path: root/arch/mips/Kconfig
2008-04-28[MIPS] DS1287: Add clockevent driverYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] add DECstation I/O ASIC clocksourceYoichi Yuasa
Add DECstation I/O ASIC clocksource Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] jmr3927: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for JMR3927 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] rbhma4500: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for RBHMA4500 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] generic txx9 gpio supportAtsushi Nemoto
This is a board-independent TXx9 gpio API implementation using gpiolib. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Move arch/mips/philips to arch/mips/nxpDaniel Laird
Signed-off-by: daniel.j.laird <daniel.j.laird@nxp.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Add support for MIPS CMP platform.Ralf Baechle
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-03-12[MIPS] Allow 48Hz to be selected if CONFIG_SYS_SUPPORTS_ARBIT_HZ is set.Ralf Baechle
This allows a 48Hz clock to be selected on Malta and other systems. Note this not normally a sensible option as it results in rather high latencies for some kernel stuff. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-09ide: introduce HAVE_IDESam Ravnborg
To allow flexible configuration of IDE introduce HAVE_IDE. All archs except arm, um and s390 unconditionally select it. For arm the actual configuration determine if IDE is supported. This is a step towards introducing drivers/Kconfig for arm. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-03remove Documentation/smp.txtAdrian Bunk
After seeing the filename I'd have expected something about the implementation of SMP in the Linux kernel - not some notes on kernel configuration and building trivialities noone would search at this place. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alan Cox <alan@redhat.com>
2008-02-03Move Kconfig.instrumentation to arch/Kconfig and init/KconfigMathieu Desnoyers
Move the instrumentation Kconfig to arch/Kconfig for architecture dependent options - oprofile - kprobes and init/Kconfig for architecture independent options - profiling - markers Remove the "Instrumentation Support" menu. Everything moves to "General setup". Delete the kernel/Kconfig.instrumentation file. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03Add HAVE_OPROFILEMathieu Desnoyers
Linus: On the per-architecture side, I do think it would be better to *not* have internal architecture knowledge in a generic file, and as such a line like depends on X86_32 || IA64 || PPC || S390 || SPARC64 || X86_64 || AVR32 really shouldn't exist in a file like kernel/Kconfig.instrumentation. It would be much better to do depends on ARCH_SUPPORTS_KPROBES in that generic file, and then architectures that do support it would just have a bool ARCH_SUPPORTS_KPROBES default y in *their* architecture files. That would seem to be much more logical, and is readable both for arch maintainers *and* for people who have no clue - and don't care - about which architecture is supposed to support which interface... Changelog: Actually, I know I gave this as the magic incantation, but now that I see it, I realize that I should have told you to just use config ARCH_SUPPORTS_KPROBES def_bool y instead, which is a bit denser. We seem to use both kinds of syntax for these things, but this is really what "def_bool" is there for... Changelog : - Moving to HAVE_*. - Add AVR32 oprofile. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-02Merge branch 'suspend' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'suspend' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (38 commits) suspend: cleanup reference to swsusp_pg_dir[] PM: Remove obsolete /sys/devices/.../power/state docs Hibernation: Invoke suspend notifications after console switch Suspend: Invoke suspend notifications after console switch Suspend: Clean up suspend_64.c Suspend: Add config option to disable the freezer if architecture wants that ACPI: Print message before calling _PTS ACPI hibernation: Call _PTS before suspending devices Hibernation: Introduce begin() and end() callbacks ACPI suspend: Call _PTS before suspending devices ACPI: Separate disabling of GPEs from _PTS ACPI: Separate invocations of _GTS and _BFS from _PTS and _WAK Suspend: Introduce begin() and end() callbacks suspend: fix ia64 allmodconfig build ACPI: clear GPE earily in resume to avoid warning Suspend: Clean up Kconfig (V2) Hibernation: Clean up Kconfig (V2) Hibernation: Update messages Suspend: Use common prefix in messages Hibernation: Remove unnecessary variable declaration ...
