path: root/arch/mips/alchemy
2011-05-19Merge branch 'timers-clocksource-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: convert mips to generic i8253 clocksource clocksource: convert x86 to generic i8253 clocksource clocksource: convert footbridge to generic i8253 clocksource clocksource: add common i8253 PIT clocksource blackfin: convert to clocksource_register_hz mips: convert to clocksource_register_hz/khz sparc: convert to clocksource_register_hz/khz alpha: convert to clocksource_register_hz microblaze: convert to clocksource_register_hz/khz ia64: convert to clocksource_register_hz/khz x86: Convert remaining x86 clocksources to clocksource_register_hz/khz Make clocksource name const
2011-05-19MIPS: Alchemy: Clean up GPIO registers and accessorsManuel Lauss
remove au_readl/au_writel, remove the predefined GPIO1/2 KSEG1 register addresses and fix the fallout in all boards and drivers. This also fixes a bug in the mtx-1_wdt driver which was introduced by commit 6ea8115bb6f359df4f45152f2b40e1d4d1891392 ("Convert mtx1 wdt to be a platform device and use generic GPIO API") before this patch mtx-1_wdt only modified GPIO215, the patch then used the gpio resource information as bit index into the GPIO2 register but the conversion to the GPIO API didn't realize that. With this patch the drivers original behaviour is restored and GPIO15 is left alone. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Florian Fainelli <florian@openwrt.org> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: linux-watchdog@vger.kernel.org Cc: Wim Van Sebroeck <wim@iguana.be> Patchwork: https://patchwork.linux-mips.org/patch/2381/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2011-05-19MIPS: Alchemy: Cleanup DMA addressesManuel Lauss
According to the databooks, the Au1000 DMA engine must be programmed with the physical FIFO addresses. This patch does that; furthermore this opened the possibility to get rid of a lot of now unnecessary address defines. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2348/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2011-05-19MIPS: Alchemy: Rewrite ethernet platform setupManuel Lauss
Rewrite ethernet setup to use runtime cpu detection, and also clean up the ethernet base address mess as far as possible. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2353/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2011-05-19MIPS: Alchemy: Rewrite UART setup and constants.Manuel Lauss
Detect CPU type at runtime and setup uarts accordingly; also clean up the uart base address mess in the process as far as possible. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2352/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org
2011-05-19MIPS: Alchemy: Convert dbdma.c to syscore_opsManuel Lauss
Convert the PM sysdev to syscore_ops and clean up the ddma addresses a bit. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2351/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Alchemy: Convert irq.c to syscore_ops.Manuel Lauss
Convert the PM sysdev to use syscore_ops instead. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2350/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Alchemy: irq code and constant cleanupManuel Lauss
replace au_readl/au_writel with __raw_readl/__raw_writel, and clean up IC-related stuff from the headers. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2354/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: DB1200: Set Config[OD] for improved stability.Manuel Lauss
Setting Config[OD] gets rid of a _LOT_ of spurious CPLD interrupts, but also decreases overall performance a bit. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Florian Fainelli <florian@openwrt.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Patchwork: https://patchwork.linux-mips.org/patch/2347/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-14Merge branch 'consolidate-clksrc-i8253' of ↵Thomas Gleixner
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource Conflicts: arch/ia64/kernel/cyclone.c arch/mips/kernel/i8253.c arch/x86/kernel/i8253.c Reason: Resolve conflicts so further cleanups do not conflict further Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-10MIPS: Alchemy: fix xxs1500 build errorManuel Lauss
This fixes: alchemy/xxs1500/init.c: In function 'prom_init': alchemy/xxs1500/init.c:57:17: error: ignoring return value of 'kstrtoul', declared with attribute warn_unused_result Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2340/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Alchemy: Fix GCC 4.6.0 build error.Ralf Baechle
