commit 30d6e0a4190d37740e9447e4e4815f06992dd8c3 upstream.
There is code duplicated over all architecture's headers for
futex_atomic_op_inuser. Namely op decoding, access_ok check for uaddr,
and comparison of the result.
Remove this duplication and leave up to the arches only the needed
assembly which is now in arch_futex_atomic_op_inuser.
This effectively distributes the Will Deacon's arm64 fix for undefined
behaviour reported by UBSAN to all architectures. The fix was done in
commit 5f16a046f8e1 (arm64: futex: Fix undefined behaviour with
FUTEX_OP_OPARG_SHIFT usage). Look there for an example dump.
And as suggested by Thomas, check for negative oparg too, because it was
also reported to cause undefined behaviour report.
Note that s390 removed access_ok check in d12a29703 ("s390/uaccess:
remove pointless access_ok() checks") as access_ok there returns true.
We introduce it back to the helper for the sake of simplicity (it gets
optimized away anyway).
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390]
Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org>
Reviewed-by: Will Deacon <will.deacon@arm.com> [core/arm64]
Cc: linux-mips@linux-mips.org
Cc: Rich Felker <dalias@libc.org>
Cc: linux-ia64@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: peterz@infradead.org
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: sparclinux@vger.kernel.org
Cc: Jonas Bonn <jonas@southpole.se>
Cc: linux-s390@vger.kernel.org
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: linux-hexagon@vger.kernel.org
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Matt Turner <mattst88@gmail.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: linux-xtensa@linux-xtensa.org
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: openrisc@lists.librecores.org
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Stafford Horne <shorne@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Chris Zankel <chris@zankel.net>
Cc: linux-parisc@vger.kernel.org
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-alpha@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20170824073105.3901-1-jslaby@suse.cz
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
Pull uaccess.h prepwork from Al Viro:
"Preparations to tree-wide switch to use of linux/uaccess.h (which,
obviously, will allow to start unifying stuff for real). The last step
there, ie
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
`git grep -l "$PATT"|grep -v ^include/linux/uaccess.h`
is not taken here - I would prefer to do it once just before or just
after -rc1. However, everything should be ready for it"
* 'work.uaccess2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
remove a stray reference to asm/uaccess.h in docs
sparc64: separate extable_64.h, switch elf_64.h to it
score: separate extable.h, switch module.h to it
mips: separate extable.h, switch module.h to it
x86: separate extable.h, switch sections.h to it
remove stray include of asm/uaccess.h from cacheflush.h
mn10300: remove a bogus processor.h->uaccess.h include
xtensa: split uaccess.h into C and asm sides
bonding: quit messing with IOCTL
kill __kernel_ds_p off
mn10300: finish verify_area() off
frv: move HAVE_ARCH_UNMAPPED_AREA to pgtable.h
exceptions: detritus removal
When doing an nmi backtrace of many cores, most of which are idle, the
output is a little overwhelming and very uninformative. Suppress
messages for cpus that are idling when they are interrupted and just
emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN".
We do this by grouping all the cpuidle code together into a new
.cpuidle.text section, and then checking the address of the interrupted
PC to see if it lies within that section.
This commit suitably tags x86 and tile idle routines, and only adds in
the minimal framework for other architectures.
Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Tested-by: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Summary of PCI changes for the v4.9 merge window:
Enumeration:
- microblaze: Add multidomain support for procfs (Bharat Kumar Gogada)
Resource management:
- Ignore requested alignment for PROBE_ONLY and fixed resources (Yongji Xie)
- Ignore requested alignment for VF BARs (Yongji Xie)
PCI device hotplug:
- Make core explicitly non-modular (Paul Gortmaker)
PCIe native device hotplug:
- Rename pcie_isr() locals for clarity (Bjorn Helgaas)
- Return IRQ_NONE when we can't read interrupt status (Bjorn Helgaas)
- Remove unnecessary guard (Bjorn Helgaas)
- Clean up dmesg "Slot(%s)" messages (Bjorn Helgaas)
- Remove useless pciehp_get_latch_status() calls (Bjorn Helgaas)
- Clear attention LED on device add (Keith Busch)
- Allow exclusive userspace control of indicators (Keith Busch)
- Process all hotplug events before looking for new ones (Mayurkumar Patel)
- Don't re-read Slot Status when queuing hotplug event (Mayurkumar Patel)
- Don't re-read Slot Status when handling surprise event (Mayurkumar Patel)
- Make explicitly non-modular (Paul Gortmaker)
Power management:
- Afford direct-complete to devices with non-standard PM (Lukas Wunner)
- Query platform firmware for device power state (Lukas Wunner)
- Recognize D3cold in pci_update_current_state() (Lukas Wunner)
- Avoid unnecessary resume after direct-complete (Lukas Wunner)
Virtualization:
- Mark Atheros AR9580 to avoid bus reset (Maik Broemme)
- Check for pci_setup_device() failure in pci_iov_add_virtfn() (Po Liu)
MSI:
- Enable PCI_MSI_IRQ_DOMAIN support for ARC (Joao Pinto)
AER:
- Remove aerdriver.nosourceid kernel parameter (Bjorn Helgaas)
- Remove aerdriver.forceload kernel parameter (Bjorn Helgaas)
- Fix aer_probe() kernel-doc comment (Cao jin)
- Add bus flag to skip source ID matching (Jon Derrick)
- Avoid memory allocation in interrupt handling path (Jon Derrick)
- Cache capability position (Keith Busch)
- Remove duplicate AER severity translation (Tyler Baicar)
- Send correct severity to calculate AER severity (Tyler Baicar)
Precision Time Measurement:
- Add Precision Time Measurement (PTM) support (Jonathan Yong)
- Add PTM clock granularity information (Bjorn Helgaas)
- Add pci_enable_ptm() for drivers to enable PTM on endpoints (Bjorn Helgaas)
Generic host bridge driver:
- Fix pci_remap_iospace() failure path (Lorenzo Pieralisi)
Altera host bridge driver:
- Remove redundant platform_get_resource() return value check (Bjorn Helgaas)
- Poll for link training status after retraining the link (Ley Foon Tan)
- Rework config accessors for use without a struct pci_bus (Ley Foon Tan)
- Move retrain from fixup to altera_pcie_host_init() (Ley Foon Tan)
- Make MSI explicitly non-modular (Paul Gortmaker)
- Relax device number checking to allow SR-IOV (Po Liu)
ARM Versatile host bridge driver:
Axis ARTPEC-6 host bridge driver:
- Drop __init from artpec6_add_pcie_port() (Niklas Cassel)
Freescale i.MX6 host bridge driver:
Intel VMD host bridge driver:
- Add quirk for AER to ignore source ID (Jon Derrick)
- Allocate IRQ lists with correct MSI-X count (Jon Derrick)
- Convert to use pci_alloc_irq_vectors() API (Jon Derrick)
- Eliminate vmd_vector member from list type (Jon Derrick)
- Eliminate index member from IRQ list (Jon Derrick)
- Synchronize with RCU freeing MSI IRQ descs (Keith Busch)
- Request userspace control of PCIe hotplug indicators (Keith Busch)
- Move VMD driver to drivers/pci/host (Keith Busch)
Marvell Aardvark host bridge driver:
- Remove redundant dev_err call in advk_pcie_probe() (Wei Yongjun)
Microsoft Hyper-V host bridge driver:
- Use zero-length array in struct pci_packet (Dexuan Cui)
- Use pci_function_description[0] in struct definitions (Dexuan Cui)
