The nmi parameter indicated if we could do wakeups from the current
context, if not, we would set some state and self-IPI and let the
resulting interrupt do the wakeup.
For the various event classes:
- hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from
the PMI-tail (ARM etc.)
- tracepoint: nmi=0; since tracepoint could be from NMI context.
- software: nmi=[0,1]; some, like the schedule thing cannot
perform wakeups, and hence need 0.
As one can see, there is very little nmi=1 usage, and the down-side of
not using it is that on some platforms some software events can have a
jiffy delay in wakeup (when arch_irq_work_raise isn't implemented).
The up-side however is that we can remove the nmi parameter and save a
bunch of conditionals in fast paths.
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
It never really belonged into syscall.c and it's about to become well more
complex.
Add NLM_XLR_BOARD, CPU_XLR and other config options
Makefile updates, mostly based on r4k
Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com>
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2334/
CPU_XLR case added to mm/tlbex.c
CPU_XLR case added to mm/c-r4k.c for PINDEX attribute
Feature overrides for XLR cpu.
Patchwork: https://patchwork.linux-mips.org/patch/2333/
CC arch/mips/mm/tlbex.o
arch/mips/mm/tlbex.c: In function 'build_r4000_tlb_refill_handler':
arch/mips/mm/tlbex.c:1155:22: error: variable 'vmalloc_mode' set but not used [-Werror=unused-but-set-variable]
arch/mips/mm/tlbex.c:1154:28: error: variable 'htlb_info' set but not used [-Werror=unused-but-set-variable]
cc1: all warnings being treated as errors
CC arch/mips/mm/c-r4k.o
arch/mips/mm/c-r4k.c: In function 'probe_scache':
arch/mips/mm/c-r4k.c:1078:6: error: variable 'tmp' set but not used [-Werror=unused-but-set-variable]
Older GCC versions didn't warn about the unused variable tmp because it was
getting initialized.
Fast-forwarded to current state of Linus' tree as there are patches to be
applied for files that didn't exist on the old branch.
Under some combinations of CONFIG_*, lastpfn in page_is_ram is 'set
but not used'. Mark it as __maybe_unused to quiet the warning/error.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/2033/
It was reported that GCC-4.3.3 (with CodeSourcery extensions) fails
without this.
Reported-by: Jonas Gorski <jonas.gorski@gmail.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2010/
On the off chance that uasm ever warns about overflow, there is no way
to know what the offending instruction is.
Change the printks to WARNs, so we can get a nice stack trace. It has
the added benefit of being much more noticeable than the short single
line warning message, so is less likely to be ignored.
Patchwork: https://patchwork.linux-mips.org/patch/1905/
Octeon can use scratch registers in the TLB handlers. Octeon II can
use LDX instructions.
Patchwork: https://patchwork.linux-mips.org/patch/1904/
Needed by Octeon II optimized TLB handlers.
Pachwork: https://patchwork.linux-mips.org/patch/1903/
If the CPU supports BBIT0 and BBIT1, use them in TLB handlers as they
are more efficient than an AND followed by an branch and then
restoring the clobbered register.
Patchwork: https://patchwork.linux-mips.org/patch/1873/
Decide at runtime to use either Context or KScratch to hold the PGD
pointer.
Patchwork: https://patchwork.linux-mips.org/patch/1876/
Patchwork: https://patchwork.linux-mips.org/patch/1875/
Seen with malta_defconfig on Linus' tree:
CC arch/mips/mm/sc-mips.o
arch/mips/mm/sc-mips.c: In function 'mips_sc_is_activated':
arch/mips/mm/sc-mips.c:77: error: 'config2' undeclared (first use in this function)
arch/mips/mm/sc-mips.c:77: error: (Each undeclared identifier is reported only once
arch/mips/mm/sc-mips.c:77: error: for each function it appears in.)
arch/mips/mm/sc-mips.c:81: error: 'tmp' undeclared (first use in this function)
make[2]: *** [arch/mips/mm/sc-mips.o] Error 1
make[1]: *** [arch/mips/mm] Error 2
make: *** [arch/mips] Error 2
[Ralf: Cosmetic changes to minimize the number of arguments passed to
mips_sc_is_activated]
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/1752/
This fixes IP22 and IP28 build errors.
