path: root/arch/mips/au1000/pb1000
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-30[MIPS] Initialization of Alchemy boardsKevin Hickey
An earlier update changed some calls from simple_strotl to strict_strtol but did not account for the differences in the syntax between the calls. simple_strotl returns the integer; strict_strtol returns an error code and takes a pointer to the result. As it was, NULL was being passed in place of the result, which led to failures during kernel initialization when using YAMON. Signed-off-by: Kevin Hickey <khickey@rmicorp.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1000: bury the remnants of the PCI codeSergei Shtylyov
Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1000 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - brace not on the same line with condition in the 'switch' statement; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - properly indent the 'switch' statement; - remove needless parentheses; - insert spaces between operator and its operands; - replace numeric literals/expressions with the matching macros; - remove useless #if dirctive from board_setup(); - remove unneeded numeric literal type casts; - remove space after the type cast's closing parenthesis; - replace spaces after the macro name with tabs in the #define directives, and sometimes insert spaces there; - remove excess new lines; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first/last line; - combine some comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] remove unused mips_machtypeYoichi Yuasa
Removed unused mips_machtype. These are only set but not used. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16[MIPS] Alchemy: Get rid of au1xxx_irq_map_t.Ralf Baechle
2007-10-15add new prom.h for AU1x00Yoichi Yuasa
Add new prom.h for AU1x00. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-09[MIPS] Alchemy: Fix USB initialization.Florian Fainelli
This patch fixes a wrong ifdef in the board setup code, leading to the GPIO pin not being pulled high, and thus the USB switch not being powered at all. This finishes the rename of CONFIG_USB_OHCI to CONFIG_USB_OHCI_HCD, which started in 2005 (before 2.6.12-rc2), then probably because things were working anyway for most people got forgotten. [Ralf: Paolo's original patch didn't fix the module case, Florian's patch only fixed MTX1 etc. so this is a combined patch plus some cleanups.] Cc: Giuseppe Patanè <giuseppe.patane@tvblob.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Alchemy: nuke usbdev; it's useless as is ...Ralf Baechle
2006-06-19[MIPS] Au1xxx: board specific irq code cleanupHerbert Valerio Riedel
Convert sizeof/sizeof use to use of ARRAY_SIZE macro, and annotate irqmap structures as __initdata. Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Void functions shouldn't return valuesLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
