Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (25 commits)
MIPS: Use GCC __builtin_prefetch() to implement prefetch().
MIPS: Octeon: Serial port fixes for OCTEON simulator.
MIPS: Octeon: Get rid of early serial.
MIPS: AR7: prevent race between clock initialization and devices registration
MIPS: AR7: use ar7_has_high_vlynq() to determine watchdog base address
MIPS: BCM63xx: Avoid namespace clash on GPIO_DIR_{IN,OUT}
MIPS: MTX-1: Update defconfig
MIPS: BCM47xx: Update defconfig
MIPS: RB532: Update defconfig
MIPS: AR7: Update defconfig
RTC: rtc-cmos: Fix binary mode support
MIPS: Oprofile: Loongson: Cleanup the comments
MIPS: Oprofile: Loongson: Cleanup of the macros
MIPS: Oprofile: Loongson: Remove unused variable from loongson2_cpu_setup()
MIPS: Oprofile: Loongson: Remove useless parentheses
MIPS: Oprofile: Loongson: Unify macro for setting events
MIPS: nofpu and nodsp only affect CPU0
MIPS: Clean up tables for bootmem allocation
MIPS: Coding style cleanups of access of FCSR rounding mode bits
MIPS: Loongson 2F: Add gpio/gpioilb support
GCC's __builtin_prefetch() was introduced a long time ago, all
supported GCC versions have it. Lets do what the big boys up in
linux/prefetch.h do, except we use '1' as the third parameter to
provoke 'PREF 0,...' and 'PREF 1,...' instead of other prefetch
hints.
This allows for better code generation. In theory the existing
embedded asm could be optimized, but the compiler has these builtins,
so there is really no point.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
To: linux-mips@linux-mips.org
Patchwork: http://patchwork.linux-mips.org/patch/1235/
This is too generic a name, so prefix it with BCM63XX_ to avoid potential
namespace clashes when including <asm/gpio.h>.
Signed-off-by: Florian Fainelli <ffainelli@freebox.fr>
Patchwork: http://patchwork.linux-mips.org/patch/1171/
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
Patchwork: http://patchwork.linux-mips.org/patch/1163/
Add a sysdev for DBDMA PM.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
To: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: http://patchwork.linux-mips.org/patch/1119/
Use a sysdev to implement PM methods for the Au1000 interrupt controllers.
Patchwork: http://patchwork.linux-mips.org/patch/1114/
Loongson doesn't support MIPSR2, therefore, MIPSR2 vectored interrupts
(cpu_has_vint) and MIPSR2 external interrupt controller mode
(cpu_has_veic) are 0.
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: http://patchwork.linux-mips.org/patch/1112/
The only way the debugger can handle a trap in inside rcu_lock,
notify_die, or atomic_notifier_call_chain without a recursive fault is
to have a low level "first opportunity handler" do_trap_or_bp() handler.
Generally this will be something the vast majority of folks will not
need, but for those who need it, it is added as a kernel .config
option called KGDB_LOW_LEVEL_TRAP.
Also added was a die notification for oops such that kdb can catch an
oops for analysis.
There appeared to be no obvious way to pass the struct pt_regs from
the original exception back to the stack back tracer, so a special
case was added to show_stack() for when kdb is active because you
generally desire to generally look at the back trace of the original
exception.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep: Reduce stack_trace usage
lockdep: No need to disable preemption in debug atomic ops
lockdep: Actually _dec_ in debug_atomic_dec
lockdep: Provide off case for redundant_hardirqs_on increment
lockdep: Simplify debug atomic ops
lockdep: Fix redundant_hardirqs_on incremented with irqs enabled
lockstat: Make lockstat counting per cpu
i8253: Convert i8253_lock to raw_spinlock
In preparation for removing volatile from the atomic_t definition, this
patch adds a volatile cast to all the atomic read functions.
In the FPU emulator code of the MIPS, the Cause bits of the FCSR register
are not currently writeable by the ctc1 instruction. In odd corner cases,
this can cause problems. For example, a case existed where a divide-by-zero
exception was generated by the FPU, and the signal handler attempted to
restore the FPU registers to their state before the exception occurred. In
this particular setup, writing the old value to the FCSR register would
cause another divide-by-zero exception to occur immediately. The solution
is to change the ctc1 instruction emulator code to allow the Cause bits of
the FCSR register to be writeable. This is the behaviour of the hardware
that the code is emulating.
This problem was found by Shane McDonald, but the credit for the fix goes
to Kevin Kissell. In Kevin's words:
I submit that the bug is indeed in that ctc_op: case of the emulator. The
Cause bits (17:12) are supposed to be writable by that instruction, but the
CTC1 emulation won't let them be updated by the instruction. I think that
actually if you just completely removed lines 387-388 [...] things would
work a good deal better. At least, it would be a more accurate emulation of
the architecturally defined FPU. If I wanted to be really, really pedantic
(which I sometimes do), I'd also protect the reserved bits that aren't
necessarily writable.
Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com>
To: anemo@mba.ocn.ne.jp
To: kevink@paralogos.com
To: sshtylyov@mvista.com
Patchwork: http://patchwork.linux-mips.org/patch/1205/
Signed-off-by: Andreas Dilger <adilger@dilger.ca>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: linux-mips <linux-mips@linux-mips.org>
Patchwork: http://patchwork.linux-mips.org/patch/1106/
There's a typo in the LOONGSON_ADDRWIN_CFG macro. The cpu window mmap
register address should contain the destination parameters not the
source one. This has not been noticed because the code is only using
source = destination.
Patchwork: http://patchwork.linux-mips.org/patch/1162/
This allows us to clean up the code by not having to explicitly code
checks for shift amounts greater than 32.
Patchwork: http://patchwork.linux-mips.org/patch/1153/
The MIPS implementation of die() forgets to call notify_die() and thus notifiers
registered via register_die_notifier() are not called. This results in kgdb not
being activated on exceptions.
The only subtlety is that notify_die declares its regs argument w/o const, so
the const had to be removed from mips die() as well.
[Ralf: Fixed build error for SGI IP22 and IP28 platforms.]
Signed-off-by: Yury Polyanskiy <ypolyans@princeton.edu>
Cc: linux-mips@linux-mips.org
Patchworks: http://patchwork.linux-mips.org/patch/1142/
Acked-by: Jason Wessel <jason.wessel@windriver.com>
In the 64-bit kernel we use swapper_pg_dir for three different things.
1) xuseg mappings for kernel threads.
2) vmap mappings for all kernel-space accesses in xkseg.
3) vmap mappings for kernel modules in ksseg (kseg2).
Due to how the TLB refill handlers work, any mapping established in
xkseg or ksseg will also establish a xuseg mapping that should never
be used by the kernel.
In order to be able to use exceptions to trap NULL pointer
dereferences, we need to ensure that nothing is mapped at address
zero. Since vmap mappings in xkseg are reflected in xuseg, this means
we need to ensure that there are no vmap mappings established at the
start of xkseg. So we move back VMALLOC_START to avoid establishing
vmap mappings at the start of xkseg.
Patchwork: http://patchwork.linux-mips.org/patch/1129/
This is needed for the fix of the M3 workaround.
Previously it was unconditionally used on all Sibyte family SOCs. The
M3 bug has to be handled in the TLB exception handler which is extremly
performance sensitive, so this modification is expected to deliver around
2-3% performance improvment. This is important as required changes to the
M3 workaround will make it more costly.
Fix typo: CONFIG_BCMCPU_IS_63xx does not exist;
CONFIG_BCM63XX_CPU_63xx is the valid config option.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
Cc: Maxime Bizon <mbizon@freebox.fr>
Patchwork: http://patchwork.linux-mips.org/patch/901/
The BCm63xx SOC has two uarts. Some boards use the second one for
bluetooth. This patch changes platform device registration code to
handle this. Changes to the UART driver were already merged in
6a2c7eabfd09ca7986bf96b8958a87ca041a19d8.
Patchwork: http://patchwork.linux-mips.org/patch/900/
The number of GPIOs on BCM6338 is 8, while BCM6345 has only 16 GPIOs
available.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/1016/
As per chapter 15 "Errata: Issue of Out-of-order in loongson"[1] to work
around the Loongson 2F erratum we need to do:
"When switching from user mode to kernel mode, you should flush the
branch target history such as BTB and RAS."
[1] Chinese version: http://www.loongson.cn/uploadfile/file/200808211
[2] English version of chapter 15:
http://groups.google.com.hk/group/loongson-dev/msg/e0d2e220958f10a6?dmode=source
Cc: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
Patchwork: http://patchwork.linux-mips.org/patch/1066/
This is a follow on to the vdso patch.
Since all processes now have signal trampolines permanently mapped, we
can use those instead of putting the trampoline on the stack and
invalidating the corresponding icache across all CPUs. We also get rid
of a bunch of ICACHE_REFILLS_WORKAROUND_WAR code.
[Ralf: GDB 7.1 which has the necessary modifications to allow backtracing
over signal frames will supposedly be released tomorrow. The old signal
frame format obsoleted by this patch exists in two variations, for sane
processors and for those requiring ICACHE_REFILLS_WORKAROUND_WAR. So
there was never a GDB which did support backtracing over signal frames
on all MIPS systems. This convinved me this series should be applied and
pushed upstream as soon as possible.]