On many of the newer MIPS32 cores, CP0 CONFIG2 bit 12 (L2B) indicates
that the L2 cache is disabled and therefore Linux should not attempt
to use it.
[Ralf: Moved the code added by Kevin's original patch into a separate
function that can easily be replaced for platforms that need more a
different probe.]
Cc: linux-mips@linux-mips.org>
Cc: <linux-kernel@vger.kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/1723/
BMIPS processor cores are used in 50+ different chipsets spread across
5+ product lines. In many cases the chipsets do not share the same
peripheral register layouts, the same register blocks, the same
interrupt controllers, the same memory maps, or much of anything else.
But, across radically different SoCs that share nothing more than the
same BMIPS CPU, a few things are still mostly constant:
SMP operations
Access to performance counters
DMA cache coherency quirks
Cache and memory bus configuration
So, it makes sense to treat each BMIPS processor type as a generic
"building block," rather than tying it to a specific SoC. This makes it
easier to support a large number of BMIPS-based chipsets without
unnecessary duplication of code, and provides the infrastructure needed
to support BMIPS-proprietary features.
Cc: mbizon@freebox.fr
Tested-by: Florian Fainelli <ffainelli@freebox.fr>
Patchwork: https://patchwork.linux-mips.org/patch/1706/
Software events are required as part of the measurable stuff by the
Linux performance counter subsystem. Here is the list of events added by
this patch:
PERF_COUNT_SW_PAGE_FAULTS
PERF_COUNT_SW_PAGE_FAULTS_MIN
PERF_COUNT_SW_PAGE_FAULTS_MAJ
PERF_COUNT_SW_ALIGNMENT_FAULTS
PERF_COUNT_SW_EMULATION_FAULTS
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: a.p.zijlstra@chello.nl
Cc: paulus@samba.org
Cc: mingo@elte.hu
Cc: acme@redhat.com
Cc: jamie.iles@picochip.com
Acked-by: David Daney <ddaney@caviumnetworks.com>
Reviewed-by: Matt Fleming <matt@console-pimps.org>
Patchwork: https://patchwork.linux-mips.org/patch/1686/
The CN63XXP1 needs a couple of workarounds to ensure memory is not written
in unexpected ways.
All PREF with hints in the range 0-4,6-24 are replaced with PREF 28. We
pass a flag to the assembler to cover compiler generated code, and patch
uasm for the dynamically generated code.
The write buffer threshold is reduced to 4.
Patchwork: http://patchwork.linux-mips.org/patch/1672/
Patchwork: http://patchwork.linux-mips.org/patch/1664/
Use asm-generic/dma-mapping-common.h to handle all DMA mapping operations
and establish a default get_dma_ops() that forwards all operations to the
existing code.
Augment dev_archdata to carry a pointer to the struct dma_map_ops, allowing
DMA operations to be overridden on a per device basis. Currently this is
never filled in, so the default dma_map_ops are used. A follow-on patch
sets this for Octeon PCI devices.
Also initialize the dma_debug system as it is now used if it is configured.
Includes fixes by Kevin Cernekee <cernekee@gmail.com>.
Patchwork: http://patchwork.linux-mips.org/patch/1637/
Patchwork: http://patchwork.linux-mips.org/patch/1678/
All callers were passing in 1 anyway.
Christoph reported a nice splat which illustrated a race in the new stack
based kmap_atomic implementation.
The problem is that we pop our stack slot before we're completely done
resetting its state -- in particular clearing the PTE (sometimes that's
CONFIG_DEBUG_HIGHMEM). If an interrupt happens before we actually clear
the PTE used for the last slot, that interrupt can reuse the slot in a
dirty state, which triggers a BUG in kmap_atomic().
Fix this by introducing kmap_atomic_idx() which reports the current slot
index without actually releasing it and use that to find the PTE and delay
the _pop() until after we're completely done.
Reported-by: Christoph Hellwig <hch@infradead.org>
Keep the current interface but ignore the KM_type and use a stack based
approach.
The advantage is that we get rid of crappy code like:
#define __KM_PTE \
(in_nmi() ? KM_NMI_PTE : \
in_irq() ? KM_IRQ_PTE : \
KM_PTE0)
and in general can stop worrying about what context we're in and what kmap
slots might be appropriate for that.
The downside is that FRV kmap_atomic() gets more expensive.
