arch/mips/kernel/traps.c:1115: warning: int format, long unsigned int arg (arg 2)
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Make sure cpu_has_fpu (which uses smp_processor_id()) is used only in
atomic context.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
If the PC was ret_from_irq or ret_from_exception, there will be no
more normal stackframe. Instead of stopping the unwinding, use PC and
RA saved by an exception handler to continue unwinding into the
interrupted context. This also simplifies the CONFIG_STACKTRACE code.
Implement stacktrace interface by using unwind_stack() and enable lockdep
support in Kconfig.
Since lmo commit 323a380bf9e1a1679a774a2b053e3c1f2aa3f179 ("Simplify
dump_stack()") made prepare_frametrace() always inlined, using $2 (v0)
in __asm__ is not safe anymore. We can use $1 (at) instead. Also we
should use "dla" instead of "la" for 64-bit kernel.
This patch allows unwind_stack() to return ra for leaf function.
But it tries to detects cases where get_frame_info() wrongly
consider nested function as a leaf one.
It also pass 'unsinged long *sp' instead of 'unsigned long **sp'
as second parameter. The code looks cleaner.
Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com>
Make dump_stack() code not depend on CONFIG_KALLSYMS.
It also make prepare_frametrace() always inlined to get
less false entries reported by show_raw_backtrace().
We usually use backtrace term for dumping a call tree during
debug. Therefore this patch renames show_frametrace() into
show_backtrace() and show_trace() into show_raw_backtrace().
It also uses the new function print_ip_sym().
Instead of dump all possible address in the stack, unwind the stack frame
based on prologue code analysis, as like as get_wchan() does. While the
code analysis might fail for some reason, there is a new kernel option
"raw_show_trace" to disable this feature.
Print call-trace in show_stack() (like on other archs). Also make
show_trace() static and simplify its argument list.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
There should never be a FP exception in kernel mode.
Signed-off-by: Chris Dearman <chris@mips.com>
Make the MT handler silent and output the MT exception type at debug
priority.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
The struct mips_fpu_soft_struct and mips_fpu_hard_struct are
completely same now and the kernel fpu emulator assumes that. This
patch unifies them to mips_fpu_struct and get rid of mips_fpu_union.
The 34K is very much like a 24K on steroids.
Nothing outside traps.c uses it.
Saves like 1,600 lines of code, is way easier to debug, compilers
frequently do a better job than the cut and paste type of handlers many
boards had. And finally having all the stuff done in a single place
also means alot of bug potencial for the MT ASE is gone.
The only surviving handler in assembler is the DECstation one; I hope
Maciej will rewrite it.
The reset state is undefined and some firmware doesn't clear this bit
possibly resulting in crashes on entry into userland.
The rdhwr emulation accidentally swallowed the SIGILL from most other
illegal instructions. Make sure to return -EFAULT by default.
Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com>
First argument of fpu_emulator_cop1Handler() was unused.
will also avoid smp_call_function from doing stupid things when called
from a CPU that is not yet marked online.
a little polishing.
already been modified.
registers.
