Fix several errors and warnings given by checkpatch.pl:
- macros with complex values not enclosed in parentheses;
- leading spaces instead of tabs;
- printk() without KERN_* facility level;
- using simple_strtol() where strict_strtol() could be used;
- line over 80 characters.
In addition to these changes, also do the following:
- initialize variable instead of assigning value later where it makes sense;
- insert spaces between operator and its operands, also remove excess spaces
there;
- remove unneeded numeric literal type casts;
- remove needless parentheses;
- remove space after the type cast's closing parenthesis;
- insert missing space before closing brace in the array initializers;
- replace spaces after the macro name with tabs in the #define directives;
- remove excess tabs after the macro name in the #define directives;
- fix typos/errors, capitalize acronyms, etc. in the comments;
- make the multi-line comment style consistent with the kernel style elsewhere
by adding empty first/last line;
- update MontaVista copyright;
- remove Pete Popov's old email address...
CONFIG_WM97XX_COMODULE doesn't exist.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
infrastructure for it.
Let it rip!
