Fix broken indentation caused by the SMTC removal
commit b633648c5ad3cfbda0b3daea50d2135d44899259
("MIPS: MT: Remove SMTC support")
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Fixes: b633648c5ad3c ("MIPS: MT: Remove SMTC support")
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/10581/
Commit 854700115ecf ([MIPS] kgdb: add arch support for the kernel's kgdb core)
added the 'kgdb_early_setup' flag to avoid calling trap_init() and init_IRQ()
the second time, however the code that called these functions earlier, from
kgdb_arch_init(), had been already removed by that time, so the flag never
served any useful purpose. Remove the related code along with ugly #ifdef'ery
at last.
[ralf@linux-mips.org: Folded in Guenter Roeck's fix.]
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Patchwork: https://patchwork.linux-mips.org/patch/10501/
Patchwork: https://patchwork.linux-mips.org/patch/10533/
Print Exception Code when printing the Cause register.
Signed-off-by: Petri Gynther <pgynther@google.com>
Patchwork: https://patchwork.linux-mips.org/patch/9998/
__show_regs() calls show_regs_print_info(), which already outputs
the Tainted: information. So, no need to output it twice.
Patchwork: https://patchwork.linux-mips.org/patch/9997/
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell:
"This is the final removal (after several years!) of the obsolete
cpus_* functions, prompted by their mis-use in staging.
With these function removed, all cpu functions should only iterate to
nr_cpu_ids, so we finally only allocate that many bits when cpumasks
are allocated offstack"
* tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
cpumask: remove __first_cpu / __next_cpu
cpumask: resurrect CPU_MASK_CPU0
linux/cpumask.h: add typechecking to cpumask_test_cpu
cpumask: only allocate nr_cpumask_bits.
Fix weird uses of num_online_cpus().
cpumask: remove deprecated functions.
mips: fix obsolete cpumask_of_cpu usage.
x86: fix more deprecated cpu function usage.
ia64: remove deprecated cpus_ usage.
powerpc: fix deprecated CPU_MASK_CPU0 usage.
CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region.
staging/lustre/o2iblnd: Don't use cpus_weight
staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_
staging/lustre/ptlrpc: Do not use deprecated cpus_* functions
blackfin: fix up obsolete cpu function usage.
parisc: fix up obsolete cpu function usage.
tile: fix up obsolete cpu function usage.
arm64: fix up obsolete cpu function usage.
mips: fix up obsolete cpu function usage.
x86: fix up obsolete cpu function usage.
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for MIPS for Linux 4.1. Most
noteworthy:
- Add more Octeon-optimized crypto functions
- Octeon crypto preemption and locking fixes
- Little endian support for Octeon
- Use correct CSR to soft reset Octeons
- Support LEDs on the Octeon-based DSR-1000N
- Fix PCI interrupt mapping for the Octeon-based DSR-1000N
- Mark prom_free_prom_memory() as __init for a number of systems
- Support for Imagination's Pistachio SOC. This includes arch and
CLK bits. I'd like to merge pinctrl bits later
- Improve parallelism of csum_partial for certain pipelines
- Organize DTB files in subdirs like other architectures
- Implement read_sched_clock for all MIPS platforms other than
Octeon
- Massive series of 38 fixes and cleanups for the FPU emulator /
kernel
- Further FPU remulator work to support new features. This sits on a
separate branch which also has been pulled into the 4.1 KVM branch
- Clean up and fixes for the SEAD3 eval board; remove unused file
- Various updates for Netlogic platforms
- A number of small updates for Loongson 3 platforms
- Increase the memory limit for ATH79 platforms to 256MB
- A fair number of fixes and updates for BCM47xx platforms
- Finish the implementation of XPA support
- MIPS FDC support. No, not floppy controller but Fast Debug Channel :)
- Detect the R16000 used in SGI legacy platforms
- Fix Kconfig dependencies for the SSB bus support"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (265 commits)
MIPS: Makefile: Fix MIPS ASE detection code
MIPS: asm: elf: Set O32 default FPU flags
MIPS: BCM47XX: Fix detecting Microsoft MN-700 & Asus WL500G
MIPS: Kconfig: Disable SMP/CPS for 64-bit
MIPS: Hibernate: flush TLB entries earlier
MIPS: smp-cps: cpu_set FPU mask if FPU present
MIPS: lose_fpu(): Disable FPU when MSA enabled
MIPS: ralink: add missing symbol for RALINK_ILL_ACC
MIPS: ralink: Fix bad config symbol in PCI makefile.
