Remove old, dead Kconfig options (in order appearing in this commit):
- EXPERIMENTAL is gone since v3.9;
- INET_LRO: commit 7bbf3cae65b6 ("ipv4: Remove inet_lro library");
- MTD_CONCAT: commit f53fdebcc3e1 ("mtd: drop MTD_CONCAT from Kconfig
entirely");
- MTD_CHAR: commit 660685d9d1b4 ("mtd: merge mtdchar module with
mtdcore");
- NETDEV_1000 and NETDEV_10000: commit f860b0522f65 ("drivers/net:
Kconfig and Makefile cleanup"); NET_ETHERNET should be replaced with
just ETHERNET but that is separate change;
- MISC_DEVICES: commit 7c5763b8453a ("drivers: misc: Remove
MISC_DEVICES config option");
- HID_SUPPORT: commit 1f41a6a99476 ("HID: Fix the generic Kconfig
options");
- BT_L2CAP and BT_SCO: commit f1e91e1640d8 ("Bluetooth: Always compile
SCO and L2CAP in Bluetooth Core");
- DEBUG_ERRORS: commit b025a3f836d1 ("ARM: 6876/1: Kconfig.debug:
Remove unused CONFIG_DEBUG_ERRORS");
- USB_DEVICE_CLASS: commit 007bab91324e ("USB: remove
CONFIG_USB_DEVICE_CLASS");
- RCU_CPU_STALL_DETECTOR: commit a00e0d714fbd ("rcu: Remove conditional
compilation for RCU CPU stall warnings");
- IP_NF_QUEUE: commit 3dd6664fac7e ("netfilter: remove unused "config
IP_NF_QUEUE"");
- IP_NF_TARGET_ULOG: commit d4da843e6fad ("netfilter: kill remnants of
ulog targets");
- IP6_NF_QUEUE: commit d16cf20e2f2f ("netfilter: remove ip_queue
support");
- IP6_NF_TARGET_LOG: commit 6939c33a757b ("netfilter: merge ipt_LOG and
ip6_LOG into xt_LOG");
- USB_LED: commit a335aaf3125c ("usb: misc: remove outdated USB LED
driver");
- MMC_UNSAFE_RESUME: commit 2501c9179dff ("mmc: core: Use
MMC_UNSAFE_RESUME as default behavior");
- AUTOFS_FS: commit 561c5cf9236a ("staging: Remove autofs3");
- VIDEO_OUTPUT_CONTROL: commit f167a64e9d67 ("video / output: Drop
display output class support");
- USB_LIBUSUAL: commit f61870ee6f8c ("usb: remove libusual");
- CRYPTO_ZLIB: 110492183c4b ("crypto: compress - remove unused pcomp
interface");
- BLK_DEV_UB: commit 68a5059ecf82 ("block: remove the deprecated ub
driver");
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: bcm-kernel-feedback-list@broadcom.com
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/16342/
Because of the removal of the scsi_tgt kernel module, the kbuild variables
CONFIG_SCSI_TGT, CONFIG_SCSI_SRP_TGT_ATTRS and CONFIG_SCSI_FC_TGT_ATTRS
are obsolete. This patch removes these variables. This patch is the result
of the following command:
find -name '*defconfig' | while read f; do grep -vwE 'CONFIG_SCSI_TGT|CONFIG_SCSI_SRP_TGT_ATTRS|CONFIG_SCSI_FC_TGT_ATTRS|CONFIG_SRP' $f >/tmp/t && mv /tmp/t $f; done
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
It no longer occurs in Kconfig.
USB: remove CONFIG_USB_DEVICEFS(fb28d58b) leaked remove defconfig.
Signed-off-by: Naoki MATSUMOTO <nekomatu+linux@gmail.com>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
Use the defconfig files generated by "make savedefconfig" for
remaining defconfig files.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Currently, MIPS kernels silently overwrite kernel command-line parameters
hardcoded in CONFIG_CMDLINE by the ones received from firmware. Therefore,
using firmware remains the only reliable method to transfer the
command-line parameters, which is not always desirable or convenient, and
the CONFIG_CMDLINE option is thereby effectively rendered useless.