- Remove the unused 'wrk' in struct hv_pcibus_device (Dexuan Cui)
- Handle vmbus_sendpacket() failure in hv_compose_msi_msg() (Dexuan Cui)
- Handle hv_pci_generic_compl() error case (Dexuan Cui)
- Use list_move_tail() instead of list_del() + list_add_tail() (Wei Yongjun)
NVIDIA Tegra host bridge driver:
- Remove redundant _data suffix (Thierry Reding)
- Use of_device_get_match_data() (Thierry Reding)
Qualcomm host bridge driver:
Renesas R-Car host bridge driver:
- Consolidate register space lookup and ioremap (Bjorn Helgaas)
- Don't disable/unprepare clocks on prepare/enable failure (Geert Uytterhoeven)
- Add multi-MSI support (Grigory Kletsko)
- Fix some checkpatch warnings (Sergei Shtylyov)
- Try increasing PCIe link speed to 5 GT/s at boot (Sergei Shtylyov)
Rockchip host bridge driver:
- Add DT bindings for Rockchip PCIe controller (Shawn Lin)
- Add Rockchip PCIe controller support (Shawn Lin)
- Improve the deassert sequence of four reset pins (Shawn Lin)
- Fix wrong transmitted FTS count (Shawn Lin)
- Increase the Max Credit update interval (Rajat Jain)
Samsung Exynos host bridge driver:
ST Microelectronics SPEAr13xx host bridge driver:
Synopsys DesignWare host bridge driver:
- Return data directly from dw_pcie_readl_rc() (Bjorn Helgaas)
- Exchange viewport of `MEMORYs' and `CFGs/IOs' (Dong Bo)
- Check LTSSM training bit before deciding link is up (Jisheng Zhang)
- Move link wait definitions to .c file (Joao Pinto)
- Wait for iATU enable (Joao Pinto)
- Add iATU Unroll feature (Joao Pinto)
- Keep viewport fixed for IO transaction if num_viewport > 2 (Pratyush Anand)
- Remove redundant platform_get_resource() return value check (Wei Yongjun)
TI DRA7xx host bridge driver:
TI Keystone host bridge driver:
- Propagate request_irq() failure (Wei Yongjun)
Xilinx AXI host bridge driver:
- Keep both legacy and MSI interrupt domain references (Bharat Kumar Gogada)
- Clear interrupt register for invalid interrupt (Bharat Kumar Gogada)
- Clear correct MSI set bit (Bharat Kumar Gogada)
- Dispose of MSI virtual IRQ (Bharat Kumar Gogada)
Xilinx NWL host bridge driver:
- Expand error logging (Bharat Kumar Gogada)
- Enable all MSI interrupts using MSI mask (Bharat Kumar Gogada)
Miscellaneous:
- Drop CONFIG_KEXEC_CORE ifdeffery (Lukas Wunner)
- portdrv: Make explicitly non-modular (Paul Gortmaker)
- Make DPC explicitly non-modular (Paul Gortmaker)"
* tag 'pci-v4.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (105 commits)
x86/PCI: VMD: Move VMD driver to drivers/pci/host
PCI: rockchip: Fix wrong transmitted FTS count
PCI: rockchip: Improve the deassert sequence of four reset pins
PCI: rockchip: Increase the Max Credit update interval
PCI: rcar: Try increasing PCIe link speed to 5 GT/s at boot
PCI/AER: Fix aer_probe() kernel-doc comment
PCI: Ignore requested alignment for VF BARs
PCI: Ignore requested alignment for PROBE_ONLY and fixed resources
PCI: Avoid unnecessary resume after direct-complete
PCI: Recognize D3cold in pci_update_current_state()
PCI: Query platform firmware for device power state
PCI: Afford direct-complete to devices with non-standard PM
PCI/AER: Cache capability position
PCI/AER: Avoid memory allocation in interrupt handling path
x86/PCI: VMD: Request userspace control of PCIe hotplug indicators
PCI: pciehp: Allow exclusive userspace control of indicators
ACPI / APEI: Send correct severity to calculate AER severity
PCI/AER: Remove duplicate AER severity translation
x86/PCI: VMD: Synchronize with RCU freeing MSI IRQ descs
x86/PCI: VMD: Eliminate index member from IRQ list
externs and defines for stuff that is never used
Cc: stable@vger.kernel.org
We create a procfs directory for every PCI bus. Previously, the directory
name was just the bus number, so using the same bus number in different
domains caused a kernel crash when we tried to create a duplicate
directory.
Make pci_proc_domain() return the domain number, so procfs directories for
buses in domain 0 are named with just the bus number, and directories for
buses in other domains include both the domain number and the bus number.
[bhelgaas: changelog]
Signed-off-by: Bharat Kumar Gogada <bharatku@xilinx.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Storing this value will help prevent unwinders from getting out of sync
with the function graph tracer ret_stack. Now instead of needing a
stateful iterator, they can compare the return address pointer to find
the right ret_stack entry.
Note that an array of 50 ftrace_ret_stack structs is allocated for every
task. So when an arch implements this, it will add either 200 or 400
bytes of memory usage per task (depending on whether it's a 32-bit or
64-bit platform).
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Nilay Vaish <nilayvaish@gmail.com>
Link: http://lkml.kernel.org/r/a95cfcc39e8f26b89a430c56926af0bb217bc0a1.1471607358.git.jpoimboe@redhat.com
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
Merge yet more updates from Andrew Morton:
- the rest of ocfs2
- various hotfixes, mainly MM
- quite a bit of misc stuff - drivers, fork, exec, signals, etc.
- printk updates
- firmware
- checkpatch
- nilfs2
- more kexec stuff than usual
- rapidio updates
- w1 things
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (111 commits)
ipc: delete "nr_ipc_ns"
kcov: allow more fine-grained coverage instrumentation
init/Kconfig: add clarification for out-of-tree modules
config: add android config fragments
init/Kconfig: ban CONFIG_LOCALVERSION_AUTO with allmodconfig
relay: add global mode support for buffer-only channels
init: allow blacklisting of module_init functions
w1:omap_hdq: fix regression
w1: add helper macro module_w1_family
w1: remove need for ida and use PLATFORM_DEVID_AUTO
rapidio/switches: add driver for IDT gen3 switches
powerpc/fsl_rio: apply changes for RIO spec rev 3
rapidio: modify for rev.3 specification changes
rapidio: change inbound window size type to u64
rapidio/idt_gen2: fix locking warning
rapidio: fix error handling in mbox request/release functions
rapidio/tsi721_dma: advance queue processing from transfer submit call
rapidio/tsi721: add messaging mbox selector parameter
rapidio/tsi721: add PCIe MRRS override parameter
rapidio/tsi721_dma: add channel mask and queue size parameters
In general, there's no need for the "restore sigmask" flag to live in
ti->flags. alpha, ia64, microblaze, powerpc, sh, sparc (64-bit only),
tile, and x86 use essentially identical alternative implementations,
placing the flag in ti->status.
Replace those optimized implementations with an equally good common
implementation that stores it in a bitfield in struct task_struct and
drop the custom implementations.
Additional architectures can opt in by removing their
TIF_RESTORE_SIGMASK defines.
Link: http://lkml.kernel.org/r/8a14321d64a28e40adfddc90e18a96c086a6d6f9.1468522723.git.luto@kernel.org
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Tested-by: Michael Ellerman <mpe@ellerman.id.au> [powerpc]
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Dmitry Safonov <dsafonov@virtuozzo.com>
There was only one use of __initdata_refok and __exit_refok
__init_refok was used 46 times against 82 for __ref.
Those definitions are obsolete since commit 312b1485fb50 ("Introduce new
section reference annotations tags: __ref, __refdata, __refconst")
This patch removes the following compatibility definitions and replaces
them treewide.
/* compatibility defines */
#define __init_refok __ref
#define __initdata_refok __refdata
#define __exit_refok __ref
I can also provide separate patches if necessary.