SSB: fix Kconfig dependencies
MIPS: Malta: Detect and fix bad memsize values
Revert "MIPS: Avoid pipeline stalls on some MIPS32R2 cores."
MIPS: Octeon: Delete override of cpu_has_mips_r2_exec_hazard.
MIPS: Fix cpu_has_mips_r2_exec_hazard.
MIPS: kernel: entry.S: Set correct ISA level for mips_ihb
MIPS: asm: spinlock: Fix addiu instruction for R10000_LLSC_WAR case
MIPS: r4kcache: Use correct base register for MIPS R6 cache flushes
MIPS: Kconfig: Fix typo for the r2-to-r6 emulator kernel parameter
MIPS: unaligned: Fix regular load/store instruction emulation for EVA
MIPS: unaligned: Surround load/store macros in do {} while statements
Rework `process_fpemu_return' and move IEEE 754 exception interpretation
there, from `do_fpe'. Record the cause bits set in FCSR before they are
cleared and pass them through to `process_fpemu_return' so as to set
`si_code' correctly too for SIGFPE signals sent from emulation rather
than those issued by hardware with the FPE processor exception only.
For simplicity `mipsr2_decoder' assumes `*fcr31' has been preinitialised
and only sets it to anything if an FPU instruction has been emulated,
which in turn is the only case SIGFPE can be issued for here.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/9705/
Clear any FCSR cause bits recorded in the saved FPU context after
emulation in all cases rather than in `do_fpe' only, so that any
unmasked IEEE 754 exception left from emulation does not cause a fatal
kernel-mode FPE hardware exception with the CTC1 instruction used by the
kernel to subsequently restore FCSR hardware from the saved FPU context.
Patchwork: https://patchwork.linux-mips.org/patch/9704/
Respect the FCSR exception mask when interpreting the IEEE 754 exception
condition to report with SIGFPE in `si_code', so as not to use one that
has been masked where a different one set in parallel caused the FPE
hardware exception to trigger. As per the IEEE Std 754 the Inexact
exception can happen together with Overflow or Underflow.
Patchwork: https://patchwork.linux-mips.org/patch/9703/
Correct ISA requirements for floating-point instructions:
* the CU3 exception signifies a real COP3 instruction in MIPS I & II,
* the BC1FL and BC1TL instructions are not supported in MIPS I,
* the SQRT.fmt instructions are indeed supported in MIPS II,
* the LDC1 and SDC1 instructions are indeed supported in MIPS32r1,
* the CEIL.W.fmt, FLOOR.W.fmt, ROUND.W.fmt and TRUNC.W.fmt instructions
are indeed supported in MIPS32,
* the CVT.L.fmt and CVT.fmt.L instructions are indeed supported in
MIPS32r2 and MIPS32r6,
* the CEIL.L.fmt, FLOOR.L.fmt, ROUND.L.fmt and TRUNC.L.fmt instructions
are indeed supported in MIPS32r2 and MIPS32r6,
* the RSQRT.fmt and RECIP.fmt instructions are indeed supported in
MIPS64r1,
Also simplify conditionals for MIPS III and MIPS IV FPU instructions and
the handling of the MOVCI minor opcode.
Patchwork: https://patchwork.linux-mips.org/patch/9700/
Do not lose the other half of the BREAK code where there is an upper
half. This is so that e.g. `BREAK 7, 7' is not interpreted as a divide
by zero trap, while `BREAK 0, 7' or `BREAK 7, 0' still are.
Patchwork: https://patchwork.linux-mips.org/patch/9697/
Add the missing microMIPS BREAK16 instruction code interpretation and
reshape code removing instruction fetching duplication and the separate
call to `do_trap_or_bp' in the MIPS16 path.
Patchwork: https://patchwork.linux-mips.org/patch/9696/
Correct the interpretation of the immediate MIPS16 BREAK instruction
code embedded in the instruction word across bits 10:5 rather than 11:6
as current code implies, fixing the interpretation of integer overflow
and divide by zero traps.
Patchwork: https://patchwork.linux-mips.org/patch/9695/
Changes applied to `do_cpu' over time reduced the use of the SIGILL
issued with `force_sig' at the end to a single CU3 case only in the
switch statement there. Move that `force_sig' call over to right where
required then and toss out the pile of gotos now not needed to skip over
the call, replacing them with regular breaks out of the switch.
