path: root/arch/mips/configs/tb0226_defconfig
2008-07-15[MIPS] SEAD: Remove support code.Ralf Baechle
2008-07-15[MIPS] Atlas: Remove support code.Ralf Baechle
2008-06-16[MIPS] TANBAC: Update defconfigYoichi Yuasa
These boards need cca setup on CMDLINE. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Qemu: Remove platform.Ralf Baechle
The Qemu platform was originally implemented to have an easily supportable platform until Qemu reaches a state where it emulates a real world system. Since the latest release Qemu is capable of emulating the MIPSsim and Malta platforms, so this goal has been reached. The Qemu plaform is also rather underfeatured so less useful than a Malta emulation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Remove CONFIG_SIBYTE_PT{1120,1125,SWARM}Ralf Baechle
According to Broadcom the PT systems are production test systems which never reached customers so no need to keep the fragmentary support we currently have. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Update tb0226_defconfigYoichi Yuasa
2007-07-31[MIPS] DDB5477: Remove supportYoichi Yuasa
2007-07-31[MIPS] Remove Momentum Ocelot support.Ralf Baechle
2007-07-10[MIPS] Delete Ocelot 3 support.Ralf Baechle
2007-07-10[MIPS] remove LASAT Networks platforms supportYoichi Yuasa
2007-07-10[MIPS] Remove Momenco Ocelot C supportFranck Bui-Huu
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> delete mode 100644 arch/mips/configs/ocelot_c_defconfig delete mode 100644 arch/mips/momentum/ocelot_c/Makefile delete mode 100644 arch/mips/momentum/ocelot_c/cpci-irq.c delete mode 100644 arch/mips/momentum/ocelot_c/dbg_io.c delete mode 100644 arch/mips/momentum/ocelot_c/irq.c delete mode 100644 arch/mips/momentum/ocelot_c/ocelot_c_fpga.h delete mode 100644 arch/mips/momentum/ocelot_c/platform.c delete mode 100644 arch/mips/momentum/ocelot_c/prom.c delete mode 100644 arch/mips/momentum/ocelot_c/reset.c delete mode 100644 arch/mips/momentum/ocelot_c/setup.c delete mode 100644 arch/mips/momentum/ocelot_c/uart-irq.c delete mode 100644 arch/mips/pci/fixup-ocelot-c.c delete mode 100644 arch/mips/pci/pci-ocelot-c.c
2007-07-10[MIPS] EV64120: Remove supportYoichi Yuasa
2007-03-13[MIPS] Viper2: Remove defective support.Ralf Baechle
A defconfig file and the 10 lines of code (including comments ...) that are rotting since lmo commit 6516a42dc8b40c6c00010346dd51496125b16644 don't quite make proper support, so let's trash it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-22[MIPS] Add basic SMARTMIPS ASE supportFranck Bui-Huu
This patch adds trivial support for SMARTMIPS extension. This extension is currently implemented by 4KS[CD] CPUs. Basically it saves/restores ACX register, which is part of the SMARTMIPS ASE, when needed. This patch does *not* add any support for Smartmips MMU features. Futhermore this patch does not add explicit support for 4KS[CD] CPUs since they are respectively mips32 and mips32r2 compliant. So with the current processor configuration, a platform that has such CPUs needs to select both configs: CPU_HAS_SMARTMIPS SYS_HAS_CPU_MIPS32_R[12] This is due to the processor configuration which is mixing up all the architecture variants and the processor types. The drawback of this, is that we currently pass '-march=mips32' option to gcc when building a kernel instead of '-march=4ksc' for 4KSC case. This can lead to a kernel image a little bit bigger than required. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-18[MIPS] Update defconfigsRalf Baechle
2006-12-09[MIPS] Rename SNI_RM200_PCI to just SNI_RM preparing for more RM machinesThomas Bogendoerfer
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-01[MIPS] lockdep: update defconfigsAtsushi Nemoto
Add those lines to all defconfigs. CONFIG_LOCKDEP_SUPPORT=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y This is a patch againt linux-mips.org git tree. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Remove EV96100 as previously announced.Ralf Baechle
2006-07-13[MIPS] Update defconfigs to 2.6.18-rc1.Ralf Baechle
2006-06-19[MIPS] Make timer interrupt frequency configurable from kconfig.Atsushi Nemoto
Make HZ configurable. DECSTATION can select 128/256/1024 HZ, JAZZ can only select 100 HZ, others can select 100/128/250/256/1000/1024 HZ if not explicitly specified). Also remove all mach-xxx/param.h files and update all defconfigs according to current HZ value. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove support for NEC DDB5476.Ralf Baechle
As warned several times before. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Remove support for NEC DDB5074.Ralf Baechle
2006-04-27[MIPS] Update MIPS defconfigs.Ralf Baechle
2006-03-21[MIPS] Update defconfigs.Ralf Baechle
2005-12-01[MIPS] Update defconfigs to reflect Kconfig changes.Ralf Baechle
2005-11-17[MIPS] Update defconfigsRalf Baechle
2005-10-29Update MIPS defconfig files.Ralf Baechle
2005-09-05[PATCH] mips: fix coherency configurationRalf Baechle
Fix the MIPS coherency configuration such that we always keep the mapping state in <asm/pci.h> when we need to on non-coherent platforms. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
