path: root/arch/mips/kernel/smp.c
2009-06-24MIPS: Add arch generic CPU hotplugRalf Baechle
Each platform has to add support for CPU hotplugging itself by providing suitable definitions for the cpu_disable and cpu_die of the smp_ops methods and setting SYS_SUPPORTS_HOTPLUG_CPU. A platform should only set SYS_SUPPORTS_HOTPLUG_CPU once all it's smp_ops definitions have the necessary changes. This patch contains the changes to the dummy smp_ops definition for uni-processor systems. Parts of the code contributed by Cavium Inc. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30MIPS: Make a needlessly global symbol static in arch/mips/kernel/smp.cDmitri Vorobiev
The variable cpu_callin_map is needlessly defined global, so let's make it static now. Build-tested using malta_defconfig. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-12-13cpumask: centralize cpu_online_map and cpu_possible_mapRusty Russell
Impact: cleanup Each SMP arch defines these themselves. Move them to a central location. Twists: 1) Some archs (m32, parisc, s390) set possible_map to all 1, so we add a CONFIG_INIT_ALL_POSSIBLE for this rather than break them. 2) mips and sparc32 '#define cpu_possible_map phys_cpu_present_map'. Those archs simply have phys_cpu_present_map replaced everywhere. 3) Alpha defined cpu_possible_map to cpu_present_map; this is tricky so I just manipulate them both in sync. 4) IA64, cris and m32r have gratuitous 'extern cpumask_t cpu_possible_map' declarations. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Tested-by: Tony Luck <tony.luck@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Mike Travis <travis@sgi.com> Cc: ink@jurassic.park.msu.ru Cc: rmk@arm.linux.org.uk Cc: starvik@axis.com Cc: tony.luck@intel.com Cc: takata@linux-m32r.org Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: paulus@samba.org Cc: schwidefsky@de.ibm.com Cc: lethal@linux-sh.org Cc: wli@holomorphy.com Cc: davem@davemloft.net Cc: jdike@addtoit.com Cc: mingo@redhat.com
2008-10-30MIPS: SMP: Do not initialize __cpu_number_map/__cpu_logical_map for CPU 0.Ralf Baechle
A system isn't necessarily booted on physical processor 0 as this code assumes. Also the array happens to be allocated in .bss so it's zero initialized anyway. Systems which need to override this can do so in their mp_ops->smp_setup() method. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-27MIPS: SMP: Don't reenable interrupts in stop_this_cpu; use WAIT instruction.Ralf Baechle
Noticed by Anirban Sinha <ASinha@zeugmasystems.com>; patch by me. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-08kernel/cpu.c: create a CPU_STARTING cpu_chain notifierManfred Spraul
Right now, there is no notifier that is called on a new cpu, before the new cpu begins processing interrupts/softirqs. Various kernel function would need that notification, e.g. kvm works around by calling smp_call_function_single(), rcu polls cpu_online_map. The patch adds a CPU_STARTING notification. It also adds a helper function that sends the message to all cpu_chain handlers. Tested on x86-64. All other archs are untested. Especially on sparc, I'm not sure if I got it right. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-26smp_call_function: get rid of the unused nonatomic/retry argumentJens Axboe
It's never used and the comments refer to nonatomic and retry interchangably. So get rid of it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-26mips: convert to generic helpers for IPI function callsJens Axboe
This converts mips to use the new helpers for smp_call_function() and friends, and adds support for smp_call_function_single(). Not tested, but it compiles. mips shares the same IPI for smp_call_function() and smp_call_function_single(), since not all mips platforms have enough available IPIs to support seperate setups. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-16[MIPS] Export smp_call_function and smp_call_function_single.Zenon Fortuna
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] fix warning message on SMP kernelsThiemo Seufer
This patch fixes a (harmless) warning message. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Add support for MIPS CMP platform.Ralf Baechle
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-06calibrate_delay() must be __cpuinitAdrian Bunk
calibrate_delay() must be __cpuinit, not __{dev,}init. I've verified that this is correct for all users. While doing the latter, I also did the following cleanups: - remove pointless additional prototypes in C files - ensure all users #include <linux/delay.h> This fixes the following section mismatches with CONFIG_HOTPLUG=n, CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x1128d): Section mismatch: reference to .init.text.1:calibrate_delay (between 'check_cx686_slop' and 'set_cx86_reorder') WARNING: vmlinux.o(.text+0x25102): Section mismatch: reference to .init.text.1:calibrate_delay (between 'smp_callin' and 'cpu_coregroup_map') Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christian Zankel <chris@zankel.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-29[MIPS] SMP: Call platform methods via ops structure.Ralf Baechle
2008-01-29[MIPS] MT: Scheduler support for SMTRalf Baechle
2007-10-13[MIPS] SMP: Fix use of cpumasks.Ralf Baechle
Noticed by Nick Piggin <nickpiggin@yahoo.com.au>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] SMP: Use ISO C struct initializer for local structs.Ralf Baechle
2007-10-11[MIPS] SMP: Kill useless casts.Ralf Baechle
2007-10-11[MIPS] Kill num_online_cpus() loops.Ralf Baechle
