path: root/arch/microblaze
2010-02-24microblaze: Fix out_le32() macroSteven J. Magnani
Trailing semicolon causes compilation involving out_le32() to fail. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-02-24microblaze: Fix cache loop function for cache rangeMichal Simek
I create wrong asm code but none test shows that this part of code is wrong. I am not convinces that were good idea to create asm optimized macros for caches. The reason is that there is not optimization with previous code that's why make sense to add old code and do some benchmarking which functions are faster. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-02-08microblaze: Invalidate dcache before enabling itMichal Simek
We found that on write-trough kernel is necessary to do that invalidation. One WB is possible to use invalidation too. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-02-03microblaze: fix interrupt state restoreSteven J. Magnani
Interrupts must be disabled while an interrupt state restore (prep for interrupt return) is in progress. Code to do this was lost in the port to the mainline kernel. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-02-03microblaze: Defconfig updateMichal Simek
There were several changes in Microblaze defconfig that's why is good to update defconfigs. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-01-18microblaze: pci_controller->arch_data really is a struct device_node *Michal Simek
we are follow powerpc change: 44ef339073f67d4abcc62ae52a5fbc069d7a4d29 Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-01-18microblaze: Add missing double apostrophe in KconfigMichal Simek
2010-01-18microblaze: Add PT_ macros for special purpose regsMichal Simek
PT_ macros are used by gdb and strace uses them too. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-01-18microblaze: Enable accept4 syscallMichal Simek
We had wrong name in unistd.h + I wire up this syscall in syscall table. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-01-18microblaze: Wire up recvmmsg syscallMichal Simek
Patch a2e2725541fad72416326798c2d7fa4dafb7d337 should contain change in unistd.h too. The same problem had MIPS. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14genirq: Convert irq_desc.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14microblaze: Remove rt_sigsuspend wrapperMichal Simek
Generic rt_sigsuspend syscalls doesn't need any asm wrapper. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: nommu: Don't clobber R11 on syscallssteve@digidescorp.com
The noMMU syscall trap has a bug that causes R11 to be zero on return to userland. Remove the extra "save" of R11 responsible for the bug. Remove reloading of mode indicator because r11 already contains it. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Remove show_tmem functionMichal Simek
show_tmem function do nothing that's why I removed it. There is also cleaning of commented ancient code. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Support for WB cacheMichal Simek
Microblaze version 7.20.d is the first MB version which can be run on MMU linux. Please do not used previous version because they contain HW bug. Based on WB support was necessary to redesign whole cache design. Microblaze versions from 7.20.a don't need to disable IRQ and cache before working with them that's why there are special structures for it. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Add PVR for Microblaze v7.30.aMichal Simek
Microblaze v7.30.a will have 0x10 version string. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Remove ancient and fake microblaze version from cpu_ver tableMichal Simek
We need to continue with next microblaze PVR version that's why I have to remove that ancient version. These version strings not match any versions. From Microblaze v5.00.a is possible to use this style. I believe that none use ancients versions. If yes they will be just labeled as unknown version. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Remove panic_timeout init valueMichal Simek
panic_timeout is in BSS section and it is cleared with BSS section. This means that value is setup to 0. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Do not count system calls in defaultMichal Simek
There is not necessary to count system calls that's why I added DEBUG macro Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Enable DTC compilationMichal Simek
For simpleImage format we need to compile DTC. There is still possibility to compile only Linux kernel without DTB compiled-in. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Core oprofile configs and hooksJohn Williams
Microblaze uses timer interrupt mode. Microblaze don't have any performance counter that's why we use just simple implementation. Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Fix level interrupt ACKingsteve@digidescorp.com
Level interrupts need to be ack'd in the unmask handler, as in powerpc. Among other issues, this bug causes the system clock to appear to run at double-speed. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Enable futimesat syscallMichal Simek
Futimesat was disabled. LTP testing shows that MB has no problem with this syscall. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Checking DTS against PVR for write-back cacheMichal Simek
WB cache has special flag in PVR. There is added checking mechanism for PVR and DTS. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Remove duplicity from pgalloc.hMichal Simek
just file cleanup Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Futex supportMichal Simek
Microblaze v7.20 provides new lwx, swx instructions which bring possibility to implement lock rutines. There are some tests in open posix thread LTP part but current toolchain not support it. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Adding dev_arch_data functionsMichal Simek
The functions, dev_arch_data_set_node and get_node are missing and are needed by some device drivers such as I2C. Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Fix the heartbeat gpio to be more robustJohn Linn
