path: root/arch/mips/configs
2011-05-26cgroup: remove the ns_cgroupDaniel Lezcano
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and leads to some problems: * cgroup creation is out-of-control * cgroup name can conflict when pids are looping * it is not possible to have a single process handling a lot of namespaces without falling in a exponential creation time * we may want to create a namespace without creating a cgroup The ns_cgroup was replaced by a compatibility flag 'clone_children', where a newly created cgroup will copy the parent cgroup values. The userspace has to manually create a cgroup and add a task to the 'tasks' file. This patch removes the ns_cgroup as suggested in the following thread: https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html The 'cgroup_clone' function is removed because it is no longer used. This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a printk warning users that the feature is planned for removal. Since that time we have heard from XXX users who were affected by this. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Jamal Hadi Salim <hadi@cyberus.ca> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19MIPS: Fix build warnings on defconfigsWanlong Gao
Since d45dcef77019012fc6769e657fc2f1a5d681bbbb ["Bluetooth: Fix BT_L2CAP and BT_SCO in Kconfig"] BT_L2CAP=m and BT_SCO=m are no longer valid so change the settings from m to y. [ralf@linux-mips.org: Merging only the MIPS parts of this patch.] Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> To: akpm@linux-foundation.org To: manuel.lauss@googlemail.com Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linuxppc-dev@lists.ozlabs.org Patchwork: https://patchwork.linux-mips.org/patch/2277/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lemote 2F, Malta: Fix build warningWanlong Gao
Since 5ada28bf76752e33dce3d807bf0dfbe6d1b943ad ["led-class: always implement blinking"] LEDS_CLASS=m is no longer valid so change the setting from m to y. Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> To: david.woodhouse@intel.com To: akpm@linux-foundation.org To: mingo@elte.hu Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2276/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Add default configuration for XLR/XLS processorsJayachandran C
Enable XLR CPU support, SMP, initramfs based root filesystem etc. [ralf@linux-mips.org: shrink the defconfig file through make savedefconfig.] Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2338/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-18MIPS: Malta: enable Cirrus FB consoleAurelien Jarno
While most users of a physical Malta board are using the serial port as the console, a lot of QEMU users would prefer to interact with a graphical console. Enable the Cirrus FB support in the Malta default configuration to make that possible. Note that the default console will still be the serial port, users have to pass "console=tty0" to the kernel to use the Cirrus FB. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2001/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-05MIPS: Alchemy: Add basic support for the GPR boardWolfgang Grandegger
From: Wolfgang Grandegger <wg@denx.de> Add basic support for the General Purpose Router (GPR) board from Trapeze ITS. Signed-off-by: Wolfgang Grandegger <wg@denx.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1460/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Alchemy: remove SOC_AU1X00 in favor of MIPS_ALCHEMYManuel Lauss
Remove the CONFIG_SOC_AU1X00 Kconfig symbol since its job can also be done by MACH_ALCHEMY, now renamed to MIPS_ALCHEMY. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1461/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: PowerTV: Simplify command line handling and needed config changesDavid VomLehn
Additional changes to Youichi Yuasa's command line simplication code The PowerTV platform uses a non-standard way to get the kernel command line--we insert a built-in command line into arcs_cmdline and to get additional command line information from the bootloader via a pointer in the a1 register. It is necessary to insert a space between to the two strings or the last argument from arcs_cmdline and the first argument from the bootloader may be inadvertantly combined. It is also necessary to set CONFIG_CMDLINE_BOOL to "y" and to set the default command line to an empty string to get the simplified code to work properly in the PowerTV environment. Signed-off-by: David VomLehn <dvomlehn@cisco.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1438/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-21MIPS: MTX-1: Update defconfigFlorian Fainelli
Updates the 4G Systems MTX-1 defconfig, and remove systems unavailable on this platform. Changes include: - built-in MTD char/block support - GPIO sysfs support - MTX-1 watchdog driver - I2C over GPIO driver as a module - SquashFS support Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1168/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-21MIPS: BCM47xx: Update defconfigFlorian Fainelli
Update Broadcom BCM47xx defconfig with: - tiny RCU - BCM47xx watchdog driver - b43/b43legacy wireless as modules - SSB Gigabit Ethernet driver - disabled IRDA 6igned-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1167/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-21MIPS: RB532: Update defconfigFlorian Fainelli