Patchwork: https://patchwork.linux-mips.org/patch/9683/
Fold a nested `if' statement for the R6 case in `do_ri' into its
containing `if' block, removing excessive indentation causing code to
extend beyond 79 columns.
Cc: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9679/
Adjust the explanatory comment for FPU emulator traps according to
ba3049ed [MIPS: Switch FPU emulator trap to BREAK instruction.];
originally coming from `do_ade'.
Patchwork: https://patchwork.linux-mips.org/patch/9672/
Read the CPU IRQ line reportedly used for the Fast Debug Channel (FDC)
interrupt from the IntCtl register and store it in cp0_fdc_irq where
platform implementations of the new weak platform function
get_c0_fdc_int() can refer to it.
[ralf@linux-mips.org: Fixed conflict.]
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9140/
Before release 2 of the architecture there weren't separate interrupt
pending bits for the local CPU interrupts (timer & perf counter
overflow), so when they were connected to the same interrupt line the
timer handler had to call the performance counter handler before knowing
whether a timer interrupt was actually pending.
Now another CPU local interrupt, for the Fast Debug Channel (FDC), can
also be routed to an arbitrary interrupt line. It isn't scalable to keep
adding cross-calls between handlers for these cases of shared interrupt
lines, especially since the FDC could in theory share its interrupt line
with the performance counter, timer, or both.
Fortunately since release 2 of the architecture separate interrupt
pending bits do exist in the Cause register. This allows local
interrupts which share an interrupt line to have separate handlers using
IRQF_SHARED. Unfortunately they can't easily have their own irqchip as
there is no generic way to individually mask them.
Enable this sharing to happen by removing the special case for when the
perf count shares an IRQ with the timer. cp0_perfcount_irq and
cp0_compare_irq can then be set to the same value with shared interrupt
handlers registered for both of them.
Pre-R2 code should be unaffected. cp0_perfcount_irq will always be -1
and the timer handler will contnue to call into the perf counter
handler.
Patchwork: https://patchwork.linux-mips.org/patch/9131/
When handling floating point exceptions (FPEs) and MSA FPEs the Cause
bits of the appropriate control and status register (FCSR for FPEs and
MSACSR for MSA FPEs) are read and cleared before enabling interrupts,
presumably so that it doesn't have to go through the pain of restoring
those bits if the process is pre-empted, since writing those bits would
cause another immediate exception while still in the kernel.
The bits aren't normally ever restored again, since userland never
expects to see them set.
However for virtualisation it is necessary for the kernel to be able to
restore these Cause bits, as the guest may have been interrupted in an
FP exception handler but before it could read the Cause bits. This can
be done by registering a die notifier, to get notified of the exception
when such a value is restored, and if the PC was at the instruction
which is used to restore the guest state, the handler can step over it
and continue execution. The Cause bits can then remain set without
causing further exceptions.
For this to work safely a few changes are made:
- __build_clear_fpe and __build_clear_msa_fpe no longer clear the Cause
bits, and now return from exception level with interrupts disabled
instead of enabled.
- do_fpe() now clears the Cause bits and enables interrupts after
notify_die() is called, so that the notifier can chose to return from
exception without this happening.
- do_msa_fpe() acts similarly, but now actually makes use of the second
argument (msacsr) and calls notify_die() with the new DIE_MSAFP,
allowing die notifiers to be informed of MSA FPEs too.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: kvm@vger.kernel.org
When running the emulator to handle an instruction that raised an FP
unimplemented operation exception, the FCSR cause bits were being
cleared. This is done to ensure that the kernel does not take an FP
exception when later restoring FP context to registers. However, this
was not being done when the emulator is invoked in response to a
coprocessor unusable exception. This happens in 2 cases:
- There is no FPU present in the system. In this case things were
OK, since the FP context is never restored to hardware registers
and thus no FP exception may be raised when restoring FCSR.
- The FPU could not be configured to the mode required by the task.
In this case it would be possible for the emulator to set cause
bits which are later restored to hardware if the task migrates
to a CPU whose associated FPU does support its mode requirements,
or if the tasks FP mode requirements change.
Consistently clear the cause bits after invoking the emulator, by moving
the clearing to process_fpemu_return and ensuring this is always called
before the tasks FP context is restored. This will make it easier to
catch further paths invoking the emulator in future, as will be
introduced in further patches.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9165/
Thanks to spatch, plus manual removal of "&*". Then a sweep for
for_each_cpu_mask => for_each_cpu.
Cc: Kevin Cernekee <cernekee@gmail.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
"This is the main pull request for MIPS:
- a number of fixes that didn't make the 3.19 release.
