path: root/arch/mips/lemote
2008-01-29[MIPS] Fulong: don't reinitialize pci_probe_only to it's default value.Ralf Baechle
2008-01-29[MIPS] remove unused mips_machtypeYoichi Yuasa
Removed unused mips_machtype. These are only set but not used. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-19[MIPS] Kill duplicated setup_irq() for cp0 timerAtsushi Nemoto
Also many plat_timer_setup() can be killed too. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Kill redundant EXTRA_AFLAGSAtsushi Nemoto
Kill redundant EXTRA_AFLAGS added after the commit d2af363cfb94f1bacb3e60327bc44a97881a38c2. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Fulong: Remove unneeded header fileSongmao Tian
Signed-off-by: Songmao Tian <tiansm@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] remove some duplicate includesJesper Juhl
This patch removes some duplicate includes from arch/mips/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-07-31[MIPS] Fix build breakage due to duplicate cpu_clock definitionRalf Baechle
commit e436d80085133858bf2613a630365e8a0459fd58 Author: Ingo Molnar <mingo@elte.hu> Date: Thu Jul 19 21:28:35 2007 +0200 [PATCH] sched: implement cpu_clock(cpu) high-speed time source broke the build of several MIPS platforms which were already using the symbol cpu_clock for the own purposes. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] New files for lemote fulong mini-PC supportSongmao Tian
Signed-off-by: Fuxin Zhang <zhangfx@lemote.com> Signed-off-by: Songmao Tian <tiansm@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
