path: root/arch/mips/kernel/module-rela.c
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-09-28MIPS: Fix module.c build for 32 bitRalf Baechle
Fixes build failure introduced by "Make most arch asm/module.h files use asm-generic/module.h" by moving all the RELA processing code to a separate file to be used only for RELA processing on 64-bit kernels. CC arch/mips/kernel/module.o arch/mips/kernel/module.c:250:14: error: 'reloc_handlers_rela' defined but not used [-Werror=unused-variable] cc1: all warnings being treated as errors make[6]: *** [arch/mips/kernel/module.o] Error 1 Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
