path: root/arch/mips/kernel/asm-offsets.c
2010-08-05MIPS: Remove unused task_struct.trap_no field.David Daney
It is initialized to zero and only ever read. Remove it, and pass zero in its place. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1531/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Two-level pagetables for 64-bit kernels with 64KB pages.David Daney
For 64-bit kernels with 64KB pages and two level page tables, there are 42 bits worth of virtual address space This is larger than the 40 bits of virtual address space obtained with the default 4KB Page size and three levels, so there are no draw backs for using two level tables with this configuration. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/761/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Use PAGE_SIZE in assembly instead of _PAGE_SIZE.Nelson Elhage
Now that PAGE_SIZE is available to assembly directly, there is no need to separately expose it as _PAGE_SIZE through asm-offsets. In addition, remove _PAGE_SHIFT from asm-offsets, since it was never needed, and is not used anywhere. Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Add hibernation supportWu Zhangjin
[Ralf: SMP support requires CPU hotplugging which MIPS currently doesn't support. As implemented in this patch cache and tlb flushing will also be invoked with interrupts disabled so smp_call_function() will blow up in charming ways. So limit to !SMP.] Reviewed-by: Pavel Machek <pavel@ucw.cz> Reviewed-by: Yan Hua <yanh@lemote.com> Reviewed-by: Arnaud Patard <apatard@mandriva.com> Reviewed-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Hu Hongbing <huhb@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-11MIPS: Add Cavium OCTEON specific registers to ptrace.h and asm-offsets.cDavid Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-29mips: use kbuild.h instead of macros in asm-offsets.cChristoph Lameter
Use the macros provided in kbuild.h Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: standardize comment inclusion in asm-offsets.h and fix MIPSChristoph Lameter
Add the ability to pass comments into asm-offsets.h by generating asm output like -># comment line Mips needs this feature to preserve the comments that are in asm-mips/asm-offsets.h right now. Then remove the special handling for mips from Kbuild and convert mips to use the new string to include the comments. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-27[MIPS] Extract {PGD,PMD,PTE}_ORDER into asm-offset.hRalf Baechle
For debugging purposes only. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Fixup secure computing stuff.Ralf Baechle
2007-05-09rename thread_info to stackRoman Zippel
This finally renames the thread_info field in task structure to stack, so that the assumptions about this field are gone and archs have more freedom about placing the thread_info structure. Nonbroken archs which have a proper thread pointer can do the access to both current thread and task structure via a single pointer. It'll allow for a few more cleanups of the fork code, from which e.g. ia64 could benefit. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> [akpm@linux-foundation.org: build fix] Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Andi Kleen <ak@muc.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27[MIPS] Remove unused _THREAD_SIZE_ORDER from asm-offset.c.Ralf Baechle
2007-02-22[MIPS] Add basic SMARTMIPS ASE supportFranck Bui-Huu
This patch adds trivial support for SMARTMIPS extension. This extension is currently implemented by 4KS[CD] CPUs. Basically it saves/restores ACX register, which is part of the SMARTMIPS ASE, when needed. This patch does *not* add any support for Smartmips MMU features. Futhermore this patch does not add explicit support for 4KS[CD] CPUs since they are respectively mips32 and mips32r2 compliant. So with the current processor configuration, a platform that has such CPUs needs to select both configs: CPU_HAS_SMARTMIPS SYS_HAS_CPU_MIPS32_R[12] This is due to the processor configuration which is mixing up all the architecture variants and the processor types. The drawback of this, is that we currently pass '-march=mips32' option to gcc when building a kernel instead of '-march=4ksc' for 4KSC case. This can lead to a kernel image a little bit bigger than required. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-10[MIPS] signal32: no need to save c0_status register in setup_sigcontext32()Franck Bui-Huu
All the information in the MIPS c0_status register is priviledged. Nothing that would constitute part of the thread context. The one flag one could possibly argument about might be c0_status.fr but none of the ABIs or tools or application software can make use of it. So for consistency with restore_sigcontext32(), which does not restore c0_status register, this patch remove the saving part. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Move some kernel globals from asm file to C file.Atsushi Nemoto
This get rid of some undesirable hole in BSS section due to random order of placement. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-01[MIPS] 16K & 64K page size fixesRalf Baechle
Derived from Peter Watkins <treestem@gmail.com>'s work. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-06-19[MIPS] Unify mips_fpu_soft_struct and mips_fpu_hard_structs.Atsushi Nemoto
The struct mips_fpu_soft_struct and mips_fpu_hard_struct are completely same now and the kernel fpu emulator assumes that. This patch unifies them to mips_fpu_struct and get rid of mips_fpu_union. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] Update struct sigcontext member namesDaniel Jacobowitz
Rename the 64-bit sc_hi and sc_lo arrays to use the same names as the 32-bit struct sigcontext (sc_mdhi, sc_hi1, et cetera). Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] MT: Improved multithreading support.Ralf Baechle
2005-10-29Support the MIPS32 / MIPS64 DSP ASE.Ralf Baechle
2005-10-29NPTL, round one.Ralf Baechle
2005-09-11mips: rename offsets.c to asm-offsets.cSam Ravnborg
Cannot build MIPS now. We need to change offset.c to asm-offsets.c Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