- a number of cleanups.
- preliminary support for Cavium's Octeon 3 SOCs which feature up to
48 MIPS64 R3 cores with FPU and hardware virtualization.
- support for MIPS R6 processors.
Revision 6 of the MIPS architecture is a major revision of the MIPS
architecture which does away with many of original sins of the
architecture such as branch delay slots. This and other changes in
R6 require major changes throughout the entire MIPS core
architecture code and make up for the lion share of this pull
request.
- finally some preparatory work for eXtendend Physical Address
support, which allows support of up to 40 bit of physical address
space on 32 bit processors"
[ Ahh, MIPS can't leave the PAE brain damage alone. It's like
every CPU architect has to make that mistake, but pee in the snow
by changing the TLA. But whether it's called PAE, LPAE or XPA,
it's horrid crud - Linus ]
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (114 commits)
MIPS: sead3: Corrected get_c0_perfcount_int
MIPS: mm: Remove dead macro definitions
MIPS: OCTEON: irq: add CIB and other fixes
MIPS: OCTEON: Don't do acknowledge operations for level triggered irqs.
MIPS: OCTEON: More OCTEONIII support
MIPS: OCTEON: Remove setting of processor specific CVMCTL icache bits.
MIPS: OCTEON: Core-15169 Workaround and general CVMSEG cleanup.
MIPS: OCTEON: Update octeon-model.h code for new SoCs.
MIPS: OCTEON: Implement DCache errata workaround for all CN6XXX
MIPS: OCTEON: Add little-endian support to asm/octeon/octeon.h
MIPS: OCTEON: Implement the core-16057 workaround
MIPS: OCTEON: Delete unused COP2 saving code
MIPS: OCTEON: Use correct instruction to read 64-bit COP0 register
MIPS: OCTEON: Save and restore CP2 SHA3 state
MIPS: OCTEON: Fix FP context save.
MIPS: OCTEON: Save/Restore wider multiply registers in OCTEON III CPUs
MIPS: boot: Provide more uImage options
MIPS: Remove unneeded #ifdef __KERNEL__ from asm/processor.h
MIPS: ip22-gio: Remove legacy suspend/resume support
mips: pci: Add ifdef around pci_proc_domain
The ERETNC instruction, introduced in MIPS R5, is similar to the ERET
one, except it does not clear the LLB bit in the LLADDR register.
This feature is necessary to safely emulate R2 LL/SC instructions.
However, on context switches, we need to clear the LLAddr/LLB bit
in order to make sure that an SC instruction from the new thread
will never succeed if it happens to interrupt an LL operation on the
same address from the previous thread.
MIPS R6 removed quite a few R2 instructions. However, there
is plenty of <R6 userland code so we add an in-kernel emulator
so we can still be able to execute all R2 userland out there.
The emulator comes with a handy debugfs under /mips/ directory
(r2-emul-stats) to provide some basic statistics of the
instructions that are being emulated.
Below are some statistics from booting a minimal buildroot image:
Instruction Total BDslot
movs 236969 0
hilo 56686 0
muls 55279 0
divs 10941 0
dsps 0 0
bops 1 0
traps 0 0
fpus 0 0
loads 214981 17
stores 103364 0
llsc 56898 0
dsemul 150418 0
jr 370158
bltzl 43
bgezl 1594
bltzll 0
bgezll 0
bltzal 39
bgezal 39
beql 14503
bnel 138741
blezl 0
bgtzl 3988
Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Add MIPS R6 support to cache and ftlb exceptions, as well as
to the hwrena and ebase register configuration.
Add a CPU_QEMU_GENERIC case to various switch statements.
Userland code may be built using an ABI which permits linking to objects
that have more restrictive floating point requirements. For example,
userland code may be built to target the O32 FPXX ABI. Such code may be
linked with other FPXX code, or code built for either one of the more
restrictive FP32 or FP64. When linking with more restrictive code, the
overall requirement of the process becomes that of the more restrictive
code. The kernel has no way to know in advance which mode the process
will need to be executed in, and indeed it may need to change during
execution. The dynamic loader is the only code which will know the
overall required mode, and so it needs to have a means to instruct the
kernel to switch the FP mode of the process.