2007-10-11[MIPS] SMP: Implement smp_call_function_mask().Ralf Baechle
2007-10-11[MIPS] Implement clockevents for R4000-style cp0 count/compare interruptRalf Baechle
2007-07-31[MIPS] Add smp_call_function_single()Peter Watkins
In the other archs, there is more factoring of smp call code, and more care in the use of get_cpu(). That can be a follow-up MIPS patch. Signed-off-by: Peter Watkins <pwatkins@sicortex.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-29Remove fs.h from mm.hAlexey Dobriyan
Remove fs.h from mm.h. For this, 1) Uninline vma_wants_writenotify(). It's pretty huge anyway. 2) Add back fs.h or less bloated headers (err.h) to files that need it. As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files rebuilt down to 3444 (-12.3%). Cross-compile tested without regressions on my two usual configs and (sigh): alpha arm-mx1ads mips-bigsur powerpc-ebony alpha-allnoconfig arm-neponset mips-capcella powerpc-g5 alpha-defconfig arm-netwinder mips-cobalt powerpc-holly alpha-up arm-netx mips-db1000 powerpc-iseries arm arm-ns9xxx mips-db1100 powerpc-linkstation arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200 arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2 arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads arm-ep93xx i386-up mips-pb1100 powerpc-pasemi arm-footbridge ia64 mips-pb1500 powerpc-pmac32 arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64 arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800 arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3 arm-h7202 ia64-gensparse mips-qemu powerpc-pseries arm-hackkit ia64-sim mips-rbhma4200 powerpc-up arm-integrator ia64-sn2 mips-rbhma4500 s390 arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig arm-iop33x ia64-zx1 mips-sead s390-up arm-ixp2000 m68k mips-tb0219 sparc arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig arm-jornada720 m68k-atari mips-workpad sparc-up arm-kafa m68k-bvme6000 mips-wrppmc sparc64 arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig arm-ks8695 m68k-mac parisc sparc64-defconfig arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64 arm-lpd7a400 m68k-q40 parisc-up x86_64 arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig arm-lusl7200 mips powerpc-celleb x86_64-up arm-mainstone mips-atlas powerpc-chrp32 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[MIPS] Transform old-style macros to newer "__noreturn"Robert P. J. Day
Convert old/obsolete NORET_TYPE and ATTRIB_NORET macros to use the newer standard of "__noreturn" as defined in compiler-gcc.h. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-09sched: zap the migration init / cache-hot balancing codeIngo Molnar
the SMP load-balancer uses the boot-time migration-cost estimation code to attempt to improve the quality of balancing. The reason for this code is that the discrete priority queues do not preserve the order of scheduling accurately, so the load-balancer skips tasks that were running on a CPU 'recently'. this code is fundamental fragile: the boot-time migration cost detector doesnt really work on systems that had large L3 caches, it caused boot delays on large systems and the whole cache-hot concept made the balancing code pretty undeterministic as well. (and hey, i wrote most of it, so i can say it out loud that it sucks ;-) under CFS the same purpose of cache affinity can be achieved without any special cache-hot special-case: tasks are sorted in the 'timeline' tree and the SMP balancer picks tasks from the left side of the tree, thus the most cache-cold task is balanced automatically. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-06-11[MIPS] Fix modpost warnings by making start_secondary __cpuinitRalf Baechle
WARNING: arch/mips/kernel/built-in.o(.text+0x9a58): Section mismatch: reference to .init.text:cpu_report (between 'start_secondary' and 'smp_prepare_boot_cpu') WARNING: arch/mips/kernel/built-in.o(.text+0x9a60): Section mismatch: reference to .init.text:per_cpu_trap_init (between 'start_secondary' and 'smp_prepare_boot_cpu') WARNING: arch/mips/kernel/built-in.o(.text+0x9adc): Section mismatch: reference to .init.text:cpu_probe (between 'start_secondary' and 'smp_prepare_boot_cpu') mipsel-linux-objcopy -S -O srec --remove-section=.reginfo --remove-section=.mdebug --remove-section=.comment --remove-section=.note --remove-section=.pdr --remove-section=.options --remove-section=.MIPS.options vmlinux arch/mips/boot/vmlinux.srec Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-22[MIPS] SMP: Get smp_tune_scheduling to do something useful.Ralf Baechle
2007-01-11[PATCH] Change cpu_up and co from __devinit to __cpuinitGautham R Shenoy
Compiling the kernel with CONFIG_HOTPLUG = y and CONFIG_HOTPLUG_CPU = n with CONFIG_RELOCATABLE = y generates the following modpost warnings WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141b7d) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141b9c) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.text:__cpu_up from .text between '_cpu_up' (at offset 0xc0141bd8) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141c05) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141c26) and 'cpu_up' WARNING: vmlinux - Section mismatch: reference to .init.data: from .text between '_cpu_up' (at offset 0xc0141c37) and 'cpu_up' This is because cpu_up, _cpu_up and __cpu_up (in some architectures) are defined as __devinit AND __cpu_up calls some __cpuinit functions. Since __cpuinit would map to __init with this kind of a configuration, we get a .text refering .init.data warning. This patch solves the problem by converting all of __cpu_up, _cpu_up and cpu_up from __devinit to __cpuinit. The approach is justified since the callers of cpu_up are either dependent on CONFIG_HOTPLUG_CPU or are of __init type. Thus when CONFIG_HOTPLUG_CPU=y, all these cpu up functions would land up in .text section, and when CONFIG_HOTPLUG_CPU=n, all these functions would land up in .init section. Tested on a i386 SMP machine running linux-2.6.20-rc3-mm1. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[MIPS] Cleanup memory barriers for weakly ordered systems.Ralf Baechle
