1134017b135
935874141df839c706cd6cdc438e85eb69d1525e
0ec62d290912bb4b989be7563851bc364ec73b56
c4caa778157dbbf04116f0ac2111e389b5cd7a29
2ea1d13f64efdf49319e86c87d9ba38c30902782
570dcf2c15463842e384eb597a87c1e39bead99b
564b3bffc619dcbdd160de597b0547a7017ea010
0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301
f8b7256096a20436f6d0926747e3ac3d64c81d24
8c7b49b3ecd48923eb64ff57e07a1cdb74782970
9206de95b1ea68357996ec02be5db0638a0de2c1
2c6a10161d0b5fc047b5bd81b03693b9af99fab5
05d72faa6d13c9d857478a5d35c85db9adada685
bb52d6694002b9d632bb355f64daa045c6293a4e
e77414e0aad6a1b063ba5e5750c582c75327ea6a
aa65607373a4daf2010e8c3867b6317619f3c1a3
Backport done by Greg Kroah-Hartman. Only minor tweaks were needed.
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Previous patch d63678d607d0e37ec7abe5ceb545d7e8aab956a4 clear
it for noMMU kernel. This one do it for MMU.
Correct noMMU version
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze: (24 commits)
microblaze: Disable heartbeat/enable emaclite in defconfigs
microblaze: Support simpleImage.dts make target
microblaze: Fix _start symbol to physical address
microblaze: Use LOAD_OFFSET macro to get correct LMA for all sections
microblaze: Create the LOAD_OFFSET macro used to compute VMA vs LMA offsets
microblaze: Copy ppc asm-compat.h for clean handling of constants in asm and C
microblaze: Actually show KiB rather than pages in "Freeing initrd memory:"
microblaze: Support ptrace syscall tracing.
microblaze: Updated CPU version and FPGA family codes in PVR
microblaze: Generate correct signal and siginfo for integer div-by-zero
microblaze: Don't be noisy when userspace causes hardware exceptions
microblaze: Remove ipc.h file which points to non-existing asm-generic file
microblaze: Clear sticky FSR register after generating exception signals
microblaze: Ensure CPU usermode is set on new userspace processes
microblaze: Use correct kbuild variable KBUILD_CFLAGS
microblaze: Save and restore msr in hw exception
microblaze: Add architectural support for USB EHCI host controllers
microblaze: Implement include/asm/syscall.h.
microblaze: Improve checking mechanism for MSR instruction
microblaze: Add checking mechanism for MSR instruction
I need to disable heartbeat function because this features
breaks testing in Qemu.
Instead of remembering to specify DTB= on the make commandline, this commit
allows the much friendlier make simpleImage.<dts>
where <dts>.dts is expected to be found in arch/microblaze/boot/dts/
The resulting vmlinux, with the compiled DTS linked in, will be copied to
boot/simpleImage.<dts>
This mirrors the same functionality as on PowerPC,
albeit achieving it in a slightly different way.
+ strip simpleImage file
The size of output file is very similar to linux.bin.
vmlinux - full elf without fdt blob
simpleImage.<dtb name>.unstrip - full elf with fdt blob
simpleImage.<dtb name> - stripped elf with fdt blob
Add symlink to generic system.dts in platform folder
Signed-off-by: John Williams <john.williams@petalogix.com>
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits)
Use macros for .data.page_aligned section.
Use macros for .bss.page_aligned section.
Use new __init_task_data macro in arch init_task.c files.
kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts.
arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0
kbuild: add static to prototypes
kbuild: fail build if recordmcount.pl fails
kbuild: set -fconserve-stack option for gcc 4.5
kbuild: echo the record_mcount command
gconfig: disable "typeahead find" search in treeviews
kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling
checkincludes.pl: add option to remove duplicates in place
markup_oops: use modinfo to avoid confusion with underscored module names
checkincludes.pl: provide usage helper
checkincludes.pl: close file as soon as we're done with it
ctags: usability fix
kernel hacking: move STRIP_ASM_SYMS from General
gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma
kbuild: Check if linker supports the -X option
kbuild: introduce ld-option
Fix trivial conflict in scripts/basic/fixdep.c
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()")
modified nr_free_pages() to return 'unsigned long' instead of 'unsigned
int'. This made the casts to 'unsigned long' in most callers superfluous,
so remove them.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Chris Zankel <zankel@tensilica.com>
_start is setup to physical kernel start address.
