path: root/arch/mips/mm/cerr-sb1.c
2007-11-15[MIPS] Sibyte: Replace use of removed IO_SPACE_BASE with IOADDR.Ralf Baechle
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-03-24[MIPS] SB1: Fix pile of gcc's bogus format string warnings.Ralf Baechle
CC arch/mips/mm/cerr-sb1.o arch/mips/mm/cerr-sb1.c: In function 'sb1_cache_error': arch/mips/mm/cerr-sb1.c:235: warning: format '%010llx' expects type 'long long unsigned int', but argument 2 has type 'uint64_t' arch/mips/mm/cerr-sb1.c: In function 'extract_ic': arch/mips/mm/cerr-sb1.c:385: warning: format '%016llx' expects type 'long long unsigned int', but argument 3 has type 'uint64_t' arch/mips/mm/cerr-sb1.c:385: warning: format '%016llX' expects type 'long long unsigned int', but argument 6 has type 'uint64_t' arch/mips/mm/cerr-sb1.c: In function 'extract_dc': arch/mips/mm/cerr-sb1.c:523: warning: format '%010llx' expects type 'long long unsigned int', but argument 3 has type 'uint64_t' arch/mips/mm/cerr-sb1.c:523: warning: format '%016llX' expects type 'long long unsigned int', but argument 7 has type 'uint64_t' arch/mips/mm/cerr-sb1.c:570: warning: format '%016llX' expects type 'long long unsigned int', but argument 3 has type 'uint64_t' LD arch/mips/mm/built-in.o Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29SB1 cache exception handling.Andrew Isaacson
Expand SB1 cache error handling by adding SB1_CEX_ALWAYS_FATAL and SB1_CEX_STALL, allowing configurable behavior on cache errors. Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
