The DDR controller need to be used by the IRQ controller to flush
the write buffer of some devices before running the IRQ handler.
It is also used by the PCI controller to setup the PCI memory windows.
The current interface used to access the DDR controller doesn't
provides any useful abstraction and simply rely on a shared global
pointer.
Replace this by a simple API to setup the PCI memory windows and use
the write buffer flush independently of the SoC type. That remove the
need for the shared global pointer, simplify the IRQ handler code.
[ralf@linux-mips.org: Folded in Alban Bedel's follup fix.]
Signed-off-by: Alban Bedel <albeu@free.fr>
Cc: linux-mips@linux-mips.org
Cc: Andrew Bresticker <abrestic@chromium.org>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: Sergey Ryazanov <ryazanov.s.a@gmail.com>
Cc: Gabor Juhos <juhosg@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/9773/
Patchwork: http://patchwork.linux-mips.org/patch/10543/
The ath79_device_reset_* are causing BUG when
those are used on the QCA955x SoCs. The patch
adds the required code to avoid that.
Cc: Rodriguez, Luis <rodrigue@qca.qualcomm.com>
Cc: Giori, Kathy <kgiori@qca.qualcomm.com>
Cc: QCA Linux Team <qca-linux-team@qca.qualcomm.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/4948/
Signed-off-by: John Crispin <blogic@openwrt.org>
Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
Cc: mcgrof@infradead.org
Patchwork: https://patchwork.linux-mips.org/patch/3511/
Knowing the exact revision of the SoC is required to make runtime decisions
in various code paths. We have determined the SoC revision already, so we
only need to store that in a global variable.
Cc: Imre Kaloz <kaloz@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/3027/
Cc: Kathy Giori <kgiori@qca.qualcomm.com>
Cc: "Luis R. Rodriguez" <rodrigue@qca.qualcomm.com>
Patchwork: https://patchwork.linux-mips.org/patch/2523/
This patch adds initial support for various Atheros SoCs based on the
MIPS 24Kc core. The following models are supported at the moment:
- AR7130
- AR7141
- AR7161
- AR9130
- AR9132
- AR7240
- AR7241
- AR7242
The current patch contains minimal support only, but the resulting
kernel can boot into user-space with using of an initramfs image on
various boards which are using these SoCs. Support for more built-in
devices and individual boards will be implemented in further patches.
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
Cc: Luis R. Rodriguez <lrodriguez@atheros.com>
Cc: Cliff Holden <Cliff.Holden@Atheros.com>
Cc: Kathy Giori <Kathy.Giori@Atheros.com>
Patchwork: https://patchwork.linux-mips.org/patch/1947/