2008-02-01Suspend: Clean up Kconfig (V2)Johannes Berg
This cleans up the suspend Kconfig and removes the need to declare centrally which architectures support suspend. All architectures that currently support suspend are modified accordingly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Russell King <rmk@arm.linux.org.uk> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01PCI: Kconfig help: don't refer to the PCI-HOWTOAdrian Bunk
A HOWTO that hasn't been updated for half a dozen years no longer "contains valuable information about which PCI hardware does work under Linux and which doesn't". Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-30spinlock: lockbreak cleanupNick Piggin
The break_lock data structure and code for spinlocks is quite nasty. Not only does it double the size of a spinlock but it changes locking to a potentially less optimal trylock. Put all of that under CONFIG_GENERIC_LOCKBREAK, and introduce a __raw_spin_is_contended that uses the lock data itself to determine whether there are waiters on the lock, to be used if CONFIG_GENERIC_LOCKBREAK is not set. Rename need_lockbreak to spin_needbreak, make it use spin_is_contended to decouple it from the spinlock implementation, and make it typesafe (rwlocks do not have any need_lockbreak sites -- why do they even get bloated up with that break_lock then?). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-29[MIPS] Cobalt 64-bits kernels can be safely unmarked experimentalFlorian Fainelli
64-bits Cobalt kernels run fine. Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Qemu: Remove platform.Ralf Baechle
The Qemu platform was originally implemented to have an easily supportable platform until Qemu reaches a state where it emulates a real world system. Since the latest release Qemu is capable of emulating the MIPSsim and Malta platforms, so this goal has been reached. The Qemu plaform is also rather underfeatured so less useful than a Malta emulation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] move the eXcite local config to excitedirectoryYoichi Yuasa
Moved the eXcite local config to excite directory. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Altas, Malta: Switch boot file format to raw.Ralf Baechle
A raw binary boots about twice as fast as SREC. The possibility to generate SREC binaries remains by simply using the vmlinux.srec target but seems only useful for the probably hypothetical case where one of these systems is booted over a serial interface. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] RM: Collected changesThomas Bogendoerfer
- EISA support for non PCI RMs (RM200 and RM400-xxx). The major part is the splitting of the EISA and onboard ISA of the RM200, which makes the EISA bus on the RM200 look like on other RMs. - 64bit kernel support - system type detection is now common for big and little endian - moved sniprom code to arch/mips/fw - added call_o32 function to arch/mips/fw/lib, which uses a private stack for calling prom functions - fix problem with ISA interrupts, which makes using PIT clockevent possible Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] IP28 supportThomas Bogendoerfer
Add support for SGI IP28 machines (Indigo 2 with R10k CPUs) This work is mainly based on Peter Fuersts work. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Remove CONFIG_SIBYTE_PT{1120,1125,SWARM}Ralf Baechle
According to Broadcom the PT systems are production test systems which never reached customers so no need to keep the fragmentary support we currently have. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] SMP: Call platform methods via ops structure.Ralf Baechle
2008-01-29[MIPS] Cleanup pcspeaker platform device registration.Ralf Baechle
Move registration into the actual platform code instead of making a desparate attempt at sharing the hand full of likes of code in pcspeaker.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] MT: Scheduler support for SMTRalf Baechle
2008-01-29[MIPS] R4000/R4400 errata workaroundsMaciej W. Rozycki
This is the gereric part of R4000/R4400 errata workarounds. They include compiler and assembler support as well as some source code modifications to address the problems with some combinations of multiply/divide+shift instructions as well as the daddi and daddiu instructions. Changes included are as follows: 1. New Kconfig options to select workarounds by platforms as necessary. 2. Arch top-level Makefile to pass necessary options to the compiler; also incompatible configurations are detected (-mno-sym32 unsupported as horribly intrusive for little gain). 3. Bug detection updated and shuffled -- the multiply/divide+shift problem is lethal enough that if not worked around it makes the kernel crash in time_init() because of a division by zero; the daddiu erratum might also trigger early potentially, though I have not observed it. On the other hand the daddi detection code requires the exception subsystem to have been initialised (and is there mainly for information). 4. r4k_daddiu_bug() added so that the existence of the erratum can be queried by code at the run time as necessary; useful for generated code like TLB fault and copy/clear page handlers. 5. __udelay() updated as it uses multiplication in inline assembly. Note that -mdaddi requires modified toolchain (which has been maintained by myself and available from my site for ~4years now -- versions covered are GCC 2.95.4 - 4.1.2 and binutils from 2.13 onwards). The -mfix-r4000 and -mfix-r4400 have been standard for a while though. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Delete unused CONFIG_64BIT_CONTEXTRalf Baechle