(One patch per tree and check in 1 month or 2 to remove old definitions)
Link: http://lkml.kernel.org/r/1466796271-3043-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
"Highlights:
- ARM64 support for ACPI host bridges
- new drivers for Axis ARTPEC-6 and Marvell Aardvark
- new pci_alloc_irq_vectors() interface for MSI-X, MSI, legacy INTx
- pci_resource_to_user() cleanup (more to come)
Detailed summary:
Enumeration:
- Move ecam.h to linux/include/pci-ecam.h (Jayachandran C)
- Add parent device field to ECAM struct pci_config_window (Jayachandran C)
- Add generic MCFG table handling (Tomasz Nowicki)
- Refactor pci_bus_assign_domain_nr() for CONFIG_PCI_DOMAINS_GENERIC (Tomasz Nowicki)
- Factor DT-specific pci_bus_find_domain_nr() code out (Tomasz Nowicki)
- Add devm_request_pci_bus_resources() (Bjorn Helgaas)
- Unify pci_resource_to_user() declarations (Bjorn Helgaas)
- Implement pci_resource_to_user() with pcibios_resource_to_bus() (microblaze, powerpc, sparc) (Bjorn Helgaas)
- Request host bridge window resources (designware, iproc, rcar, xgene, xilinx, xilinx-nwl) (Bjorn Helgaas)
- Make PCI I/O space optional on ARM32 (Bjorn Helgaas)
- Ignore write combining when mapping I/O port space (Bjorn Helgaas)
- Claim bus resources on MIPS PCI_PROBE_ONLY set-ups (Bjorn Helgaas)
- Remove unicore32 pci=firmware command line parameter handling (Bjorn Helgaas)
- Support I/O resources when parsing host bridge resources (Jayachandran C)
- Add helpers to request/release memory and I/O regions (Johannes Thumshirn)
- Use pci_(request|release)_mem_regions (NVMe, lpfc, GenWQE, ethernet/intel, alx) (Johannes Thumshirn)
- Extend pci=resource_alignment to specify device/vendor IDs (Koehrer Mathias (ETAS/ESW5))
- Add generic pci_bus_claim_resources() (Lorenzo Pieralisi)
- Claim bus resources on ARM32 PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi)
- Remove ARM32 and ARM64 arch-specific pcibios_enable_device() (Lorenzo Pieralisi)
- Add pci_unmap_iospace() to unmap I/O resources (Sinan Kaya)
- Remove powerpc __pci_mmap_set_pgprot() (Yinghai Lu)
PCI device hotplug:
- Allow additional bus numbers for hotplug bridges (Keith Busch)
- Ignore interrupts during D3cold (Lukas Wunner)
Power management:
- Enforce type casting for pci_power_t (Andy Shevchenko)
- Don't clear d3cold_allowed for PCIe ports (Mika Westerberg)
- Put PCIe ports into D3 during suspend (Mika Westerberg)
- Power on bridges before scanning new devices (Mika Westerberg)
- Runtime resume bridge before rescan (Mika Westerberg)
- Add runtime PM support for PCIe ports (Mika Westerberg)
- Remove redundant check of pcie_set_clkpm (Shawn Lin)
Virtualization:
- Add function 1 DMA alias quirk for Marvell 88SE9182 (Aaron Sierra)
- Add DMA alias quirk for Adaptec 3805 (Alex Williamson)
- Mark Atheros AR9485 and QCA9882 to avoid bus reset (Chris Blake)
- Add ACS quirk for Solarflare SFC9220 (Edward Cree)
MSI:
- Fix PCI_MSI dependencies (Arnd Bergmann)
- Add pci_msix_desc_addr() helper (Christoph Hellwig)
- Switch msix_program_entries() to use pci_msix_desc_addr() (Christoph Hellwig)
- Make the "entries" argument to pci_enable_msix() optional (Christoph Hellwig)
- Provide sensible IRQ vector alloc/free routines (Christoph Hellwig)
- Spread interrupt vectors in pci_alloc_irq_vectors() (Christoph Hellwig)
Error Handling:
- Bind DPC to Root Ports as well as Downstream Ports (Keith Busch)
- Remove DPC tristate module option (Keith Busch)
- Convert Downstream Port Containment driver to use devm_* functions (Mika Westerberg)
- Select IRQ_DOMAIN (Arnd Bergmann)
- Claim bus resources on PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi)
ACPI host bridge driver:
- Add ARM64 acpi_pci_bus_find_domain_nr() (Tomasz Nowicki)
- Add ARM64 ACPI support for legacy IRQs parsing and consolidation with DT code (Tomasz Nowicki)
- Implement ARM64 AML accessors for PCI_Config region (Tomasz Nowicki)
- Support ARM64 ACPI-based PCI host controller (Tomasz Nowicki)
- Check link status before retrain link (Ley Foon Tan)
- Poll for link up status after retraining the link (Ley Foon Tan)
- Add PCI_MSI_IRQ_DOMAIN dependency (Arnd Bergmann)
- Add DT binding for Axis ARTPEC-6 PCIe controller (Niklas Cassel)
- Add Axis ARTPEC-6 PCIe controller driver (Niklas Cassel)
- Use lock save/restore in interrupt enable path (Jon Derrick)
- Select device dma ops to override (Keith Busch)
- Initialize list item in IRQ disable (Keith Busch)
- Use x86_vector_domain as parent domain (Keith Busch)
- Separate MSI and MSI-X vector sharing (Keith Busch)
- Add DT binding for the Aardvark PCIe controller (Thomas Petazzoni)
- Add Aardvark PCI host controller driver (Thomas Petazzoni)
- Add Aardvark PCIe support for Armada 3700 (Thomas Petazzoni)
- Fix interrupt cleanup path (Cathy Avery)
- Don't leak buffer in hv_pci_onchannelcallback() (Vitaly Kuznetsov)
- Handle all pending messages in hv_pci_onchannelcallback() (Vitaly Kuznetsov)
- Program PADS_REFCLK_CFG* always, not just on legacy SoCs (Stephen Warren)
- Program PADS_REFCLK_CFG* registers with per-SoC values (Stephen Warren)
- Use lower-case hex consistently for register definitions (Thierry Reding)
- Use generic pci_remap_iospace() rather than ARM32-specific one (Thierry Reding)
- Stop setting pcibios_min_mem (Thierry Reding)
- Drop gen2 dummy I/O port region (Bjorn Helgaas)
- Fix return value in case of error (Christophe JAILLET)
Miscellaneous:
- Make bus_attr_resource_alignment static (Ben Dooks)
- Include <asm/dma.h> for isa_dma_bridge_buggy (Ben Dooks)
- MAINTAINERS: Add file patterns for PCI device tree bindings (Geert Uytterhoeven)
- Make host bridge drivers explicitly non-modular (Paul Gortmaker)"
* tag 'pci-v4.8-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (125 commits)
PCI: xgene: Make explicitly non-modular
PCI: thunder-pem: Make explicitly non-modular
PCI: thunder-ecam: Make explicitly non-modular
PCI: tegra: Make explicitly non-modular
PCI: rcar-gen2: Make explicitly non-modular
PCI: rcar: Make explicitly non-modular
PCI: mvebu: Make explicitly non-modular
PCI: layerscape: Make explicitly non-modular
PCI: keystone: Make explicitly non-modular
PCI: hisi: Make explicitly non-modular
PCI: generic: Make explicitly non-modular
PCI: designware-plat: Make it explicitly non-modular
PCI: artpec6: Make explicitly non-modular
PCI: armada8k: Make explicitly non-modular
PCI: artpec: Add PCI_MSI_IRQ_DOMAIN dependency
PCI: Add ACS quirk for Solarflare SFC9220
arm64: dts: marvell: Add Aardvark PCIe support for Armada 3700
PCI: aardvark: Add Aardvark PCI host controller driver
dt-bindings: add DT binding for the Aardvark PCIe controller
PCI: tegra: Program PADS_REFCLK_CFG* registers with per-SoC values
drivers/nvme/host/pci.c
Merge updates from Andrew Morton:
- a few misc bits
- ocfs2
- most(?) of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (125 commits)
thp: fix comments of __pmd_trans_huge_lock()
cgroup: remove unnecessary 0 check from css_from_id()
cgroup: fix idr leak for the first cgroup root
mm: memcontrol: fix documentation for compound parameter
mm: memcontrol: remove BUG_ON in uncharge_list
mm: fix build warnings in <linux/compaction.h>
mm, thp: convert from optimistic swapin collapsing to conservative
mm, thp: fix comment inconsistency for swapin readahead functions
thp: update Documentation/{vm/transhuge,filesystems/proc}.txt
shmem: split huge pages beyond i_size under memory pressure
thp: introduce CONFIG_TRANSPARENT_HUGE_PAGECACHE
khugepaged: add support of collapse for tmpfs/shmem pages
shmem: make shmem_inode_info::lock irq-safe
khugepaged: move up_read(mmap_sem) out of khugepaged_alloc_page()
thp: extract khugepaged from mm/huge_memory.c
shmem, thp: respect MADV_{NO,}HUGEPAGE for file mappings
shmem: add huge pages support
shmem: get_unmapped_area align huge page
shmem: prepare huge= mount option and sysfs knob
mm, rmap: account shmem thp pages
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.8 kernel cycle. The big
news is the completion of the chardev ABI which I'm very happy about
and apart from that it's an ordinary, quite busy cycle. The details
are below.
The patches are tested in linux-next for some time, patches to other
subsystem mostly have ACKs.
I got overly ambitious with configureing lines as input for IRQ lines
but it turns out that some controllers have their interrupt-enable and
input-enabling in orthogonal settings so the assumption that all IRQ
lines are input lines does not hold. Oh well, revert and back to the
drawing board with that.
Core changes:
- The big item is of course the completion of the character device
ABI. It has now replaced and surpassed the former unmaintainable
sysfs ABI: we can now hammer (bitbang) individual lines or sets of
lines and read individual lines or sets of lines from userspace,
and we can also register to listen to GPIO events from userspace.
As a tie-in we have two new tools in tools/gpio: gpio-hammer and
gpio-event-mon that illustrate the proper use of the new ABI. As
someone said: the wild west days of GPIO are now over.
- Continued to remove the pointless ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB
Kconfig symbols. I'm patching hexagon, openrisc, powerpc, sh,
unicore, ia64 and microblaze. These are either ACKed by their
maintainers or patched anyways after a grace period and no response
from maintainers.
Some archs (ARM) come in from their trees, and others (x86) are
still not fixed, so I might send a second pull request to root it
out later in this merge window, or just defer to v4.9.
- The GPIO tools are moved to the tools build system.
New drivers:
- New driver for the MAX77620/MAX20024.
- New driver for the Intel Merrifield.
- Enabled PCA953x for the TI PCA9536.
- Enabled PCA953x for the Intel Edison.
- Enabled R8A7792 in the RCAR driver.
Driver improvements:
- The STMPE and F7188x now supports the .get_direction() callback.
- The Xilinx driver supports setting multiple lines at once.
- ACPI support for the Vulcan GPIO controller.
- The MMIO GPIO driver supports device tree probing.
- The Acer One 10 is supported through the _DEP ACPI attribute.
