The commit a96102be70 introduced set_isa() where compatible ISA info is
also set aside from the one gets passed in. It means, for example, 1004K
will have MIPS_CPU_ISA_M32R2/M32R1/II/I flags. This leads to things like
the following inappropriate:
if (c->isa_level == MIPS_CPU_ISA_M32R1 ||
c->isa_level == MIPS_CPU_ISA_M32R2 ||
c->isa_level == MIPS_CPU_ISA_M64R1 ||
c->isa_level == MIPS_CPU_ISA_M64R2)
This patch fixes it.
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: linux-mips@linux-mips.org
git://git.linux-mips.org/pub/scm/john/linux-john into mips-for-linux-next
Signed-off-by: Steven J. Hill <sjhill@mips.com>
Patchwork: http://patchwork.linux-mips.org/patch/4682/
Signed-off-by: John Crispin <blogic@openwrt.org>
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
mips-for-linux-next
Nobody seems to be interested anymore and upstream also never had an
ethernet driver.
Normally r4k_dma_cache_inv should only ever be called with cacheline
aligned addresses. If however, it isn't there is the theoretical
possibility of data corruption. There is no correct way of handling this
and anyway, it should only happen if the DMA API is used incorrectly
so drop
There is a different corruption scenario with these CACHE instructions
removed but again there is no way of handling this correctly and it can
be triggered only through incorrect use of the DMA API.
So just get rid of the complexity.
Reported-by: James Rodriguez <jamesr@juniper.net>
Commit 97ce2c88f9ad42e3c60a9beb9fca87abf3639faa (jump-label: initialize
jump-label subsystem much earlier) caused MIPS to break, so this was
resolved with commit 6650df3c380e0db558dbfec63ed860402c6afb2a (MIPS:
Move cache setup to setup_arch().). Unfortunately, after this commit,
the coherency kernel parameters, cca and coherentio, are no longer
processed before their values are used.
This patch fixes this problem by marking them as early_param, which
results in them being processed before they are needed.
Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com>
Acked-by: David Daney <david.daney@cavium.com>
Patchwork: http://patchwork.linux-mips.org/patch/3961
This affects certain 4Kc cores.
Signed-off-by: Douglas Leung <douglas@mips.com>
Patchwork: https://patchwork.linux-mips.org/patch/3855/
[ralf@linux-mips.org: Fixed whitespace damage.]
Patchwork: https://patchwork.linux-mips.org/patch/3773/
Signed-off-by: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/3821/
Disintegrate asm/system.h for MIPS.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
cc: linux-mips@linux-mips.org
Signed-off-by: Cong Wang <amwang@redhat.com>
Add support for Netlogic's XLP MIPS SoC. This patch adds:
* XLP processor ID in cpu_probe.c and asm/cpu.h
* XLP case to asm/module.h
* CPU_XLP case to mm/tlbex.c
* minor change to r4k cache handling to ignore XLP secondary cache
* XLP cpu overrides to mach-netlogic/cpu-feature-overrides.h
Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com>
Patchwork: https://patchwork.linux-mips.org/patch/2966/
Until now flush_kernel_vmap_range() and invalidate_kernel_vmap_range() did
not exist on MIPS resulting in heavy cache corruption on XFS filesystems.
Left for the post-3.0 time: optimization and make this work with highmem,
too. Since the combination of highmem + cache aliases atm doesn't work
this isn't a regression.
Patchwork: https://patchwork.linux-mips.org/patch/2505/
On processors with deep write buffers, it is likely that many cycles
will pass between a CACHE instruction and the time the data actually
gets written out to DRAM. Add a SYNC instruction to ensure that the
buffers get emptied before the flush functions return.
Actual problem seen in the wild:
1) dma_alloc_coherent() allocates cached memory
2) memset() is called to clear the new pages
3) dma_cache_wback_inv() is called to flush the zero data out to memory
4) dma_alloc_coherent() returns an uncached (kseg1) pointer to the
freshly allocated pages
5) Caller writes data through the kseg1 pointer
6) Buffered writeback data finally gets flushed out to DRAM
7) Part of caller's data is inexplicably zeroed out
This patch adds SYNC between steps 3 and 4, which fixed the problem.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Patchwork:
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
CPU_XLR case added to mm/tlbex.c
CPU_XLR case added to mm/c-r4k.c for PINDEX attribute
Feature overrides for XLR cpu.
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2333/
CC arch/mips/mm/c-r4k.o
arch/mips/mm/c-r4k.c: In function 'probe_scache':
arch/mips/mm/c-r4k.c:1078:6: error: variable 'tmp' set but not used [-Werror=unused-but-set-variable]
cc1: all warnings being treated as errors
Older GCC versions didn't warn about the unused variable tmp because it was
getting initialized.
All callers were passing in 1 anyway.
Some of the were relying into smp.h being dragged in by another header
which of course is fragile. <asm/cpu-info.h> uses smp_processor_id()
only in macros and including smp.h there leads to an include loop, so
don't change cpu-info.h.
This patch removes the various CPU_AU1??? model constants in favor of
a single CPU_ALCHEMY one.
