path: root/arch/mips/Makefile
2006-11-02[MIPS] Do not use -msym32 option for modules.Atsushi Nemoto
On 64-bit kernel, modules are loaded into XKSEG for now. While XKSEG address is not a sign-extended 32-bit address, we can not use -msym32 option. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-11[MIPS] Workaround for bug in gcc -EB / -EL options.Ralf Baechle
Certain gcc versions upto gcc 4.1.1 (probably 4.2-subversion as of 2006-10-10 don't properly change the the predefined symbols if -EB / -EL are used, so we kludge that here. A bug has been filed at http://gcc.gnu.org/bugzilla/show_bug.cgi?id=29413. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-03[MIPS] Remove IT8172-based platforms, ITE 8172G and Globespan IVR support.Yoichi Yuasa
As per feature-removal-schedule.txt. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Remove EV96100 as previously announced.Ralf Baechle
2006-09-27[MIPS] SEAD defconfig build fixMaciej W. Rozycki
Signed-off-by: Maciej W. Rozycki <macro@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Remove vmlinux.rm200 target from makefile.Yoichi Yuasa
Long ago in the dark ages this was used a MIPS a.out binary to be used with Milo which is obsolete since years. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29[MIPS] Consistent formatting for Qemu makefile segment.Ralf Baechle
2006-06-19[MIPS] Support for the RM9000-based Basler eXcite smart camera platform.Ralf Baechle
Signed-off-by: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Support for the R5500-based NEC EMMA2RH Mark-eins boarddmitry pervushin
Signed-off-by: dmitry pervushin <dpervushin@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove support for NEC DDB5476.Ralf Baechle
As warned several times before. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove support for NEC DDB5074.Ralf Baechle
2006-06-19[MIPS] Wind River 4KC PPMC Eval Board SupportMark.Zhan
Support for the GT-64120-based Wind River 4KC PPMC Evaluation board. Signed-off-by: Rongkai.Zhan <Rongkai.zhan@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Fix optimization for size build.Ralf Baechle
It took a while longer than on other architectures but gcc has finally started to strike us as well ... This also fixes the damage by 6edfba1b33c701108717f4e036320fc39abe1912. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-27[MIPS] Sparse: fix sparse for 64-bit kernels.Atsushi Nemoto
This commit breaks sparse for 64bit kernel. The -m64 option is required. Also, some macro values (such as _MIPS_TUNE, etc.) contain double-quote characters so it would be better quoting arguments by single-quote characters. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] Fix Makefile bugs for MIPS32/MIPS64 R1 and R2.Ralf Baechle
This fixes kernel builds with gcc 3.2 (not 64-bit, that is looking like it is beyond recovery) and 3.3. With these bugs fixed we now also can get undo 3b4c4996a0c24da9e6f8be764e3950b756b18cc0 and similar bits for SMTC that were added in 79cc8007b93838a670b164b8a55ab3e735a12a8b. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] Fix breakage due to the grand makefile crapectomy.Ralf Baechle
It's cc-option not cc-options. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-21[MIPS] Makefile crapectomy.Ralf Baechle
Dump all the ridiculously complicated stuff that was needed support compilers older and newer than 3.0. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Thiemo Seufer <ths@networkno.de>
2006-03-21[MIPS] Remove CONFIG_BUILD_ELF64.Ralf Baechle
This option is no longer usable with supported compilers. It will be replaced by usage of -msym32 in a separate patch. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-18[MIPS] SB1: Check for -mno-sched-prolog if building corelis debug kernel.Ralf Baechle
2006-03-09[MIPS] Always pass -msoft-float.Ralf Baechle
Some people still haven't heared that fp in the kernel is forbidden. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-14[MIPS] Get rid of kludgery needed to keep stdargs of old compilers working.Ralf Baechle
2006-02-07[MIPS] Remove commented out code to add -mmad for Nevada.Ralf Baechle
Adding -mmad is not usable since over half a decade in gcc and when fixed the proper -march option values should enable the use of the mad, madu and mul instructions of the R5500, RM5200, RM7000 and RM9000 families. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-07[MIPS] Sparse: Add _MIPS_SZINT and _MIPS_ISA to CHECKFLAGS to fix sparse ↵Atsushi Nemoto
warnings. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-07[MIPS] Rename include/asm-mips/cobalt to include/asm-mips/mach-cobalt.Ralf Baechle
2006-01-10MIPS: Don't pass -finline-limit=100000.Ralf Baechle
This was a stop gap meassure for gcc 3.3 and newer sometimes not inlining inline functions in the 2.4 days. Starting we pass the always_inline attribute, so -finline-limit is no longer necessary and it's been shown to problematic on Sparc. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-17[MIPS] JMR3927: need include/asm-mips/mach-jmr3927 in it's include path.Ralf Baechle
2005-10-29Support for BigSur board.Andrew Isaacson
Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Add support for BCM1480 family of chips.Andrew Isaacson
- Kconfig and Makefile changes - arch/mips/sibyte/bcm1480/ - changes to sibyte common code to support 1480 Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Support for MIPSsim, the cycle accurate MIPS simulator.Ralf Baechle
2005-10-29Support for Toshiba's RBHMA4500 eval board for the TX4938.Ralf Baechle
2005-10-29commit 1858f72fa2e2f63e62114a9bd40c8e68468d8c5eRalf Baechle
Author: Ralf Baechle <ralf@linux-mips.org> Date: Fri Jul 22 05:46:02 2005 +0000 New build target vmlinux.bin build raw binary image for Qemu. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Philips PNX8550 support: MIPS32-like core with 2 Trimedias on it.Pete Popov
2005-10-29Generate code for MIPS32 / MIPS64 Release 2 if configured for one ofRalf Baechle
these architectures. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29... and it isn't a canonicalized triplet but just the n-plet used toThiemo Seufer
configure gcc. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Thiemo Seufer <ths@networkno.de>
2005-10-29Grep deesn't like shell-style matching...Thiemo Seufer
2005-10-29Hack to make compiles for the other endianness easier.Thiemo Seufer
2005-10-29Rename CONFIG_CPU_MIPS{32,64} to CONFIG_CPU_MIPS{32|64}_R1.Ralf Baechle
2005-10-29When building for Atlas, Malta or SEAD convert the kernel to srecs byRalf Baechle
default. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Sparseify MIPS.Ralf Baechle
2005-10-29Base Au1200 2.6 support.Pete Popov
2005-10-29Resurrect Cobalt support for 2.6.Ralf Baechle
2005-10-29-nostdlib boilerplate.Thiemo Seufer
Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-09kbuild: mips use generic asm-offsets.h supportSam Ravnborg
Removed obsolete stuff from arch makefile. mips had a special rule for generating asm-offsets.h so preserved it using an architecture specific hook in top-level Kbuild file. Renamed .h file to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-06Merge master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuild Linus Torvalds
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: add TANBAC VR4131 multichip moduleYoichi Yuasa
This patch has added TANBAC VR4131 multichip module in arch/mips/Kconfig Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: add support for Qemu system architectureRalf Baechle
Add support for the virtual MIPS system that is emulated by Qemu. See http://www.linux-mips.org/wiki/Qemu for a detailed current status. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: moreover remove vr4181Yoichi Yuasa
We also need this patch for removing mips vr4181. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: change system type name in proc for vr41xxYoichi Yuasa
This patch has changed system type name in proc for vr41xx. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