Cleanups:
- A major cleanup of the OF/DT support code. It is way easier to
read and understand now, probably this improves performance too.
- Drop a few redundant .owner assignments.
- Remove CLPS711x boardfile support: we are 100% DT"
* tag 'gpio-v4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (67 commits)
MAINTAINERS: Add INTEL MERRIFIELD GPIO entry
gpio: dwapb: add missing fwnode_handle_put() in dwapb_gpio_get_pdata()
gpio: merrifield: Protect irq_ack() and gpio_set() by lock
gpio: merrifield: Introduce GPIO driver to support Merrifield
gpio: intel-mid: Make it depend to X86_INTEL_MID
gpio: intel-mid: Sort header block alphabetically
gpio: intel-mid: Remove potentially harmful code
gpio: rcar: add R8A7792 support
gpiolib: remove duplicated include from gpiolib.c
Revert "gpio: convince line to become input in irq helper"
gpiolib: of_find_gpio(): Don't discard errors
gpio: of: Allow overriding the device node
gpio: free handles in fringe cases
gpio: tps65218: Add platform_device_id table
gpio: max77620: get gpio value based on direction
gpio: lynxpoint: avoid potential warning on error path
tools/gpio: add install section
tools/gpio: move to tools buildsystem
gpio: intel-mid: switch to devm_gpiochip_add_data()
gpio: 74x164: Use spi_write() helper instead of open coding
We always have vma->vm_mm around.
Link: http://lkml.kernel.org/r/1466021202-61880-8-git-send-email-kirill.shutemov@linux.intel.com
http://git.linaro.org/people/daniel.lezcano/linux into timers/core
Pull the clockevents/clocksource tree from Daniel Lezcano:
- Convert the clocksource-probe init functions to return a value in order to
prepare the consolidation of the drivers using the DT. It is a big patchset
but went through 01.org (kbuild bot), linux next and kernel-ci (continuous
integration) (Daniel Lezcano)
- Fix a bad error handling by returning the right value for cadence_ttc
(Christophe Jaillet)
- Fix typo in the Kconfig for the Samsung pwm (Alexandre Belloni)
- Change functions to static for armada-370-xp and digicolor (Ben Dooks)
- Add support for the rk3399 SoC timer by adding bindings and a slight
change in the base address. Take the opportunity to add the DYNIRQ flag
(Huang Tao)
- Fix endian accessors for the Samsung pwm timer (Matthew Leach)
- Add Oxford Semiconductor RPS Dual Timer driver (Neil Armstrong)
- Add a kernel parameter to swich on/off the event stream feature of the arch
arm timer (Will Deacon)
All the clocksource drivers's init function are now converted to return
an error code. CLOCKSOURCE_OF_DECLARE is no longer used as well as the
clksrc-of table.
Let's convert back the names:
- CLOCKSOURCE_OF_DECLARE_RET => CLOCKSOURCE_OF_DECLARE
- clksrc-of-ret => clksrc-of
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
For exynos_mct and samsung_pwm_timer:
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
For arch/arc:
For mediatek driver:
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
For the Rockchip-part
Acked-by: Heiko Stuebner <heiko@sntech.de>
For STi :
Acked-by: Patrice Chotard <patrice.chotard@st.com>
For the mps2-timer.c and versatile.c changes:
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
For the OXNAS part :
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
For LPC32xx driver:
Acked-by: Sylvain Lemieux <slemieux.tyco@gmail.com>
For Broadcom Kona timer change:
Acked-by: Ray Jui <ray.jui@broadcom.com>
For Sun4i and Sun5i:
Acked-by: Chen-Yu Tsai <wens@csie.org>
For Meson6:
Acked-by: Carlo Caione <carlo@caione.org>
For Keystone:
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
For NPS:
Acked-by: Noam Camus <noamca@mellanox.com>
For bcm2835:
Acked-by: Eric Anholt <eric@anholt.net>
The init functions do not return any error. They behave as the following:
- panic, thus leading to a kernel crash while another timer may work and
make the system boot up correctly
or
- print an error and let the caller unaware if the state of the system
Change that by converting the init functions to return an error conforming
to the CLOCKSOURCE_OF_RET prototype.
Proper error handling (rollback, errno value) will be changed later case
by case, thus this change just return back an error or success in the init
function.
This is the third version of the patchset previously sent [1]. I have
basically only rebased it on top of 4.7-rc1 tree and dropped "dm: get
rid of superfluous gfp flags" which went through dm tree. I am sending
it now because it is tree wide and chances for conflicts are reduced
considerably when we want to target rc2. I plan to send the next step
and rename the flag and move to a better semantic later during this
release cycle so we will have a new semantic ready for 4.8 merge window
hopefully.
Motivation:
While working on something unrelated I've checked the current usage of
__GFP_REPEAT in the tree. It seems that a majority of the usage is and
always has been bogus because __GFP_REPEAT has always been about costly
high order allocations while we are using it for order-0 or very small
orders very often. It seems that a big pile of them is just a
copy&paste when a code has been adopted from one arch to another.
I think it makes some sense to get rid of them because they are just
making the semantic more unclear. Please note that GFP_REPEAT is
documented as
* __GFP_REPEAT: Try hard to allocate the memory, but the allocation attempt
* _might_ fail. This depends upon the particular VM implementation.
while !costly requests have basically nofail semantic. So one could
reasonably expect that order-0 request with __GFP_REPEAT will not loop
for ever. This is not implemented right now though.
I would like to move on with __GFP_REPEAT and define a better semantic
for it.
$ git grep __GFP_REPEAT origin/master | wc -l
111
$ git grep __GFP_REPEAT | wc -l
36
So we are down to the third after this patch series. The remaining
places really seem to be relying on __GFP_REPEAT due to large allocation
requests. This still needs some double checking which I will do later
after all the simple ones are sorted out.
I am touching a lot of arch specific code here and I hope I got it right
but as a matter of fact I even didn't compile test for some archs as I
do not have cross compiler for them. Patches should be quite trivial to
review for stupid compile mistakes though. The tricky parts are usually
hidden by macro definitions and thats where I would appreciate help from
arch maintainers.
[1] http://lkml.kernel.org/r/1461849846-27209-1-git-send-email-mhocko@kernel.org
This patch (of 19):
__GFP_REPEAT has a rather weak semantic but since it has been introduced
around 2.6.12 it has been ignored for low order allocations. Yet we
have the full kernel tree with its usage for apparently order-0
allocations. This is really confusing because __GFP_REPEAT is
explicitly documented to allow allocation failures which is a weaker
semantic than the current order-0 has (basically nofail).
Let's simply drop __GFP_REPEAT from those places. This would allow to
identify place which really need allocator to retry harder and formulate
a more specific semantic for what the flag is supposed to do actually.
Link: http://lkml.kernel.org/r/1464599699-30131-2-git-send-email-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Jan Kara <jack@suse.cz>
Cc: John Crispin <blogic@openwrt.org>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
"User" addresses are shown in /sys/devices/pci.../.../resource and
/proc/bus/pci/devices and used as mmap offsets for /proc/bus/pci/BB/DD.F
files. For I/O port resources on microblaze, these are PCI bus addresses,
i.e., raw BAR values.
Previously pci_resource_to_user() computed the user address by subtracting
"hose->io_base_virt - _IO_BASE" from the resource start:
if (IO)
offset = (unsigned long)hose->io_base_virt - _IO_BASE;
*start = rsrc->start - offset;
We've already told the PCI core about that "hose->io_base_virt - _IO_BASE"
offset:
pcibios_setup_phb_resources()
res = &hose->io_resource;
pci_add_resource_offset(resources, res, hose->io_base_virt - _IO_BASE);
so pcibios_resource_to_bus() knows how to do that translation.
No functional change intended.
Acked-by: Yinghai Lu <yinghai@kernel.org>
Replace the pci_resource_to_user() declarations in each arch that defines
HAVE_ARCH_PCI_RESOURCE_TO_USER with a single one in linux/pci.h.
Change the MIPS static inline implementation to a non-inline version so the
static inline doesn't conflict with the new non-static linux/pci.h
declaration.
The microblaze __pci_mmap_set_pgprot() was apparently copied from powerpc,
where it computes either an uncacheable pgprot_t or a write-combining one.
But on microblaze, we always use the regular uncacheable pgprot_t.
Remove the useless code in __pci_mmap_set_pgprot() and inline it at the
only call site.
This symbols is not needed to get access to selecting the
GPIOLIB anymore: any arch can select GPIOLIB.
Cc: Michael Büsch <m@bues.ch>
Pull string hash improvements from George Spelvin:
"This series does several related things:
- Makes the dcache hash (fs/namei.c) useful for general kernel use.
(Thanks to Bruce for noticing the zero-length corner case)
- Converts the string hashes in <linux/sunrpc/svcauth.h> to use the
above.
- Avoids 64-bit multiplies in hash_64() on 32-bit platforms. Two
32-bit multiplies will do well enough.
