path: root/arch/mips/mm/cerr-sb1.c
2013-06-21MIPS: Sibyte: Fix build for SIBYTE_BW_TRACE on BCM1x55 and BCM1x80.Ralf Baechle
CC arch/mips/mm/cerr-sb1.o arch/mips/mm/cerr-sb1.c: In function ‘sb1_cache_error’: arch/mips/mm/cerr-sb1.c:186:98: error: ‘M_BCM1480_SCD_TRACE_CFG_FREEZE’ undeclared (first use in this function) arch/mips/mm/cerr-sb1.c:186:98: note: each undeclared identifier is reported only once for each function it appears in make[1]: *** [arch/mips/mm/cerr-sb1.o] Error 1 This happens because 8deab1144b553548fb2f1b51affdd36dcd652aaa [[MIPS] Updated Sibyte headers] changed the headers but not all the users. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reported-by: Markos Chandras <markos.chandras@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/5511/
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Sibyte: Use hweight8 instead of counting bitsAkinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/637/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-15[MIPS] Sibyte: Replace use of removed IO_SPACE_BASE with IOADDR.Ralf Baechle
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-03-24[MIPS] SB1: Fix pile of gcc's bogus format string warnings.Ralf Baechle
CC arch/mips/mm/cerr-sb1.o arch/mips/mm/cerr-sb1.c: In function 'sb1_cache_error': arch/mips/mm/cerr-sb1.c:235: warning: format '%010llx' expects type 'long long unsigned int', but argument 2 has type 'uint64_t' arch/mips/mm/cerr-sb1.c: In function 'extract_ic': arch/mips/mm/cerr-sb1.c:385: warning: format '%016llx' expects type 'long long unsigned int', but argument 3 has type 'uint64_t' arch/mips/mm/cerr-sb1.c:385: warning: format '%016llX' expects type 'long long unsigned int', but argument 6 has type 'uint64_t' arch/mips/mm/cerr-sb1.c: In function 'extract_dc': arch/mips/mm/cerr-sb1.c:523: warning: format '%010llx' expects type 'long long unsigned int', but argument 3 has type 'uint64_t' arch/mips/mm/cerr-sb1.c:523: warning: format '%016llX' expects type 'long long unsigned int', but argument 7 has type 'uint64_t' arch/mips/mm/cerr-sb1.c:570: warning: format '%016llX' expects type 'long long unsigned int', but argument 3 has type 'uint64_t' LD arch/mips/mm/built-in.o Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29SB1 cache exception handling.Andrew Isaacson
Expand SB1 cache error handling by adding SB1_CEX_ALWAYS_FATAL and SB1_CEX_STALL, allowing configurable behavior on cache errors. Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