The device tree handling for the gpio in the heart beat was not handling the system when there was no gpio and it wasn't working with a newer version of the gpio core which does not have the is-bidir property. Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Simple __copy_tofrom_user for noMMUJohn Williams
This is first patch which clear part of uaccess.h. uaccess.h will be clear later. Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Export memory_start for modulesMichal Simek
memory_start symbol is needed by kernel modules. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Use lowest-common-denominator default CPU settingsJohn Williams
This will ensure that kernels built with no custom CPU settings will still boot OK on hardware that has additional CPU hardware instructions etc. Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Update default generic DTSMichal Simek
It is generated with longer compatible list Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Enable asm optimization only for HW with barrel-shifterMichal Simek
Asm code uses barrel-shifter instruction that's why we have to protect cases when HW don't have it. Reported-by: John Linn <john.linn@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Remove the buggy ALLOW_EDIT_AUTO config optionJohn Williams
This was intended to allow manual override of CPU settings copied automatically to Kconfig.auto, however it's problematic for several reasons, but mostly: * If the defconfig doesn't have ALLOW_EDIT_AUTO=y, then it's impossible for that defconfig to iverride the values in the kernel source tree. This leads to very strange errors where the kernel is compiled with the wrong CPUFLAGS. Next patch in the series will back out the default in Kconfig.auto to baseline settings, so a kernel built with no default values will at least boot on any hardware, just not make use of additional CPU features. Signed-off-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Move cache macro from cache.h to cacheflush.hMichal Simek
2009-12-14microblaze: support U-BOOT image formatMichal Simek
Two version are generated. linux.bin.ub which is created from linux.bin file and simpleImage.<dts>.ub which is created from stripped simpleImage.<dts> file Load address and entry point is for microblaze first instruction which is CONFIG_KERNEL_BASE_ADDR variable. There is possible for simpleImage format parse _start symbol too. simpleImage.<dts> is still stripped elf file I cleared simpleImage.<dts>.unstrip file because there are so big. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Ptrace notifying from signal codeMichal Simek
After the signal frame is set up on the userspace stack, ptrace() should be given an opportunity to single-step into the signal handler FRV, Blackfin, mn10300 and UM. Worth to look at that patches. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Extend cpuinfo for support write-back cachesMichal Simek
There is missing checking agains PVR but this is not important for now. There are some missing checking too. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Fix cache_line_lenghtMichal Simek
We used cache_line as cache_line_lenght. For this reason we did cache flushing 4 times longer than was necessary. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Detect new 7.20.d versionMichal Simek
2009-12-14microblaze: Support both levels for resetMichal Simek
Till this patch reset always perform writen to 1. Now we can use negative logic and perform reset write to 0. It is opposite level than is currently read from that pin Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Fix announce message for reset gpioMichal Simek
I had to change message for gpio-reset because I always not to see it. Prefix RESET is big and visible. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Remove saving and restoring before calling signal codeMichal Simek
Saving is done in SAVE_STATE macros that's why another save discard previous saved value. This change has no effect to normal programs because they ends in any exception and they are killed. On the other side has effect on debugging. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: Fix pfn_valid() for noMMUsteve@digidescorp.com
Configuring DEBUG_SLAB causes a noMMU kernel to die during initialization with an invalid virtual address panic in kfree_debugcheck(). The panic is due to an improper definition of pfn_valid(). Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: ftrace: Add dynamic function graph tracerMichal Simek
This patch add support for dynamic function graph tracer. There is one my expactation that I can do flush_icache after all code modification. On microblaze is this safer than do flush for every entry. For icache is used name flush but correct should be invalidation - this will be fix in upcomming new cache implementaion and WB support. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: ftrace: add function graph supportMichal Simek
For more information look at Documentation/trace folder. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: ftrace: Add dynamic trace supportMichal Simek
With dynamic function tracer, by default, _mcount is defined as an "empty" function, it returns directly without any more action. When enabling it in user-space, it will jump to a real tracing function(ftrace_caller), and do the real job for us. Differ from the static function tracer, dynamic function tracer provides two functions ftrace_make_call()/ftrace_make_nop() to enable/disable the tracing of some indicated kernel functions(set_ftrace_filter). In the kernel version, there is only one "_mcount" string for every kernel function, so, we just need to match this one in mcount_regex of scripts/recordmcount.pl. For more information please look at code and Documentation/trace folder. Steven ACK that scripts/recordmcount.pl part. Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-14microblaze: ftrace: enable HAVE_FUNCTION_TRACE_MCOUNT_TESTMichal Simek
Implement MCOUNT_TEST in asm code - it is faster than use generic code Signed-off-by: Michal Simek <monstr@monstr.eu>
