path: root/arch/mips/au1000/common
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-27[MIPS] au1000: Make sure GPIO value is zero or oneBruno Randolf
David Brownell <david-b@pacbell.net> wrote: > The problem is that "value" is zero-or-nonzero. > This code wrongly assumes it's zero-or-one. > Possible fix: "((!!value) << gpio)". Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-24[MIPS] au1000: Fix gpio directionBruno Randolf
When setting the direction of one GPIO pin we have to keep the state of the other pins, hence use binary OR. Also gpio_direction_output() wants to set an initial value, so add that too. This fixes a problem with the USB power switch on mtx-1 boards. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-30[MIPS] kgdb: Remove existing implementationJason Wessel
This patch explicitly removes the kgdb implementation, for mips which is intended to be followed by a patch that adds a kgdb implementation for MIPS that makes use of the kgdb core in the kernel. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-24remove include/linux/pm_legacy.hAdrian Bunk
Remove the obsolete and no longer used include/linux/pm_legacy.h Reviewed-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Pavel Machek <pavel@suse.cz> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-15[MIPS] Alchemy, PNX: Use symbolic constants for DMA masks.Ralf Baechle
2008-06-16[MIPS] Au1200: MMC resource size off by oneSergei Shtylyov
Au12x0 MMC platform device strangely claims 0x41 bytes for its memory-mapped registers. Make it claim the whole 0x80000 instead according to the memory map given in the datasheets. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-05[MIPS] Alchemy: dbdma: add API to delete custom DDMA device ids.Manuel Lauss
Add API to delete custom DDMA device ids create with au1xxx_ddma_device_add(). Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-05[MIPS] Alchemy: export get_au1x00_speed for modulesManuel Lauss
au1xmmc.c driver depends on it, so export it for modules. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Alchemy common code style cleanupSergei Shtylyov
Fix many errors and warnings given by checkpatch.pl: - use of C99 // comments; - missing space between the type and asterisk in a variable declaration; - space between the asterisk and function/variable name; - leading spaces instead of tabs; - space after opening and before closing parentheses; - initialization of a 'static' variable to 0; - missing spaces around assignement/comparison operator; - brace not on the same line with condition (or 'else') in the 'if'/'switch' statement; - missing space between 'if'/'for'/'while' and opening parenthesis; - use of assignement in 'if' statement's condition; - printk() without KERN_* facility level; - EXPORT_SYMBOL() not following its function immediately; - unnecessary braces for single-statement block; - adding new 'typedef' (where including <linux/types.h> will do); - use of 'extern' in the .c file (where it can be avoided by including header); - line over 80 characters. In addition to these changes, also do the following: - insert missing space after opening brace and/or before closing brace in the structure initializers; - insert spaces between operator and its operands; - put the function's result type and name/parameters on the same line; - properly indent multi-line expressions; - remove commented out code; - remove useless initializers and code; - remove needless parentheses; - fix broken/excess indentation; - add missing spaces between operator and its operands; - insert missing and remove excess new lines; - group 'else' and 'if' together where possible; - make au1xxx_platform_init() 'static'; - regroup variable declarations in pm_do_freq() for prettier look; - replace numeric literals with the matching macros; - fix printk() format specifiers mismatching the argument types; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space on their left side; - make two-line comments that only have one line of text one-line; - fix typos/errors, capitalize acronyms, etc. in the comments; - fix/remove obsolete references in the comments; - reformat some comments; - add comment about the CPU:counter clock ratio to calc_clock(); - update MontaVista copyright; - remove Pete Popov's and Steve Longerbeam's old email addresses... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Alchemy: SMBus resource fixSergei Shtylyov
