commit 8a38dacf87180738d42b058334c951eba15d2d47 upstream.
The Ethernet Switch core mask was set to 0, causing the switch core to
be not reset on BCM6368 on boot. Provide the proper mask so the switch
core gets reset to a known good state.
Fixes: 799faa626c71 ("MIPS: BCM63XX: add core reset helper")
Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com>
Signed-off-by: Paul Burton <paul.burton@mips.com>
Cc: linux-mips@vger.kernel.org
Cc: James Hogan <jhogan@kernel.org>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
[ Upstream commit e4f5cb1a9b27c0f94ef4f5a0178a3fde2d3d0e9e ]
The vectors span more than one byte, so mark them as arrays.
Fixes the following build error when building when using GCC 8.3:
In file included from ./include/linux/string.h:19,
from ./include/linux/bitmap.h:9,
from ./include/linux/cpumask.h:12,
from ./arch/mips/include/asm/processor.h:15,
from ./arch/mips/include/asm/thread_info.h:16,
from ./include/linux/thread_info.h:38,
from ./include/asm-generic/preempt.h:5,
from ./arch/mips/include/generated/asm/preempt.h:1,
from ./include/linux/preempt.h:81,
from ./include/linux/spinlock.h:51,
from ./include/linux/mmzone.h:8,
from ./include/linux/bootmem.h:8,
from arch/mips/bcm63xx/prom.c:10:
arch/mips/bcm63xx/prom.c: In function 'prom_init':
./arch/mips/include/asm/string.h:162:11: error: '__builtin_memcpy' forming offset [2, 32] is out of the bounds [0, 1] of object 'bmips_smp_movevec' with type 'char' [-Werror=array-bounds]
__ret = __builtin_memcpy((dst), (src), __len); \
arch/mips/bcm63xx/prom.c:97:3: note: in expansion of macro 'memcpy'
memcpy((void *)0xa0000200, &bmips_smp_movevec, 0x20);
In file included from arch/mips/bcm63xx/prom.c:14:
./arch/mips/include/asm/bmips.h:80:13: note: 'bmips_smp_movevec' declared here
extern char bmips_smp_movevec;
Fixes: 18a1eef92dcd ("MIPS: BMIPS: Introduce bmips.h")
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Paul Burton <paulburton@kernel.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Make the behaviour of clk_get_rate consistent with common clk's
clk_get_rate by accepting NULL clocks as parameter. Some device
drivers rely on this, and will cause an OOPS otherwise.
Fixes: e7300d04bd08 ("MIPS: BCM63xx: Add support for the Broadcom BCM63xx family of SOCs.")
Reported-by: Mathias Kresin <dev@kresin.me>
Cc: bcm-kernel-feedback-list@broadcom.com
Cc: James Hogan <james.hogan@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/16776/
Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. In the case of
some code where it is modular, we can extend that to also include
files that are building basic support functionality but not related
to loading or registering the final module; such files also have
no need whatsoever for module.h
The advantage in removing such instances is that module.h itself
sources about 15 other headers; adding significantly to what we feed
cpp, and it can obscure what headers we are effectively using.
Since module.h might have been the implicit source for init.h
(for __init) and for export.h (for EXPORT_SYMBOL) we consider each
instance for the presence of either and replace/add as needed.
Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code.
Build coverage of all the mips defconfigs revealed the module.h
header was masking a couple of implicit include instances, so
we add the appropriate headers there.
Cc: David Daney <david.daney@cavium.com>
Cc: John Crispin <john@phrozen.org>
Cc: "Steven J. Hill" <steven.hill@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/15131/
[james.hogan@imgtec.com: Preserve sort order where it already exists]
Signed-off-by: James Hogan <james.hogan@imgtec.com>
In many of clk_disable() implementations, it is a no-op for a NULL
pointer input, but this is one of the exceptions.
Making it treewide consistent will allow clock consumers to call
clk_disable() without NULL pointer check.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Michael Turquette <mturquette@baylibre.com>
Patchwork: https://patchwork.linux-mips.org/patch/14264/
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd into devel
We're planning to remove the gpiochip_add() function to swith
to gpiochip_add_data() with NULL for data argument.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
function"
This reverts commit 5bdb102b3f9785cb88467bc7c75fa0f5cacc8dc5.
Brian Norris <computersforpeace@gmail.com> is reporting:
Ralf,
Please revert this and send it to Linus (or else, I can send it myself).
This is causing build failures, because I didn't take the rest of
Simon's series yet.
drivers/mtd/bcm63xxpart.c: In function 'bcm63xx_parse_cfe_partitions':
drivers/mtd/bcm63xxpart.c:93:2: error: implicit declaration of function
'bcm63xx_nvram_get_psi_size' [-Werror=implicit-function-declaration]
References: https://www.linux-mips.org/cgi-bin/mesg.cgi?a=linux-mips&i=20160126191607.GA111152%40google.com
Remove bcm63xx_nvram_get_psi_size() as it now has no users.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Kevin Cernekee <cernekee@gmail.com>
Cc: Jonas Gorski <jogo@openwrt.org>
Cc: Linux Kernel Mailing List <linux-kernel@vger.kernel.org>
Cc: MIPS Mailing List <linux-mips@linux-mips.org>
Cc: MTD Maling List <linux-mtd@lists.infradead.org>
Patchwork: https://patchwork.linux-mips.org/patch/11836/
Use the common definition of the nvram structure from the header file
include/linux/bcm963xx_nvram.h instead of maintaining a separate copy.