This patch introduces 2 new options to the prctl syscall which provide
such a capability. The FP mode of the process is represented as a
simple bitmask combining a number of mode bits mirroring those present
in the hardware. Userland can either retrieve the current FP mode of
the process:
mode = prctl(PR_GET_FP_MODE);
or modify the current FP mode of the process:
err = prctl(PR_SET_FP_MODE, new_mode);
Cc: Matthew Fortune <matthew.fortune@imgtec.com>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/8899/
Commit 842dfc11ea9a ("MIPS: Fix build with binutils 2.24.51+") in v3.18
enabled -msoft-float and sprinkled ".set hardfloat" where necessary to
use FP instructions. However it missed enable_restore_fp_context() which
since v3.17 does a ctc1 with inline assembly, causing the following
assembler errors on Mentor's 2014.05 toolchain:
{standard input}: Assembler messages:
{standard input}:2913: Error: opcode not supported on this processor: mips32r2 (mips32r2) `ctc1 $2,$31'
scripts/Makefile.build:257: recipe for target 'arch/mips/kernel/traps.o' failed
Fix that to use the new write_32bit_cp1_register() macro so that ".set
hardfloat" is automatically added when -msoft-float is in use.
Fixes 842dfc11ea9a ("MIPS: Fix build with binutils 2.24.51+")
Cc: <stable@vger.kernel.org> # 3.18+, depends on "MIPS: mipsregs.h: Add write_32bit_cp1_register()"
Patchwork: https://patchwork.linux-mips.org/patch/9173/
They can be useful to determine how the MMU is configured on a MC
exception.
Patchwork: https://patchwork.linux-mips.org/patch/8401/
The HTW registers can be useful to debug a MC exception.
Patchwork: https://patchwork.linux-mips.org/patch/8400/
printk should not be used without a KERN_ facility level
Patchwork: https://patchwork.linux-mips.org/patch/8399/
Hybrid FPRs is a scheme where scalar FP registers are 64b wide, but
accesses to odd indexed single registers use bits 63:32 of the
preceeding even indexed 64b register. In this mode all FP code
except that built for the plain FP64 ABI can execute correctly. Most
notably a combination of FP64A & FP32 code can execute correctly,
allowing for existing FP32 binaries to be linked with new FP64A binaries
that can make use of 64 bit FP & MSA.
Hybrid FPRs are implemented by setting both the FR & FRE bits, trapping
& emulating single precision FP instructions (via Reserved Instruction
exceptions) whilst allowing others to execute natively. It therefore has
a penalty in terms of execution speed, and should only be used when no
fully native mode can be. As more binaries are recompiled to use either
the FPXX or FP64(A) ABIs, the need for hybrid FPRs should diminish.
However in the short to mid term it allows for a gradual transition
towards that world, rather than a complete ABI break which is not
feasible for some users & not desirable for many.
A task will be executed using the hybrid FPR scheme when its
TIF_HYBRID_FPREGS flag is set & TIF_32BIT_FPREGS is clear. A further
patch will set the flags as necessary, this patch simply adds the
infrastructure necessary for the hybrid FPR mode to work.
Cc: linux-fsdevel@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/7683/
Preemption must be disabled throughout the process of enabling the FPU,
enabling MSA & initialising the vector registers. Without doing so it
is possible to lose the FPU or MSA whilst initialising them causing
that initialisation to fail.
Patchwork: https://patchwork.linux-mips.org/patch/7307/
If a task does not execute scalar FP instructions prior to using MSA
then the flags indicating that the task has live MSA context were not
being set. The upper 64b of each vector register would then be lost
upon the tasks first context switch after using MSA.
Patchwork: https://patchwork.linux-mips.org/patch/7500/
When a task first makes use of MSA we need to ensure that the upper
64b of the vector registers are set to some value such that no
information can be leaked to it from the previous task to use MSA
context on the CPU. The architecture formerly specified that these
bits would be cleared to 0 when a scalar FP instructions wrote to the
aliased FP registers, which would have implicitly handled this as the
kernel restored scalar FP context. However more recent versions of the
specification now state that the value of the bits in such cases is
unpredictable. Initialise them explictly to be sure, and set all the
bits to 1 rather than 0 for consistency with the least significant
64b.
Patchwork: https://patchwork.linux-mips.org/patch/7497/
Switching the vector context implicitly saves & restores the state of
the aliased scalar FP data registers, however the scalar FP control
& status register is distinct from the MSA control & status register.
In order to allow scalar FP to function correctly in programs using
MSA, the scalar CSR needs to be saved & restored along with the MSA
vector context.
