It was plain a bad idea ...
Add new prom.h for AU1x00.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Update AU1000 get_ethernet_addr().
Three functions were brought together in one.
Hard to follow who is pointing what to where and why so it's simply getting
in the way of the time code renovation.
The PCI controller IO base was not set in the au1000 pci code.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: John Crispin <blogic@openwrt.org>
Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu>
Noticed by Robert P. J. Day (rpjday@mindspring.com).
MODPOST vmlinux
WARNING: arch/mips/au1000/common/built-in.o(.text+0x1750): Section mismatch: reference to .init.data: (between 'au1xxx_platform_init' and '__fixup_bigphys_addr')
WARNING: arch/mips/au1000/common/built-in.o(.text+0x1754): Section mismatch: reference to .init.data: (between 'au1xxx_platform_init' and '__fixup_bigphys_addr')
This patch adds support for the generic GPIO API to Au1x00 boards. It requires
the generic GPIO patch for MIPS boards by Yoichi Yuasa. Now there is a MIPS
target using it, can you queue these patchset for 2.6.22 ? Thank you very
much in advance.
The semantic effect of insert_at_head is that it would allow new registered
sysctl entries to override existing sysctl entries of the same name. Which is
pain for caching and the proc interface never implemented.
I have done an audit and discovered that none of the current users of
register_sysctl care as (excpet for directories) they do not register
duplicate sysctl entries.
So this patch simply removes the support for overriding existing entries in
the sys_sysctl interface since no one uses it or cares and it makes future
enhancments harder.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Corey Minyard <minyard@acm.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: David Chinner <dgc@sgi.com>
Cc: Patrick McHardy <kaber@trash.net>
The assignment of binary numbers for sys_sysctl use was in shambles and
despite requiring methods. Nothing was implemented on the sys_sysctl side.
So this patch gives a mercy killing to the sys_sysctl support for
powermanagment on mips/au1000.
CC arch/mips/au1000/common/pci.o
arch/mips/au1000/common/pci.c:42: warning: large integer implicitly truncated to unsigned type
arch/mips/au1000/common/pci.c:43: warning: large integer implicitly truncated to unsigned type
arch/mips/au1000/common/pci.c:49: warning: large integer implicitly truncated to unsigned type
arch/mips/au1000/common/pci.c:50: warning: large integer implicitly truncated to unsigned type
arch/mips/au1000/common/pci.c: In function ‘au1x_pci_setup’:
arch/mips/au1000/common/pci.c:82: warning: ISO C90 forbids mixed declarations and code
The "typename" field was obsoleted by the "name" field.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Current prom_free_prom_memory() implementations are almost same as
free_init_pages(), or no-op. Make free_init_pages() extern (again)
and make prom_free_prom_memory() use it.
The problem was introduced in 2.6.18.3 with the casting of some
36bit-defines (PCI memory) in au1000.h to resource_size_t which may be
u32 or u64 depending on the experimental CONFIG_RESOURCES_64BIT.
With unset CONFIG_RESOURCES_64BIT, the pci-memory cannot be accessed
because the ioremap in arch/mips/au1000/common/pci.c already used the
truncated addresses.
With set CONFIG_RESOURCES_64BIT, things get even worse, because PCI-scan
aborts, due to resource conflict: request_resource() in arch/mips/pci/pci.c
fails because the maximum iomem-address is 0xffffffff (32bit) but the
pci-memory-start-address is 0x440000000 (36bit).
To get pci working again, I propose the following patch:
1. remove the resource_size_t-casting from au1000.h again
2. make the casting in arch/mips/au1000/common/pci.c (it's allowed and
necessary here. The 36bit-handling will be done in __fixup_bigphys_addr).
With this patch pci works again like in 2.6.18.2, the gcc-compile warnings
in pci.c are gone and it doesn't depend on CONFIG_EXPERIMENTAL.
Signed-off-by: Alexander Bigga <ab@mycable.de>
This is a big irq cleanup patch.
* Use set_irq_chip() to register irq_chip.
* Initialize .mask, .unmask, .mask_ack field. Functions for these
method are already exist in most case.
* Do not initialize .startup, .shutdown, .enable, .disable fields if
default routines provided by irq_chip_set_defaults() were suitable.
* Remove redundant irq_desc initializations.
* Remove unnecessary local_irq_save/local_irq_restore, spin_lock.
With this cleanup, it would be easy to switch to slightly lightwait
irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ().
Though whole this patch is quite large, changes in each irq_chip are
not quite simple. Please review and test on your platform. Thanks.
Since we already moved to GENERIC_TIME, we should implement alternatives
of old do_gettimeoffset routines to get sub-jiffies resolution from
gettimeofday(). This patch includes:
* MIPS clocksource support (based on works by Manish Lachwani).
* remove unused gettimeoffset routines and related codes.
* remove unised 64bit do_div64_32().
* simplify mips_hpt_init. (no argument needed, __init tag)
* simplify c0_hpt_timer_init. (no need to write to c0_count)
* remove some hpt_init routines.
* mips_hpt_mask variable to specify bitmask of hpt value.
