path: root/arch/mips/kernel/ptrace.c
2007-10-29[MIPS] Store sign-extend register values for PTRACE_GETREGSAtsushi Nemoto
A comment on ptrace_getregs() states "Registers are sign extended to fill the available space." but it is not true. Fix code to match the comment. Also fix casts on each caller to get rid of some warnings. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16Consolidate PTRACE_DETACHAlexey Dobriyan
Identical handlers of PTRACE_DETACH go into ptrace_request(). Not touching compat code. Not touching archs that don't call ptrace_request. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-07-31[MIPS] Fixup secure computing stuff.Ralf Baechle
2007-07-17PTRACE_POKEDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata() function. AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless return EPERM. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_PEEKDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_PEEKDATA go into generic_ptrace_peekdata() function. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-22[MIPS] Add basic SMARTMIPS ASE supportFranck Bui-Huu
This patch adds trivial support for SMARTMIPS extension. This extension is currently implemented by 4KS[CD] CPUs. Basically it saves/restores ACX register, which is part of the SMARTMIPS ASE, when needed. This patch does *not* add any support for Smartmips MMU features. Futhermore this patch does not add explicit support for 4KS[CD] CPUs since they are respectively mips32 and mips32r2 compliant. So with the current processor configuration, a platform that has such CPUs needs to select both configs: CPU_HAS_SMARTMIPS SYS_HAS_CPU_MIPS32_R[12] This is due to the processor configuration which is mixing up all the architecture variants and the processor types. The drawback of this, is that we currently pass '-march=mips32' option to gcc when building a kernel instead of '-march=4ksc' for 4KSC case. This can lead to a kernel image a little bit bigger than required. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Make sure cpu_has_fpu is used only in atomic contextAtsushi Nemoto
Make sure cpu_has_fpu (which uses smp_processor_id()) is used only in atomic context. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Unify mips_fpu_soft_struct and mips_fpu_hard_structs.Atsushi Nemoto
The struct mips_fpu_soft_struct and mips_fpu_hard_struct are completely same now and the kernel fpu emulator assumes that. This patch unifies them to mips_fpu_struct and get rid of mips_fpu_union. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-05-01[PATCH] drop task argument of audit_syscall_{entry,exit}Al Viro
... it's always current, and that's a good thing - allows simpler locking. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-04-19[MIPS] MT: Improved multithreading support.Ralf Baechle
2006-01-12[PATCH] mips: task_thread_info()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] mips: task_pt_regs()Al Viro
2006-01-10MIPS: DSP: eleminate used_dsp.Ralf Baechle
used_dsp was meant to be used like used_math - but since the FPU context is small and lazy context switching is a stupid idea on multiprocessors this idea only got halfway implemented and those bits are were now breaking ptrace. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] unify sys_ptrace prototypeChristoph Hellwig
Make sure we always return, as all syscalls should. Also move the common prototype to <linux/syscalls.h> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Protect manipulation of c0_status against preemption and multithreading.Ralf Baechle
2005-10-29Revise MIPS 64-bit ptrace interfaceDaniel Jacobowitz
Change the N32 debugging ABI to something more sane, and add support for o32 and n32 debuggers to trace n64 programs. Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Avoid defining variables in the middle of a block which breaks olderRalf Baechle
compilers. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Support the MIPS32 / MIPS64 DSP ASE.Ralf Baechle
2005-10-29Fix tasteless #ifdef mess in audit_arch(), minor cleanups.Ralf Baechle
2005-10-29NPTL, round one.Ralf Baechle
2005-10-29Sparseify MIPS.Ralf Baechle
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-03Merge with master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-29mips: warning fix audit_arch()Yoichi Yuasa
arch/mips/kernel/ptrace.c:305: warning: function declaration isn't a prototype Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-04-29[AUDIT] Don't allow ptrace to fool auditing, log arch of audited syscalls.
We were calling ptrace_notify() after auditing the syscall and arguments, but the debugger could have _changed_ them before the syscall was actually invoked. Reorder the calls to fix that. While we're touching ever call to audit_syscall_entry(), we also make it take an extra argument: the architecture of the syscall which was made, because some architectures allow more than one type of syscall. Also add an explicit success/failure flag to audit_syscall_exit(), for the benefit of architectures which return that in a condition register rather than only returning a single register. Change type of syscall return value to 'long' not 'int'. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-04-16[PATCH] mips: remove #include <linux/audit.h> two timesYoichi Yuasa
This patch removes #include <linux/audit.h>. Because it includes it two times. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