This caused that when you load vmlinux (with MMU kernel)
via XMD program counter (pc) is setup correctly
and then you can write con and start kernel.
Currently, vmlinux has LMA==VMA for all sections, which is wrong for MMU
kernels. Previous patches in this series defined the LOAD_OFFSET constant,
now we make use of it in our link script.
Other minor changes in this patch:
* brace/indenting cleanup of some sections
* put __fdt_* symbols in their own section, and apply LOAD_OFFSET fixup
LOAD_OFFSET is the offset between the physical load address and the kernel's
virtual address. It will be used in the upcoming commit to vmlinux.ld.S to
make sure that the LMAs of sections in vmlinux are correct.
Provides the ASM_CONST macro for creating asm-safe constants.
No users yet, we'll be using it in upcoming page.h commit, for generating
Fix "Freeing initrd memory:" message on microblaze to show kilobytes as
claimed rather than number of pages.
Signed-off-by: Lennart Sorensen <lsorense@csclub.uwaterloo.ca>
Signed-off-by: Edgar E. Iglesias <edgar.iglesias@gmail.com>
FSR is sticky, so after the userspace exception/signal generation, clear
it ready for next time.
Fixes the bug introduced in 9552158573f847aa429334bb97995bb290bb4b0d
I thought that this part of code could be removed because just
save and restore MSR but any code can't change it. But seems to
that any part of code works with this information.
This patch solved problem with allocation.
Add architectural support for USB EHCI host controllers. It has been tested
using the USB EHCI host controller from Xilinx Inc., using both High Speed
devices and Full Speed devices.
Signed-off-by: Julie Zhu <julie.zhu@xilinx.com>
It is more safe to use clear instead of msrset.
We save some instructions too.
It was necessary to use fourth parameter(r8) in early_printk
to show messages on console.
I wasn't able to further clean up the linker script using the
INIT_DATA_SECTION macro because of the FIXME comment for the
.init.ramfs section; when that is resolved we should convert
microblaze to use INIT_DATA_SECTION.
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Cc: microblaze-uclinux@itee.uq.edu.au
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Paul Mackerras <paulus@samba.org>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: <linux-arch@vger.kernel.org>
LKML-Reference: <new-submission>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits)
powerpc64: convert to dynamic percpu allocator
sparc64: use embedding percpu first chunk allocator
percpu: kill lpage first chunk allocator
x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA
percpu: update embedding first chunk allocator to handle sparse units
percpu: use group information to allocate vmap areas sparsely
vmalloc: implement pcpu_get_vm_areas()
vmalloc: separate out insert_vmalloc_vm()
percpu: add chunk->base_addr
percpu: add pcpu_unit_offsets[]
percpu: introduce pcpu_alloc_info and pcpu_group_info
percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward
percpu: add @align to pcpu_fc_alloc_fn_t
percpu: make @dyn_size mandatory for pcpu_setup_first_chunk()
percpu: drop @static_size from first chunk allocators
percpu: generalize first chunk allocator selection
percpu: build first chunk allocators selectively
percpu: rename 4k first chunk allocator to page
percpu: improve boot messages
percpu: fix pcpu_reclaim() locking
Fix trivial conflict as by Tejun Heo in kernel/sched.c
For noMMU system when you use larger rootfs image
there is problem with using _end label because
we increase klimit but in memory initialization
we use still _end which is wrong. Larger mtd rootfs
was rewritten by init_bootmem_node.
MMU kernel use static initialization where klimit
is setup to _end. There is no any other hanling
with klimit.