- Rids the world of the bad hash multipliers in hash_32.
This finishes the job started in commit 689de1d6ca95 ("Minimal
fix-up of bad hashing behavior of hash_64()")
The vast majority of Linux architectures have hardware support for
32x32-bit multiply and so derive no benefit from "simplified"
multipliers.
The few processors that do not (68000, h8/300 and some models of
Microblaze) have arch-specific implementations added. Those
patches are last in the series.
- Overhauls the dcache hash mixing.
The patch in commit 0fed3ac866ea ("namei: Improve hash mixing if
CONFIG_DCACHE_WORD_ACCESS") was an off-the-cuff suggestion.
Replaced with a much more careful design that's simultaneously
faster and better. (My own invention, as there was noting suitable
in the literature I could find. Comments welcome!)
- Modify the hash_name() loop to skip the initial HASH_MIX(). This
would let us salt the hash if we ever wanted to.
- Sort out partial_name_hash().
The hash function is declared as using a long state, even though
it's truncated to 32 bits at the end and the extra internal state
contributes nothing to the result. And some callers do odd things:
- fs/hfs/string.c only allocates 32 bits of state
- fs/hfsplus/unicode.c uses it to hash 16-bit unicode symbols not bytes
- Modify bytemask_from_count to handle inputs of 1..sizeof(long)
rather than 0..sizeof(long)-1. This would simplify users other
than full_name_hash"
Special thanks to Bruce Fields for testing and finding bugs in v1. (I
learned some humbling lessons about "obviously correct" code.)
On the arch-specific front, the m68k assembly has been tested in a
standalone test harness, I've been in contact with the Microblaze
maintainers who mostly don't care, as the hardware multiplier is never
omitted in real-world applications, and I haven't heard anything from
the H8/300 world"
* 'hash' of git://ftp.sciencehorizons.net/linux:
h8300: Add <asm/hash.h>
microblaze: Add <asm/hash.h>
m68k: Add <asm/hash.h>
<linux/hash.h>: Add support for architecture-specific functions
fs/namei.c: Improve dcache hash function
Eliminate bad hash multipliers from hash_32() and hash_64()
Change hash_64() return value to 32 bits
<linux/sunrpc/svcauth.h>: Define hash_str() in terms of hashlen_string()
fs/namei.c: Add hashlen_string() function
Pull out string hash to <linux/stringhash.h>
Microblaze is an FPGA soft core that can be configured various ways.
If it is configured without a multiplier, the standard __hash_32()
will require a call to __mulsi3, which is a slow software loop.
Instead, use a shift-and-add sequence for the constant multiply.
GCC knows how to do this, but it's not as clever as some.
Signed-off-by: George Spelvin <linux@sciencehorizons.net>
Cc: Alistair Francis <alistair.francis@xilinx.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Pull Microblaze updates from Michal Simek:
- Wire-up new syscalls
- Fix link error
* tag 'microblaze-4.7-rc1' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: pci: export isa_io_base to fix link errors
microblaze: Wire up userfaultfd, membarrier, mlock2 syscalls
The binary GCD algorithm is based on the following facts:
1. If a and b are all evens, then gcd(a,b) = 2 * gcd(a/2, b/2)
2. If a is even and b is odd, then gcd(a,b) = gcd(a/2, b)
3. If a and b are all odds, then gcd(a,b) = gcd((a-b)/2, b) = gcd((a+b)/2, b)
Even on x86 machines with reasonable division hardware, the binary
algorithm runs about 25% faster (80% the execution time) than the
division-based Euclidian algorithm.
On platforms like Alpha and ARMv6 where division is a function call to
emulation code, it's even more significant.
There are two variants of the code here, depending on whether a fast
__ffs (find least significant set bit) instruction is available. This
allows the unpredictable branches in the bit-at-a-time shifting loop to
be eliminated.
If fast __ffs is not available, the "even/odd" GCD variant is used.
I use the following code to benchmark:
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
#include <time.h>
#include <unistd.h>
#define swap(a, b) \
do { \
a ^= b; \
b ^= a; \
a ^= b; \
} while (0)
unsigned long gcd0(unsigned long a, unsigned long b)
unsigned long r;
if (a < b) {
swap(a, b);
if (b == 0)
return a;
while ((r = a % b) != 0) {
a = b;
b = r;
return b;
unsigned long gcd1(unsigned long a, unsigned long b)
unsigned long r = a | b;
if (!a || !b)
return r;
b >>= __builtin_ctzl(b);
for (;;) {
a >>= __builtin_ctzl(a);
if (a == b)
return a << __builtin_ctzl(r);
if (a < b)
swap(a, b);
a -= b;
unsigned long gcd2(unsigned long a, unsigned long b)
if (!a || !b)
return r;
r &= -r;
while (!(b & r))
b >>= 1;
for (;;) {
while (!(a & r))
a >>= 1;
if (a == b)
return a;
if (a < b)
swap(a, b);
a -= b;
a >>= 1;
if (a & r)
a += b;
a >>= 1;
unsigned long gcd3(unsigned long a, unsigned long b)
if (!a || !b)
return r;
if (b == 1)
return r & -r;
for (;;) {
if (a == 1)
return r & -r;
if (a == b)
if (a < b)
swap(a, b);
a -= b;
unsigned long gcd4(unsigned long a, unsigned long b)
if (!a || !b)
return r;
r &= -r;
while (!(b & r))
b >>= 1;
if (b == r)
return r;
for (;;) {
while (!(a & r))
a >>= 1;
if (a == r)
return r;
if (a == b)
return a;
if (a < b)
swap(a, b);
a -= b;
a >>= 1;
if (a & r)
a += b;
a >>= 1;
static unsigned long (*gcd_func[])(unsigned long a, unsigned long b) = {
gcd0, gcd1, gcd2, gcd3, gcd4,
#define TEST_ENTRIES (sizeof(gcd_func) / sizeof(gcd_func[0]))
#if defined(__x86_64__)
#define rdtscll(val) do { \
unsigned long __a,__d; \
__asm__ __volatile__("rdtsc" : "=a" (__a), "=d" (__d)); \
(val) = ((unsigned long long)__a) | (((unsigned long long)__d)<<32); \
} while(0)
static unsigned long long benchmark_gcd_func(unsigned long (*gcd)(unsigned long, unsigned long),
unsigned long a, unsigned long b, unsigned long *res)
unsigned long long start, end;
unsigned long long ret;
unsigned long gcd_res;
rdtscll(start);
gcd_res = gcd(a, b);
rdtscll(end);
if (end >= start)
ret = end - start;
else
ret = ~0ULL - start + 1 + end;
*res = gcd_res;
return ret;
#else
static inline struct timespec read_time(void)
struct timespec time;
clock_gettime(CLOCK_PROCESS_CPUTIME_ID, &time);
return time;
static inline unsigned long long diff_time(struct timespec start, struct timespec end)
struct timespec temp;
if ((end.tv_nsec - start.tv_nsec) < 0) {
temp.tv_sec = end.tv_sec - start.tv_sec - 1;
temp.tv_nsec = 1000000000ULL + end.tv_nsec - start.tv_nsec;
} else {
temp.tv_sec = end.tv_sec - start.tv_sec;
temp.tv_nsec = end.tv_nsec - start.tv_nsec;
return temp.tv_sec * 1000000000ULL + temp.tv_nsec;
struct timespec start, end;
start = read_time();
end = read_time();
*res = gcd_res;
return diff_time(start, end);
#endif
static inline unsigned long get_rand()
if (sizeof(long) == 8)
return (unsigned long)rand() << 32 | rand();
else
return rand();
int main(int argc, char **argv)
unsigned int seed = time(0);
int loops = 100;
int repeats = 1000;
unsigned long (*res)[TEST_ENTRIES];
unsigned long long elapsed[TEST_ENTRIES];
int i, j, k;
for (;;) {
int opt = getopt(argc, argv, "n:r:s:");
/* End condition always first */
if (opt == -1)
break;
switch (opt) {
case 'n':
loops = atoi(optarg);
break;
case 'r':
repeats = atoi(optarg);
break;
case 's':
seed = strtoul(optarg, NULL, 10);
break;
default:
/* You won't actually get here. */
break;
res = malloc(sizeof(unsigned long) * TEST_ENTRIES * loops);
memset(elapsed, 0, sizeof(elapsed));
srand(seed);
for (j = 0; j < loops; j++) {
unsigned long a = get_rand();
/* Do we have args? */
unsigned long b = argc > optind ? strtoul(argv[optind], NULL, 10) : get_rand();
unsigned long long min_elapsed[TEST_ENTRIES];
for (k = 0; k < repeats; k++) {
for (i = 0; i < TEST_ENTRIES; i++) {
unsigned long long tmp = benchmark_gcd_func(gcd_func[i], a, b, &res[j][i]);
if (k == 0 || min_elapsed[i] > tmp)
min_elapsed[i] = tmp;
elapsed[i] += min_elapsed[i];
printf("gcd%d: elapsed %llu\n", i, elapsed[i]);
k = 0;
srand(seed);
for (i = 1; i < TEST_ENTRIES; i++) {
if (res[j][i] != res[j][0])
break;
if (i < TEST_ENTRIES) {
if (k == 0) {
k = 1;
fprintf(stderr, "Error:\n");
fprintf(stderr, "gcd(%lu, %lu): ", a, b);
fprintf(stderr, "%ld%s", res[j][i], i < TEST_ENTRIES - 1 ? ", " : "\n");
if (k == 0)
fprintf(stderr, "PASS\n");
free(res);
return 0;
Compiled with "-O2", on "VirtualBox 4.4.0-22-generic #38-Ubuntu x86_64" got:
zhaoxiuzeng@zhaoxiuzeng-VirtualBox:~/develop$ ./gcd -r 500000 -n 10
gcd0: elapsed 10174
gcd1: elapsed 2120
gcd2: elapsed 2902
gcd3: elapsed 2039
gcd4: elapsed 2812
PASS
gcd0: elapsed 9309
gcd1: elapsed 2280
gcd2: elapsed 2822
gcd3: elapsed 2217
gcd4: elapsed 2710
PASS
gcd0: elapsed 9589
gcd1: elapsed 2098
gcd2: elapsed 2815
gcd3: elapsed 2030
gcd4: elapsed 2718
PASS
gcd0: elapsed 9914
gcd1: elapsed 2309
gcd2: elapsed 2779
gcd3: elapsed 2228
gcd4: elapsed 2709
PASS
[akpm@linux-foundation.org: avoid #defining a CONFIG_ variable]
Signed-off-by: Zhaoxiu Zeng <zhaoxiu.zeng@gmail.com>
Signed-off-by: George Spelvin <linux@horizon.com>
Define HAVE_EXIT_THREAD for archs which want to do something in
exit_thread. For others, let's define exit_thread as an empty inline.
