path: root/arch/mips/au1000/common/time.c
2008-05-12[MIPS] Alchemy common code style cleanupSergei Shtylyov
Fix many errors and warnings given by checkpatch.pl: - use of C99 // comments; - missing space between the type and asterisk in a variable declaration; - space between the asterisk and function/variable name; - leading spaces instead of tabs; - space after opening and before closing parentheses; - initialization of a 'static' variable to 0; - missing spaces around assignement/comparison operator; - brace not on the same line with condition (or 'else') in the 'if'/'switch' statement; - missing space between 'if'/'for'/'while' and opening parenthesis; - use of assignement in 'if' statement's condition; - printk() without KERN_* facility level; - EXPORT_SYMBOL() not following its function immediately; - unnecessary braces for single-statement block; - adding new 'typedef' (where including <linux/types.h> will do); - use of 'extern' in the .c file (where it can be avoided by including header); - line over 80 characters. In addition to these changes, also do the following: - insert missing space after opening brace and/or before closing brace in the structure initializers; - insert spaces between operator and its operands; - put the function's result type and name/parameters on the same line; - properly indent multi-line expressions; - remove commented out code; - remove useless initializers and code; - remove needless parentheses; - fix broken/excess indentation; - add missing spaces between operator and its operands; - insert missing and remove excess new lines; - group 'else' and 'if' together where possible; - make au1xxx_platform_init() 'static'; - regroup variable declarations in pm_do_freq() for prettier look; - replace numeric literals with the matching macros; - fix printk() format specifiers mismatching the argument types; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space on their left side; - make two-line comments that only have one line of text one-line; - fix typos/errors, capitalize acronyms, etc. in the comments; - fix/remove obsolete references in the comments; - reformat some comments; - add comment about the CPU:counter clock ratio to calc_clock(); - update MontaVista copyright; - remove Pete Popov's and Steve Longerbeam's old email addresses... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless time variablesSergei Shtylyov
Since the commit 91a2fcc88634663e9e13dcdfad0e4a860e64aeee ([MIPS] Consolidate all variants of MIPS cp0 timer interrupt handlers) removed the Alchemy specific timer handler, 'r4k_offset' and 'r4k_cur' variables became practically useless, so get rid of them at last, renaming cal_r4off() function into calc_clock() and making it return CPU frequency. Also, make 'no_au1xxx_32khz' variable static... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: don't unmask timer IRQ earlySergei Shtylyov
Defer the unmasking of the count/compare interrupt (IRQ5) till the clockevent driver initialization: - only enable the cascaded IRQs 0 thru 4 in arch_init_irq(); kill the ALLINTS macro -- this change is blessed by AMD as I saw it in their own patch; :-) - do not force IRQ5 enabled in plat_time_init() if PM is enabled and there's no 32 KHz crystal. Update the copyrights (taking into account my prior changes), also removing Pete Popov's old email... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-01[MIPS] Alchemy: work around clock misdetection on early Au1000Sergei Shtylyov
Work around the CPU clock miscalculation on Au1000DA/HA/HB due the sys_cpupll register being write-only, i.e. actually do what the comment before cal_r4off() function advertised for years but the code failed at. This is achieved by just giving user a chance to define the clock explicitly in the board config. via CONFIG_SOC_AU1000_FREQUENCY option, defaulting to 396 MHz if the option is not given... The patch is based on the AMD's big unpublished patch, the issue seems to be an undocumented errata (or feature :-)... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Alchemy: Convert from plat_timer_setup to plat_time_init.Ralf Baechle
The old plat_timer_setup hook is no longer getting called so the Alchemy time initialization was getting skipped. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Alchemy: micro-optimizatize time code.Ralf Baechle
2007-10-29[MIPS] Alchemy: Nuke homebrew setup_irq(), it's broken and unnecessary.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] Consolidate all variants of MIPS cp0 timer interrupt handlers.Ralf Baechle
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-13[MIPS] Alchemy: Remove code wrapped by dead symbol CONFIG_AU1000_SRC_CLKRalf Baechle
Noticed by Robert P. J. Day (rpjday@mindspring.com). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-13[MIPS] Alchemy: Remove code wrapped by dead symbol CONFIG_AU1000_USE32KRalf Baechle
2006-10-31[MIPS] Fixup migration to GENERIC_TIMEAtsushi Nemoto
Since we already moved to GENERIC_TIME, we should implement alternatives of old do_gettimeoffset routines to get sub-jiffies resolution from gettimeofday(). This patch includes: * MIPS clocksource support (based on works by Manish Lachwani). * remove unused gettimeoffset routines and related codes. * remove unised 64bit do_div64_32(). * simplify mips_hpt_init. (no argument needed, __init tag) * simplify c0_hpt_timer_init. (no need to write to c0_count) * remove some hpt_init routines. * mips_hpt_mask variable to specify bitmask of hpt value. * convert jmr3927_do_gettimeoffset to jmr3927_hpt_read. * convert ip27_do_gettimeoffset to ip27_hpt_read. * convert bcm1480_do_gettimeoffset to bcm1480_hpt_read. * simplify sb1250 hpt functions. (no need to subtract and shift) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] Au1000: Fix warning about unused variable.Yoichi Yuasa
arch/mips/au1000/common/time.c: In function `mips_timer_interrupt': arch/mips/au1000/common/time.c:82: warning: unused variable `count' Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-30[MIPS] Au1xx0 code sets incorrect mips_hpt_frequencySergei Shtylyov
Alchemy CPU counter ticks at the full CPU clock speed. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-09-29[PATCH] simplify update_times (avoid jiffies/jiffies_64 aliasing problem)Atsushi Nemoto
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390 timer interrupt handler with this change. Currently update_times() calculates ticks by "jiffies - wall_jiffies", but callers of do_timer() should know how many ticks to update. Passing ticks get rid of this redundant calculation. Also there are another redundancy pointed out by Martin Schwidefsky. This cleanup make a barrier added by 5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes it. As a bonus, this cleanup make wall_jiffies can be removed easily, since now wall_jiffies is always synced with jiffies. (This patch does not really remove wall_jiffies. It would be another cleanup patch) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-06-19[MIPS] arch/mips/au1000/time.c cleanupSergei Shtylyov
Mark au1xxx_timer_setup() __init, just because it is. Get rid of unneeded extern's (note that (*do_gettimeoffset)() is already declared by <asm/time.c>) and an unused variable. Kill some whitespace... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] AU1xxx mips_timer_interrupt() fixesHerbert Valerio Riedel
common/au1000/irq.c was missing a mips_timer_interrupt() prototype, whereas in common/au1000/time.c the actual mips_timer_interrupt() implementation was missing an irq_exit() invocation, causing a preempt_count() leak. Signed-off-by: Herbert Valerio Riedel <hvr@hvrlab.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-21[MIPS] War on whitespace: cleanup initial spaces followed by tabs.Ralf Baechle
2005-10-29Au1x PM fixes.Pete Popov
2005-10-29Fixed buglet with previous patch that broke non au1x builds.Pete Popov
2005-10-29Remove CONFIG_PM dependency from au1x wait in cpu_probe.Pete Popov
Additional work necessary to completely remove that config option. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29When CONFIG_PM is enabled, it uses the TOY_MATCH2 interrupt as the systemPete Popov
timer tick. Prior to this patch, if IDE IRQ probing occured, then the TOY_MATCH2 interrupt would be permanently disabled, and no system timer tick occurs. This patch corrects this situation by correctly registering the TOY_MATCH2 interrupt so that IDE IRQ probing doesn't have adverse side effects. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