The merge of the code to use this was never completed so delete it for the time being. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Delete unused CONFIG_DMA_IP32.Ralf Baechle
The functionality of the former dma-ip32.c has been folded into dma-default.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-15[MIPS] Kconfig fixes for BCM47XX platformAurelien Jarno
The patch below fixes two problems for Kconfig on the BCM47xx platform: - arch/mips/bcm47xx/gpio.c uses ssb_extif_* functions. Selecting SSB_DRIVER_EXTIF makes sure those functions are available. - arch/mips/pci/pci.c needs, when enabled, platform specific functions, which are defined when SSB_PCICORE_HOSTMODE is enabled. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-07[MIPS] Move inclusing of kernel/time/Kconfig menu to appropriate placeAtsushi Nemoto
CONFIG_NO_HZ, CONFIG_HIGH_RES_TIMERS should be selected in "Kernel type" menu, not in "CPU selection" menu. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-06Fix oprofile configuration breakageRalf Baechle
The cleanup 09cadedbdc01f1a4bea1f427d4fb4642eaa19da9 broke the oprofile configuration for MIPS by allowing oprofile support to be built for kernel models where oprofile doesn't have a chance in hell to work. Just a dependecy list on a number of architectures is - surprise - broken and should as per past discussions probably in most considered to be broken in most cases. So I introduce a dependency for the oprofile configuration on ARCH_SUPPORTS_OPROFILE. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-26[MIPS] IP22: Fix broken EISA interrupt setup by switching to generic i8259Thomas Bogendoerfer
2007-11-26[MIPS] 64-bit Sibyte kernels need DMA32.Ralf Baechle
Sibyte SOCs only have 32-bit PCI. Due to the sparse use of the address space only the first 1GB of memory is mapped at physical addresses below 1GB. If a system has more than 1GB of memory 32-bit DMA will not be able to reach all of it. For now this patch is good enough to keep Sibyte users happy but it seems eventually something like swiotlb will be needed for Sibyte. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-26[MIPS] Only build r4k clocksource for systems that work ok with it.Ralf Baechle
In particular as-is it's not suited for multicore and mutiprocessors systems where there is on guarantee that the counter are synchronized or running from the same clock at all. This broke Sibyte and probably others since the "[MIPS] Handle R4000/R4400 mfc0 from count register." commit. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-15[MIPS] Fix shadow register support.Ralf Baechle
Shadow register support would not possibly have worked on multicore systems. The support code for it was also depending not on MIPS R2 but VSMP or SMTC kernels even though it makes perfect sense with UP kernels. SR sets are a scarce resource and the expected usage pattern is that users actually hardcode the register set numbers in their code. So fix the allocator by ditching it. Move the remaining CPU probe bits into the generic CPU probe. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-15[MIPS] Qemu: Add early printk, your friend in a cold night.Ralf Baechle
2007-11-02[MIPS] Bigsur supports highmem.Ralf Baechle
2007-11-02[MIPS] Sibyte: Split and move clock code.Ralf Baechle
2007-10-29[MIPS] txx9tmr clockevent/clocksource driverAtsushi Nemoto
Convert jmr3927_clock_event_device to more generic txx9tmr_clock_event_device which supports one-shot mode. The txx9tmr_clock_event_device can be used for TX49 too if the cp0 timer interrupt was not available. Convert jmr3927_hpt_read to txx9_clocksource driver which does not depends jiffies anymore. The txx9_clocksource itself can be used for TX49, but normally TX49 uses higher precision clocksource_mips. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-22[MIPS] time: Add GT641xx timer0 clockevent driverYoichi Yuasa
And make use of it for Cobalt. A few others such as the Malta could make use of it as well. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-20typo fixesMatt LaPlante
Most of these fixes were already submitted for old kernel versions, and were approved, but for some reason they never made it into the releases. Because this is a consolidation of a couple old missed patches, it touches both Kconfigs and documentation texts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Combine instrumentation menus in kernel/Kconfig.instrumentationMathieu Desnoyers
Quoting Randy: "It seems sad that this patch sources Kconfig.marker, a 7-line file, 20-something times. Yes, you (we) don't want to put those 7 lines into 20-something different files, so sourcing is the right thing. However, what you did for avr32 seems more on the right track to me: make _one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES, and MARKERS and then use (source) that in all of the arches." Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18[MIPS] time: Move R4000 clockevent device code to separate configurable fileRalf Baechle
2007-10-16[MIPS] Lasat: Fix build by conversion to irq_cpu.c.Ralf Baechle
2007-10-16[MIPS] IP32: Fix build by conversion to irq_cpu.c.Ralf Baechle
2007-10-11[MIPS] i8253 PIT clocksource and clockevent driversRalf Baechle
Derived from the i386 variant with a few x86 complexities chopped off. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Dyntick support for SMTC:Ralf Baechle
The kernel currently only supports broadcasting of the timer interrupt from a single timer, not multicasting into two multicast groups of processors. So the implemented mechanism for SMTC works by broadcasting the cp0 compare interrupt on VPE 0 and ignoring it on any additional VPEs. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Implement clockevents for R4000-style cp0 count/compare interruptRalf Baechle