CC arch/mips/alchemy/devboards/db1x00/board_setup.o arch/mips/alchemy/devboards/db1x00/board_setup.c: In function 'board_setup': arch/mips/alchemy/devboards/db1x00/board_setup.c:130:6: error: variable 'pin_func' set but not used [-Werror=unused-but-set-variable] Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-29MIPS: Convert the irq functions to the new namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29MIPS: alchemy: Use proper irq accessorsThomas Gleixner
This really starts to be a sysiphean task. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25MIPS: Alchemy: Convert to new irq chip functionsThomas Gleixner
Fix the deadlock in set_type() while at it: The code called set_irq_chip_and_handler_name() resp. set_irq_chip() from the set_type() callback. That only works on UP and lock debugging disabled. Otherwise it would dead lock on desc->lock. __irq_set_chip_handler_name_locked() avoids that. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2173/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Alchemy: Fix reset for MTX-1 and XXS1500Florian Fainelli
Since commit 32fd6901 (MIPS: Alchemy: get rid of common/reset.c) Alchemy-based boards use their own reset function. For MTX-1 and XXS1500, the reset function pokes at the BCSR.SYSTEM_RESET register, but this does not work. According to Bruno Randolf, this was not tested when written. Previously, the generic au1000_restart() routine called the board specific reset function, which for MTX-1 and XXS1500 did not work, but finally made a jump to the reset vector, which really triggers a system restart. Fix reboot for both targets by jumping to the reset vector. Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2093/ Acked-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: MTX-1: Make au1000_eth probe all PHY addressesFlorian Fainelli
When au1000_eth probes the MII bus for PHY address, if we do not set au1000_eth platform data's phy_search_highest_address, the MII probing logic will exit early and will assume a valid PHY is found at address 0. For MTX-1, the PHY is at address 31, and without this patch, the link detection/speed/duplex would not work correctly. CC: stable@kernel.org Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2111/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-02-21mips: convert to clocksource_register_hz/khzJohn Stultz
This converts the mips clocksources to use clocksource_register_hz/khz CC: Ralf Baechle <ralf@linux-mips.org> CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-16MIPS: Alchemy: fix build with SERIAL_8250=nManuel Lauss
In commit 7d172bfe ("Alchemy: Add UART PM methods") I introduced platform PM methods which call a function of the 8250 driver; this patch works around link failures when the kernel is built without 8250 support. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1737/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-12-16MIPS: Alchemy: Add return value check for strict_strtoul()Yoichi Yuasa
arch/mips/alchemy/devboards/prom.c: In function 'prom_init': arch/mips/alchemy/devboards/prom.c:60: error: ignoring return value of 'strict_strtoul', declared with attribute warn_unused_result Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1761/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-11-16suspend: constify platform_suspend_opsLionel Debroux
While at it, fix two checkpatch errors. Several non-const struct instances constified by this patch were added after the introduction of platform_suspend_ops in checkpatch.pl's list of "should be const" structs (79404849e90a41ea2109bd0e2f7c7164b0c4ce73). Patch against mainline. Inspired by hunks of the grsecurity patch, updated for newer kernels. Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-25Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: arch/powerpc/platforms/85xx/p1022_ds.c
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (49 commits) serial8250: ratelimit "too much work" error serial: bfin_sport_uart: speed up sport RX sample rate to be 3% faster serial: abstraction for 8250 legacy ports serial/imx: check that the buffer is non-empty before sending it out serial: mfd: add more baud rates support jsm: Remove the uart port on errors Alchemy: Add UART PM methods. 8250: allow platforms to override PM hook. altera_uart: Don't use plain integer as NULL pointer altera_uart: Fix missing prototype for registering an early console altera_uart: Fixup type usage of port flags altera_uart: Make it possible to use Altera UART and 8250 ports together altera_uart: Add support for different address strides altera_uart: Add support for getting mapbase and IRQ from resources altera_uart: Add support for polling mode (IRQ-less) serial: Factor out uart_poll_timeout() from 8250 driver serial: mark the 8250 driver as maintained serial: 8250: Don't delay after transmitter is ready. tty: MAINTAINERS: add drivers/serial/jsm/ as maintained driver vcs: invoke the vt update callback when /dev/vcs* is written to ...