Patchwork: http://patchwork.linux-mips.org/patch/974/
This is a preliminary patch to add a vdso to all user processes. Still
missing are ELF headers and .eh_frame information. But it is enough to
allow us to move signal trampolines off of the stack. Note that emulation
of branch delay slots in the FPU emulator still requires the stack.
We allocate a single page (the vdso) and write all possible signal
trampolines into it. The stack is moved down by one page and the vdso is
mapped into this space.
Patchwork: http://patchwork.linux-mips.org/patch/975/
Patchwork: http://patchwork.linux-mips.org/patch/976/
On AR7, we already redefine PHYS_OFFSET to match the system specifities, it
is however not sufficient when unsing dma_{map,unmap}_single, specifically
in the ethernet driver, we must also adjust CAC_ADDR and UNCAC_ADDR for DMA
to work correctly. This patch fixes the following issue, seen in cpmac_open:
ops[#1]:
Cpu 0
$ 0 : 00000000 10008400 a0f5b120 00000000
$ 4 : 94c59000 94270f64 00000020 00000010
$ 8 : 00000010 94103ce0 0000000a 94c03400
$12 : ffffffff 94c03408 94c03410 00000001
$16 : a0f5ba20 00000041 94c592c0 94c59200
$20 : 94c59000 000005ee 00002000 9438c8f0
$24 : 00000010 00000000
$28 : 94fac000 94fadd58 94390000 942724a8
Hi : 00000000
Lo : 00000001
epc : 94272518 cpmac_open+0x208/0x3f8
Not tainted
ra : 942724a8 cpmac_open+0x198/0x3f8
Status: 10008403 KERNEL EXL IE
Cause : 3080000c
BadVA : 00000000
PrId : 00018448 (MIPS 4KEc)
Modules linked in:
Process ifconfig (pid: 278, threadinfo=94fac000, task=94e79590, tls=00000000)
Stack : 7f8da120 2ab05cb0 94c59000 943356f0 00000000 943d0000 94c59000 943356f0
94c59030 943d0000 943c27c0 94fade10 00000000 94fade20 94c59000 9428e5a4
00000000 94c59000 00000041 94289768 94c59000 00000041 00001002 00001043
00000000 9428d810 00000000 94fade10 7f8da4e8 9428e6b8 00000000 7f8da4a8
7f8da4e8 00008914 00000000 942f7f2c 00000000 00000008 00408000 00008913
Call Trace:
[<94272518>] cpmac_open+0x208/0x3f8
[<9428e5a4>] dev_open+0x164/0x264
[<9428d810>] dev_change_flags+0xd0/0x1bc
[<942f7f2c>] devinet_ioctl+0x2d8/0x908
[<942771f8>] sock_ioctl+0x29c/0x2fc
[<941a0fb4>] vfs_ioctl+0x2c/0x7c
[<941a16ec>] do_vfs_ioctl+0x5dc/0x630
[<941a1790>] sys_ioctl+0x50/0x88
[<94101e10>] stack_done+0x20/0x3c
Signed-off-by: peter fuerst <post@pfrst.de>
Patchwork: http://patchwork.linux-mips.org/patch/1050/
kernel/elfcore.c includes <linux/elf.h> which includes the <asm/elf.h>. In
<asm/elf.h>, struct pt_regs is declared inside the parameter list of the
elf_dump_regs function which causes a kernel build warning.
Fixed by adding a forward declaration of struct pt_regs.
Caused by 38b7827fcdd660f591d645bd3ae6644456a4773c - no, cpu_local_* was
not unused.
Acked-by: David Daney <ddaney@caviumnetworks.com>
All the architectures properly set NEED_DMA_MAP_STATE now so we can safely
add linux/pci-dma.h to linux/pci.h and remove the linux/pci-dma.h
inclusion in arch's asm/pci.h
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Add generic implementations of the old and really old uname system calls.
Note that sh only implements sys_olduname but not sys_oldolduname, but I'm
not going to bother with another ifdef for that special case.
m32r implemented an old uname but never wired it up, so kill it, too.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andreas Schwab <schwab@linux-m68k.org>
On an architecture that supports 32-bit compat we need to override the
reported machine in uname with the 32-bit value. Instead of doing this
separately in every architecture introduce a COMPAT_UTS_MACHINE define in
<asm/compat.h> and apply it directly in sys_newuname().
Add a generic implementation of the ipc demultiplexer syscall. Except for
s390 and sparc64 all implementations of the sys_ipc are nearly identical.
There are slight differences in the types of the parameters, where mips
and powerpc as the only 64-bit architectures with sys_ipc use unsigned
long for the "third" argument as it gets casted to a pointer later, while
it traditionally is an "int" like most other paramters. frv goes even
further and uses unsigned long for all parameters execept for "ptr" which
is a pointer type everywhere. The change from int to unsigned long for
"third" and back to "int" for the others on frv should be fine due to the
in-register calling conventions for syscalls (we already had a similar
issue with the generic sys_ptrace), but I'd prefer to have the arch
maintainers looks over this in details.