This code path doesn't test any returned pointers for NULL, leading to a bad
kernel page fault if there's no timer/intc found.
Slightly better is to BUG(), but even better still would be a printk beforehand.
arch/sparc/kernel/smp_64.c
arch/x86/kernel/cpu/perf_counter.c
arch/x86/kernel/setup_percpu.c
drivers/cpufreq/cpufreq_ondemand.c
mm/percpu.c
Conflicts in core and arch percpu codes are mostly from commit
ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many
num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all
the first chunk allocators into mm/percpu.c, the changes are moved
from arch code to mm/percpu.c.
* 'fixes-for-linus' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Makefile cleanup
microblaze: Typo fix for cpu param inconsistency
microblaze: Add support for R_MICROBLAZE_64_NONE
microblaze: Get module loading working
microblaze: remove sys_ipc
microblaze: Support unaligned address for put/get_user macros
microblaze: Detect new Microblaze 7.20 versions
microblaze: Fix do_page_fault for no context
microblaze: Add _PAGE_FILE macros to pgtable.h
microblaze: Fix put_user macro for 64bits arguments
microblaze: Clear print messages for DTB passing via r7
microblaze: Not to clear r7 after copying DTB to kernel
microblaze: Add messages about FDT blob
microblaze: Final support for statically linked DTB
microblaze: remove duplicated #include
microblaze: Define tlb_flush macro
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()
Upcoming paches to support the new 64-bit "BookE" powerpc architecture
will need to have the virtual address corresponding to PTE page when
freeing it, due to the way the HW table walker works.
Basically, the TLB can be loaded with "large" pages that cover the whole
virtual space (well, sort-of, half of it actually) represented by a PTE
page, and which contain an "indirect" bit indicating that this TLB entry
RPN points to an array of PTEs from which the TLB can then create direct
entries. Thus, in order to invalidate those when PTE pages are deleted,
we need the virtual address to pass to tlbilx or tlbivax instructions.
The old trick of sticking it somewhere in the PTE page struct page sucks
too much, the address is almost readily available in all call sites and
almost everybody implemets these as macros, so we may as well add the
argument everywhere. I added it to the pmd and pud variants for consistency.
Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV]
Acked-by: Nick Piggin <npiggin@suse.de>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390]
Reviewed the Makefile on request by Michal and this is the resulting changes.
o Use ':=' for assignmnet so we do not re-evaluate for each use
o Use $(shell echo xxx) to remove ""
o Replaced CFLAGS_KERNEL with KBUILD_CFLAGS
The settings are equally relevant for modules and the linked kernel
o Dropped LDFLAGS_BLOB - it is no longer used
o Refactored assignmnets to libs-y and core-y
o Use MMU for the MMU specific extension. "MMUEXT" was hurting my eyes
and I did not wanted it spread to m68k
For example reiserfs use this relocation type.
New reloc type R_MICROBLAZE_32_PCREL_LO requires a null handler (no work to do).
Remove legacy hack for broken linker pre gcc-4.1.1, that required us to extract
an offset from the code, add it to the addend, then rewrite the instruction.
Fixup the invalid reloc type error output.
Boot tested with the xilinx_emaclite ethernet driver.
The ipc system call is now unused in microblaze,
as the system call table points directly to the
indidual system calls for IPC.
This patch add support for cases where load/store instruction
in put/get_user macro gets unaligned pointer to data and this
address is not valid. I prevent all cases which can failed.
I had to disable first stage of unaligned handler which is used
only for noMMU kernel and the whole work is done when interrupt
is enabled.
You have enable HW support for detect unaligned access in Microblaze.
This patch fixed three LTP tests:
getpeername01, getsockname01, socketpair01
Calling fixup when we are in kernel mode. This
prevent fault for copy_to/from_user. This fault
was find thanks to writev01/03/04 LTP tests.
We need to define _PAGE_FILE macro and change pte
functions. Microblaze use the same MMU as PowerPC
that's why we define _PAGE_FILE in the same style.
This change fixed remap_file_pages01 LTP test.
