path: root/arch/mips/Makefile
2009-09-20arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0Sam Ravnborg
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported: Bash 4 filters out variables which contain a dot in them. This happends to be the case of CPPFLAGS_vmlinux.lds. This is rather unfortunate, as it now causes build failures when using SHELL=/bin/bash to compile, or when bash happens to be used by make (eg when it's /bin/sh) Remove the common definition of CPPFLAGS_vmlinux.lds by pushing relevant stuff to either Makefile.build or the arch specific kernel/Makefile where we build the linker script. This is also nice cleanup as we move the information out where it is used. Notes for the different architectures touched: arm - we use an already exported symbol cris - we use a config symbol aleady available [Not build tested] mips - the jiffies complexity has moved to vmlinux.lds.S where we need it. Added a few variables to CPPFLAGS - they are only used by the linker script. [Not build tested] powerpc - removed assignment that is not needed [not build tested] sparc - simplified it using $(BITS) um - introduced a few new exported variables to deal with this xtensa - added options to CPP invocation [not build tested] Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-17MIPS: BCM63xx: Add support for the Broadcom BCM63xx family of SOCs.Maxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Add GCC 4.4 support for Loongson2EWu Zhangjin
Because only gcc >=4.4 have loongson-specific support, we need to choose the suitable -march argument for gcc <= 4.3 and gcc >= 4.4, and here, we use -march=loongson2e for loongson2e. Thanks goes to Arnaud Patard <apatard@mandriva.com> for suggestion of using cc-options(Documentation/kbuild/makefiles.txt). and thanks Zhang Le for introducing the new CPU_LOONGSON2E kernel option. NOTE: -mtune option is not need if -march and -mtune use the same value. Signed-off-by: Zhang Le <r0bertz@gentoo.org> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Split common loongson source code outWu Zhangjin
To share common loongson source code between all of the loongson-based machines. there is a need to split it out of the fuloong-2e/ directory. at the same time, other according tuning is needed. the machine-specific parts are defined as macros in relative header file, pci.h, mem.h, machine.h. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Change naming methodsWu Zhangjin
To make source code of loongson sharable to the machines(such as gdium) made by the other companies, we rename arch/mips/lemote to arch/mips/loongson, asm/mach-lemote to asm/mach-loongson, and rename lm2e to the name of the machine: fuloong-2e. accordingly, FULONG are renamed to FULOONG2E to make it distinguishable to the future FULOONG2F. and also, some other relative tuning is needed. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: Add support for Texas Instruments AR7 System-on-a-ChipFlorian Fainelli
This patch adds support for the Texas Instruments AR7 System-on-a-Chip. It supports the TNETD7100, 7200 and 7300 versions of the SoC. Signed-off-by: Matteo Croce <matteo@openwrt.org> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Eugene Konev <ejka@openwrt.org> Signed-off-by: Nicolas Thill <nico@openwrt.org> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Add hibernation supportWu Zhangjin
[Ralf: SMP support requires CPU hotplugging which MIPS currently doesn't support. As implemented in this patch cache and tlb flushing will also be invoked with interrupts disabled so smp_call_function() will blow up in charming ways. So limit to !SMP.] Reviewed-by: Pavel Machek <pavel@ucw.cz> Reviewed-by: Yan Hua <yanh@lemote.com> Reviewed-by: Arnaud Patard <apatard@mandriva.com> Reviewed-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Hu Hongbing <huhb@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Alchemy: Rewrite GPIO support.Manuel Lauss
The current in-kernel Alchemy GPIO support is far too inflexible for all my use cases. To address this, the following changes are made: * create generic functions which deal with manipulating the on-chip GPIO1/2 blocks. Such functions are universally useful. * Macros for GPIO2 shared interrupt management and block control. * support for both built-in CONFIG_GPIOLIB and fast, inlined GPIO macros. If CONFIG_GPIOLIB is not enabled, provide linux gpio framework compatibility by directly inlining the GPIO1/2 functions. GPIO access is limited to on-chip ones and they can be accessed as documented in the datasheets (GPIO0-31 and 200-215). If CONFIG_GPIOLIB is selected, two (2) gpio_chip-s, one for GPIO1 and one for GPIO2, are registered. GPIOs can still be accessed by using the numberspace established in the databooks. However this is not yet flexible enough for my uses: My Alchemy systems have a documented "external" gpio interface (fixed, different numberspace) and can support a variety of baseboards, some of which are equipped with I2C gpio expanders. I want to be able to provide the default 16 GPIOs of the CPU board numbered as 0..15 and also support gpio expanders, if present, starting as gpio16. To achieve this, a new Kconfig symbol for Alchemy is introduced, CONFIG_ALCHEMY_GPIO_INDIRECT, which boards can enable to signal that they don't want the Alchemy numberspace exposed to the outside world, but instead want to provide their own. Boards are now respon- sible for providing the linux gpio interface glue code (either in a custom gpio.h header (in board include directory) or with gpio_chips). To make the board-specific inlined gpio functions work, the MIPS Makefile must be changed so that the mach-au1x00/gpio.h header is included _after_ the board headers, by moving the inclusion of the mach-au1x00/ to the end of the header list. See arch/mips/include/asm/mach-au1x00/gpio.h for more info. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Sibyte: Remove standalone kernel supportImre Kaloz
