path: root/arch/mips/basler/excite
2008-04-29proc: switch /proc/excite/unit_id to seq_file interfaceAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-29[MIPS]: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] move the eXcite local config to excitedirectoryYoichi Yuasa
Moved the eXcite local config to excite directory. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] remove unused mips_machtypeYoichi Yuasa
Removed unused mips_machtype. These are only set but not used. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-02[MIPS] Excite: Fix build error.Ralf Baechle
2007-10-29[MIPS] time: Merge eXcite plat_timer_setup into plat_time_init.Ralf Baechle
Fixme: At the time of this writing cevt-r4k.c doesn't yet know about how to handle the alternate timer interrupt of the RM9000. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-18serial: add early_serial_setup() back to header fileYinghai Lu
early_serial_setup was removed from serial.h, but forgot to put in serial_8250.h Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11[MIPS] excite: use __maybe_unusedDavid Rientjes
Replace variable instances of __attribute__((unused)) with __maybe_unused. Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Use DEFINE_SPINLOCK instead of SPIN_LOCK_UNLOCKED.Milind Arun Choudhary
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] excite: Set serial driver iotype to UPIO_RM9000Thomas Koeller
Signed-off-by: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Define MIPS_CPU_IRQ_BASE in generic headerAtsushi Nemoto
The irq_base for {mips,rm7k,rm9k}_cpu_irq_init() are constant on all platforms and are same value on most platforms (0 or 16, depends on CONFIG_I8259). Define them in asm-mips/mach-generic/irq.h and make them customizable. This will save a few cycle on each CPU interrupt. A good side effect is removing some dependencies to MALTA in generic SMTC code. Although MIPS_CPU_IRQ_BASE is customizable, this patch changes irq mappings on DDB5477, EMMA2RH and MIPS_SIM, since really customizing them might cause some header dependency problem and there seems no good reason to customize it. So currently only VR41XX is using custom MIPS_CPU_IRQ_BASE value, which is 0 regardless of CONFIG_I8259. Testing this patch on those platforms is greatly appreciated. Thank you. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-10-01[MIPS] Remove excite_flash.cYoichi Yuasa
excite_flashtest.c is unused. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Move excite_fpga.h to include/asm-mips/mach-excitethomas@koeller.dyndns.org
excite_fpga.h, like all platform headers, really belongs in the platform header directory. Signed-off-by: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Suppress compiler warningsthomas@koeller.dyndns.org
The excite platform exports hardware resources for device drivers to use. Any driver wanting to use these resources will look up them by their names. Since these resources are declared to have static linkage, but are not used in the source file defining them, the compiler used to emit an 'unused' warning, which this patch suppresses. Signed-off-by: Thomas Koeller <thomas.koeller@baslerweb.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] Don't include obsolete <linux/config.h>.Ralf Baechle
2006-07-02[PATCH] irq-flags: MIPS: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[MIPS] excite: plat_setup -> plat_mem_setup.Ralf Baechle
2006-06-19[MIPS] Support for the RM9000-based Basler eXcite smart camera platform.Ralf Baechle
