It's more than the au1000 these days.
An earlier update changed some calls from simple_strotl to strict_strtol but
did not account for the differences in the syntax between the calls.
simple_strotl returns the integer; strict_strtol returns an error code and
takes a pointer to the result. As it was, NULL was being passed in place of
the result, which led to failures during kernel initialization when using
YAMON.
Signed-off-by: Kevin Hickey <khickey@rmicorp.com>
Fix several errors and warnings given by checkpatch.pl:
- use of C99 // comments;
- using simple_strtol() where strict_strtol() could be used.
In addition to these changes, also do the following:
- remove needless parentheses;
- remove unneeded numeric literal type cast;
- insert spaces between operator and its operands;
- remove excess new lines;
- remove space after the type cast's closing parenthesis;
- insert missing space before closing brace in the structure initializer;
- fix typos, capitalize acronyms, etc. in the comments;
- update MontaVista copyright;
- remove Pete Popov's old email address...
Go thru the Alchemy code and hunt down every unneeded #include, #define, and
extern (some of which refer to already long dead functions).
Removed unused mips_machtype. These are only set but not used.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Add new prom.h for AU1x00.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
This has not been any serious user of this ill conceived thing since the
original invention in like '95.
infrastructure for it.
Let it rip!
