path: root/arch/mips/math-emu
2008-04-28[MIPS] replace __inline with inlineHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-26[MIPS] Compliment va_start() with va_end().Richard Knutsson
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-07-13[MIPS] Add some __user tagsAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-13[MIPS] math-emu minor cleanupAtsushi Nemoto
Declaring emulpc and contpc as "unsigned long" can get rid of some casts. This also get rid of some sparse warnings. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Add debugfs files to show fpuemu statisticsAtsushi Nemoto
Export contents of struct mips_fpu_emulator_stats via debugfs. There is no way to read these statistics for now but they (at least the "emulated" count) might be sometimes useful for performance tuning on FPU-less CPUs. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-17[MIPS] FPU ownership management & preemption fixesAtsushi Nemoto
2006-10-09[MIPS] Make sure cpu_has_fpu is used only in atomic contextAtsushi Nemoto
Make sure cpu_has_fpu (which uses smp_processor_id()) is used only in atomic context. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Unify mips_fpu_soft_struct and mips_fpu_hard_structs.Atsushi Nemoto
The struct mips_fpu_soft_struct and mips_fpu_hard_struct are completely same now and the kernel fpu emulator assumes that. This patch unifies them to mips_fpu_struct and get rid of mips_fpu_union. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix compiler warnings (field width, unused variable)Atsushi Nemoto
Fix following warnings: linux/arch/mips/kernel/setup.c:432: warning: field width is not type int (arg 2) linux/arch/mips/kernel/setup.c:432: warning: field width is not type int (arg 4) linux/arch/mips/kernel/syscall.c:279: warning: unused variable `len' linux/arch/mips/kernel/syscall.c:280: warning: unused variable `name' linux/arch/mips/math-emu/dp_fint.c:32: warning: unused variable `xc' linux/arch/mips/math-emu/dp_flong.c:32: warning: unused variable `xc' linux/arch/mips/math-emu/sp_fint.c:32: warning: unused variable `xc' linux/arch/mips/math-emu/sp_flong.c:32: warning: unused variable `xc' (original patch by Atsushi, slight changes to the setup.c part by me.) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-07[MIPS] ieee754[sd]p_neg workaroundAtsushi Nemoto
It looks glibc's pow() assumes an unary '-' operation for any number (including NaNs) always inverts its sign bit (though IEEE754 does not specify the sign bit for NaNs). This patch make the kernel math-emu emulates real MIPS neg.[ds] instruction. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-01-10MIPS: FP: Remove silly trick to avoid warning.Ralf Baechle
Just doesn't fool a modern compiler anymore. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Get rid of SINGLE_ONLY_FPU. Linux does not support half FPU other thanRalf Baechle
by emulation of a full FPU. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Fix all the get_user / put_user related sparse warnings.Ralf Baechle
2005-10-29Delete unused ieee754_cname[] and declaration.Ralf Baechle
2005-10-29Include for prototypes.Ralf Baechle
2005-10-29Protect against multiple inclusion.Ralf Baechle
2005-10-29FPU emulator garbage collection.Ralf Baechle
First argument of fpu_emulator_cop1Handler() was unused. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29GCC bulletproofing: __mips64 is only defined when compiling for 64-bitRalf Baechle
processors. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Now that a struct is the only member left in structRalf Baechle
mips_fpu_emulator_stats cleanup that unnecessary nesting of structs. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Get rid of the eir struct mips_fpu_emulator_private member. It'sRalf Baechle
never initialized been initialized anywhere, just saved to and restored from signal frames so nonsense anyway. As neat side effect of being shared between all processors it was also abusable as a nice covert channel between processes. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Fix preemption and SMP problems in the FP emulator code.Ralf Baechle
2005-10-29Gross macro abuse. Get rid of gpreg_t, vaddr_t, REG_TO_VA andRalf Baechle
VA_TO_REG. Who ever wrote this apparently did enjoy the C Puzzle Book. ISBN 0201604612, a little old but still fun reading for the next blackout ;) Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Cleanup fpuemuprivate declarations.Ralf Baechle
2005-09-05[PATCH] mips: fix build warningsYoichi Yuasa
This patch has fixed the following warnings. arch/mips/kernel/genex.S:250:5: warning: "CONFIG_64BIT" is not defined arch/mips/math-emu/cp1emu.c:1128:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:1206:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:1270:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:323:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:808:5: warning: "__mips64" is not defined arch/mips/math-emu/cp1emu.c:953:5: warning: "__mips64" is not defined arch/mips/mm/tlbex.c:519:5: warning: "CONFIG_64BIT" is not defined include/asm/reg.h:73:5: warning: "CONFIG_64BIT" is not defined Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
