path: root/arch/mips/emma2rh/markeins/setup.c
2008-10-27MIPS: EMMA: Move arch/mips/emma2rh/ into arch/mips/emma/Shinya Kuribayashi
git mv arch/mips/{emma2rh,emma} and fixups Makefiles. We'll put all NEC EMMA series based machines there in the future. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-08-26[MIPS] emma2rh: Fix build error by header file inclusion weeding.Ralf Baechle
CC arch/mips/emma2rh/markeins/setup.o In file included from arch/mips/emma2rh/markeins/setup.c:30: include/linux/ide.h:645: error: ‘CONFIG_IDE_MAX_HWIFS’ undeclared here (not in a function) make[1]: *** [arch/mips/emma2rh/markeins/setup.o] Error 1 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-08-05remove unneeded #include <linux/ide.h>'sAdrian Bunk
This patch remove unneeded #include <linux/ide.h>'s. It also adds a required #include <linux/interrupt.h> that was previously implicitely pulled by ide.h Signed-off-by: Adrian Bunk <bunk@kernel.org> [bart: revert change to tests/lkdtm.c (spotted by Stephen Rothwell)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-30[MIPS] kgdb: Remove existing implementationJason Wessel
This patch explicitly removes the kgdb implementation, for mips which is intended to be followed by a patch that adds a kgdb implementation for MIPS that makes use of the kgdb core in the kernel. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] markeins: build fixAdrian Bunk
This patch fixes the following build errror caused by commit 7dffa3c673fbcf835cd7be80bb4aec8ad3f51168 (ntp: handle leap second via timer): <-- snip --> ... CC arch/mips/emma2rh/markeins/setup.o /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/mips/emma2rh/markeins/setup.c:79: error: conflicting types for 'clock' /home/bunk/linux/kernel-2.6/git/linux-2.6/include/linux/clocksource.h:96: error: previous declaration of 'clock' was here make[2]: *** [arch/mips/emma2rh/markeins/setup.o] Error 1 <-- snip --> [Ralf: reformated to 80 colums after the fix and marked emma2rh_clock as __initdata] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-19[MIPS] Kill duplicated setup_irq() for cp0 timerAtsushi Nemoto
Also many plat_timer_setup() can be killed too. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-06-06[MIPS] EMMA2RH: remove dead KGDB codeSergei Shtylyov
Get rid of the cross-arch KGDB specific code which shouldn't have been there in the first place... Signed-off-by: Sergey Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] Don't include obsolete <linux/config.h>.Ralf Baechle
2006-06-19[MIPS] Support for the R5500-based NEC EMMA2RH Mark-eins boarddmitry pervushin
Signed-off-by: dmitry pervushin <dpervushin@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