This is a cleanup before we change the prototype of exit_thread to
accept a task parameter.
[akpm@linux-foundation.org: fix mips]
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Steven Miao <realmz6@gmail.com>
ERROR: "isa_io_base" [sound/pci/vx222/snd-vx222.ko] undefined!
ERROR: "isa_io_base" [sound/pci/trident/snd-trident.ko] undefined!
ERROR: "isa_io_base" [sound/pci/snd-via82xx.ko] undefined!
ERROR: "isa_io_base" [drivers/watchdog/wdt_pci.ko] undefined!
ERROR: "isa_io_base" [drivers/watchdog/pcwd_pci.ko] undefined!
ERROR: "isa_io_base" [drivers/video/vgastate.ko] undefined!
ERROR: "isa_io_base" [drivers/video/fbdev/cirrusfb.ko] undefined!
ERROR: "isa_io_base" [drivers/video/fbdev/arkfb.ko] undefined!
ERROR: "isa_io_base" [drivers/usb/host/uhci-hcd.ko] undefined!
ERROR: "isa_io_base" [drivers/usb/host/isp1362-hcd.ko] undefined!
ERROR: "isa_io_base" [drivers/tty/serial/jsm/jsm.ko] undefined!
ERROR: "isa_io_base" [drivers/tty/serial/8250/8250_pci.ko] undefined!
ERROR: "isa_io_base" [drivers/scsi/qla2xxx/qla2xxx.ko] undefined!
ERROR: "isa_io_base" [drivers/scsi/ppa.ko] undefined!
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Wire up new syscalls userfaultfd, membarrier and mlock2.
KASAN needs to know whether the allocation happens in an IRQ handler.
This lets us strip everything below the IRQ entry point to reduce the
number of unique stack traces needed to be stored.
Move the definition of __irq_entry to <linux/interrupt.h> so that the
users don't need to pull in <linux/ftrace.h>. Also introduce the
__softirq_entry macro which is similar to __irq_entry, but puts the
corresponding functions to the .softirqentry.text section.
Signed-off-by: Alexander Potapenko <glider@google.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Andrey Konovalov <adech.fo@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Pull networking updates from David Miller:
"Highlights:
1) Support more Realtek wireless chips, from Jes Sorenson.
2) New BPF types for per-cpu hash and arrap maps, from Alexei
Starovoitov.
3) Make several TCP sysctls per-namespace, from Nikolay Borisov.
4) Allow the use of SO_REUSEPORT in order to do per-thread processing
of incoming TCP/UDP connections. The muxing can be done using a
BPF program which hashes the incoming packet. From Craig Gallek.
5) Add a multiplexer for TCP streams, to provide a messaged based
interface. BPF programs can be used to determine the message
boundaries. From Tom Herbert.
6) Add 802.1AE MACSEC support, from Sabrina Dubroca.
7) Avoid factorial complexity when taking down an inetdev interface
with lots of configured addresses. We were doing things like
traversing the entire address less for each address removed, and
flushing the entire netfilter conntrack table for every address as
well.
8) Add and use SKB bulk free infrastructure, from Jesper Brouer.
9) Allow offloading u32 classifiers to hardware, and implement for
ixgbe, from John Fastabend.
10) Allow configuring IRQ coalescing parameters on a per-queue basis,
from Kan Liang.
11) Extend ethtool so that larger link mode masks can be supported.
From David Decotigny.
12) Introduce devlink, which can be used to configure port link types
(ethernet vs Infiniband, etc.), port splitting, and switch device
level attributes as a whole. From Jiri Pirko.
13) Hardware offload support for flower classifiers, from Amir Vadai.
14) Add "Local Checksum Offload". Basically, for a tunneled packet
the checksum of the outer header is 'constant' (because with the
checksum field filled into the inner protocol header, the payload
of the outer frame checksums to 'zero'), and we can take advantage
of that in various ways. From Edward Cree"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits)
bonding: fix bond_get_stats()
net: bcmgenet: fix dma api length mismatch
net/mlx4_core: Fix backward compatibility on VFs
phy: mdio-thunder: Fix some Kconfig typos
lan78xx: add ndo_get_stats64
lan78xx: handle statistics counter rollover
RDS: TCP: Remove unused constant
RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket
net: smc911x: convert pxa dma to dmaengine
team: remove duplicate set of flag IFF_MULTICAST
bonding: remove duplicate set of flag IFF_MULTICAST
net: fix a comment typo
ethernet: micrel: fix some error codes
ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it
bpf, dst: add and use dst_tclassid helper
bpf: make skb->tc_classid also readable
net: mvneta: bm: clarify dependencies
cls_bpf: reset class and reuse major in da
ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c
ldmvsw: Add ldmvsw.c driver code
"This is the bulk of GPIO changes for kernel v4.6. There is quite a
lot of interesting stuff going on.
The patches to other subsystems and arch-wide are ACKed as far as
possible, though I consider things like per-arch <asm/gpio.h> as
essentially a part of the GPIO subsystem so it should not be needed.
Core changes:
- The gpio_chip is now a *real device*. Until now the gpio chips
were just piggybacking the parent device or (gasp) floating in
space outside of the device model.
We now finally make GPIO chips devices. The gpio_chip will create
a gpio_device which contains a struct device, and this gpio_device
struct is kept private. Anything that needs to be kept private
from the rest of the kernel will gradually be moved over to the
gpio_device.
- As a result of making the gpio_device a real device, we have added
resource management, so devm_gpiochip_add_data() will cut down on
overhead and reduce code lines. A huge slew of patches convert
almost all drivers in the subsystem to use this.
- Building on making the GPIO a real device, we add the first step of
a new userspace ABI: the GPIO character device. We take small
steps here, so we first add a pure *information* ABI and the tool
"lsgpio" that will list all GPIO devices on the system and all
lines on these devices.
We can now discover GPIOs properly from userspace. We still have
not come up with a way to actually *use* GPIOs from userspace.
- To encourage people to use the character device for the future, we
have it always-enabled when using GPIO. The old sysfs ABI is still
opt-in (and can be used in parallel), but is marked as deprecated.
We will keep it around for the foreseeable future, but it will not
be extended to cover ever more use cases.
Cleanup:
- Bjorn Helgaas removed a whole slew of per-architecture <asm/gpio.h>
includes.
This dates back to when GPIO was an opt-in feature and no shared
library even existed: just a header file with proper prototypes was
provided and all semantics were up to the arch to implement. These
patches make the GPIO chip even more a proper device and cleans out
leftovers of the old in-kernel API here and there.
Still some cruft is left but it's very little now.
- There is still some clamping of return values for .get() going on,
but we now return sane values in the vast majority of drivers and
the errorpath is sanitized. Some patches for powerpc, blackfin and
unicore still drop in.
- We continue to switch the ARM, MIPS, blackfin, m68k local GPIO
implementations to use gpiochip_add_data() and cut down on code
lines.
- MPC8xxx is converted to use the generic GPIO helpers.
