path: root/arch/mips/cobalt
2011-09-21MIPS: Mark cascade and low level interrupts IRQF_NO_THREADWu Zhangjin
Mark interrupts with no_action handler, cascade interrupts, low level interrupts (bus error, halt ..) with IRQF_NO_THREAD to exclude them from forced threading. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Cc: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-06-09i8253: Create linux/i8253.h and use it in all 8253 related filesRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> arch/arm/mach-footbridge/isa-timer.c | 2 +- arch/mips/cobalt/time.c | 2 +- arch/mips/jazz/irq.c | 2 +- arch/mips/kernel/i8253.c | 2 +- arch/mips/mti-malta/malta-time.c | 2 +- arch/mips/sgi-ip22/ip22-time.c | 2 +- arch/mips/sni/time.c | 2 +- arch/x86/kernel/apic/apic.c | 2 +- arch/x86/kernel/apm_32.c | 2 +- arch/x86/kernel/hpet.c | 2 +- arch/x86/kernel/i8253.c | 2 +- arch/x86/kernel/time.c | 2 +- drivers/block/hd.c | 2 +- drivers/clocksource/i8253.c | 2 +- drivers/input/gameport/gameport.c | 2 +- drivers/input/joystick/analog.c | 2 +- drivers/input/misc/pcspkr.c | 2 +- include/linux/i8253.h | 11 +++++++++++ sound/drivers/pcsp/pcsp.h | 2 +- 19 files changed, 29 insertions(+), 18 deletions(-)
2010-08-05MIPS: Move Cobalt Makefile parts to their own Platform fileYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1321/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Cobalt: Fix theoretical port aliasing issueRalf Baechle
Because the VIA SuperIO chip only decodes 24 bits of address space but port address space currently being configured as 32MB there is the theoretical possibility of aliases within the I/O port address range. The complicated solution is to reserve all address range that potencially could cause such aliases. But with the PCI spec limiting port allocations for devices to a maximum of 256 bytes 16MB of port address space already is way more than one would ever expect to be used so we just reduce the port space to 16MB. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Yoichi Yuasa <yuasa@linux-mips.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: linux-mips@linux-mips.org Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Patchwork: http://patchwork.linux-mips.org/patch/995/
2010-01-12MIPS: Cobalt use strlcat() for the command line argumentsYoichi Yuasa
Tested with CoLo v1.22 Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/807/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03Update Yoichi Yuasa's e-mail addressYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30cpumask: remove references to struct irqaction's mask field.Rusty Russell
Impact: cleanup It's unused, since about 1995. So remove all initialization of it in preparation for actually removing the field. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-20[MIPS] Cobalt: Fix I/O port resource rangeYoichi Yuasa
LCD and buttons don't use I/O port space. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] Cobalt: Register new LCD platform device.Yoichi Yuasa
2008-01-29[MIPS] add cpu_wait() to machine_halt()Yoichi Yuasa
Added cpu_wait() to machine_halt(). For the power reduction in halt. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] remove unneeded button check for resetYoichi Yuasa
Removed unneeded button check for reset. Because, the Cobalt has power switch. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-15[MIPS] Cobalt: Qube1 has no serial port so don't use itThomas Bogendoerfer
Because Qube1 doesn't have a serial chip waiting for transmit fifo empty takes forever, which isn't a good idea. No prom_putchar/early console for Qube1 fixes this. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-14[MIPS] time: Set up Cobalt's mips_hpt_frequencyYoichi Yuasa
2007-10-22[MIPS] time: Add GT641xx timer0 clockevent driverYoichi Yuasa
And make use of it for Cobalt. A few others such as the Malta could make use of it as well. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Remove cobalt_machine_power_off()Yoichi Yuasa
It's same as cobalt_machine_halt(). Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Move reset port definition to arch/mips/cobalt/reset.cYoichi Yuasa
It's only used in arch/mips/cobalt/reset.c. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Move UART base definition to arch/mips/cobalt/console.cYoichi Yuasa
They're only used in arch/mips/cobalt/console.c. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Add Qube series front LED support to platform registerYoichi Yuasa
Add Cobalt Qube series front LED support to platform register. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Add Cobalt Raq LED platform register and power off triggerYoichi Yuasa
2007-10-11[MIPS] i8253 PIT clocksource and clockevent driversRalf Baechle
Derived from the i386 variant with a few x86 complexities chopped off. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Add GT641xx IRQ routines.Yoichi Yuasa