The Alchemy platform code registers the SMBus device using the virtual address of its registers instead of the physical one -- fix this, taking into account that actually the whole megabyte is decoded by any of the programmable serial controllers (one of which is SMBus), and that all the Alchemy peripherals are directly mappable into KSEG1 kernel space and therefore ioremap() call would just boil down to CKSEG1ADDR() invocation. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-30Merge branches 'release', 'acpica', 'bugzilla-10224', 'bugzilla-9772', ↵Len Brown
'bugzilla-9916', 'ec', 'eeepc', 'idle', 'misc', 'pm-legacy', 'sysfs-links-2.6.26', 'thermal', 'thinkpad' and 'video' into release
2008-04-28[MIPS] Pb1200/DBAu1200: move platform code to its proper placeSergei Shtylyov
Since both the IDE interface and SMC 91C111 Ethernet chip are on-board devices, not SOC devices, move the platform device registration form the common to the board specific code. While at it, remove semicolon (which didn't break compilation only by chance) from the AU1XXX_ATA_DDMA_REQ macro and do some renaming: - change 'au1200_ide0_' variable name prefix to the mere 'ide_'; - change 'smc91x_' variable name prefix to 'smc91c111_' since that's the name of the chip used on the boards; - drop 'AU1XXX_' prefix from the names of macros describing IDE and Ethernet on-board devices; - change 'SMC91111_' to 'SMC91C111_', change 'IRQ' to 'INT' in the names of the macros describing the Ethernet chip for consistency with the IDE macros; - change 'ATA_' to 'IDE_' and 'OFFSET' to 'SHIFT' (since this value is indeed a shift count) in the names of the macros describing the IDE interface. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Pb1200: do register SMC 91C111Sergei Shtylyov
Pb1200 does have SMC 91C111 Ethernet chip on board but the platform code did not register it, so one couldn't mount NFS... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] DBAu1200: fix bad SMC 91C111 resource sizeSergei Shtylyov
The on-board SMC 91C111 chip only decodes 16 bytes of memory (obviously, it can not decode a whole megabyte starting from address 0x19000300). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: move UART platform code to its proper placeSergei Shtylyov
Move the code registering the Alchemy UART platform devices from drivers/serial/ to its proper place, into the Alchemy platform code. Fix the related Kconfig entry, while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless time variablesSergei Shtylyov
Since the commit 91a2fcc88634663e9e13dcdfad0e4a860e64aeee ([MIPS] Consolidate all variants of MIPS cp0 timer interrupt handlers) removed the Alchemy specific timer handler, 'r4k_offset' and 'r4k_cur' variables became practically useless, so get rid of them at last, renaming cal_r4off() function into calc_clock() and making it return CPU frequency. Also, make 'no_au1xxx_32khz' variable static... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: don't unmask timer IRQ earlySergei Shtylyov
Defer the unmasking of the count/compare interrupt (IRQ5) till the clockevent driver initialization: - only enable the cascaded IRQs 0 thru 4 in arch_init_irq(); kill the ALLINTS macro -- this change is blessed by AMD as I saw it in their own patch; :-) - do not force IRQ5 enabled in plat_time_init() if PM is enabled and there's no 32 KHz crystal. Update the copyrights (taking into account my prior changes), also removing Pete Popov's old email... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-17Pb1200/DBAu1200: fix bad IDE resource sizeSergei Shtylyov
The header files for the Pb1200/DBAu1200 boards have wrong definition for the IDE interface's decoded range length -- it should be 512 bytes according to what the IDE driver does. In addition, the IDE platform device claims 1 byte too many for its memory resource -- fix the platform code and the IDE driver in accordance. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-15MIPS Alchemy: Crapectomy after removal of pm_send_all calls.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-15PM: Remove legacy PMPavel Machek
AFAICT pm_send_all is a nop when noone uses pm_register... Hmm.. can we just force CONFIG_PM_LEGACY=n, and see what happens? Or maybe this is better idea? It may break build somewhere, but it should be easy to fix... (it builds here, i386 and x86-64). Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-01[MIPS] Alchemy: work around clock misdetection on early Au1000Sergei Shtylyov