* convert jmr3927_do_gettimeoffset to jmr3927_hpt_read.
* convert ip27_do_gettimeoffset to ip27_hpt_read.
* convert bcm1480_do_gettimeoffset to bcm1480_hpt_read.
* simplify sb1250 hpt functions. (no need to subtract and shift)
arch/mips/au1000/common/time.c: In function `mips_timer_interrupt':
arch/mips/au1000/common/time.c:82: warning: unused variable `count'
Alchemy CPU counter ticks at the full CPU clock speed.
Use the new typedef for interrupt handler function pointers rather than
actually spelling out the full thing each time. This was scripted with the
following small shell script:
#!/bin/sh
egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* |
while read i
do
echo $i
perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $?
done
Signed-Off-By: David Howells <dhowells@redhat.com>
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390
timer interrupt handler with this change.
Currently update_times() calculates ticks by "jiffies - wall_jiffies", but
callers of do_timer() should know how many ticks to update. Passing ticks
get rid of this redundant calculation. Also there are another redundancy
pointed out by Martin Schwidefsky.
This cleanup make a barrier added by
5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes
it.
As a bonus, this cleanup make wall_jiffies can be removed easily, since now
wall_jiffies is always synced with jiffies. (This patch does not really
remove wall_jiffies. It would be another cleanup patch)
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata.hirokazu@renesas.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Richard Curnow <rc@rc0.org.uk>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Cc: Chris Zankel <chris@zankel.net>
Acked-by: "Luck, Tony" <tony.luck@intel.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
The third argument of au1xxx_dbdma_chan_alloc's callback function is not
used anywhere.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Domen Puncer <domen.puncer@ultra.si>
> #define hw_interrupt_type irq_chip
> typedef struct irq_chip hw_irq_controller;
> #define no_irq_type no_irq_chip
> typedef struct irq_desc irq_desc_t;
Use the new IRQF_ constants and remove the SA_INTERRUPT define
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (33 commits)
[MIPS] Add missing backslashes to macro definitions.
[MIPS] Death list of board support to be removed after 2.6.18.
[MIPS] Remove BSD and Sys V compat data types.
[MIPS] ioc3.h: Uses u8, so include <linux/types.h>.
[MIPS] 74K: Assume it will also have an AR bit in config7
[MIPS] Treat CPUs with AR bit as physically indexed.
[MIPS] Oprofile: Support VSMP on 34K.
[MIPS] MIPS32/MIPS64 S-cache fix and cleanup
[MIPS] excite: PCI makefile needs to use += if it wants a chance to work.
[MIPS] excite: plat_setup -> plat_mem_setup.
[MIPS] au1xxx: export dbdma functions
[MIPS] au1xxx: dbdma, no sleeping under spin_lock
[MIPS] au1xxx: fix PSC_SMBTXRX_RSR.
[MIPS] Early printk for IP27.
[MIPS] Fix handling of 0 length I & D caches.
[MIPS] Typo fixes.
[MIPS] MIPS32/MIPS64 secondary cache management
[MIPS] Fix FIXADDR_TOP for TX39/TX49.
[MIPS] Remove first timer interrupt setup in wrppmc_timer_setup()
[MIPS] Fix configuration of R2 CPU features and multithreading.
These are needed for au1550_ac97 module.
kmalloc under spin_lock can't sleep.
This patch-queue improves the generic IRQ layer to be truly generic, by adding
various abstractions and features to it, without impacting existing
functionality.
While the queue can be best described as "fix and improve everything in the
generic IRQ layer that we could think of", and thus it consists of many
smaller features and lots of cleanups, the one feature that stands out most is
the new 'irq chip' abstraction.
The irq-chip abstraction is about describing and coding and IRQ controller
driver by mapping its raw hardware capabilities [and quirks, if needed] in a
straightforward way, without having to think about "IRQ flow"
(level/edge/etc.) type of details.
This stands in contrast with the current 'irq-type' model of genirq
architectures, which 'mixes' raw hardware capabilities with 'flow' details.
The patchset supports both types of irq controller designs at once, and
converts i386 and x86_64 to the new irq-chip design.
As a bonus side-effect of the irq-chip approach, chained interrupt controllers
(master/slave PIC constructs, etc.) are now supported by design as well.
The end result of this patchset intends to be simpler architecture-level code
and more consolidation between architectures.
We reused many bits of code and many concepts from Russell King's ARM IRQ
layer, the merging of which was one of the motivations for this patchset.
This patch:
rename desc->handler to desc->chip.
Originally i did not want to do this, because it's a big patch. But having
both "desc->handler", "desc->handle_irq" and "action->handler" caused a
large degree of confusion and made the code appear alot less clean than it
truly is.
I have also attempted a dual approach as well by introducing a
desc->chip alias - but that just wasnt robust enough and broke
frequently.
So lets get over with this quickly. The conversion was done automatically
via scripts and converts all the code in the kernel.
This renaming patch is the first one amongst the patches, so that the
remaining patches can stay flexible and can be merged and split up
without having some big monolithic patch act as a merge barrier.
[akpm@osdl.org: build fix]
[akpm@osdl.org: another build fix]