- ATH79 is converted to use the generic GPIO helpers.
New drivers:
- WinSystems WS16C48
- Acces 104-DIO-48E
- F81866 (a F7188x variant)
- Qoric (a MPC8xxx variant)
- TS-4800
- SPI serializers (pisosr): simple 74xx shift registers connected to
SPI to obtain a dirt-cheap output-only GPIO expander.
- Texas Instruments TPIC2810
- Texas Instruments TPS65218
- Texas Instruments TPS65912
- X-Gene (ARM64) standby GPIO controller"
* tag 'gpio-v4.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (194 commits)
Revert "Share upstreaming patches"
gpio: mcp23s08: Fix clearing of interrupt.
gpiolib: Fix comment referring to gpio_*() in gpiod_*()
gpio: pca953x: Fix pca953x_gpio_set_multiple() on 64-bit
gpio: xgene: Fix kconfig for standby GIPO contoller
gpio: Add generic serializer DT binding
gpio: uapi: use 0xB4 as ioctl() major
gpio: tps65912: fix bad merge
Revert "gpio: lp3943: Drop pin_used and lp3943_gpio_request/lp3943_gpio_free"
gpio: omap: drop dev field from gpio_bank structure
gpio: mpc8xxx: Slightly update the code for better readability
gpio: mpc8xxx: Remove *read_reg and *write_reg from struct mpc8xxx_gpio_chip
gpio: mpc8xxx: Fixup setting gpio direction output
gpio: mcp23s08: Add support for mcp23s18
dt-bindings: gpio: altera: Fix altr,interrupt-type property
gpio: add driver for MEN 16Z127 GPIO controller
gpio: timberdale: Switch to devm_ioremap_resource()
gpio: ts4800: Add IMX51 dependency
gpiolib: rewrite gpiodev_add_to_list
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security layer updates from James Morris:
"There are a bunch of fixes to the TPM, IMA, and Keys code, with minor
fixes scattered across the subsystem.
IMA now requires signed policy, and that policy is also now measured
and appraised"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (67 commits)
X.509: Make algo identifiers text instead of enum
akcipher: Move the RSA DER encoding check to the crypto layer
crypto: Add hash param to pkcs1pad
sign-file: fix build with CMS support disabled
MAINTAINERS: update tpmdd urls
MODSIGN: linux/string.h should be #included to get memcpy()
certs: Fix misaligned data in extra certificate list
X.509: Handle midnight alternative notation in GeneralizedTime
X.509: Support leap seconds
Handle ISO 8601 leap seconds and encodings of midnight in mktime64()
X.509: Fix leap year handling again
PKCS#7: fix unitialized boolean 'want'
firmware: change kernel read fail to dev_dbg()
KEYS: Use the symbol value for list size, updated by scripts/insert-sys-cert
KEYS: Reserve an extra certificate symbol for inserting without recompiling
modsign: hide openssl output in silent builds
tpm_tis: fix build warning with tpm_tis_resume
ima: require signed IMA policy
ima: measure and appraise the IMA policy itself
ima: load policy using path
"PCI changes for v4.6:
Enumeration:
- Disable IO/MEM decoding for devices with non-compliant BARs (Bjorn Helgaas)
- Mark Broadwell-EP Home Agent & PCU as having non-compliant BARs (Bjorn Helgaas
- Mark shadow copy of VGA ROM as IORESOURCE_PCI_FIXED (Bjorn Helgaas)
- Don't assign or reassign immutable resources (Bjorn Helgaas)
- Don't enable/disable ROM BAR if we're using a RAM shadow copy (Bjorn Helgaas)
- Set ROM shadow location in arch code, not in PCI core (Bjorn Helgaas)
- Remove arch-specific IORESOURCE_ROM_SHADOW size from sysfs (Bjorn Helgaas)
- ia64: Use ioremap() instead of open-coded equivalent (Bjorn Helgaas)
- ia64: Keep CPU physical (not virtual) addresses in shadow ROM resource (Bjorn Helgaas)
- MIPS: Keep CPU physical (not virtual) addresses in shadow ROM resource (Bjorn Helgaas)
- Remove unused IORESOURCE_ROM_COPY and IORESOURCE_ROM_BIOS_COPY (Bjorn Helgaas)
- Don't leak memory if sysfs_create_bin_file() fails (Bjorn Helgaas)
- rcar: Remove PCI_PROBE_ONLY handling (Lorenzo Pieralisi)
- designware: Remove PCI_PROBE_ONLY handling (Lorenzo Pieralisi)
Virtualization:
- Wait for up to 1000ms after FLR reset (Alex Williamson)
- Support SR-IOV on any function type (Kelly Zytaruk)
- Add ACS quirk for all Cavium devices (Manish Jaggi)
AER:
- Rename pci_ops_aer to aer_inj_pci_ops (Bjorn Helgaas)
- Restore pci_ops pointer while calling original pci_ops (David Daney)
- Fix aer_inject error codes (Jean Delvare)
- Use dev_warn() in aer_inject (Jean Delvare)
- Log actual error causes in aer_inject (Jean Delvare)
- Log aer_inject error injections (Jean Delvare)
VPD:
- Prevent VPD access for buggy devices (Babu Moger)
- Move pci_read_vpd() and pci_write_vpd() close to other VPD code (Bjorn Helgaas)
- Move pci_vpd_release() from header file to pci/access.c (Bjorn Helgaas)
- Remove struct pci_vpd_ops.release function pointer (Bjorn Helgaas)
- Rename VPD symbols to remove unnecessary "pci22" (Bjorn Helgaas)
- Fold struct pci_vpd_pci22 into struct pci_vpd (Bjorn Helgaas)
- Sleep rather than busy-wait for VPD access completion (Bjorn Helgaas)
- Update VPD definitions (Hannes Reinecke)
- Allow access to VPD attributes with size 0 (Hannes Reinecke)
- Determine actual VPD size on first access (Hannes Reinecke)
- Move structure definitions to separate header file (David Daney)
- Add pci_host_common_probe(), based on gen_pci_probe() (David Daney)
- Expose pci_host_common_probe() for use by other drivers (David Daney)
- Fix altera_pcie_link_is_up() (Ley Foon Tan)
Cavium ThunderX host bridge driver:
- Add PCIe host driver for ThunderX processors (David Daney)
- Add driver for ThunderX-pass{1,2} on-chip devices (David Daney)
- Add DT bindings to configure PHY Tx driver settings (Justin Waters)
- Move imx6_pcie_reset_phy() near other PHY handling functions (Lucas Stach)
- Move PHY reset into imx6_pcie_establish_link() (Lucas Stach)
- Remove broken Gen2 workaround (Lucas Stach)
- Move link up check into imx6_pcie_wait_for_link() (Lucas Stach)
Freescale Layerscape host bridge driver:
- Add "fsl,ls2085a-pcie" compatible ID (Yang Shi)
- Attach VMD resources to parent domain's resource tree (Jon Derrick)
- Set bus resource start to 0 (Keith Busch)
- Add fwnode_handle to x86 pci_sysdata (Jake Oshins)
- Look up IRQ domain by fwnode_handle (Jake Oshins)
- Add paravirtual PCI front-end for Microsoft Hyper-V VMs (Jake Oshins)
- Add pci_ops.{add,remove}_bus() callbacks (Thierry Reding)
- Implement ->{add,remove}_bus() callbacks (Thierry Reding)
- Remove unused struct tegra_pcie.num_ports field (Thierry Reding)
- Track bus -> CPU mapping (Thierry Reding)
- Remove misleading PHYS_OFFSET (Thierry Reding)
- Depend on ARCH_RENESAS, not ARCH_SHMOBILE (Simon Horman)
- ARC: Add PCI support (Joao Pinto)
- Add generic dw_pcie_wait_for_link() (Joao Pinto)
- Add default link up check if sub-driver doesn't override (Joao Pinto)
- Add driver for prototyping kits based on ARC SDP (Joao Pinto)
- Defer probing if devm_phy_get() returns -EPROBE_DEFER (Shawn Lin)
- Use of_pci_get_host_bridge_resources() to parse DT (Bharat Kumar Gogada)
- Remove dependency on ARM-specific struct hw_pci (Bharat Kumar Gogada)
- Don't call pci_fixup_irqs() on Microblaze (Bharat Kumar Gogada)
- Update Zynq binding with Microblaze node (Bharat Kumar Gogada)
- microblaze: Support generic Xilinx AXI PCIe Host Bridge IP driver (Bharat Kumar Gogada)
- Add support for Xilinx NWL PCIe Host Controller (Bharat Kumar Gogada)
Miscellaneous:
- Check device_attach() return value always (Bjorn Helgaas)
- Move pci_set_flags() from asm-generic/pci-bridge.h to linux/pci.h (Bjorn Helgaas)
- Remove includes of empty asm-generic/pci-bridge.h (Bjorn Helgaas)
- ARM64: Remove generated include of asm-generic/pci-bridge.h (Bjorn Helgaas)
- Remove empty asm-generic/pci-bridge.h (Bjorn Helgaas)
- Remove includes of asm/pci-bridge.h (Bjorn Helgaas)
- Consolidate PCI DMA constants and interfaces in linux/pci-dma-compat.h (Bjorn Helgaas)