All currently existing Alchemy models are identical in terms of cpu
core and cache size/organization. The parts of the mips kernel which
need to know the exact CPU revision extract it from the c0_prid register
already; and finally nothing else in-tree depends on those any more.
Should a new variant with slightly different "company options" and/or
"processor revision" bits in c0_prid appear, it will be supported
immediately (minus an exact model string in cpuinfo).
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
See discussion e9c3a7c20901051031y528d0d31r18d44c5096c59e0@mail.gmail.com.
trap_init issues flush_icache_range(), which uses ipi functions to
get icache flushing done on all cpus. But this is done before interrupts
are enabled and caused WARN_ON messages. This changeset introduces
a new local_flush_icache_range() and uses it before interrupts (and
additional CPUs) are enabled to avoid this problem.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
It's never used and the comments refer to nonatomic and retry
interchangably. So get rid of it.
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Assuming the call of kmap_coherent in local_r4k_flush_cache_page doesn't
need fixing this was skipped in fcae549295bcae801ac48fc1c2030ab8cc487020.
Turns out it needed the same change after all.
Build error was caused by commit 351336929ccf222ae38ff0cb7a8dd5fd5c6236a0.
Signed-off-by: Chris Dearman <chris@mips.com>
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Slightly tacky, but there is a precedent in the sparc archirecture code.
flush_cache_vmap / flush_cache_vunmap were calling flush_cache_all which -
having been deprecated - turned into a nop ...
So far flush_cache_range() did't consider the I-cache largely because it
did rarely ever matter to real world code. This was working primarily
because normally code and data are don't share the same pages - with the
exception of MIPS16 code which uses address constants embedded between
the code. The following sequence of events may break the code:
o MIPS16 executable being loaded
o dynamic linker relocates the address constants embedded into the code:
o Uses mprotect(2) to make code pages PROT_READ|PROT_WRITE
o Performs the actual relocations by writing to the pages which likely
are COW. Because no PROT_EXEC is set I-cache coherence will not be
considered.
o Uses mprotect(2) to switch code pages back to PROT_READ|PROT_EXEC.
This results in a call to flush_cache_range() which also does not
consider I-caches.
o => executing the page just having been relocated may now result in the
I-cache getting refilled with stale data from memory.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch adds IDs for new Au1200 variants: Au1210 and Au1250.
They are essentially identical to the Au1200 except for the Au1210
which has a different SoC-ID in the PRId register [bits 31:24].
The Au1250 is a "Au1200 V0.2".
R10k non coherent machines need a real dma cache invalidate to get rid of
speculative stores in cache. For other machines this promises a slight
speedup.
The recent switch of the Sibyte SOCs from the processor specific cache
managment code in c-sb1.c to c-r4k.c lost this old hack
[MIPS] Hack for SB1 cache issues
Removing flush_icache_page a while ago broke SB1 which was using an empty
flush_data_cache_page function. This glues things well enough so a more
efficient but also more intrusive solution can be found later.
Signed-Off-By: Thiemo Seufer <ths@networkno.de>
in the hope it was no longer needed. As it turns it still is so resurrect
it until there is a better solution.
When GDB writes a breakpoint into address area of inferior process the
kernel needs to invalidate the modified memory in the inferior which
is done by calling flush_cache_page which in turns calls
r4k_flush_cache_page and local_r4k_flush_cache_page for VSMP or SMTC
kernel via r4k_on_each_cpu().
As the VSMP and SMTC SMP kernels for 34K are running on a single shared
caches it is possible to get away without interprocessor function calls.
This optimization is implemented in r4k_on_each_cpu, so
local_r4k_flush_cache_page is only ever called on the local CPU.
This is where the following code in local_r4k_flush_cache_page() strikes:
* If ownes no valid ASID yet, cannot possibly have gotten
* this page into the cache.
if (cpu_context(smp_processor_id(), mm) == 0)
return;
On VSMP and SMTC had a function of cpu_context() for each CPU(TC).
So in case another CPU than the CPU executing local_r4k_cache_flush_page
has not accessed the mm but one of the other CPUs has there may be data
to be flushed in the cache yet local_r4k_cache_flush_page will falsely
return leaving the I-cache inconsistent for the breakpoint.
While the issue was discovered with GDB it also exists in
local_r4k_flush_cache_range() and local_r4k_flush_cache().
Fixed by introducing a new function has_valid_asid which on MT kernels
returns true if a mm is active on any processor in the system.
This is relativly expensive since for memory acccesses in that loop
cache misses have to be assumed but it seems the most viable solution
for 2.6.23 and older -stable kernels.
This should help making bug reports for the gadzillion of cores with all
their configuration and synthesis options more useful.
This saves a few k on systems which only ever ship with a single CPU type.
On MP configurations it's highly dubious what this code will actually
affect since blasting away cachelines may or may not do the right
thing wrt. cache coherency.
It may not be perfect yet but the SB1 code is badly borken and has
horrible performance issues.
Downside: This seriously breaks support for pass 1 parts of the BCM1250
where indexed cacheops don't work quite reliable but I seem to be the
last one on the planet with a pass 1 part anyway.
