path: root/arch/mips/gt64120/wrppmc/setup.c
2008-07-15[MIPS] remove wrppmc_machine_power_off()Yoichi Yuasa
It can be replace wrppmc_machine_halt(). Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] remove unused mips_machtypeYoichi Yuasa
Removed unused mips_machtype. These are only set but not used. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] WRPPMC serial support move to platform deviceYoichi Yuasa
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-18serial: add early_serial_setup() back to header fileYinghai Lu
early_serial_setup was removed from serial.h, but forgot to put in serial_8250.h Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[MIPS] WRPPMC: Fix build.Ralf Baechle
Using another systems defines is a safe way to get your code broken by accident when that system is removed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] Don't include obsolete <linux/config.h>.Ralf Baechle
2006-06-29[MIPS] Fix the build error of Wind River PPMC board, rewrite irq code to CMark.Zhan
o Fix the build error Wind River PPMC board caused by the change of plat_setup hook interface. o Rewrite first level interrupt dispatch code to C. Signed-off-by: Rongkai.Zhan <rongkai.zhan@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Wind River 4KC PPMC Eval Board SupportMark.Zhan
Support for the GT-64120-based Wind River 4KC PPMC Evaluation board. Signed-off-by: Rongkai.Zhan <Rongkai.zhan@windriver.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