Also the R4000 / R4600 LL/SC instructions imply a sync so no explicit sync needed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-29[MIPS] Do topology_init even on uniprocessor kernels.Ralf Baechle
Otherwise CPU 0 doesn't show up in sysfs which breaks some software. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-11[MIPS] Pass NULL not 0 for pointer value.Ralf Baechle
2006-10-09[MIPS] NUMA: Register all nodes before cpus or sysfs will barf.Ralf Baechle
2006-07-13[MIPS] Avoid interprocessor function calls.Ralf Baechle
On the 34K where multiple virtual processors are implemented in a single core and share a single TLB, interprocessor function calls are not needed to flush a cache, so avoid them. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-27[PATCH] node hotplug: register cpu: remove node structKAMEZAWA Hiroyuki
With Goto-san's patch, we can add new pgdat/node at runtime. I'm now considering node-hot-add with cpu + memory on ACPI. I found acpi container, which describes node, could evaluate cpu before memory. This means cpu-hot-add occurs before memory hot add. In most part, cpu-hot-add doesn't depend on node hot add. But register_cpu(), which creates symbolic link from node to cpu, requires that node should be onlined before register_cpu(). When a node is onlined, its pgdat should be there. This patch-set holds off creating symbolic link from node to cpu until node is onlined. This removes node arguments from register_cpu(). Now, register_cpu() requires 'struct node' as its argument. But the array of struct node is now unified in driver/base/node.c now (By Goto's node hotplug patch). We can get struct node in generic way. So, this argument is not necessary now. This patch also guarantees add cpu under node only when node is onlined. It is necessary for node-hot-add vs. cpu-hot-add patch following this. Moreover, register_cpu calculates cpu->node_id by cpu_to_node() without regard to its 'struct node *root' argument. This patch removes it. Also modify callers of register_cpu()/unregister_cpu, whose args are changed by register-cpu-remove-node-struct patch. [Brice.Goglin@ens-lyon.org: fix it] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-06[MIPS] Fix SMP now that fixup_cpu_present_map is gone.Ralf Baechle
2006-04-19[MIPS] MT: Improved multithreading support.Ralf Baechle
2006-04-19[MIPS] Sort out duplicate exports.Ralf Baechle
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-27[MIPS] SMP: Fix initialization order bug.Ralf Baechle
A recent change requires cpu_possible_map to be initialized before smp_sched_init() but most MIPS platforms were initializing their processors in the prom_prepare_cpus callback of smp_prepare_cpus. The simple fix of calling prom_prepare_cpus from one of the earlier SMP initialization hooks doesn't work well either since IPIs may require init_IRQ() to have completed, so bit the bullet and split prom_prepare_cpus into two initialization functions, plat_smp_setup which is called early from setup_arch and plat_prepare_cpus called where prom_prepare_cpus used to be called. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-21[MIPS] Add topology_init.Rojhalat Ibrahim
A recent patch introduced cpu topology in sysfs. When you run a kernel with SMP and sysfs enabled, you now get an Oops on boot. The following patch fixes that by adding topology_init to arch/mips/kernel/smp.c. The code is copied from arch/s390/kernel/smp.c. Signed-off-by: Rojhalat Ibrahim <imr@rtschenk.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-09[PATCH] sched: disable preempt in idle tasksNick Piggin
Run idle threads with preempt disabled. Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()). How did it ever work before? Might fix the CPU hotplugging hang which Nigel Cunningham noted. We think the bug hits if the idle thread is preempted after checking need_resched() and before going to sleep, then the CPU offlined. After calling stop_machine_run, the CPU eventually returns from preemption and into the idle thread and goes to sleep. The CPU will continue executing previous idle and have no chance to call play_dead. By disabling preemption until we are ready to explicitly schedule, this bug is fixed and the idle threads generally become more robust. From: alexs <ashepard@u.washington.edu> PPC build fix From: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> MIPS build fix Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Delete old junk.Ralf Baechle
2005-10-29Make sure that the processor is actually online or die spectacularly.Ralf Baechle
2005-10-29Fix BogoMIPS display on UP and some minor cosmetical things.Ralf Baechle
2005-10-29Merge do_boot_cpu() into the new style __cpu_up().Ralf Baechle
2005-10-29Document why calling smp_call_function will deadlock when called withRalf Baechle
interrupts disabled. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