2010-10-22Alchemy: Add UART PM methods.Manuel Lauss
Custom UART PM hook for Alchemy chips: do standard UART pm and additionally en/disable uart block clocks as needed. This allows to get rid of a debug port PM hack in the Alchemy pm code. Tested on Db1200. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-07MIPS: Add missing #inclusions of <linux/irq.h>David Howells
Add missing #inclusions of <linux/irq.h> to a whole bunch of files that should really include it. Note that this can replace #inclusions of <asm/irq.h>. This is required for the patch to sort out irqflags handling function naming to compile on MIPS. The problem is that these files require access to things like setup_irq() - which isn't available by #including <linux/interrupt.h> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-04MIPS: Alchemy: Resolve prom section mismatchesManuel Lauss
The function prom_init_cmdline() references the variable __initdata arcs_cmdline. The function prom_get_ethernet_addr() references the variable __initdata arcs_cmdline. Annotate prom_init_cmdline() as __init, unexport and annotate prom_get_ethernet_addr() since it's no longer called from within driver code. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1547/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-31ASoC: fix au1x platformManuel Lauss
This patch fixes up the au1x audio platform after the multi-component merge: - compile fixes and updates to get DB1200 platform audio working again, - removal of global variables in AC97/I2S/DMA(PCM) modules. The AC97 part is limited to one instance only for now due to issues with getting at driver data in the soc_ac97_ops. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-05MIPS: Ritually kill stupid printk.Ralf Baechle
This belongs into userland. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Alchemy: Add basic support for the GPR boardWolfgang Grandegger
From: Wolfgang Grandegger <wg@denx.de> Add basic support for the General Purpose Router (GPR) board from Trapeze ITS. Signed-off-by: Wolfgang Grandegger <wg@denx.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1460/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: au1000_eth: Get ethernet address from platform_dataManuel Lauss
au1000_eth uses firmware calls to get a valid MAC address, and changes it depending on platform device id. This patch moves this logic out of the driver into the platform device registration part, where boards with supported chips can use whatever firmware interface they need; the default implementation maintains compatibility with existing, YAMON-based firmware. Tested-by: Wolfgang Grandegger <wg@denx.de> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: netdev@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1481/ Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05SERIAL: 8250: Remove SERIAL_8250_AU1X00Manuel Lauss
Remove the SERIAL_8250_AU1X00 config symbol. Instead, use the MIPS_ALCHEMY one which is always defined when building an Au1x00-based platform. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Linux-serial <linux-serial@vger.kernel.org> Patchwork: https://patchwork.linux-mips.org/patch/1461/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> This one depends on a previous patch (which removes SOC_AU1X00 and changes MACH_ALCHEMY) to apply cleanly (and then actually work), so I'd love for this to go in via the mips tree.
2010-08-05MIPS: Alchemy: remove SOC_AU1X00 in favor of MIPS_ALCHEMYManuel Lauss
Remove the CONFIG_SOC_AU1X00 Kconfig symbol since its job can also be done by MACH_ALCHEMY, now renamed to MIPS_ALCHEMY. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1461/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: MTX-1: cleanup and commentsBruno Randolf
Add some comments about mtx1_pci_idsel() and remove a dead block of old code. Signed-off-by: Bruno Randolf <br1@einfach.org> To: linux-mips@linux-mips.org To: manuel.lauss@googlemail.com Cc: florian@openwrt.org Patchwork: https://patchwork.linux-mips.org/patch/1449/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Alchemy: Remove dead CONFIG_SOC_AU1000_FREQUENCYChristoph Egger
CONFIG_SOC_AU1000_FREQUENCY doesn't exist in Kconfig, therefore removing all references for it from the source code. Signed-off-by: Christoph Egger <siccegge@cs.fau.de> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org Cc: vamos@i4.informatik.uni-erlangen.de Patchwork: https://patchwork.linux-mips.org/patch/1367/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Move Alchemy Makefile parts to their own Platform file.Manuel Lauss
[Ralf: Remove a forgotten -Werror in Pb1200 Makefile.] Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Patchwork: https://patchwork.linux-mips.org/patch/1319/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Alchemy: fix deprecated compile warningsFUJITA Tomonori
Replace deprecated DMA_32BIT_MASK with DMA_BIT_MASK. This is needed because the new style platform makefiles will enable -Werror. cc1: warnings being treated as errors arch/mips/alchemy/devboards/db1200/platform.c:219: error: 'DMA_nnBIT_MASK' is deprecated arch/mips/alchemy/devboards/db1200/platform.c:226: error: 'DMA_nnBIT_MASK' is deprecated arch/mips/alchemy/devboards/db1200/platform.c:388: error: 'DMA_nnBIT_MASK' is deprecated arch/mips/alchemy/devboards/db1200/platform.c:393: error: 'DMA_nnBIT_MASK' is deprecated Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> To: linux-mips@linux-mips.org Acked-by: Manuel Lauss <manuel.lauss@googlemail.com> Patchwork: https://patchwork.linux-mips.org/patch/1427/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Alchemy: move boards over to obj-yManuel Lauss
