Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit f86f55d3ad21b21b736bdeb29bee0f0937b77138 upstream.
The BMIPS5000 (Zephyr) processor utilizes instruction speculation. A
stale misprediction address in either the JTB or the CRS may trigger
a prefetch inside a region that is currently being used by a DMA engine,
which is not IO-coherent. This prefetch will fetch a line into the
scache, and that line will soon become stale (ie wrong) during/after the
DMA. Mayhem ensues.
In dma-default.c, the r10000 is handled as a special case in the same way
that we want to handle Zephyr. So we generalize the exception cases into
a function, and include Zephyr as one of the processors that needs this
special care.
Signed-off-by: Jim Quinlan <jim2101024@gmail.com>
Cc: linux-mips@linux-mips.org
Cc: cernekee@gmail.com
Patchwork: https://patchwork.linux-mips.org/patch/5776/
Cc: John Ulvr <julvr@broadcom.com>
Unlike global OOM handling, memory cgroup code will invoke the OOM killer
in any OOM situation because it has no way of telling faults occuring in
kernel context - which could be handled more gracefully - from
user-triggered faults.
Pass a flag that identifies faults originating in user space from the
architecture-specific fault handlers to generic code so that memcg OOM
handling can be improved.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: azurIt <azurit@pobox.sk>
(cherry picked from commit 407c454cb0ac6e68ca66974da787a71118cfef84)
arch/arc/mm/fault.c
arch/arm64/mm/fault.c
arch/metag/mm/fault.c
arch/parisc/mm/fault.c
Change-Id: Iee53942737627be8dd8e2e325b5ba87fe85d6814
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/266410
GVS: Gerrit_Virtual_Submit
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Kernel faults are expected to handle OOM conditions gracefully (gup,
uaccess etc.), so they should never invoke the OOM killer. Reserve this
for faults triggered in user context when it is the only option.
Most architectures already do this, fix up the remaining few.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Change-Id: Id58a8ebe3ee619ef9ae3590b5788823fa6bd2dce
Reviewed-on: http://git-master/r/266404
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
In C, one definition is sufficient.
Signed-off-by: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/5304/
This reverts commit d532f3d26716a39dfd4b88d687bd344fbe77e390.
The original commit has several problems:
1) Doesn't work with 64-bit kernels.
2) Calls TLBMISS_HANDLER_SETUP() before the code is generated.
3) Calls TLBMISS_HANDLER_SETUP() twice in per_cpu_trap_init() when
only one call is needed.
[ralf@linux-mips.org: Also revert the bits of the ASID patch which were
hidden in the KVM merge.]
Cc: "Steven J. Hill" <Steven.Hill@imgtec.com>
Cc: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/5242/
This reverts commit f6b06d9361a008afb93b97fb3683a6e92d69d0f4.
The next revert depends on this one, so this has to go too.
Patchwork: https://patchwork.linux-mips.org/patch/5241/
Pull MIPS updates from Ralf Baechle:
- More work on DT support for various platforms
- Various fixes that were to late to make it straight into 3.9
- Improved platform support, in particular the Netlogic XLR and
BCM63xx, and the SEAD3 and Malta eval boards.
- Support for several Ralink SOC families.
- Complete support for the microMIPS ASE which basically reencodes the
existing MIPS32/MIPS64 ISA to use non-constant size instructions.
- Some fallout from LTO work which remove old cruft and will generally
make the MIPS kernel easier to maintain and resistant to compiler
optimization, even in absence of LTO.
- KVM support. While MIPS has announced hardware virtualization
extensions this KVM extension uses trap and emulate mode for
virtualization of MIPS32. More KVM work to add support for VZ
hardware virtualizaiton extensions and MIPS64 will probably already
be merged for 3.11.
Most of this has been sitting in -next for a long time. All defconfigs
have been build or run time tested except three for which fixes are being
sent by other maintainers.
Semantic conflict with kvm updates done as per Ralf
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (118 commits)
MIPS: Add new GIC clockevent driver.
MIPS: Formatting clean-ups for clocksources.
MIPS: Refactor GIC clocksource code.