CFE is the only supported and used bootloader on the SiByte boards, the standalone kernel support has been never used outside Broadcom. Remove it and make the kernel use CFE by default. Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-05-20MIPS: IP28: Change to build with -mr10k-cache-barrier=storepeter fuerst
Richard Sandiford's new code for inserting the cache-barriers, for GCC 4.3 and above and already incorporated in the current GCC-release, uses a slightly different option-syntax. Signed-off-by: peter fuerst <post@pfrst.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-05-14MIPS: Use -mno-check-zero-divisionRalf Baechle
I don't think that in 15 years of Linux/MIPS the zero division checking code generated by gcc by default has ever caught anything. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-05-14MIPS: Set compiler options only after the compiler prefix has ben set.Ralf Baechle
Otherwise indigestable options might be passed to the host compiler. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30MIPS: Makefile: Add simple make install target.Ralf Baechle
2009-03-13MIPS: Mark Eins: Fix configuration.Ralf Baechle
2009-01-11MIPS: Alchemy: Move development board code to common subdirectoryManuel Lauss
This should ease sharing of common devboard code. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-11MIPS: Hook up Cavium OCTEON in arch/mips.David Daney
Take all the OCTEON specific files that were added, and hook them into the build system for the arch/mips. For versions of GCC that lack OCTEON support, override gas target architecture. Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-27MIPS: EMMA: Move arch/mips/emma2rh/ into arch/mips/emma/Shinya Kuribayashi
git mv arch/mips/{emma2rh,emma} and fixups Makefiles. We'll put all NEC EMMA series based machines there in the future. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-27MIPS: EMMA: Kconfig reorganizationShinya Kuribayashi
- Move EMMA related stuff into arch/mips/emma/Kconfig - Create CONFIG_SOC_EMMA* to handle more EMMA SoCs effectively - Rename CONFIG_MARKEINS into CONFIG_NEC_MARKEINS Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-27MIPS: Add CONFIG_CPU_R5500 for NEC VR5500 series processorsShinya Kuribayashi
We already have sufficient infrastructure to support VR5500 and VR5500A series processors. Here's a Makefile support to make it selectable by ports, and enable it for NEC EMMA2RH Markeins board. This patch also fixes a confused target help, and adds 1Gb PageMask bits supported by VR5500 and its variants. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-27MIPS: Add support for NXP PNX833x (STB222/5) into linux kernelDaniel Laird
The following patch add support for the NXP PNX833x SOC. More specifically it adds support for the STB222/5 variant. It fixes the vectored interrupt issue. Signed-off-by: daniel.j.laird <daniel.j.laird@nxp.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Move headfiles to new location below arch/mips/includeRalf Baechle
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: TXx9: Add RBTX4939 board supportAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> create mode 100644 arch/mips/txx9/rbtx4939/Makefile create mode 100644 arch/mips/txx9/rbtx4939/irq.c create mode 100644 arch/mips/txx9/rbtx4939/prom.c create mode 100644 arch/mips/txx9/rbtx4939/setup.c create mode 100644 include/asm-mips/txx9/rbtx4939.h
2008-07-20[MIPS] Routerboard 532: Support for base systemRalf Baechle
Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] TXx9: rename asm-mips/mach-jmr3927 to asm-mips/mach-tx39xxAtsushi Nemoto
Rename mach-jmr3927 directory to more proper name to make adding other platforms easier. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] cmbvr4133: Remove supportYoichi Yuasa
It cannot be built for a long time and nobody maintains it. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] TXx9: Make single kernel can support multiple boardsAtsushi Nemoto
Make single kernel can be used on RBTX4927/37/38. Also make some SoC-specific code independent from board-specific code. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] TXx9: Reorganize codeAtsushi Nemoto
Move arch/mips/{jmr3927,tx4927,tx4938} into arch/mips/txx9/ tree. This will help more code sharing and maintainance. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] Malta: Cleanup organization of code into directories.Ralf Baechle
2008-07-15[MIPS] Remove always true ifdef conditions.Ralf Baechle
2008-07-15[MIPS] SEAD: Remove support code.Ralf Baechle
2008-07-15[MIPS] Atlas: Remove support code.Ralf Baechle
2008-07-15[MIPS] Enable -ffunction-sections sections.Ralf Baechle
-ffunction-sections serves as a workaround for the problems caused by the limited branch range in some inline assembler fragments for very large compilation units. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-16[MIPS] Sibyte: Build RTC support as an objectMaciej W. Rozycki
Build the SWARM platform library is as an object rather than an archive so that files which only contain symbols used by initcalls and do not provide any symbols that would pull them from an archive still work. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-16[MIPS] Better load address for big endian SNI RMThomas Bogendoerfer
Use better load address for big endian kernels to avoid clashes with PROM / SASH. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Move arch/mips/philips to arch/mips/nxpDaniel Laird