Preparatory step for moving Alchemy over to new MIPS Platform build system support. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1318/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: MTX1: Fix build.Ralf Baechle
CC arch/mips/alchemy/mtx-1/board_setup.o {standard input}: Assembler messages: {standard input}:263: Error: opcode not supported on this processor: mips1 (mips1) `sync' {standard input}:274: Error: opcode not supported on this processor: mips1 (mips1) `sync' {standard input}:296: Error: opcode not supported on this processor: mips1 (mips1) `sync' [...] Any .set mipsX statement other than .set mips0 at the end of inline assembler is a big fat bug. Introduced by 9482eabeca315c0276ffb50026b7482481b7097b (linux-mips.org) rsp. 32fd6901a6d8d19f94e4de6be4e4b552ab078620 (kernel.org). While at it, fix the same issue in arch/mips/alchemy/devboards/pb1000/board_setup.c arch/mips/alchemy/xxs1500/board_setup.c as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-07-26MIPS: Alchemy: Define eth platform devices in the correct orderWolfgang Grandegger
Currently, the eth devices are probed in the inverse order, first au1xxx_eth1_device and then au1xxx_eth0_device. On the GPR board, this makes trouble: # ifconfig|grep HWaddr eth0 Link encap:Ethernet HWaddr 00:50:C2:0C:30:01 eth1 Link encap:Ethernet HWaddr 66:22:01:80:38:10 A bogous ethernet hwaddr is assigned to the first device and au1xxx_eth0_device is mapped to eth1, which even does not work properly. With this patch, the problems are gone: # ifconfig|grep HWaddr eth0 Link encap:Ethernet HWaddr 66:22:11:32:38:10 eth1 Link encap:Ethernet HWaddr 66:22:11:32:38:11 Signed-off-by: Wolfgang Grandegger <wg@denx.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1473/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-07-26MIPS: MTX-1: Fix PCI on the MeshCube and related boardsBruno Randolf
This patch fixes a regression introduced by commit "MIPS: Alchemy: MTX-1: Use linux gpio api." (bb706b28bbd647c2fd7f22d6bf03a18b9552be05) which broke PCI bus operation. The problem is caused by alchemy_gpio2_enable() which resets the GPIO2 block. Two PCI signals (PCI_SERR and PCI_RST) are connected to GPIO2 and they obviously do not to like the reset. Since GPIO2 is correctly initialized by the boot monitor (YAMON) it is not necessary to call this function, so just remove it. Also replace gpio_set_value() with alchemy_gpio_set_value() to avoid problems in case gpiolib gets initialized after PCI. And since alchemy gpio_set_value() calls au_sync() we don't have to au_sync() again later. Signed-off-by: Bruno Randolf <br1@einfach.org> To: linux-mips@linux-mips.org To: manuel.lauss@googlemail.com Patchwork: https://patchwork.linux-mips.org/patch/1448/ Tested-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-07-05MIPS: Alchemy: sleepcode without compile-time cputype dependenciesManuel Lauss
Split the low-level sleepcode into per-cpu functions instead of relying on compile-time-defined cpu type. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1281/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-21MIPS: Alchemy: add sysdev for DBDMA PM.Manuel Lauss
Add a sysdev for DBDMA PM. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1119/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-21MIPS: Alchemy: add sysdev for IRQ PM.Manuel Lauss
Use a sysdev to implement PM methods for the Au1000 interrupt controllers. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1114/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-21MIPS: Alchemy: Fix up residual devboard poweroff/reboot code.Manuel Lauss
Clean out stray unused board_reset() calls in pb1x boards, the PB1000 is different from the rest and gets private methods. (Cleanup after 32fd6901a6d8d19f94e4de6be4e4b552ab078620) Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1085/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-30MIPS: DB1200: PCMCIA card detection must not be auto-enabled.Manuel Lauss
Same issues as SD card detection: One of both is always triggering and the handlers take care to shut it up and enable the other. To avoid messages about "unbalanced interrupt enable/disable" they must not be automatically enabled when initally requested. This was not an issue with the db1200_defconfig due to fortunate timings; on a build without network chip support the warnings appear. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1133/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-12MIPS: Alchemy: DB1200: Remove custom wait implementationManuel Lauss
While playing with the out-of-tree MAE driver module, the system would panic after a while in the db1200 custom wait code after wakeup due to a clobbered k0 register being used as target address of a store op. Remove the custom wait implementation and revert back to the Alchemy- recommended implementation already set as default. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1092/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
