path: root/arch/mips/au1000/mtx-1/init.c
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-30[MIPS] Initialization of Alchemy boardsKevin Hickey
An earlier update changed some calls from simple_strotl to strict_strtol but did not account for the differences in the syntax between the calls. simple_strotl returns the integer; strict_strtol returns an error code and takes a pointer to the result. As it was, NULL was being passed in place of the result, which led to failures during kernel initialization when using YAMON. Signed-off-by: Kevin Hickey <khickey@rmicorp.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] MTX-1 code style cleanupSergei Shtylyov
Fix many errors and warnings given by checkpatch.pl: - space after opening and before closing parentheses; - use of C99 // comments; - leading spaces instead of tabs; - brace not on the same line with 'else' in the 'if' statement; statement; - printk() without KERN_* facility level; - using simple_strtol() where strict_strtol() could be used. - including <asm/gpio.h> instead of <linux/gpio.h>. In addition to these changes, also do the following: - insert spaces between operator and its operands; - replace tab between the function type and name with space in mtx1_pci_idsel() declaration; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array/structure initializers; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] remove unused mips_machtypeYoichi Yuasa
Removed unused mips_machtype. These are only set but not used. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-15add new prom.h for AU1x00Yoichi Yuasa
Add new prom.h for AU1x00. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Arrested for multiple offences of header file inclusion.Ralf Baechle