Read the version 5 size of nvram data from memory and then call the
new checksum verification function from the header file.
Patchwork: https://patchwork.linux-mips.org/patch/11831/
Pull MIPS updates from Ralf Baechle:
"These are the highlists of the main MIPS pull request for 4.4:
- Add latencytop support
- Support appended DTBs
- VDSO support and initially use it for gettimeofday.
- Drop the .MIPS.abiflags and ELF NOTE sections from vmlinux
- Support for the 5KE, an internal test core.
- Switch all MIPS platfroms to libata drivers.
- Improved support, cleanups for ralink and Lantiq platforms.
- Support for the new xilfpga platform.
- A number of DTB improvments for BMIPS.
- Improved support for CM and CPS.
- Minor JZ4740 and BCM47xx enhancements"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (120 commits)
MIPS: idle: add case for CPU_5KE
MIPS: Octeon: Support APPENDED_DTB
MIPS: vmlinux: create a section for appended DTB
MIPS: Clean up compat_siginfo_t
MIPS: Fix PAGE_MASK definition
MIPS: BMIPS: Enable GZIP ramdisk and timed printks
MIPS: Add xilfpga defconfig
MIPS: xilfpga: Add mipsfpga platform code
MIPS: xilfpga: Add xilfpga device tree files.
dt-bindings: MIPS: Document xilfpga bindings and boot style
MIPS: Make MIPS_CMDLINE_DTB default
MIPS: Make the kernel arguments from dtb available
MIPS: Use USE_OF as the guard for appended dtb
MIPS: BCM63XX: Use pr_* instead of printk
MIPS: Loongson: Cleanup CONFIG_LOONGSON_SUSPEND.
MIPS: lantiq: Disable xbar fpi burst mode
MIPS: lantiq: Force the crossbar to big endian
MIPS: lantiq: Initialize the USB core on boot
MIPS: lantiq: Return correct value for fpi clock on ar9
MIPS: ralink: Add missing clock on rt305x
Signed-off-by: Gregory Fong <gregory.0xf0@gmail.com>
Cc: Joe Perches <joe@perches.com>
Cc: Nicolas Schichan <nschichan@freebox.fr>
Patchwork: https://patchwork.linux-mips.org/patch/11300/
Move all register definitions and structs into the driver. This allows
us dropping the platform_data struct and drop any arch specific
includes. Make use of different device names to identify the version of
the block we have.
Since we now have full control over the message width, we can drop the
size check, which was broken anyway, since it never set ret to any error
code.
Also since we now have no arch depedendent resources, we can now allow
compiling it for any arch, hidden behind COMPILE_TEST.
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
Make the message control word parameters part of the register offsets
array so we have them all in one struct.
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle.
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: LKML <linux-kernel@vger.kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/10701/
This is a preparatory patch for moving irq_data struct members.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/10699/
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell:
"This is the final removal (after several years!) of the obsolete
cpus_* functions, prompted by their mis-use in staging.
With these function removed, all cpu functions should only iterate to
nr_cpu_ids, so we finally only allocate that many bits when cpumasks
are allocated offstack"
* tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
cpumask: remove __first_cpu / __next_cpu
cpumask: resurrect CPU_MASK_CPU0
linux/cpumask.h: add typechecking to cpumask_test_cpu
cpumask: only allocate nr_cpumask_bits.
Fix weird uses of num_online_cpus().
cpumask: remove deprecated functions.
mips: fix obsolete cpumask_of_cpu usage.
x86: fix more deprecated cpu function usage.
ia64: remove deprecated cpus_ usage.
powerpc: fix deprecated CPU_MASK_CPU0 usage.
CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region.
staging/lustre/o2iblnd: Don't use cpus_weight
staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_
staging/lustre/ptlrpc: Do not use deprecated cpus_* functions
blackfin: fix up obsolete cpu function usage.
parisc: fix up obsolete cpu function usage.
tile: fix up obsolete cpu function usage.
arm64: fix up obsolete cpu function usage.
mips: fix up obsolete cpu function usage.
x86: fix up obsolete cpu function usage.
When called from prom init code, bcm63xx_gpio_init() will fail as it
will call gpiochip_add() which relies on a working kmalloc() to alloc
the gpio_desc array and kmalloc is not useable yet at prom init time.
Move bcm63xx_gpio_init() to bcm63xx_register_devices() (an
arch_initcall) where kmalloc works.
Fixes: 14e85c0e69d5 ("gpio: remove gpio_descs global array")
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Patchwork: https://patchwork.linux-mips.org/patch/9530/
Thanks to spatch, plus manual removal of "&*". Then a sweep for
for_each_cpu_mask => for_each_cpu.