- unicore32: Remove unused HAVE_ARCH_PCI_SET_DMA_MASK definition (Bjorn Helgaas)
- Cleanup pci/pcie/Kconfig whitespace (Andreas Ziegler)
- Include pci/hotplug Kconfig directly from pci/Kconfig (Bjorn Helgaas)
- Include pci/pcie/Kconfig directly from pci/Kconfig (Bogicevic Sasa)
- frv: Remove stray pci_{alloc,free}_consistent() declaration (Christoph Hellwig)
- Move pci_dma_* helpers to common code (Christoph Hellwig)
- Add PCI_CLASS_SERIAL_USB_DEVICE definition (Heikki Krogerus)
- Add QEMU top-level IDs for (sub)vendor & device (Robin H. Johnson)
- Fix broken URL for Dell biosdevname (Naga Venkata Sai Indubhaskar Jupudi)"
* tag 'pci-v4.6-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (94 commits)
PCI: Add PCI_CLASS_SERIAL_USB_DEVICE definition
PCI: designware: Add driver for prototyping kits based on ARC SDP
PCI: designware: Add default link up check if sub-driver doesn't override
PCI: designware: Add generic dw_pcie_wait_for_link()
PCI: Cleanup pci/pcie/Kconfig whitespace
PCI: Simplify pci_create_attr() control flow
PCI: Don't leak memory if sysfs_create_bin_file() fails
PCI: Simplify sysfs ROM cleanup
PCI: Remove unused IORESOURCE_ROM_COPY and IORESOURCE_ROM_BIOS_COPY
MIPS: Loongson 3: Keep CPU physical (not virtual) addresses in shadow ROM resource
MIPS: Loongson 3: Use temporary struct resource * to avoid repetition
ia64/PCI: Keep CPU physical (not virtual) addresses in shadow ROM resource
ia64/PCI: Use ioremap() instead of open-coded equivalent
ia64/PCI: Use temporary struct resource * to avoid repetition
PCI: Clean up pci_map_rom() whitespace
PCI: Remove arch-specific IORESOURCE_ROM_SHADOW size from sysfs
PCI: thunder: Add driver for ThunderX-pass{1,2} on-chip devices
PCI: thunder: Add PCIe host driver for ThunderX processors
PCI: generic: Expose pci_host_common_probe() for use by other drivers
PCI: generic: Add pci_host_common_probe(), based on gen_pci_probe()
'pci/host-rcar', 'pci/host-tegra', 'pci/host-thunder', 'pci/host-vmd', 'pci/host-xilinx' and 'pci/host-xilinx-nwl' into next
* pci/host-altera:
PCI: altera: Fix altera_pcie_link_is_up()
* pci/host-imx6:
PCI: imx6: Add DT bindings to configure PHY Tx driver settings
* pci/host-keystone:
PCI: keystone: Defer probing if devm_phy_get() returns -EPROBE_DEFER
* pci/host-rcar:
PCI: rcar: Depend on ARCH_RENESAS, not ARCH_SHMOBILE
* pci/host-tegra:
PCI: tegra: Remove misleading PHYS_OFFSET
PCI: tegra: Track bus -> CPU mapping
PCI: tegra: Remove unused struct tegra_pcie.num_ports field
PCI: tegra: Implement ->{add,remove}_bus() callbacks
PCI: Add pci_ops.{add,remove}_bus() callbacks
* pci/host-thunder:
PCI: generic: Move structure definitions to separate header file
* pci/host-vmd:
x86/PCI: VMD: Attach VMD resources to parent domain's resource tree
x86/PCI: VMD: Set bus resource start to 0
x86/PCI: VMD: Document code for maintainability
* pci/host-xilinx:
microblaze/PCI: Support generic Xilinx AXI PCIe Host Bridge IP driver
PCI: xilinx: Update Zynq binding with Microblaze node
PCI: xilinx: Don't call pci_fixup_irqs() on Microblaze
PCI: xilinx: Remove dependency on ARM-specific struct hw_pci
PCI: xilinx: Use of_pci_get_host_bridge_resources() to parse DT
* pci/host-xilinx-nwl:
PCI: xilinx-nwl: Add support for Xilinx NWL PCIe Host Controller
This patch updates all instances of csum_tcpudp_magic and
csum_tcpudp_nofold to reflect the types that are usually used as the source
inputs. For example the protocol field is populated based on nexthdr which
is actually an unsigned 8 bit value. The length is usually populated based
on skb->len which is an unsigned integer.
This addresses an issue in which the IPv6 function csum_ipv6_magic was
generating a checksum using the full 32b of skb->len while
csum_tcpudp_magic was only using the lower 16 bits. As a result we could
run into issues when attempting to adjust the checksum as there was no
protocol agnostic way to update it.
With this change the value is still truncated as many architectures use
"(len + proto) << 8", however this truncation only occurs for values
greater than 16776960 in length and as such is unlikely to occur as we stop
the inner headers at ~64K in size.
I did have to make a few minor changes in the arm, mn10300, nios2, and
score versions of the function in order to support these changes as they
were either using things such as an OR to combine the protocol and length,
or were using ntohs to convert the length which would have truncated the
value.
I also updated a few spots in terms of whitespace and type differences for
the addresses. Most of this was just to make sure all of the definitions
were in sync going forward.
Signed-off-by: Alexander Duyck <aduyck@mirantis.com>
Modify the Microblaze PCI subsystem to work with the generic
drivers/pci/host/pcie-xilinx.c driver on Microblaze and Zynq.
Signed-off-by: Ravi Kiran Gummaluri <rgummal@xilinx.com>
For a long time all architectures implement the pci_dma_* functions using
the generic DMA API, and they all use the same header to do so.
Move this header, pci-dma-compat.h, to include/linux and include it from
the generic pci.h instead of having each arch duplicate this include.
asm/gpio.h is included only by linux/gpio.h, and then only when the arch
selects ARCH_HAVE_CUSTOM_GPIO_H. Only the following arches select it: arm
avr32 blackfin m68k (COLDFIRE only) sh unicore32.
Remove the unused asm/gpio.h files for the arches that do not select
This is a follow-on to 7563bbf89d06 ("gpiolib/arches: Centralise
bolierplate asm/gpio.h").
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
CONFIG_KEYS_DEBUG_PROC_KEYS is no longer an option as /proc/keys is now
mandatory if the keyrings facility is enabled (it's used by libkeyutils in
userspace).
The defconfig references were removed with:
perl -p -i -e 's/CONFIG_KEYS_DEBUG_PROC_KEYS=y\n//' \
`git grep -l CONFIG_KEYS_DEBUG_PROC_KEYS=y`
and the integrity Kconfig fixed by hand.
cc: Andreas Ziegler <andreas.ziegler@fau.de>
cc: Dmitry Kasatkin <dmitry.kasatkin@huawei.com>
Lockdep is initialized at compile time now. Get rid of lockdep_init().
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Mike Krinkin <krinkin.m.u@gmail.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: mm-commits@vger.kernel.org
Move the generic implementation to <linux/dma-mapping.h> now that all
architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now
that everyone supports them.
[valentinrothberg@gmail.com: remove leftovers in Kconfig]
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
As illustrated by commit a3afe70b83fd ("[S390] latencytop s390
support."), HAVE_LATENCYTOP_SUPPORT is defined by an architecture to
advertise an implementation of save_stack_trace_tsk.
However, as of 9212ddb5eada ("stacktrace: provide save_stack_trace_tsk()
weak alias") a dummy implementation is provided if STACKTRACE=y. Given
that LATENCYTOP already depends on STACKTRACE_SUPPORT and selects
STACKTRACE, we can remove HAVE_LATENCYTOP_SUPPORT altogether.
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
commit db0fa0cb0157 "scatterlist: use sg_phys()" did replacements of
the form:
phys_addr_t phys = page_to_phys(sg_page(s));
phys_addr_t phys = sg_phys(s) & PAGE_MASK;
However, this breaks platforms where sizeof(phys_addr_t) >
sizeof(unsigned long). Revert for 4.3 and 4.4 to make room for a
combined helper in 4.5.
Cc: <stable@vger.kernel.org>
Cc: Jens Axboe <axboe@fb.com>
Fixes: db0fa0cb0157 ("scatterlist: use sg_phys()")
Suggested-by: Joerg Roedel <joro@8bytes.org>
Reported-by: Vitaly Lavrov <vel21ripn@gmail.com>
Removal started in commit 5bbeed12bdc3 ("sparc32: drop unused
kmap_atomic_to_page"). Let's do it across the whole tree.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
