It's more than the au1000 these days.
au1xmmc.c driver depends on it, so export it for modules.
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
Fix many errors and warnings given by checkpatch.pl:
- use of C99 // comments;
- missing space between the type and asterisk in a variable declaration;
- space between the asterisk and function/variable name;
- leading spaces instead of tabs;
- space after opening and before closing parentheses;
- initialization of a 'static' variable to 0;
- missing spaces around assignement/comparison operator;
- brace not on the same line with condition (or 'else') in the 'if'/'switch'
statement;
- missing space between 'if'/'for'/'while' and opening parenthesis;
- use of assignement in 'if' statement's condition;
- printk() without KERN_* facility level;
- EXPORT_SYMBOL() not following its function immediately;
- unnecessary braces for single-statement block;
- adding new 'typedef' (where including <linux/types.h> will do);
- use of 'extern' in the .c file (where it can be avoided by including header);
- line over 80 characters.
In addition to these changes, also do the following:
- insert missing space after opening brace and/or before closing brace in the
structure initializers;
- insert spaces between operator and its operands;
- put the function's result type and name/parameters on the same line;
- properly indent multi-line expressions;
- remove commented out code;
- remove useless initializers and code;
- remove needless parentheses;
- fix broken/excess indentation;
- add missing spaces between operator and its operands;
- insert missing and remove excess new lines;
- group 'else' and 'if' together where possible;
- make au1xxx_platform_init() 'static';
- regroup variable declarations in pm_do_freq() for prettier look;
- replace numeric literals with the matching macros;
- fix printk() format specifiers mismatching the argument types;
- make the multi-line comment style consistent with the kernel style elsewhere
by adding empty first line and/or adding space on their left side;
- make two-line comments that only have one line of text one-line;
- fix typos/errors, capitalize acronyms, etc. in the comments;
- fix/remove obsolete references in the comments;
- reformat some comments;
- add comment about the CPU:counter clock ratio to calc_clock();
- update MontaVista copyright;
- remove Pete Popov's and Steve Longerbeam's old email addresses...
infrastructure for it.
Let it rip!