For now we use a CPP trick suggested by Andrew:
#define kmap_atomic(page, args...) __kmap_atomic(page)
to avoid having to touch all kmap_atomic() users in a single patch.
[ not compiled on:
- mn10300: the arch doesn't actually build with highmem to begin with ]
[akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c]
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Li Zefan <lizf@cn.fujitsu.com>
This only matters for ISA devices with a 24-bit DMA limit or for devices
with a 32-bit DMA limit on systems with ZONE_DMA32 enabled. The latter
currently only affects 32-bit PCI cards on Sibyte-based systems with more
than 1GB RAM installed.
Signed-off-by: Ricardo Mendoza <ricmm@gentoo.org>
Patchwork: https://patchwork.linux-mips.org/patch/1540/
Architectures implement dma_is_consistent() in different ways (some
misinterpret the definition of API in DMA-API.txt). So it hasn't been so
useful for drivers. We have only one user of the API in tree. Unlikely
out-of-tree drivers use the API.
Even if we fix dma_is_consistent() in some architectures, it doesn't look
useful at all. It was invented long ago for some old systems that can't
allocate coherent memory at all. It's better to export only APIs that are
definitely necessary for drivers.
Let's remove this API.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <linux-arch@vger.kernel.org>
kunmap_atomic() is currently at level -4 on Rusty's "Hard To Misuse"
list[1] ("Follow common convention and you'll get it wrong"), except in
some architectures when CONFIG_DEBUG_HIGHMEM is set[2][3].
kunmap() takes a pointer to a struct page; kunmap_atomic(), however, takes
takes a pointer to within the page itself. This seems to once in a while
trip people up (the convention they are following is the one from
kunmap()).
Make it much harder to misuse, by moving it to level 9 on Rusty's list[4]
("The compiler/linker won't let you get it wrong"). This is done by
refusing to build if the type of its first argument is a pointer to a
struct page.
The real kunmap_atomic() is renamed to kunmap_atomic_notypecheck()
(which is what you would call in case for some strange reason calling it
with a pointer to a struct page is not incorrect in your code).
The previous version of this patch was compile tested on x86-64.
[1] http://ozlabs.org/~rusty/index.cgi/tech/2008-04-01.html
[2] In these cases, it is at level 5, "Do it right or it will always
break at runtime."
[3] At least mips and powerpc look very similar, and sparc also seems to
share a common ancestor with both; there seems to be quite some
degree of copy-and-paste coding here. The include/asm/highmem.h file
for these three archs mention x86 CPUs at its top.
[4] http://ozlabs.org/~rusty/index.cgi/tech/2008-03-30.html
[5] As an aside, could someone tell me why mn10300 uses unsigned long as
the first parameter of kunmap_atomic() instead of void *?
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
Cc: Russell King <linux@arm.linux.org.uk> (arch/arm)
Cc: Ralf Baechle <ralf@linux-mips.org> (arch/mips)
Cc: David Howells <dhowells@redhat.com> (arch/frv, arch/mn10300)
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> (arch/mn10300)
Cc: Kyle McMartin <kyle@mcmartin.ca> (arch/parisc)
Cc: Helge Deller <deller@gmx.de> (arch/parisc)
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> (arch/parisc)
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> (arch/powerpc)
Cc: Paul Mackerras <paulus@samba.org> (arch/powerpc)
Cc: "David S. Miller" <davem@davemloft.net> (arch/sparc)
Cc: Thomas Gleixner <tglx@linutronix.de> (arch/x86)
Cc: Ingo Molnar <mingo@redhat.com> (arch/x86)
Cc: "H. Peter Anvin" <hpa@zytor.com> (arch/x86)
Cc: Arnd Bergmann <arnd@arndb.de> (include/asm-generic)
Cc: Rusty Russell <rusty@rustcorp.com.au> ("Hard To Misuse" list)
This patch is based on previous work by Sony and Himanshu Chauhan.
I have done some cleanup and implemented JProbes and KRETPROBES. The
KRETPROBES part is pretty much copied verbatim from powerpc. A possible
future enhance might be to factor out the common code.