This updates the Mikrotik RB532 defconfig with: - tiny RCU - RB532 input buttons driver - RB532 LED driver - RC32434 watchdog driver - GPIO sysfs support - Wireless support - SquashFS support - more LED triggers Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1166/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-21MIPS: AR7: Update defconfigFlorian Fainelli
Update Texas Instruments AR7 defconfig with: - tiny RCU - LEDs GPIO - disable SSB - enable zboot support - enable GPIO sysfs support Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1165/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-30MIPS: BCM63xx: Update defconfigFlorian Fainelli
the defconfig was out-of-sync since 2.6.30-rc6, update it with the new symbols and enable BCM6338, 6345, wireless, b43 driver and LEDs support. Signed-off-by: Fainelli <ffainelli@freebox.fr> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1081/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-12MIPS: Big Sur: Make defconfig more useful.Ralf Baechle
2010-02-27MIPS: Alchemy: defconfig updatesManuel Lauss
Updated, leaner defconfig for the alchemy development boards. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1005/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Loongson: Lemote-2F: update defconfigWu Zhangjin
Changes: o Serial port related configuration Disable EARLY_PRINTK, CONFIG_SYS_SUPPORTS_ZBOOT_UART16550 Enable the serial port support as module. o PM related support Enable CPUFreq as module, use the external timer(MFGPT) instead of r4k timer. Enable Suspend support Enable Run Time PM support o Enable SM7XX Video Driver Disable the buggy 2d acceleration o Enable CONFIG_OPROFILE as module o Use GZIP instead of LZMA, which need less decompression time o Enable more USB devices support o Enable initrd support(needed by gNewsense) o Enable more crypto support Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: linux-mips@linux-mips.org Cc: yanh@lemote.com Cc: huhb@lemote.com Cc: zhangfx@lemote.com Patchwork: http://patchwork.linux-mips.org/patch/830/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Alchemy: DB1200 defconfig updateManuel Lauss
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-10MIPS: IP27: Make defconfig useful again.Ralf Baechle
RTC support was rewritten but the defconfig files were not updated. Enable IPv6 support which for some folks already is a must have. Assign useful values to other new options. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Fix and enhance built-in kernel command lineDmitri Vorobiev
Currently, MIPS kernels silently overwrite kernel command-line parameters hardcoded in CONFIG_CMDLINE by the ones received from firmware. Therefore, using firmware remains the only reliable method to transfer the command-line parameters, which is not always desirable or convenient, and the CONFIG_CMDLINE option is thereby effectively rendered useless. This patch fixes the problem described above and introduces a more flexible scheme of handling the kernel command line, in a manner identical to what is currently used for x86. The default behavior, i.e. when CONFIG_CMDLINE_BOOL is not defined, retains the existing semantics, and firmware command-line arguments override the hardcoded ones. [Ralf: I fixed up all the defconfig files so the stay unaffected by this change.] Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/689/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: eXcite: Remove platform.Ralf Baechle
The platform has never been fully merged Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Thomas Koeller <thomas.koeller@baslerweb.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: linux-kernel@vger.kernel.org Cc: linux-mtd@lists.infradead.org Acked-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Wim Van Sebroeck <wim@iguana.be>
2009-12-17MIPS: PowerTV: Base files for Cisco PowerTV platformDavid VomLehn
Add the Cisco Powertv cable settop box to the MIPS tree. This platform is based on a MIPS 24Kc processor with various devices integrated on the same ASIC. There are multiple models of this box, with differing configuration but the same kernel runs across the product line. Signed-off-by: David VomLehn <dvomlehn@cisco.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/132/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Lemote 2F: Add defconfig fileWu Zhangjin
Add default config file for Lemote Loongson 2F family machines. The resulting kernel image can be shared between Fuloong 2F, Yeeloong 2F and other Lemote Loongson 2F family machines. If you are using an old PMON, and not using a 2f box, please add a new command line argument in the boot.cfg. For example, add this argument for 8.9inches notebook: machtype=lemote-yeeloong-2f-8.9inches or machtype=8.9 More information from arch/mips/loongson/common/machtype.c. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: zhangfx@lemote.com Cc: yanh@lemote.com Cc: huhb@lemote.com Cc: Nicholas Mc Guire <hofrat@hofr.at> Cc: Arnaud Patard <apatard@mandriva.com> Cc: loongson-dev@googlegroups.com Cc: linux-mips@linux-mips.org Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Remove addinitrd and CONFIG_PROBE_INITRD_HEADERRalf Baechle
Addinitrd has been superseded by initramfs ages ago. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Fuloong 2E: Update defconfig fileWu Zhangjin
