Fix the cache index value in tx49_blast_icache32_page_indexed().
This is damage by de62893bc0725f8b5f0445250577cd7a10b2d8f8 commit.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
If dcache_size != icache_size or dcache_size != scache_size, or
set-associative cache, icache/scache does not flushed properly. Make
blast_?cache_page_indexed() masks its index value correctly. Also,
use physical address for physically indexed pcache/scache.
Found by make buildcheck.
When a CPU has no scache, the scache flushing functions currently
aren't getting initialized and the NULL pointer is eventually called
as a function. Initialize the scache flushing functions as a noop
when there's no scache.
Initial patch by me and most of the debugging done by Martin Michlmayr.
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
Add blast_xxx_range(), protected_blast_xxx_range() etc. for common
use. They are built by __BUILD_BLAST_CACHE_RANGE().
Use protected_cache_op() macro for various protected_ routines.
Output code should be logically same.
I'm pretty sure that the CKSEG0 bits are wrong, but I did need to
cover that region - because the SB-1 kernel links at 0xffffffff80100000
or so, disassembly and printing static variables don't work unless the
debugger can read that region.
Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com>
This fixes sparse warnings 'dereference of noderef expression'.
Page count should be initialized to 1 on each of the MIPS empty zero pages,
to avoid a bad_page warning whenever one of them is freed from all mappings.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
First step in pushing down the page_table_lock. init_mm.page_table_lock has
been used throughout the architectures (usually for ioremap): not to serialize
kernel address space allocation (that's usually vmlist_lock), but because
pud_alloc,pmd_alloc,pte_alloc_kernel expect caller holds it.
Reverse that: don't lock or unlock init_mm.page_table_lock in any of the
architectures; instead rely on pud_alloc,pmd_alloc,pte_alloc_kernel to take
and drop it when allocating a new one, to check lest a racing task already
did. Similarly no page_table_lock in vmalloc's map_vm_area.
Some temporary ugliness in __pud_alloc and __pmd_alloc: since they also handle
user mms, which are converted only by a later patch, for now they have to lock
differently according to whether or not it's init_mm.
If sources get muddled, there's a danger that an arch source taking
init_mm.page_table_lock will be mixed with common source also taking it (or
neither take it). So break the rules and make another change, which should
break the build for such a mismatch: remove the redundant mm arg from
pte_alloc_kernel (ppc64 scrapped its distinct ioremap_mm in 2.6.13).
Exceptions: arm26 used pte_alloc_kernel on user mm, now pte_alloc_map; ia64
used pte_alloc_map on init_mm, now pte_alloc_kernel; parisc had bad args to
pmd_alloc and pte_alloc_kernel in unused USE_HPPA_IOREMAP code; ppc64
map_io_page forgot to unlock on failure; ppc mmu_mapin_ram and ppc64 im_free
took page_table_lock for no good reason.
Expand SB1 cache error handling by adding SB1_CEX_ALWAYS_FATAL and
SB1_CEX_STALL, allowing configurable behavior on cache errors.
Signed-Off-By: Andy Isaacson <adi@broadcom.com>
Cacheflush(0, 0, 0) was crashing the system. This is because
flush_icache_range(start, end) tries to flushing whole address space
(0 - ~0UL) if both start and end are zero.
This may have made sense on a paranoid day with pass 1 BCM1250 processors
that were throwing cache error exception left and right for no good
reason. On modern silicion that hardly makes sense and the code had
gotten just an obscurity ...
Signed-Off-By: Andrew Isaacson <adi@broadcom.com>
tx39_flush_cache_range() does nothing if !cpu_has_dc_aliases. It should
flush d-cache and invalidate i-cache since the TX39(H2) has separate I/D
cache.
Signed-off-by: Thiemo Seufer <ths@networkno.de>
Code cleanup.
will also avoid smp_call_function from doing stupid things when called
from a CPU that is not yet marked online.
a little polishing.
Those literals are long.
Minor clean-ups.
delay slots properly and avoiding an unnecessary jump to a jump.