Cc: Himanshu Chauhan <hschauhan@nulltrace.org>
To: ananth@in.ibm.com,
To: anil.s.keshavamurthy@intel.com
To: davem@davemloft.net
To: masami.hiramatsu.pt@hitachi.com
Patchwork: https://patchwork.linux-mips.org/patch/1525/
Patchwork: https://patchwork.linux-mips.org/patch/1530/
A 'select EXPORT_UASM' in Kconfig will cause the uasm to be exported
for use in modules. When it is exported, all the uasm data and code
cease to be __init and __initdata.
Also daddiu_bug cannot be __cpuinitdata if uasm is exported. The
cleanest thing is to just make it normal data.
To: wim@iguana.be
Patchwork: https://patchwork.linux-mips.org/patch/1500/
These are OCTEON specific instructions.
To: wim@iguana.be
Patchwork: https://patchwork.linux-mips.org/patch/1496/
To: wim@iguana.be
Patchwork: https://patchwork.linux-mips.org/patch/1495/
Adds a new cpu type for the JZ4740 to the Linux MIPS architecture code.
It also adds the iomem addresses for the different components found on
a JZ4740 SoC.
Patchwork: https://patchwork.linux-mips.org/patch/1464/
Add support for the external T-cache interface. Allow for platform
independent size probing from 512KB to 8MB in powers of two.
Patchwork: https://patchwork.linux-mips.org/patch/1477/
Small cleanup of the cache code to get rid of inline asm, in preparation
to give tertiary cache support.
Patchwork: https://patchwork.linux-mips.org/patch/1476/
Adding subdirs-ccflags-y := -Werror to arch/mips/Kbuild
let us in one go cover all files with -Werror.
In addition this allows us to remove the
individual -Werror definition in various Makefile.
Adding the definition to Kbuild as a recursive
option help us not to forget to do so.
With this change we now compile arch/mips/kernel/cpufreq with -Werror
One drawback:
When specifying a subdirectory covered by the Kbuild file like this:
make arch/mips/kernel/
then kbuild fails to pick up the -Werror definition.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
To: linux-mips <linux-mips@linux-mips.org>
To: Wu Zhangjin <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/1301/
For some combinations of PAGE_SIZE and vmbits, it is possible to have
userspace access that are beyond what is covered by the PGD, but within
vmbits. Such an access would cause the TLB refill handler to load garbage
values for PMD and PTE potentially giving userspace access to parts of the
physical address space to which it is not entitled.
In the TLB refill hot path, we add a single dsrl instruction so we can
check if any bits outside of the range covered by the PGD are set. In
the vmalloc side we then separate the bad case from the normal vmalloc
case and call tlb_do_page_fault_0 if warranted. This slows us down a
bit, but has the benefit of yielding deterministic behavior.
[Ralf: Fixed build error for 32-bit kernels.]
[Ralf: Folded lmo commit c8c0e22b2aa3982852b44279638ef37f9aa31b7d into this
commit.]
Patchwork: http://patchwork.linux-mips.org/patch/1152/
This makes the code somewhat cleaner while reducing the risk of shift
amount overflows when various page table related options are changed.
Patchwork: http://patchwork.linux-mips.org/patch/1154/
Commit b3594a089f1c17ff919f8f78505c3f20e1f6f8ce (lmo) rsp.
351336929ccf222ae38ff0cb7a8dd5fd5c6236a0 (kernel.org) break non-GPL modules
that use __vmalloc() or any of the vmap(), vm_map_ram(), etc functions on
MIPS.
All those functions are EXPORT_SYMBOL() so are meant to be allowed to be
used by non-GPL kernel modules. These calls all take page protection as
an argument which is normally a constant like PAGE_KERNEL.
This commit causes all protection constants like PAGE_KERNEL to not be
constants and instead to contain the GPL-only symbol _page_cachable_default.
This means that all calls to __vmalloc(), vmap(), etc, cause non-GPL
modules to fail to link with the complaint that they are trying to use the
GPL-only symbol _page_cachable_default...
Change EXPORT_SYMBOL_GPL(_page_cachable_default) to EXPORT_SYMBOL() for
non-GPL modules that call __vmalloc(), vmap(), vm_map_ram() etc.
Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
Cc: Chris Dearman <chris@mips.com>
Patchwork: http://patchwork.linux-mips.org/patch/1084/
The M3 workaround needs to cmpare the region and VPN2 fields only.
This is needed for the fix of the M3 workaround.
Patchwork: http://patchwork.linux-mips.org/patch/976/