Enable hibernation support by default. Also enable sparsemem to avoid the hibernation failures with flatmem and save memory wasted by flatmem. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Cc: yanh@lemote.com Cc: huhb@lemote.com Cc: Zhang Le <r0bertz@gentoo.org> Cc: zhangfx@lemote.com Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-11-13MIPS: TXx9: Update rbtx49xx_defconfigAtsushi Nemoto
Enable following features: * MTD (RBTX4939, NAND_TXX9NDFMC) * HW_RANDOM (HW_RANDOM_TX4939) * SOUND (SND_SOC_TXX9ACLC) * DMADEVICE (TXX9_DMAC) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: BCM63xx: Add support for the Broadcom BCM63xx family of SOCs.Maxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Get rid of CONFIG_CPU_HAS_LLSCRalf Baechle
CONFIG_CPU_HAS_LLSC duplicated the function of cpu_has_llsc for no good reason and and the results if the one was enabled and the other disabled was very unobvious. Remove it now that there are no more remaining users. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Update the default config file for fuloong2eWu Zhangjin
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: Add support for Texas Instruments AR7 System-on-a-ChipFlorian Fainelli
This patch adds support for the Texas Instruments AR7 System-on-a-Chip. It supports the TNETD7100, 7200 and 7300 versions of the SoC. Signed-off-by: Matteo Croce <matteo@openwrt.org> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Eugene Konev <ejka@openwrt.org> Signed-off-by: Nicolas Thill <nico@openwrt.org> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-15i2c/chips: Move max6875 to drivers/misc/eepromWolfram Sang
This driver only reads the user EEPROM of that chip, so we can move it to the eeprom-directory in order to further clean up (and later remove) drivers/i2c/chips. The Kconfig text was updated to match the current functionality, dropping the meanwhile obsoleted parts. Defconfigs have been adapted. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Ben Gardner <gardner.ben@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-03-13MIPS: Mark Eins: Fix configuration.Ralf Baechle
2009-03-11MIPS: IP27: Enable RAID5 moduleRalf Baechle
2009-03-11MIPS: TXx9: update defconfigsAtsushi Nemoto
Enable following features: * MTD (PHYSMAP) * LED (LEDS_GPIO) * RBTX4939 * 7SEGLED * IDE (IDE_TX4938, IDE_TX4939) * SMC91X * RTC_DRV_TX4939 Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: IP27: Switch from DMA_IP27 to DMA_COHERENTRalf Baechle
The special IP27 DMA code selected by DMA_IP27 has been removed a while ago turning DMA_IP27 into almost a nop. Also fixup the broken logic of its last users memcpy.S and memcpy-inatomic.s. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2009-01-11MIPS: Add defconfig for Cavium OCTEON.David Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-12MIPS: IP32: Update defconfigDavid Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-04MIPS: IP22, Fulong, Malta: Update defconfigs.Ralf Baechle
These haven't seen much attention for too long but particularly important enable RTC_CLASS and CONFIG_RTC_HCTOSYS so the wall clock time is set on kernel startup. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-04MIPS: Malta: Add back RTC supportTiejun Chen
With the conversion of MIPS to RTC_LIB the old RTC driver CONFIG_RTC became unselectable. Fix by setting up a platform device. Also enable RTC_CLASS so system time gets set from RTC on kernel initialization. [Ralf: Original patch by Tiejun; polished nice and shiny by me] Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-30CHAR: Delete old and now unused M48T35 RTC driver for SGI IP27.Ralf Baechle
It was only used by this one SGI platform which recently was converted to RTC_LIB and with RTC_LIB enabled the legacy drivers are no more selectable. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-30CHAR: Delete old and now unused DS1286 driver.Ralf Baechle
It was only used by two SGI platforms which recently were converted to RTC_LIB and with RTC_LIB enabled the legacy drivers are no more selectable. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
2008-10-27MIPS: Add support for NXP PNX833x (STB222/5) into linux kernelDaniel Laird
The following patch add support for the NXP PNX833x SOC. More specifically it adds support for the STB222/5 variant. It fixes the vectored interrupt issue. Signed-off-by: daniel.j.laird <daniel.j.laird@nxp.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-30[MIPS] Cobalt: update defconfigYoichi Yuasa
Select new LCD framebuffer driver. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-30[MIPS] kgdb: Remove existing implementationJason Wessel
This patch explicitly removes the kgdb implementation, for mips which is intended to be followed by a patch that adds a kgdb implementation for MIPS that makes use of the kgdb core in the kernel. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-20[MIPS] Routerboard 532: Support for base systemRalf Baechle
Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] TXx9: Update and merge defconfigsAtsushi Nemoto
Merge rbhma4200(RBTX4927/37) and rbhma4500(RBTX4938) defconfig into single rbtx49xx defconfig. And jmr3927 defconfig is also updated. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] TXx9: Update defconfigsAtsushi Nemoto
2008-07-15[MIPS] Remove always true ifdef conditions.Ralf Baechle
