In preparation for making the clockevents core NTP correction aware,
all clockevent device drivers must set ->min_delta_ticks and
->max_delta_ticks rather than ->min_delta_ns and ->max_delta_ns: a
clockevent device's rate is going to change dynamically and thus, the
ratio of ns to ticks ceases to stay invariant.
Make the MIPS arch's clockevent drivers initialize these fields properly.
This patch alone doesn't introduce any change in functionality as the
clockevents core still looks exclusively at the (untouched) ->min_delta_ns
and ->max_delta_ns. As soon as this has changed, a followup patch will
purge the initialization of ->min_delta_ns and ->max_delta_ns from these
drivers.
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Keguang Zhang <keguang.zhang@gmail.com>
Cc: John Crispin <john@phrozen.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
There is no point in having an extra type for extra confusion. u64 is
unambiguous.
Conversion was done with the following coccinelle script:
@rem@
-typedef u64 cycle_t;
@fix@
typedef cycle_t;
-cycle_t
+u64
Cc: John Stultz <john.stultz@linaro.org>
Migrate jz4740 driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Cc: linux-mips@linux-mips.org
Cc: linaro-kernel@lists.linaro.org
Patchwork: https://patchwork.linux-mips.org/patch/10601/
Support the Ingenic JZ4780 SoC using the existing code under
arch/mips/jz4740 now that it has been generalised sufficiently.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: devicetree@vger.kernel.org
Cc: Joshua Kinard <kumba@gentoo.org>
Cc: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Cc: Andreas Herrmann <andreas.herrmann@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/10164/
The jz4740-cgu driver already has access to the CGU, so it makes sense
to move the few remaining accesses to the CGU from arch/mips/jz4740
there too. Move the jz4740_clock_{suspend,resume} functions there for
such consistency. The arch/mips/jz4740/clock.c file now contains nothing
more of use & so is removed.
Cc: Mike Turquette <mturquette@linaro.org>
Cc: linux-clk@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/10158/
Migrate the JZ4740 & the qi_lb60 board to use common clock framework
via the new Ingenic SoC CGU driver. Note that the JZ4740-specific
debugfs code is removed since common clock framework provides its own
debug capabilities.
Co-authored-by: Paul Cercueil <paul@crapouillou.net>
Cc: Fabian Frederick <fabf@skynet.be>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Brian Norris <computersforpeace@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/10151/
Replace uses of the jz4740_clock_bdata struct with calls to clk_get_rate
for the appropriate clock. This is in preparation for migrating the
clocks towards common clock framework & devicetree.
Cc: Apelete Seketeli <apelete@seketeli.net>
Patchwork: https://patchwork.linux-mips.org/patch/10149/
Call jz4740_clock_init before any uses of jz4740_clock_bdata occur. This
is in preparation for replacing uses of that struct with calls to
clk_get_rate, which will allow the clocks to be migrated towards common
Patchwork: https://patchwork.linux-mips.org/patch/10148/
Use jz4740 timer counter for sched_clock source. This implementation will
give high resolution cputime accounting.
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Cc: macro@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/9485/
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
This is a prerequisite for allowing the PWM driver to be converted to
the PWM framework.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Tested-by: Lars-Peter Clausen <lars@metafoo.de>
* 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: convert mips to generic i8253 clocksource
clocksource: convert x86 to generic i8253 clocksource
clocksource: convert footbridge to generic i8253 clocksource
clocksource: add common i8253 PIT clocksource
blackfin: convert to clocksource_register_hz
mips: convert to clocksource_register_hz/khz
sparc: convert to clocksource_register_hz/khz
alpha: convert to clocksource_register_hz
microblaze: convert to clocksource_register_hz/khz
ia64: convert to clocksource_register_hz/khz
x86: Convert remaining x86 clocksources to clocksource_register_hz/khz
Make clocksource name const
The code for supporting one-shot mode for the clockevent is already there,
only the feature flag was not set. Setting the one-shot flag allows the
kernel to run in tickless mode.
Patchwork: https://patchwork.linux-mips.org/patch/2261/
This converts the mips clocksources to use clocksource_register_hz/khz
CC: Ralf Baechle <ralf@linux-mips.org>
CC: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Add clocksource and clockevent support for the timer/counter unit on
JZ4740 SoCs.
Patchwork: https://patchwork.linux-mips.org/patch/1397/