MIPS: Move 'gic_frequency' to common location.
MIPS: Move 'gic_present' to common location.
MIPS: MIPS16e: Add unaligned access support.
MIPS: MIPS16e: Support handling of delay slots.
MIPS: MIPS16e: Add instruction formats.
MIPS: microMIPS: Optimise 'strnlen' core library function.
MIPS: microMIPS: Optimise 'strlen' core library function.
MIPS: microMIPS: Optimise 'strncpy' core library function.
MIPS: microMIPS: Optimise 'memset' core library function.
MIPS: microMIPS: Add configuration option for microMIPS kernel.
MIPS: microMIPS: Disable LL/SC and fix linker bug.
MIPS: microMIPS: Add vdso support.
MIPS: microMIPS: Add unaligned access support.
MIPS: microMIPS: Support handling of delay slots.
MIPS: microMIPS: Add support for exception handling.
MIPS: microMIPS: Floating point support.
MIPS: microMIPS: Fix macro naming in micro-assembler.
git://git.linux-mips.org/pub/scm/sjhill/linux-sjhill into mips-for-linux-next
All exceptions must be taken in microMIPS mode, never in classic
MIPS mode or the kernel falls apart. A few NOP instructions are
used to maintain the correct alignment of microMIPS versions of
the exception vectors.
Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
The macros did not properly take into account the ISA that
the kernel was being compiled with. A classic MIPS kernel
will have the standard 'uasm_i_##op' macro functions with
'MM_uasm_i_##op' macro functions for the microMIPS version.
A pure microMIPS kernel will have the standard macros with
'CL_uasm_i_##op' macro functions for the classic version.
Jump or branch target addresses have the first bit set. The
original mask did not take this into account and will cause
a field overflow warning for the target address when a jump
immediate instruction is built.
Changes for pure microMIPS cores to dynamically determine the ASID
size at boot time.
Includes bug fix https://patchwork.linux-mips.org/patch/5230/
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
Original patch by Ralf Baechle and removed by Harold Koerfgen
with commit f67e4ffc79905482c3b9b8c8dd65197bac7eb508. This
allows for more generic kernels since the size of the ASID
and corresponding masks can be determined at run-time. This
patch is also required for the new Aptiv cores and has been
tested on Malta and Malta Aptiv platforms.
[ralf@linux-mips.org: Added relevant part of fix
https://patchwork.linux-mips.org/patch/5213/]
Signed-off-by: Sanjay Lal <sanjayl@kymasys.com>
Cc: kvm@vger.kernel.org
git://git.linux-mips.org/pub/scm/john/linux-john into mips-for-linux-next
This and the next patch resolve memory corruption problems while CPU
hotplug. Without these patches, memory corruption can triggered easily
as below:
On a quad-core MIPS platform, use "spawn" of UnixBench-5.1.3 (http://
code.google.com/p/byte-unixbench/) and a CPU hotplug script like this
(hotplug.sh):
while true; do
echo 0 >/sys/devices/system/cpu/cpu1/online
echo 0 >/sys/devices/system/cpu/cpu2/online
echo 0 >/sys/devices/system/cpu/cpu3/online
sleep 1
echo 1 >/sys/devices/system/cpu/cpu1/online
echo 1 >/sys/devices/system/cpu/cpu2/online
echo 1 >/sys/devices/system/cpu/cpu3/online
sleep 1
done
Run "hotplug.sh" and then run "spawn 10000", spawn will get segfault
after a few minutes.
This patch:
Currently, clear_page()/copy_page() are generated by Micro-assembler
dynamically. But they are unavailable until uasm_resolve_relocs() has
finished because jump labels are illegal before that. Since these
functions are shared by every CPU, we only call build_clear_page()/
build_copy_page() only once at boot time. Without this patch, programs
will get random memory corruption (segmentation fault, bus error, etc.)
while CPU Hotplug (e.g. one CPU is using clear_page() while another is
generating it in cpu_cache_init()).
For similar reasons we modify build_tlb_refill_handler()'s invocation.
