path: root/arch/mips/configs/sb1250-swarm_defconfig
2007-03-13[MIPS] Viper2: Remove defective support.Ralf Baechle
A defconfig file and the 10 lines of code (including comments ...) that are rotting since lmo commit 6516a42dc8b40c6c00010346dd51496125b16644 don't quite make proper support, so let's trash it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-22[MIPS] Add basic SMARTMIPS ASE supportFranck Bui-Huu
This patch adds trivial support for SMARTMIPS extension. This extension is currently implemented by 4KS[CD] CPUs. Basically it saves/restores ACX register, which is part of the SMARTMIPS ASE, when needed. This patch does *not* add any support for Smartmips MMU features. Futhermore this patch does not add explicit support for 4KS[CD] CPUs since they are respectively mips32 and mips32r2 compliant. So with the current processor configuration, a platform that has such CPUs needs to select both configs: CPU_HAS_SMARTMIPS SYS_HAS_CPU_MIPS32_R[12] This is due to the processor configuration which is mixing up all the architecture variants and the processor types. The drawback of this, is that we currently pass '-march=mips32' option to gcc when building a kernel instead of '-march=4ksc' for 4KSC case. This can lead to a kernel image a little bit bigger than required. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-18[MIPS] Update defconfigsRalf Baechle
2006-12-09[MIPS] Rename SNI_RM200_PCI to just SNI_RM preparing for more RM machinesThomas Bogendoerfer
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-01[MIPS] lockdep: update defconfigsAtsushi Nemoto
Add those lines to all defconfigs. CONFIG_LOCKDEP_SUPPORT=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y This is a patch againt linux-mips.org git tree. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Remove EV96100 as previously announced.Ralf Baechle
2006-07-13[MIPS] Update defconfigs to 2.6.18-rc1.Ralf Baechle
2006-06-19[MIPS] Make timer interrupt frequency configurable from kconfig.Atsushi Nemoto
Make HZ configurable. DECSTATION can select 128/256/1024 HZ, JAZZ can only select 100 HZ, others can select 100/128/250/256/1000/1024 HZ if not explicitly specified). Also remove all mach-xxx/param.h files and update all defconfigs according to current HZ value. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove support for NEC DDB5476.Ralf Baechle
As warned several times before. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove support for NEC DDB5074.Ralf Baechle
2006-04-27[MIPS] Update MIPS defconfigs.Ralf Baechle
2006-03-21[MIPS] Update defconfigs.Ralf Baechle
2006-03-21[MIPS] Remove CONFIG_BUILD_ELF64.Ralf Baechle
This option is no longer usable with supported compilers. It will be replaced by usage of -msym32 in a separate patch. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-01-10MIPS: Remove unused CONFIG_CPU_HAS_LLDSCD.Ralf Baechle
2005-12-01[MIPS] Update defconfigs to reflect Kconfig changes.Ralf Baechle
2005-11-17[MIPS] Update defconfigsRalf Baechle
2005-10-29Update MIPS defconfig files.Ralf Baechle
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