Except for that h8300, m68k and m68knommu lack an impplementation of the
semtimedop sub call which this patch adds, and various architectures have
gets used - at least on i386 it seems superflous as the compat code on
x86-64 and ia64 doesn't even bother to implement it.
[akpm@linux-foundation.org: add sys_ipc to sys_ni.c]
Reviewed-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: add __percpu sparse annotations to what's left
percpu: add __percpu sparse annotations to fs
percpu: add __percpu sparse annotations to core kernel subsystems
local_t: Remove leftover local.h
this_cpu: Remove pageset_notifier
this_cpu: Page allocator conversion
percpu, x86: Generic inc / dec percpu instructions
local_t: Move local.h include to ringbuffer.c and ring_buffer_benchmark.c
module: Use this_cpu_xx to dynamically allocate counters
local_t: Remove cpu_local_xx macros
percpu: refactor the code in pcpu_[de]populate_chunk()
percpu: remove compile warnings caused by __verify_pcpu_ptr()
percpu: make accessors check for percpu pointer in sparse
percpu: add __percpu for sparse.
percpu: make access macros universal
percpu: remove per_cpu__ prefix.
i8253_lock needs to be a real spinlock in preempt-rt, i.e. it can
not be converted to a sleeping lock.
Convert it to raw_spinlock and fix up all users.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Takashi Iwai <tiwai@suse.de>
Cc: Jens Axboe <jens.axboe@oracle.com>
LKML-Reference: <20100217163751.030764372@linutronix.de>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits)
ARM: Eliminate decompressor -Dstatic= PIC hack
ARM: 5958/1: ARM: U300: fix inverted clk round rate
ARM: 5956/1: misplaced parentheses
ARM: 5955/1: ep93xx: move timer defines into core.c and document
ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c
ARM: 5953/1: ep93xx: fix broken build of clock.c
ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig
ARM: 5949/1: NUC900 add gpio virtual memory map
ARM: 5948/1: Enable timer0 to time4 clock support for nuc910
ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk
ARM: make_coherent(): fix problems with highpte, part 2
MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself
ARM: 5945/1: ep93xx: include correct irq.h in core.c
ARM: 5933/1: amba-pl011: support hardware flow control
ARM: 5930/1: Add PKMAP area description to memory.txt.
ARM: 5929/1: Add checks to detect overlap of memory regions.
ARM: 5928/1: Change type of VMALLOC_END to unsigned long.
ARM: 5927/1: Make delimiters of DMA area globally visibly.
ARM: 5926/1: Add "Virtual kernel memory..." printout.
ARM: 5920/1: OMAP4: Enable L2 Cache
Fix up trivial conflict in arch/arm/mach-mx25/clock.c
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
Patchwork: http://patchwork.linux-mips.org/patch/979/
On Alchemy the PCMCIA area lies at the end of the chips 36bit system bus
area. Currently, addresses at the far end of the 32bit area are assumed
to belong to the PCMCIA area and fixed up to the real 36bit address before
being passed to ioremap().
A previous commit enabled 64 bit physical size for the resource datatype on
Alchemy and this allows to use the correct 36bit addresses when registering
the PCMCIA sockets.
This patch removes the 32-to-36bit address fixup and registers the Alchemy
demo board pcmcia socket with the correct 36bit physical addresses.
Tested on DB1200, with a CF card (ide-cs driver) and a 3c589 PCMCIA ethernet
card.
Cc: Manuel Lauss <manuel.lauss@gmail.com>
Patchwork: http://patchwork.linux-mips.org/patch/994/
The current locking mechanism uses a ll/sc sequence to release a
spinlock. This is slower than a wmb() followed by a store to unlock.
The branching forward to .subsection 2 on sc failure slows down the
contended case. So we get rid of that part too.
Since we are now working on naturally aligned u16 values, we can get
rid of a masking operation as the LHU already does the right thing.
The ANDI are reversed for better scheduling on multi-issue CPUs
On a 12 CPU 750MHz Octeon cn5750 this patch improves ipv4 UDP packet
forwarding rates from 3.58*10^6 PPS to 3.99*10^6 PPS, or about 11%.
Patchwork: http://patchwork.linux-mips.org/patch/937/
Patchwork: http://patchwork.linux-mips.org/patch/959/
Patchwork: http://patchwork.linux-mips.org/patch/960/
Patchwork: http://patchwork.linux-mips.org/patch/958/
Patchwork: http://patchwork.linux-mips.org/patch/957/
