will also avoid smp_call_function from doing stupid things when called
from a CPU that is not yet marked online.
Those literals are long.
delay slots properly and avoiding an unnecessary jump to a jump.
Signed-off-by: Thiemo Seufer <ths@networkno.de>
TLB handlers a bit, match definitions in pgtable-{32,64}.h better.
This patch has fixed the following warnings.
arch/mips/kernel/genex.S:250:5: warning: "CONFIG_64BIT" is not defined
arch/mips/math-emu/cp1emu.c:1128:5: warning: "__mips64" is not defined
arch/mips/math-emu/cp1emu.c:1206:5: warning: "__mips64" is not defined
arch/mips/math-emu/cp1emu.c:1270:5: warning: "__mips64" is not defined
arch/mips/math-emu/cp1emu.c:323:5: warning: "__mips64" is not defined
arch/mips/math-emu/cp1emu.c:808:5: warning: "__mips64" is not defined
arch/mips/math-emu/cp1emu.c:953:5: warning: "__mips64" is not defined
arch/mips/mm/tlbex.c:519:5: warning: "CONFIG_64BIT" is not defined
include/asm/reg.h:73:5: warning: "CONFIG_64BIT" is not defined
Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp>
Start cleaning 32-bit vs. 64-bit configuration.
infrastructure for it.
Let it rip!