Work around the CPU clock miscalculation on Au1000DA/HA/HB due the sys_cpupll register being write-only, i.e. actually do what the comment before cal_r4off() function advertised for years but the code failed at. This is achieved by just giving user a chance to define the clock explicitly in the board config. via CONFIG_SOC_AU1000_FREQUENCY option, defaulting to 396 MHz if the option is not given... The patch is based on the AMD's big unpublished patch, the issue seems to be an undocumented errata (or feature :-)... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-03-12[MIPS] Alchemy: Fix ids in Alchemy db dma device tableWolfgang Ocker
0 is a valid device id (DSCR_CMD0_UART0_TX), so we can't use it to mark an empty entry in the device table. Use ~0 instead and search for id ~0 when looking for a free entry. Signed-off-by: Wolfgang Ocker <weo@reccoware.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-06Remove inclusions of <linux/autoconf.h>Ralf Baechle
Nothing should ever include this file. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: "Mike Frysinger" <vapier.adi@gmail.com> Acked-by: "Bryan Wu" <cooloney.lkml@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-29[MIPS] clean up au1xxx_irqmap.c include filesYoichi Yuasa
Clean up au1xxx_irqmap.c include files. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Converting most array size calculations to use ARRAY_SIZE().Alejandro Martinez Ruiz
Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-27i2c-au1550: Convert to platform driverManuel Lauss
Convert the i2c-au1550 bus driver to platform driver, and register a platform device for the Alchemy Db/Pb series of boards. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-07[MIPS] Alchemy: Fix use of __init code bug exposed by modpost warningSergei Shtylyov
WARNING: vmlinux.o(.text+0x1ca608): Section mismatch: reference to .init.text: add_wired_entry (between 'config_access' and 'config_read') by refactoring the code calling add_wired_entry() from config_access() to a separate function which is called from aau1x_pci_setup(). While at it: - make some unnecassarily global variables 'static'; - fix the letter case, whitespace, etc. in the comments... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-14[MIPS] Alchemy: fix off by two error in __fixup_bigphys_addr()Sergei Shtylyov
the PCI specific code in this function doesn't check for the address range being under the upper bound of the PCI memory window correctly -- fix this, somewhat beautifying the code around the check, while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-14[MIPS] Alchemy: fix PCI resource conflictSergei Shtylyov
... by getting the PCI resources back into the 32-bit range -- there's no need therefore for CONFIG_RESOURCES_64BIT either. This makes Alchemy PCI work again while currently the kernel skips the bus scan. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-06[MIPS] Alchemy: fix IRQ basesSergei Shtylyov
Do what the commits commits f3e8d1da389fe2e514e31f6e93c690c8e1243849 and 9d360ab4a7568a8d177280f651a8a772ae52b9b9 failed to achieve -- actually convert the Alchemy code to irq_cpu. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-06[MIPS] Alchemy: replace ffs() with __ffs()Sergei Shtylyov
Fix havoc wrought by commit 56f621c7f6f735311eed3f36858b402013023c18 -- au_ffs() and ffs() are equivalent, that patch should have just replaced one with another. Now replace ffs() with __ffs() which returns an unbiased bit number. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Alchemy: Convert from plat_timer_setup to plat_time_init.Ralf Baechle
The old plat_timer_setup hook is no longer getting called so the Alchemy time initialization was getting skipped. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] Alchemy: micro-optimizatize time code.Ralf Baechle
2007-10-29[MIPS] Alchemy: Nuke homebrew setup_irq(), it's broken and unnecessary.Ralf Baechle
2007-10-17[MIPS] Alchemy: Reformat PM code.Ralf Baechle
2007-10-17[MIPS] Alchemy: Fix build by conversion to irq_cpu.c.Ralf Baechle
2007-10-16[MIPS] Alchemy: Get rid of au1xxx_irq_map_t.Ralf Baechle
2007-10-16[MIPS] Alchemy: Get rid of au_ffs().Ralf Baechle
It was plain a bad idea ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16[MIPS] Alchemy: cleanup interrupt code.Ralf Baechle
2007-10-15add new prom.h for AU1x00Yoichi Yuasa
Add new prom.h for AU1x00. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15update AU1000 get_ethernet_addr()Yoichi Yuasa
Update AU1000 get_ethernet_addr(). Three functions were brought together in one. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] Implement clockevents for R4000-style cp0 count/compare interruptRalf Baechle
2007-10-11[MIPS] Consolidate all variants of MIPS cp0 timer interrupt handlers.Ralf Baechle
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Alchemy: remove useless prototypes.Ralf Baechle
