path: root/arch/mips/kernel/mips_ksyms.c
2007-03-07[MIPS] Export __copy_user_inatomic.Ralf Baechle
2007-01-08[MIPS] csum_partial and copy in parallelAtsushi Nemoto
Implement optimized asm version of csum_partial_copy_nocheck, csum_partial_copy_from_user and csum_and_copy_to_user which can do calculate and copy in parallel, based on memcpy.S. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] Sort out duplicate exports.Ralf Baechle
2006-04-11[PATCH] No arch-specific strpbrk implementationsKyle McMartin
While cleaning up parisc_ksyms.c earlier, I noticed that strpbrk wasn't being exported from lib/string.c. Investigating further, I noticed a changeset that removed its export and added it to _ksyms.c on a few more architectures. The justification was that "other arches do it." I think this is wrong, since no architecture currently defines __HAVE_ARCH_STRPBRK, there's no reason for any of them to be exporting it themselves. Therefore, consolidate the export to lib/string.c. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