Patchwork: https://patchwork.linux-mips.org/patch/7301/
Use the regular tlb_do_page_fault_0 (no write) handler to handle
the RI and XI exceptions. Also skip the RI/XI validation check
on TLB load handler since it's redundant when the CPU has
unique RI/XI exceptions.
Singed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/7339/
Performing vma lookups without taking the mm->mmap_sem is asking
for trouble. While doing the search, the vma in question can be
modified or even removed before returning to the caller. Take the
lock (exclusively) in order to avoid races while iterating through
the vmacache and/or rbtree.
Updates two functions:
- process_fpemu_return()
- cteon_flush_cache_sigtramp()
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Tested-by: Andreas Herrmann <andreas.herrmann@caviumnetworks.com>
Cc: akpm@linux-foundation.org
Cc: zeus@gnu.org
Cc: aswin@hp.com
Cc: davidlohr@hp.com
Cc: linux-mm@kvack.org
Patchwork: http://patchwork.linux-mips.org/patch/6811/
mips-for-linux-next
Introduced by the following two commits:
75b5b5e0a262790fa11043fe45700499c7e3d818
"MIPS: Add support for FTLBs"
6de20451857ed14a4eecc28d08f6de5925d1cf96
"MIPS: Add printing of ES bit for Imgtec cores when cache error occurs"
Reported-by: Matheus Almeida <Matheus.Almeida@imgtec.com>
Cc: stable@vger.kernel.org # v3.14+
Patchwork: https://patchwork.linux-mips.org/patch/6980/
Nobody is maintaining SMTC anymore and there also seems to be no userbase.
Which is a pity - the SMTC technology primarily developed by Kevin D.
Kissell <kevink@paralogos.com> is an ingenious demonstration for the MT
ASE's power and elegance.
Based on Markos Chandras <Markos.Chandras@imgtec.com> patch
https://patchwork.linux-mips.org/patch/6719/ which while very similar did
no longer apply cleanly when I tried to merge it plus some additional
post-SMTC cleanup - SMTC was a feature as tricky to remove as it was to
merge once upon a time.
Implement a CPU power management callback for restoring trap related CPU
configuration after CPU power up from a low power state. The following
state is restored:
- Status register
- HWREna register
- Exception vector configuration registers
- Context/XContext register
When a breakpoint or trap happens when operating in kernel mode but
on users behalf (eg syscall) it is necessary to change the address
limit to KERNEL_DS so any address checking can be bypassed and print
the correct stack trace.
Add a CPU_P5600 case to various switch statements, doing the same thing
as for CPU_PROAPTIV.
Reviewed-by: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/6408/
This patch adds a simple handler for MSA FP exceptions which delivers a
SIGFPE to the running task. In the future it should probably be extended
to re-execute the instruction with the MSACSR.NX bit set in order to
generate results for any elements which did not cause an exception
before delivering the SIGFPE signal.
Patchwork: https://patchwork.linux-mips.org/patch/6432/
This patch adds support for context switching the MSA vector registers.
These 128 bit vector registers are aliased with the FP registers - an
FP register accesses the least significant bits of the vector register
with which it is aliased (ie. the register with the same index). Due to
both this & the requirement that the scalar FPU must be 64-bit (FR=1) if
enabled at the same time as MSA the kernel will enable MSA & scalar FP
at the same time for tasks which use MSA. If we restore the MSA vector
context then we might as well enable the scalar FPU since the reason it
was left disabled was to allow for lazy FP context restoring - but we
just restored the FP context as it's a subset of the vector context. If
we restore the FP context and have previously used MSA then we have to
restore the whole vector context anyway (see comment in
enable_restore_fp_context for details) so similarly we might as well
enable MSA.
Thus if a task does not use MSA then it will continue to behave as
without this patch - the scalar FP context will be saved & restored as
usual. But if a task executes an MSA instruction then it will save &
restore the vector context forever more.
Patchwork: https://patchwork.linux-mips.org/patch/6431/
The 1074K is a multiprocessing coherent processing system (CPS) based
on modified 74K cores. This patch makes the 1074K an actual unique
CPU type, instead of a 74K derivative, which it is not.
Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
Reviewed-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/6389/
The interAptiv is a power-efficient multi-core microprocessor
for use in system-on-chip (SoC) applications. The interAptiv combines
a multi-threading pipeline with a coherence manager to deliver improved
computational throughput and power efficiency. The interAptiv can
contain one to four MIPS32R3 interAptiv cores, system level
coherence manager with L2 cache, optional coherent I/O port,
and optional floating point unit.
Signed-off-by: John Crispin <blogic@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/6163/