V2:
1, Rework the code to make CPU#0 can be online/offline.
2, Introduce cpu_has_local_ebase feature since some types of MIPS CPU
need a per-CPU tlb_refill_handler().
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Signed-off-by: Hongbing Hu <huhb@lemote.com>
Acked-by: David Daney <david.daney@cavium.com>
Patchwork: http://patchwork.linux-mips.org/patch/4994/
Acked-by: John Crispin <blogic@openwrt.org>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Some MIPS controllers have hardware I/O coherency. This patch
detects those and turns off software coherency. A new kernel
command line option also allows the user to manually turn
software coherency on or off.
Add new file 'uasm-micromips.c' that allows the micro assembler
to generate microMIPS ISA code. It can be included in the kernel
alongside the classic ISA as long as the platform supports the
microMIPS ISA.
Signed-off-by: Steven J. Hill <sjhill@mips.com>
Cc: kevink@paralogos.com
Cc: ddaney.cavm@gmail.com
Patchwork: https://patchwork.linux-mips.org/patch/4923/
(cherry picked from commit 5f011a866afbd03a5379f67f4e70e5efbdfc16e9)
Split 'uasm.c' into two files. The new file 'uasm-mips.c' has the
functions specific to the classic MIPS ISA. The 'uasm.c' file
contains common code that can be used by classic or other ISAs
that could be supported by the kernel.
Patchwork: https://patchwork.linux-mips.org/patch/4922/
(cherry picked from commit 0961103562ab958fa74f35043bf4f72e51ed6155)
Use helper function free_highmem_page() to free highmem pages into
the buddy system.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Cong Wang <amwang@redhat.com>
Use common help functions to free reserved pages.
Split kcore bits from linux/procfs.h into linux/kcore.h.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
cc: linux-mips@linux-mips.org
cc: sparclinux@vger.kernel.org
cc: x86@kernel.org
cc: linux-mm@kvack.org
tlbmiss_handler_setup_pgd is run-time generated code and it was convenient
to pretend the symbol was an array in the generator but a function for
the users. LTO gcc won't tolerate this kind of lie anymore so solve the
problem through a cast and function pointer instead.
The commit a96102be70 introduced set_isa() where compatible ISA info is
also set aside from the one gets passed in. It means, for example, 1004K
will have MIPS_CPU_ISA_M32R2/M32R1/II/I flags. This leads to things like
the following inappropriate:
if (c->isa_level == MIPS_CPU_ISA_M32R1 ||
c->isa_level == MIPS_CPU_ISA_M32R2 ||
c->isa_level == MIPS_CPU_ISA_M64R1 ||
c->isa_level == MIPS_CPU_ISA_M64R2)
This patch fixes it.
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Patchwork: http://patchwork.linux-mips.org/patch/4682/
Signed-off-by: John Crispin <blogic@openwrt.org>
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
Commit d3ce88431892 "MIPS: Fix modpost error in modules attepting to use
virt_addr_valid()" moved __virt_addr_valid() from a macro in a header
file to a function in ioremap.c. But ioremap.c is only compiled for MIPS
32, and not for MIPS 64.
When compiling for my yeeloong2, which supposedly supports hibernation,
which compiles kernel/power/snapshot.c which calls virt_addr_valid(), I
got this error:
LD init/built-in.o
kernel/built-in.o: In function `memory_bm_free':
snapshot.c:(.text+0x4c9c4): undefined reference to `__virt_addr_valid'
snapshot.c:(.text+0x4ca58): undefined reference to `__virt_addr_valid'
kernel/built-in.o: In function `snapshot_write_next':
(.text+0x4e44c): undefined reference to `__virt_addr_valid'
(.text+0x4e890): undefined reference to `__virt_addr_valid'
make[1]: *** [vmlinux] Error 1
make: *** [sub-make] Error 2
I suspect that __virt_addr_valid() is fine for mips 64. I moved it to
mmap.c such that it gets compiled for mips 64 and 32.
Patchwork: https://patchwork.linux-mips.org/patch/4842/
ERROR: "min_low_pfn" [drivers/block/aoe/aoe.ko] undefined!