2007-10-11[MIPS] cleanup struct irqaction initializersThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> CC: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Cobalt: Enable UART on RaQ1Martin Michlmayr
Unlike the current code suggests, the RaQ1 actually has an UART. Only the Qube1 (Qube 2700) lacks one. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-06-26[MIPS] add io_map_base to pci_controller on CobaltYoichi Yuasa
2007-05-11[MIPS] Rework cobalt_board_idYoichi Yuasa
This patch has reworked cobalt_board_id. The cobalt_board_id is read from PCI config register. It should be in PCI routine. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-05-11[MIPS] Use RTC_CMOS for CobaltYoichi Yuasa
2007-05-11[MIPS] Use platform_device for Cobalt UARTYoichi Yuasa
2007-05-01Merge master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
Conflicts: drivers/usb/input/Makefile drivers/usb/input/gtco.c
2007-04-27[MIPS] merge GT64111 PCI routines and GT64120 PCI_0 routinesYoichi Yuasa
This patch has merged GT64111 PCI routines and GT64120 PCI_0 routines. GT64111 PCI is almost the same as GT64120's PCI_0. This patch don't change GT64120 PCI routines. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Cobalt: Split PCI codes from setup.cYoichi Yuasa
It's removed #ifdef CONFIG_PCI/#endif from cobalt setup.c . Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Cobalt: clean up include filesYoichi Yuasa
2007-04-12Input: cobalt buttons - separate device and driver registrationDmitry Torokhov
Create platform device for cobalt buttons as part of arch setup. This makes the driver follow current driver model more closely. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
2007-03-07[MIPS] Cobalt: Fix early printkYoichi Yuasa
2007-03-04[MIPS] Cobalt: update reserved resourcesYoichi Yuasa
This patch has removed unused timer resource. Moreover, the name of reserved resources ware changed. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] Kill redundant EXTRA_AFLAGSAtsushi Nemoto
Many Makefiles in arch/mips have EXTRA_AFLAGS := $(CFLAGS) line. This is redundant while AFLAGS contains $(cflags-y) and any options only listed in CFLAGS (not in cflags-y) should be unnecessary for asm sources. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-22[MIPS] Cobalt: Rename "Colo" MTD partition to "firmware".Ralf Baechle
2007-02-20Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [NET] Eliminate user-selectable CONFIG_MV643XX_ETH_[012] [MIPS] Drop __init from init_8259A() [MIPS] Fix Kconfig typo bug [MIPS] Fix double signal on trap and break instruction [MIPS] sigset_32 has been made redundand by compat_sigset_t. [MIPS] emma2rh: Remove needless <asm/i8259.h> inclusion. [MIPS] Add MTD device support for Cobalt
2007-02-20[MIPS] Add MTD device support for CobaltYoichi Yuasa
This patch has added MTD device support for Cobalt. Moreover, removes old type FlashROM support. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-20[MIPS] Cobalt: Fix UART I/O typeYoichi Yuasa
The Cobalt UART is actually connected to memory resource area. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Define MIPS_CPU_IRQ_BASE in generic headerAtsushi Nemoto
The irq_base for {mips,rm7k,rm9k}_cpu_irq_init() are constant on all platforms and are same value on most platforms (0 or 16, depends on CONFIG_I8259). Define them in asm-mips/mach-generic/irq.h and make them customizable. This will save a few cycle on each CPU interrupt. A good side effect is removing some dependencies to MALTA in generic SMTC code. Although MIPS_CPU_IRQ_BASE is customizable, this patch changes irq mappings on DDB5477, EMMA2RH and MIPS_SIM, since really customizing them might cause some header dependency problem and there seems no good reason to customize it. So currently only VR41XX is using custom MIPS_CPU_IRQ_BASE value, which is 0 regardless of CONFIG_I8259. Testing this patch on those platforms is greatly appreciated. Thank you. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] Rewrite GALILEO_INL/GALILEO_OUTL to GT_READ/GT_WRITEYoichi Yuasa
This patch has rewritten GALILEO_INL/GALILEO_OUTL using GT_READ/GT_WRITE. This patch tested on Cobalt Qube2. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-10-08[MIPS] Cobalt: Time runs too quicklyScott Ashcroft
A kernel built with HZ==250 runs about 4 four times too quickly on a Cobalt RaQ2. Signed-off-by: Scott Ashcroft <scott.ashcroft@talk21.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-01[SERIAL] Remove wrong asm/serial.h inclusionsRussell King
asm/serial.h is supposed to contain the definitions for the architecture specific 8250 ports for the 8250 driver. It may also define BASE_BAUD, but this is the base baud for the architecture specific ports _only_. Therefore, nothing other than the 8250 driver should be including this header file. In order to move towards this goal, here is a patch which removes some of the more obvious incorrect includes of the file. Acked-by: Paul Fulghum <paulkf@microgate.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
