Fix many errors and warnings given by checkpatch.pl:
- use of C99 // comments;
- missing space between the type and asterisk in a variable declaration;
- space between the asterisk and function/variable name;
- leading spaces instead of tabs;
- space after opening and before closing parentheses;
- initialization of a 'static' variable to 0;
- missing spaces around assignement/comparison operator;
- brace not on the same line with condition (or 'else') in the 'if'/'switch'
statement;
- missing space between 'if'/'for'/'while' and opening parenthesis;
- use of assignement in 'if' statement's condition;
- printk() without KERN_* facility level;
- EXPORT_SYMBOL() not following its function immediately;
- unnecessary braces for single-statement block;
- adding new 'typedef' (where including <linux/types.h> will do);
- use of 'extern' in the .c file (where it can be avoided by including header);
- line over 80 characters.
In addition to these changes, also do the following:
- insert missing space after opening brace and/or before closing brace in the
structure initializers;
- insert spaces between operator and its operands;
- put the function's result type and name/parameters on the same line;
- properly indent multi-line expressions;
- remove commented out code;
- remove useless initializers and code;
- remove needless parentheses;
- fix broken/excess indentation;
- add missing spaces between operator and its operands;
- insert missing and remove excess new lines;
- group 'else' and 'if' together where possible;
- make au1xxx_platform_init() 'static';
- regroup variable declarations in pm_do_freq() for prettier look;
- replace numeric literals with the matching macros;
- fix printk() format specifiers mismatching the argument types;
- make the multi-line comment style consistent with the kernel style elsewhere
by adding empty first line and/or adding space on their left side;
- make two-line comments that only have one line of text one-line;
- fix typos/errors, capitalize acronyms, etc. in the comments;
- fix/remove obsolete references in the comments;
- reformat some comments;
- add comment about the CPU:counter clock ratio to calc_clock();
- update MontaVista copyright;
- remove Pete Popov's and Steve Longerbeam's old email addresses...
Go thru the Alchemy code and hunt down every unneeded #include, #define, and
extern (some of which refer to already long dead functions).
Work around the CPU clock miscalculation on Au1000DA/HA/HB due the
sys_cpupll register being write-only, i.e. actually do what the comment
before cal_r4off() function advertised for years but the code failed at.
This is achieved by just giving user a chance to define the clock
explicitly in the board config. via CONFIG_SOC_AU1000_FREQUENCY option,
defaulting to 396 MHz if the option is not given...
The patch is based on the AMD's big unpublished patch, the issue seems to
be an undocumented errata (or feature :-)...
the PCI specific code in this function doesn't check for the address range
being under the upper bound of the PCI memory window correctly -- fix this,
somewhat beautifying the code around the check, while at it...
Add new prom.h for AU1x00.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Hard to follow who is pointing what to where and why so it's simply getting
in the way of the time code renovation.
Noticed by Robert P. J. Day (rpjday@mindspring.com).
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Historically plat_mem_setup did the entire platform initialization. This
was rather impractical because it meant plat_mem_setup had to get away
without any kind of memory allocator. To keep old code from breaking
plat_setup was just renamed to plat_setup and a second platform
initialization hook for anything else was introduced.
As announced in feature-removal-schedule.txt.
This is needed to make console output appear with the new driver...
Delete leftovers of the FB_E1356 and anything that did depend on it.
Signed-off-by: Antonino Daplas <adaplas@pol.net>
- fixed an iounmap warning
- export fixup_xx, needed by the module
Acked-by: Antonino Daplas <adaplas@pol.net>
initialization actually useful and as is certainly unmergable with
upstream.
infrastructure for it.
Let it rip!