Based on the spatch
expression e;
- return (e);
+ return e;
with heavy hand editing because some of the changes are either whitespace
or identation only or result in excessivly long lines.
Delete successive assignments to the same location. In each case, the
duplicated assignment is modified to be in line with other nearby code.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression i;
*i = ...;
i = ...;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: joe@perches.com
Cc: kernel-janitors@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/7565/
Wire up the set_affinity call for the internal PIC if booting on
a cpu supporting it.
Affinity is kept to boot cpu as default.
Cc: John Crispin <blogic@openwrt.org>
Cc: Maxime Bizon <mbizon@freebox.fr>
Cc: Florian Fainelli <florian@openwrt.org>
Cc: Gregory Fong <gregory.0xf0@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/7323/
In preparation for applying affinity, use the irq descriptor as the
argument for (un)mask.
Patchwork: https://patchwork.linux-mips.org/patch/7317/
Patchwork: https://patchwork.linux-mips.org/patch/7322/
Since we will have the chance of accessing the registers concurrently,
protect any accesses through a spinlock.
Patchwork: https://patchwork.linux-mips.org/patch/7321/
Patchwork: https://patchwork.linux-mips.org/patch/7320/
Set it to zero if there is no second set.
Patchwork: https://patchwork.linux-mips.org/patch/7319/
The SMP capable irq controllers have two interrupt output pins which are
controlled through separate registers, so make the variables arrays.
Patchwork: https://patchwork.linux-mips.org/patch/7318/
The generic version uses a variable length of u32 registers instead of u32/u64.
This allows easier support for "wider" registers without having to rewrite
everything.
This "generic" version is as fast as the old version in the best case
(i == next set bit), and twice as fast in the worst case in 64 bits.
Using a macro was chosen over a (forced) inline version because gcc generated
more compact code with the macro.
The change from (signed) int to unsigned int for i and to_call was intentional
as the value can be only between 0 and (width - 1) anyway, and allowed gcc to
optimise the code a bit further.
Patchwork: https://patchwork.linux-mips.org/patch/7316/
Allows up to drop the prototypes from the top.
Patchwork: https://patchwork.linux-mips.org/patch/7315/
Make it follow the same naming convention as the other functions.
Patchwork: https://patchwork.linux-mips.org/patch/7314/
Use the same pattern as with get_*_cpu_type() to allow the compiler
to remove code for non enabled SoC types.
Patchwork: https://patchwork.linux-mips.org/patch/7273/
Patchwork: https://patchwork.linux-mips.org/patch/7270/
Patchwork: https://patchwork.linux-mips.org/patch/7271/
Patchwork: https://patchwork.linux-mips.org/patch/7269/
Patchwork: https://patchwork.linux-mips.org/patch/7268/
Patchwork: https://patchwork.linux-mips.org/patch/7267/
If current_cpu_type() is pre-defined in cpu-feature-overrides.h, This
may save about 10k for the compressed kernel image(vmlinuz).
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/1901/
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Signed-off-by: John Crispin <blogic@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/6320/
BUG() can be a noop if CONFIG_BUG is not selected,
leading to the following build problem on a randconfig:
arch/mips/bcm63xx/cpu.c: In function 'detect_cpu_clock':
arch/mips/bcm63xx/cpu.c:254:1: error: control reaches end of
non-void function [-Werror=return-type]
We fix this problem by replacing BUG() with panic() since it's
best to handle the case of an unknown board instead of silently
returning a random clock frequency.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Acked-by: Steven J. Hill <Steven.Hill@imgtec.com>
Acked-by: Jonas Gorski <jogo@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/5932/
Update the early_printk code to include linux/serial_bcm63xx.h which
provides the definitions for the UART block registers. While at it,
remove the inclusion of serial_bcm63xx.h which was just there to allow
smooth transition.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/6203/
Let each supported chip select the appropirate SYS_HAS_CPU_BMIPS*
option for its embedded processor, so support will be conditionally
included.
Patchwork: http://patchwork.linux-mips.org/patch/6250/
Use the return value for guarding further SMP setup.
Patchwork: http://patchwork.linux-mips.org/patch/6249/
Add a helper similar to the generic register_XXX_smp_ops() for bmips.
Register SMP UP ops in case of BMIPS32/3300.
Patchwork: http://patchwork.linux-mips.org/patch/6248/
Allow building for all bmips cpus at the same time by changing ifdefs
to checks for the cpu type, or adding appropriate checks to the
assembly.
Since BMIPS43XX and BMIPS5000 require different IPI implementations,
split the SMP ops into one for each, so the runtime overhead is only
at registration time for them.
Patchwork: http://patchwork.linux-mips.org/patch/6241/
BCM3368 has the same shared TLB as BCM6358.
Patchwork: http://patchwork.linux-mips.org/patch/6239/
Patchwork: http://patchwork.linux-mips.org/patch/6180/
Properly set up the HSSPI clock rate depending on the SoC's PLL rate.
Patchwork: http://patchwork.linux-mips.org/patch/6177/
Patchwork: http://patchwork.linux-mips.org/patch/6178/