Fixed by moving the implementation of virt_addr_valid() into the kernel
proper and exporting it which removes the pains of an inline or macro
implementation.
So far we're jumping through hoops to keep the file usable from assembler
source but it's getting just too painful. Turns out that many uses of
<asm/page.h> are unnecessary anyway, so just remove those.
This reverts commit ff401e52100dcdc85e572d1ad376d3307b3fe28e.
This breaks on MIPS64 R2 cores such as Broadcom's.
"The MIPS bits for 3.8. This also includes a bunch fixes that were
sitting in the linux-mips.org git tree for a long time. This pull
request contains updates to several OCTEON drivers and the board
support code for BCM47XX, BCM63XX, XLP, XLR, XLS, lantiq, Loongson1B,
updates to the SSB bus support, MIPS kexec code and adds support for
kdump.
When pulling this, there are two expected merge conflicts in
include/linux/bcma/bcma_driver_chipcommon.h which are trivial to
resolve, just remove the conflict markers and keep both alternatives."
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (90 commits)
MIPS: PMC-Sierra Yosemite: Remove support.
VIDEO: Newport Fix console crashes
MIPS: wrppmc: Fix build of PCI code.
MIPS: IP22/IP28: Fix build of EISA code.
MIPS: RB532: Fix build of prom code.
MIPS: PowerTV: Fix build.
MIPS: IP27: Correct fucked grammar in ops-bridge.c
MIPS: Highmem: Fix build error if CONFIG_DEBUG_HIGHMEM is disabled
MIPS: Fix potencial corruption
MIPS: Fix for warning from FPU emulation code
MIPS: Handle COP3 Unusable exception as COP1X for FP emulation
MIPS: Fix poweroff failure when HOTPLUG_CPU configured.
MIPS: MT: Fix build with CONFIG_UIDGID_STRICT_TYPE_CHECKS=y
MIPS: Remove unused smvp.h
MIPS/EDAC: Improve OCTEON EDAC support.
MIPS: OCTEON: Add definitions for OCTEON memory contoller registers.
MIPS: OCTEON: Add OCTEON family definitions to octeon-model.h
ata: pata_octeon_cf: Use correct byte order for DMA in when built little-endian.
MIPS/OCTEON/ata: Convert pata_octeon_cf.c to use device tree.
MIPS: Remove usage of CEVT_R4K_LIB config option.
mips-for-linux-next
Nobody seems to be interested anymore and upstream also never had an
ethernet driver.
CC arch/mips/mm/highmem.o
/home/ralf/src/linux/linux-mips/arch/mips/mm/highmem.c: In function ‘__kunmap_atomic’:
/home/ralf/src/linux/linux-mips/arch/mips/mm/highmem.c:70:6: error: variable ‘type’ set but not used [-Werror=unused-but-set-variable]
cc1: all warnings being treated as errors
This warning exists in gcc 4.6.0 and newer. Kernels 2.6.40 and newer use
-Wunused-but-set-variable to suppress it.
Normally r4k_dma_cache_inv should only ever be called with cacheline
aligned addresses. If however, it isn't there is the theoretical
possibility of data corruption. There is no correct way of handling this
and anyway, it should only happen if the DMA API is used incorrectly
so drop
There is a different corruption scenario with these CACHE instructions
removed but again there is no way of handling this correctly and it can
be triggered only through incorrect use of the DMA API.
So just get rid of the complexity.
Reported-by: James Rodriguez <jamesr@juniper.net>
Some initialization errors are reported with the existing OCTEON EDAC
support patch. Also some parts have more than one memory controller.
Fix the errors and add multiple controllers if present.
Drivers for EDAC on Cavium. Supported subsystems are:
o CPU primary caches. These are parity protected only, so only error
reporting.
o Second level cache - ECC protected, provides SECDED.
o Memory: ECC / SECDEC if used with suitable DRAM modules. The driver will
will only initialize if ECC is enabled on a system so is safe to run on
non-ECC memory.
o PCI: Parity error reporting
Since it is very hard to test this sort of code the implementation is very
conservative and uses polling where possible for now.
