Pull MIPS updates from Ralf Baechle:
"This is the main pull request for MIPS for Linux 4.1. Most
noteworthy:
- Add more Octeon-optimized crypto functions
- Octeon crypto preemption and locking fixes
- Little endian support for Octeon
- Use correct CSR to soft reset Octeons
- Support LEDs on the Octeon-based DSR-1000N
- Fix PCI interrupt mapping for the Octeon-based DSR-1000N
- Mark prom_free_prom_memory() as __init for a number of systems
- Support for Imagination's Pistachio SOC. This includes arch and
CLK bits. I'd like to merge pinctrl bits later
- Improve parallelism of csum_partial for certain pipelines
- Organize DTB files in subdirs like other architectures
- Implement read_sched_clock for all MIPS platforms other than
Octeon
- Massive series of 38 fixes and cleanups for the FPU emulator /
kernel
- Further FPU remulator work to support new features. This sits on a
separate branch which also has been pulled into the 4.1 KVM branch
- Clean up and fixes for the SEAD3 eval board; remove unused file
- Various updates for Netlogic platforms
- A number of small updates for Loongson 3 platforms
- Increase the memory limit for ATH79 platforms to 256MB
- A fair number of fixes and updates for BCM47xx platforms
- Finish the implementation of XPA support
- MIPS FDC support. No, not floppy controller but Fast Debug Channel :)
- Detect the R16000 used in SGI legacy platforms
- Fix Kconfig dependencies for the SSB bus support"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (265 commits)
MIPS: Makefile: Fix MIPS ASE detection code
MIPS: asm: elf: Set O32 default FPU flags
MIPS: BCM47XX: Fix detecting Microsoft MN-700 & Asus WL500G
MIPS: Kconfig: Disable SMP/CPS for 64-bit
MIPS: Hibernate: flush TLB entries earlier
MIPS: smp-cps: cpu_set FPU mask if FPU present
MIPS: lose_fpu(): Disable FPU when MSA enabled
MIPS: ralink: add missing symbol for RALINK_ILL_ACC
MIPS: ralink: Fix bad config symbol in PCI makefile.
SSB: fix Kconfig dependencies
MIPS: Malta: Detect and fix bad memsize values
Revert "MIPS: Avoid pipeline stalls on some MIPS32R2 cores."
MIPS: Octeon: Delete override of cpu_has_mips_r2_exec_hazard.
MIPS: Fix cpu_has_mips_r2_exec_hazard.
MIPS: kernel: entry.S: Set correct ISA level for mips_ihb
MIPS: asm: spinlock: Fix addiu instruction for R10000_LLSC_WAR case
MIPS: r4kcache: Use correct base register for MIPS R6 cache flushes
MIPS: Kconfig: Fix typo for the r2-to-r6 emulator kernel parameter
MIPS: unaligned: Fix regular load/store instruction emulation for EVA
MIPS: unaligned: Surround load/store macros in do {} while statements
As part of addressing in-kernel y2038 issues, this patch adds
read_persistent_clock64() and replaces all the call sites of
read_persistent_clock() with this function. This is a __weak
implementation, which simply calls the existing y2038 unsafe
read_persistent_clock().
This allows architecture specific implementations to be
converted independently, and eventually the y2038 unsafe
read_persistent_clock() can be removed after all its
architecture specific implementations have been converted to
read_persistent_clock64().
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Xunlei Pang <pang.xunlei@linaro.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Link: http://lkml.kernel.org/r/1427945681-29972-3-git-send-email-john.stultz@linaro.org
Remove the function proc_dolasatint() that is not used anywhere.
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/8868/
This typedef is unnecessary and should just be removed.
Cc: Jiri Kosina <trivial@kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/5460/
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
Commit 163931922220e4cb5effd5af1e105038c2f0ab7a "sysctl mips/lasat: Remove
dead binary sysctl support" obviously wasn't test built ...
For consistency drop & in front of every proc_handler. Explicity
taking the address is unnecessary and it prevents optimizations
like stubbing the proc_handlers to NULL.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Joe Perches <joe@perches.com>
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name
and .strategy members of sysctl tables are dead code. Remove them.
The deleted strategy routines here surprise me. ctl_name was
CTL_UNNUMBERED so they would not have been called at all.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
It's unused.
It isn't needed -- read or write flag is already passed and sysctl
shouldn't care about the rest.
It _was_ used in two places at arch/frv for some reason.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
The persistent clock of some architectures (e.g. s390) have a
better granularity than seconds. To reduce the delta between the
host clock and the guest clock in a virtualized system change the
read_persistent_clock function to return a struct timespec.
Acked-by: John Stultz <johnstul@us.ibm.com>
Cc: Daniel Walker <dwalker@fifo99.com>
LKML-Reference: <20090814134811.013873340@de.ibm.com>
name and nlen parameters passed to ->strategy hook are unused, remove
them. In general ->strategy hook should know what it's doing, and don't
do something tricky for which, say, pointer to original userspace array
may be needed (name).
Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ]
Cc: Matt Mackall <mpm@selenic.com>
LASAT's sysctl interface was broken, it failed a check during boot because
a single entry had a sysctl number and the rest were unnumbered. When I
fixed it I noticed that the whole sysctl file needed a spring clean, it was
using mutexes where it wasn't needed (it's only needed to protect during
writes to the EEPROM), so I moved that stuff out and generally cleaned the
whole thing up.
So now, LASAT's sysctl/proc interface is working again.
Signed-off-by: Thomas Horsten <thomas@horsten.com>
Hard to follow who is pointing what to where and why so it's simply getting
in the way of the time code renovation.
Signed-off-by: Brian Murphy <brian@murphy.dk>
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
The semantic effect of insert_at_head is that it would allow new registered
sysctl entries to override existing sysctl entries of the same name. Which is
pain for caching and the proc interface never implemented.
I have done an audit and discovered that none of the current users of
register_sysctl care as (excpet for directories) they do not register
duplicate sysctl entries.
So this patch simply removes the support for overriding existing entries in
the sys_sysctl interface since no one uses it or cares and it makes future
enhancments harder.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Corey Minyard <minyard@acm.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: David Chinner <dgc@sgi.com>
Cc: Patrick McHardy <kaber@trash.net>
While C99 converting the ctl_table initializers I realized that the binary
sysctl numbers were in conflict with the binary values under CTL_KERN.
Including CTL_KERN KERN_VERSION as used by glibc. So I just removed the
sysctl binary interface for these values, as it was unsupportable.
Luckily these sysctl were inserted at the end of the sysctl list so this bug
was not visible to userspace.
Cc: Andi Kleen <ak@suse.de>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Jens Axboe <axboe@suse.de>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Acked-by: Alasdair G Kergon <agk@redhat.com>
Cc: Greg KH <greg@kroah.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Adam Belay <ambx1@neo.rr.com>
infrastructure for it.
Let it rip!