Signed-off-by: daniel.j.laird <daniel.j.laird@nxp.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-01[MIPS] Check for GCC r10k-cache-barrier supportThomas Bogendoerfer
Check whether gcc supports -mr10-cache-barrier=1 and issue a cleaner error message if not. This option is needed to build working SGI IP28 kernels. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-03-12[MIPS] Use KBUILD_DEFCONFIGAdrian Bunk
With KBUILD_DEFCONFIG we don't have to ship a second copy of ip22_defconfig. Signed-off-by: Adrian Bunk <adrian.bunk@movial.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Qemu: Remove platform.Ralf Baechle
The Qemu platform was originally implemented to have an easily supportable platform until Qemu reaches a state where it emulates a real world system. Since the latest release Qemu is capable of emulating the MIPSsim and Malta platforms, so this goal has been reached. The Qemu plaform is also rather underfeatured so less useful than a Malta emulation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Altas, Malta: Switch boot file format to raw.Ralf Baechle
A raw binary boots about twice as fast as SREC. The possibility to generate SREC binaries remains by simply using the vmlinux.srec target but seems only useful for the probably hypothetical case where one of these systems is booted over a serial interface. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] RM: Collected changesThomas Bogendoerfer
- EISA support for non PCI RMs (RM200 and RM400-xxx). The major part is the splitting of the EISA and onboard ISA of the RM200, which makes the EISA bus on the RM200 look like on other RMs. - 64bit kernel support - system type detection is now common for big and little endian - moved sniprom code to arch/mips/fw - added call_o32 function to arch/mips/fw/lib, which uses a private stack for calling prom functions - fix problem with ISA interrupts, which makes using PIT clockevent possible Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] IP28 supportThomas Bogendoerfer
Add support for SGI IP28 machines (Indigo 2 with R10k CPUs) This work is mainly based on Peter Fuersts work. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] R4000/R4400 errata workaroundsMaciej W. Rozycki
This is the gereric part of R4000/R4400 errata workarounds. They include compiler and assembler support as well as some source code modifications to address the problems with some combinations of multiply/divide+shift instructions as well as the daddi and daddiu instructions. Changes included are as follows: 1. New Kconfig options to select workarounds by platforms as necessary. 2. Arch top-level Makefile to pass necessary options to the compiler; also incompatible configurations are detected (-mno-sym32 unsupported as horribly intrusive for little gain). 3. Bug detection updated and shuffled -- the multiply/divide+shift problem is lethal enough that if not worked around it makes the kernel crash in time_init() because of a division by zero; the daddiu erratum might also trigger early potentially, though I have not observed it. On the other hand the daddi detection code requires the exception subsystem to have been initialised (and is there mainly for information). 4. r4k_daddiu_bug() added so that the existence of the erratum can be queried by code at the run time as necessary; useful for generated code like TLB fault and copy/clear page handlers. 5. __udelay() updated as it uses multiplication in inline assembly. Note that -mdaddi requires modified toolchain (which has been maintained by myself and available from my site for ~4years now -- versions covered are GCC 2.95.4 - 4.1.2 and binutils from 2.13 onwards). The -mfix-r4000 and -mfix-r4400 have been standard for a while though. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-15[MIPS] Makefile: Fix canonical system namesMaciej W. Rozycki
The GNU `config.guess' uses "linux-gnu" as the canonical system name. Fix the list of compiler prefixes checked to spell it correctly. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-22[MIPS] Kbuild: Use the new cc-cross-prefix feature.Ralf Baechle
2007-10-17lk201: remove obsolete driverMaciej W. Rozycki
Remove the old-fashioned lk201 driver under drivers/tc/ that used to be used by the old dz.c and zs.c drivers, which is now orphan code referred to from nowhere and does not build anymore. A modern replacement is available as drivers/input/keyboard/lkkbd.c. There are no plans to do anything about this piece of code and it does not fit anywhere anymore, so it is not just a matter of maintenance or the lack of. There are still some bits that might be added to the new lkkbd.c driver based on the old code, and the embedded hardware documentation which is otherwise quite hard to get hold of might be useful to keep too. Both of these can be done separately though. RIP. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-11[MIPS] Don't abort the build process if '-msym32' isn't supportedFranck Bui-Huu
-msym32 and previously the strategy to tell the compiler to generate 64-bit code but the assembler to put it into 32-bit ELF was initially a hack to get around the lack of proper 64-bit binutils support and later turned into a neat optimization with significant code size savings. But it's really just an optimization so there is nothing wrong with just dropping the option (and whatever else goes along with it, I forgot all the nasty details) on the floor if due to a vintage compiler it can't be suported. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Move ARC code into arch/mips/fw/arcAurelien Jarno
Move the ARC code to arch/mips/fw/arc from arch/mips/arc. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
