path: root/arch/mips/mm/page.c
2014-05-28MIPS: R46000: Fix Micro-assembler field overflow for R4600 V2Thomas Bogendoerfer
Fix uasm warning, which triggered because of workaround for R4600 V2 CPUs. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6716/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-01-24mips: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: John Crispin <blogic@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/6320/
2013-09-17MIPS: Optimize current_cpu_type() for better code.Ralf Baechle
o Move current_cpu_type() to a separate header file o #ifdefing on supported CPU types lets modern GCC know that certain code in callers may be discarded ideally turning current_cpu_type() into a function returning a constant. o Use current_cpu_type() rather than direct access to struct cpuinfo_mips. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5833/
2013-07-14MIPS: Delete __cpuinit/__CPUINIT usage from MIPS codePaul Gortmaker
commit 3747069b25e419f6b51395f48127e9812abc3596 upstream. The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) and are flagged as __cpuinit -- so if we remove the __cpuinit from the arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit related content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. Here, we remove all the MIPS __cpuinit from C code and __CPUINIT from asm files. MIPS is interesting in this respect, because there are also uasm users hiding behind their own renamed versions of the __cpuinit macros. [1] https://lkml.org/lkml/2013/5/20/589 [ralf@linux-mips.org: Folded in Paul's followup fix.] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5494/ Patchwork: https://patchwork.linux-mips.org/patch/5495/ Patchwork: https://patchwork.linux-mips.org/patch/5509/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-07-01MIPS: Cleanup indentation and whitespaceTony Wu
Signed-off-by: Tony Wu <tung7970@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5536/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-05-08MIPS: Build uasm-generated code only once to avoid CPU Hotplug problemHuacai Chen
This and the next patch resolve memory corruption problems while CPU hotplug. Without these patches, memory corruption can triggered easily as below: On a quad-core MIPS platform, use "spawn" of UnixBench-5.1.3 (http:// code.google.com/p/byte-unixbench/) and a CPU hotplug script like this (hotplug.sh): while true; do echo 0 >/sys/devices/system/cpu/cpu1/online echo 0 >/sys/devices/system/cpu/cpu2/online echo 0 >/sys/devices/system/cpu/cpu3/online sleep 1 echo 1 >/sys/devices/system/cpu/cpu1/online echo 1 >/sys/devices/system/cpu/cpu2/online echo 1 >/sys/devices/system/cpu/cpu3/online sleep 1 done Run "hotplug.sh" and then run "spawn 10000", spawn will get segfault after a few minutes. This patch: Currently, clear_page()/copy_page() are generated by Micro-assembler dynamically. But they are unavailable until uasm_resolve_relocs() has finished because jump labels are illegal before that. Since these functions are shared by every CPU, we only call build_clear_page()/ build_copy_page() only once at boot time. Without this patch, programs will get random memory corruption (segmentation fault, bus error, etc.) while CPU Hotplug (e.g. one CPU is using clear_page() while another is generating it in cpu_cache_init()). For similar reasons we modify build_tlb_refill_handler()'s invocation. V2: 1, Rework the code to make CPU#0 can be online/offline. 2, Introduce cpu_has_local_ebase feature since some types of MIPS CPU need a per-CPU tlb_refill_handler(). Signed-off-by: Huacai Chen <chenhc@lemote.com> Signed-off-by: Hongbing Hu <huhb@lemote.com> Acked-by: David Daney <david.daney@cavium.com> Patchwork: http://patchwork.linux-mips.org/patch/4994/ Acked-by: John Crispin <blogic@openwrt.org>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-12-13MIPS: PMC-Sierra Yosemite: Remove support.Ralf Baechle
Nobody seems to be interested anymore and upstream also never had an ethernet driver. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-07-19MIPS: Refactor 'clear_page' and 'copy_page' functions.Steven J. Hill
Remove usage of the '__attribute__((alias("...")))' hack that aliased to integer arrays containing micro-assembled instructions. This hack breaks when building a microMIPS kernel. It also makes the code much easier to understand. [ralf@linux-mips.org: Added back export of the clear_page and copy_page symbols so certain modules will work again. Also fixed build with CONFIG_SIBYTE_DMA_PAGEOPS enabled.] Signed-off-by: Steven J. Hill <sjhill@mips.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3866/ Acked-by: David Daney <david.daney@cavium.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2010-02-27MIPS: Move arch/mips/mm/uasm.h to arch/mips/include/asm/uasm.hFlorian Fainelli
Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org To: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/887/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-11MIPS: NEC VR5500 processor support fixupShinya Kuribayashi
Current VR5500 processor support lacks of some functions which are expected to be configured/synthesized on arch initialization. Here're some VR5500A spec notes: * All execution hazards are handled in hardware. * Once VR5500A stops the operation of the pipeline by WAIT instruction, it could return from the standby mode only when either a reset, NMI request, or all enabled interrupts is/are detected. In other words, if interrupts are disabled by Status.IE=0, it keeps in standby mode even when interrupts are internally asserted. Notes on WAIT: The operation of the processor is undefined if WAIT insn is in the branch delay slot. The operation is also undefined if WAIT insn is executed when Status.EXL and Status.ERL are set to 1. * VR5500A core only implements the Load prefetch. With these changes, it boots fine. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-08[MIPS] Fix 32bit kernels on R4k with 128 byte cache line sizeThomas Bogendoerfer
The generated copy_page for R4k CPU with a 128 byte cache line size used Create Dirty Exclusive cache line operations even if only part of the cache line was filled. This change avoids generating cache operations, if only part of the cache line size is copied in one loop. It also increases the maxmimum loop size, because the generated code even fits into the available space for r4k CPUs with 128 byte cache line size. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-16[MIPS] Fix the fix for divide by zero error in build_{clear,copy}_pageAtsushi Nemoto
2008-06-05Fix divide by zero error in build_clear_page() and build_copy_page()Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Reimplement clear_page/copy_pageThiemo Seufer
Fold the SB-1 specific implementation of clear_page/copy_page in the generic version, and rewrite that one in tlbex style. The immediate benefits: - It converts the compile-time workaround for SB-1 pass 1 prefetches to a more efficient run-time check. - It allows adjustment of loop unfolling, which helps to reduce the number of redundant cdex cache ops. - It fixes some esoteric cornercases (the cache line length calculations can go wrong, and support for 64k pages without prefetch instructions will overflow the addiu immediate). - Somewhat better guesses of "good" prefetch values. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
