path: root/arch/mips/mm/uasm-mips.c
2016-08-20MIPS: mm: Fix definition of R6 cache instructionMatt Redfearn
commit 4f53989b0652ffe2605221c81ca8ffcfc90aed2a upstream. Commit a168b8f1cde6 ("MIPS: mm: Add MIPS R6 instruction encodings") added an incorrect definition of the redefined MIPSr6 cache instruction. Executing any kernel code including this instuction results in a reserved instruction exception and kernel panic. Fix the instruction definition. Fixes: a168b8f1cde6588ff7a67699fa11e01bc77a5ddd Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/13663/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-20MIPS: mm: Remove dead macro definitionsAndreas Ruprecht
In commit c441d4a54c6e ("MIPS: mm: Only build one microassembler that is suitable"), the Makefile at arch/mips/mm was rewritten to only build the "right" microassembler file, depending on whether CONFIG_CPU_MICROMIPS is set or not. In the files, however, there are still preprocessor definitions depending on CONFIG_CPU_MICROMIPS. The #ifdef around them can now never evaluate to true, so let's remove them altogether. This inconsistency was found using the undertaker-checkpatch tool. Signed-off-by: Andreas Ruprecht <rupran@einserver.de> Reviewed-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: Valentin Rothberg <valentinrothberg@gmail.com> Cc: Paul Bolle <pebolle@tiscali.nl> Patchwork: https://patchwork.linux-mips.org/patch/9267/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-02-16MIPS: mm: Add MIPS R6 instruction encodingsLeonid Yegoshin
MIPS R6 defines new opcodes for ll, sc, cache and pref instructions so we need to take these into consideration in the micro-assembler. Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2014-11-24MIPS: Add MFHC0 and MTHC0 instructions to uasm.Steven J. Hill
New instructions for Extended Physical Addressing (XPA) functionality. Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/8453/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: mm: uasm: Fix lh micro-assembler instructionMarkos Chandras
Commit d6b3314b49e12e8c349deb4ca28e7028db00728f "MIPS: uasm: Add lh uam instruction" added the 'lh' micro-assembler instruction but it used the 'lw' opcode for it. Fix it by using the correct 'lh' opcode. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7121/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-26MIPS: uasm: Add SLT uasm instructionMarkos Chandras
It will be used later on by bpf-jit Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Markos Chandras <markos.chandras@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/7120/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-30MIPS: uasm: Add lb uasm instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Resolved conflict.] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2014-05-30MIPS: uasm: Add mflo uasm instructionMarkos Chandras
2014-05-30MIPS: uasm: Add mul uasm instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Resolved conflict.] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/6736/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-30MIPS: uasm: Add lh uam instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Resolved conflict.] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/6733/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-30MIPS: uasm: Add wsbh uasm instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Resolved conflict.] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/6732/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-30MIPS: uasm: Add sltu uasm instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Resolved conflict.] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/6731/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-30MIPS: uasm: Add sltiu uasm instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Resolved conflict.] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/6730/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-30MIPS: uasm: Add mfhi uasm instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Resolved conflict.] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Markos Chandras <markos.chandras@imgtec.com> Patchwork: http://patchwork.linux-mips.org/patch/6728/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-30MIPS: uasm: Add divu uasm instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Resolved conflict.] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/6727/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-30MIPS: uasm: Add srlv uasm instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Fixed conflict due to other preceeding conflicts.] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/6726/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-30MIPS: uasm: Add sllv uasm instructionMarkos Chandras
It will be used later on by bpf-jit [ralf@linux-mips.org: Fixed conflict with 49e9529b9d43773307b8c73bd251b71784830c3d [MIPS: uasm: add jalr instruction]. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/6725/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-28MIPS: uasm: add MT ASE yield instructionPaul Burton
This patch allows use of the MT ASE yield instruction from uasm. It will be used by a subsequent patch. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2014-05-28MIPS: uasm: add wait instructionPaul Burton
This patch allows use of the wait instruction from uasm. It will be used by a subsequent patch. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2014-05-28MIPS: uasm: add sync instructionPaul Burton
This patch allows use of the sync instruction from uasm. It will be used by a subsequent patch. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2014-05-28MIPS: uasm: add jalr instructionPaul Burton
This patch allows use of the jalr instruction from uasm. It will be used by a subsequent patch. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2014-01-24mips: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: John Crispin <blogic@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/6320/
2013-07-14MIPS: Delete __cpuinit/__CPUINIT usage from MIPS codePaul Gortmaker
commit 3747069b25e419f6b51395f48127e9812abc3596 upstream. The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) and are flagged as __cpuinit -- so if we remove the __cpuinit from the arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit related content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. Here, we remove all the MIPS __cpuinit from C code and __CPUINIT from asm files. MIPS is interesting in this respect, because there are also uasm users hiding behind their own renamed versions of the __cpuinit macros. [1] https://lkml.org/lkml/2013/5/20/589 [ralf@linux-mips.org: Folded in Paul's followup fix.] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5494/ Patchwork: https://patchwork.linux-mips.org/patch/5495/ Patchwork: https://patchwork.linux-mips.org/patch/5509/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-05-09MIPS: microMIPS: Fix macro naming in micro-assembler.Steven J. Hill
The macros did not properly take into account the ISA that the kernel was being compiled with. A classic MIPS kernel will have the standard 'uasm_i_##op' macro functions with 'MM_uasm_i_##op' macro functions for the microMIPS version. A pure microMIPS kernel will have the standard macros with 'CL_uasm_i_##op' macro functions for the classic version. Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
2013-05-01MIPS: microMIPS: uasm: Split 'uasm.c' into two files.Steven J. Hill
Split 'uasm.c' into two files. The new file 'uasm-mips.c' has the functions specific to the classic MIPS ISA. The 'uasm.c' file contains common code that can be used by classic or other ISAs that could be supported by the kernel. Signed-off-by: Steven J. Hill <sjhill@mips.com> Cc: linux-mips@linux-mips.org Cc: cernekee@gmail.com Cc: kevink@paralogos.com Cc: ddaney.cavm@gmail.com Patchwork: https://patchwork.linux-mips.org/patch/4922/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> (cherry picked from commit 0961103562ab958fa74f35043bf4f72e51ed6155)