Reviewed-by: Borislav Petkov <borislav.petkov@amd.com>
We need Huge TLBs for HUGETLB_PAGE, or the soon to follow
TRANSPARENT_HUGEPAGE. collect this information under a single Kconfig
symbol.
Update the mips arch_get_unmapped_area[_topdown] functions to make use of
vm_unmapped_area() instead of implementing a brute force search.
[akpm@linux-foundation.org: remove now-unused COLOUR_ALIGN_DOWN()]
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Problem:
1) Huge page mapping of anonymous memory is initially invalid. Will be
faulted in by copy-on-write mechanism.
2) Userspace attempts store at the end of the huge mapping.
3) TLB Refill exception handler fill TLB with a normal (4K sized)
invalid page at the end of the huge mapping virtual address range.
4) Userspace restarted, and re-attempts the store at the end of the
huge mapping.
5) Page from #3 is invalid, we get a fault and go to the hugepage
fault handler. This tries to map a huge page and calls
huge_ptep_set_access_flags() to install the mapping.
6) We just call the generic ptep_set_access_flags() to set up the page
tables, but the flush there assumes a normal (4K sized) page and
only tries to flush the first part of the huge page virtual address
out of the TLB, since the existing entry from step #3 doesn't
conflict, nothing is flushed.
7) We attempt to load the mapping into the TLB, but because it
conflicts with the entry from step #3, we get a Machine Check
exception.
The fix: Flush the entire rage covered by the huge page in
huge_ptep_set_access_flags(), and remove the optimization in
local_flush_tlb_range() so that the flush actually does the correct
thing.
Cc: Hillf Danton <dhillf@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/4661/
(cherry picked from commit dd617f258cc39d36be26afee9912624a2d23112c)
Pgtable bits are assigned dynamically depending on processor feature and
statically based on kernel configuration. To make sense out of the
disassembled TLB exception handlers a list of the actual assignments
used for a particular configuration and hardware setup can be very useful.
Output the actual TLB exception handlers in a format that simplifies their
post processsing from dmesg output.
From a software perspective R5000 and R5000A are the same thing which is
why the symbol CPU_R5000A never got used, so finally delete it.
Commit 97ce2c88f9ad42e3c60a9beb9fca87abf3639faa (jump-label: initialize
jump-label subsystem much earlier) caused MIPS to break, so this was
resolved with commit 6650df3c380e0db558dbfec63ed860402c6afb2a (MIPS:
Move cache setup to setup_arch().). Unfortunately, after this commit,
the coherency kernel parameters, cca and coherentio, are no longer
processed before their values are used.
This patch fixes this problem by marking them as early_param, which
results in them being processed before they are needed.
Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com>
Patchwork: http://patchwork.linux-mips.org/patch/3961
The new functions introduced in commit 02a5417751 (MIPS: tlbex: Deal with
re-definition of label) should be marked __cpuinit, to eliminate a
warning that can pop up when CONFIG_EXPORT_UASM is disabled:
LD arch/mips/mm/built-in.o
WARNING: arch/mips/mm/built-in.o(.text+0x2a4c): Section mismatch in reference from the function uasm_bgezl_hazard() to the function .cpuinit.text:uasm_il_bgezl()
The function uasm_bgezl_hazard() references
the function __cpuinit uasm_il_bgezl().
This is often because uasm_bgezl_hazard lacks a __cpuinit
annotation or the annotation of uasm_il_bgezl is wrong.
WARNING: arch/mips/mm/built-in.o(.text+0x2a68): Section mismatch in reference from the function uasm_bgezl_label() to the function .cpuinit.text:uasm_build_label()
The function uasm_bgezl_label() references
the function __cpuinit uasm_build_label().
This is often because uasm_bgezl_label lacks a __cpuinit
annotation or the annotation of uasm_build_label is wrong.
(This warning might not occur if the function was inlined.)
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Patchwork: http://patchwork.linux-mips.org/patch/4517
On some CPU the write to pagemask might complete before the TLB write
instruction reads from the pagemask register.