This patch fixes the problem described above and introduces a more flexible
scheme of handling the kernel command line, in a manner identical to what is
currently used for x86. The default behavior, i.e. when CONFIG_CMDLINE_BOOL
is not defined, retains the existing semantics, and firmware command-line
arguments override the hardcoded ones.
[Ralf: I fixed up all the defconfig files so the stay unaffected by this
change.]
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com>
Patchwork: http://patchwork.linux-mips.org/patch/689/
The platform has never been fully merged
Cc: Thomas Koeller <thomas.koeller@baslerweb.com>
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: linux-mtd@lists.infradead.org
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
These boards need cca setup on CMDLINE.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
The Qemu platform was originally implemented to have an easily supportable
platform until Qemu reaches a state where it emulates a real world system.
Since the latest release Qemu is capable of emulating the MIPSsim and
Malta platforms, so this goal has been reached. The Qemu plaform is also
rather underfeatured so less useful than a Malta emulation.
According to Broadcom the PT systems are production test systems which
never reached customers so no need to keep the fragmentary support we
currently have.
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
delete mode 100644 arch/mips/configs/ocelot_c_defconfig
delete mode 100644 arch/mips/momentum/ocelot_c/Makefile
delete mode 100644 arch/mips/momentum/ocelot_c/cpci-irq.c
delete mode 100644 arch/mips/momentum/ocelot_c/dbg_io.c
delete mode 100644 arch/mips/momentum/ocelot_c/irq.c
delete mode 100644 arch/mips/momentum/ocelot_c/ocelot_c_fpga.h
delete mode 100644 arch/mips/momentum/ocelot_c/platform.c
delete mode 100644 arch/mips/momentum/ocelot_c/prom.c
delete mode 100644 arch/mips/momentum/ocelot_c/reset.c
delete mode 100644 arch/mips/momentum/ocelot_c/setup.c
delete mode 100644 arch/mips/momentum/ocelot_c/uart-irq.c
delete mode 100644 arch/mips/pci/fixup-ocelot-c.c
delete mode 100644 arch/mips/pci/pci-ocelot-c.c
A defconfig file and the 10 lines of code (including comments ...) that
are rotting since lmo commit 6516a42dc8b40c6c00010346dd51496125b16644
don't quite make proper support, so let's trash it.
This patch adds trivial support for SMARTMIPS extension. This extension
is currently implemented by 4KS[CD] CPUs.
Basically it saves/restores ACX register, which is part of the SMARTMIPS
ASE, when needed. This patch does *not* add any support for Smartmips MMU
features.
Futhermore this patch does not add explicit support for 4KS[CD] CPUs since
they are respectively mips32 and mips32r2 compliant. So with the current
processor configuration, a platform that has such CPUs needs to select
both configs:
CPU_HAS_SMARTMIPS
SYS_HAS_CPU_MIPS32_R[12]
This is due to the processor configuration which is mixing up all the
architecture variants and the processor types.
The drawback of this, is that we currently pass '-march=mips32' option to
gcc when building a kernel instead of '-march=4ksc' for 4KSC case. This
can lead to a kernel image a little bit bigger than required.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Add those lines to all defconfigs.
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
This is a patch againt linux-mips.org git tree.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Make HZ configurable. DECSTATION can select 128/256/1024 HZ, JAZZ can
only select 100 HZ, others can select 100/128/250/256/1000/1024 HZ if
not explicitly specified). Also remove all mach-xxx/param.h files and
update all defconfigs according to current HZ value.
As warned several times before.
Fix the MIPS coherency configuration such that we always keep the mapping
state in <asm/pci.h> when we need to on non-coherent platforms.
Start cleaning 32-bit vs. 64-bit configuration.
infrastructure for it.
Let it rip!
