Remove the function pci_enable_swapping() that is not used anywhere.
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Patchwork: https://patchwork.linux-mips.org/patch/8867/
Signed-off-by: Paul Burton <paul.burton@mips.com>
Cc: John Crispin <blogic@openwrt.org>
Cc: linux-mips@linux-mips.org
IP27 is coherent and has a reasonably direct mapping, just with a little
per-bus offset added into the dma address.
Patchwork: https://patchwork.linux-mips.org/patch/19542/
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: David Daney <david.daney@cavium.com>
Cc: Kevin Cernekee <cernekee@gmail.com>
Cc: Jiaxun Yang <jiaxun.yang@flygoat.com>
Cc: Tom Bogendoerfer <tsbogend@alpha.franken.de>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: iommu@lists.linux-foundation.org
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Signed-off-by: John Crispin <blogic@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/6320/
commit 3747069b25e419f6b51395f48127e9812abc3596 upstream.
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
and are flagged as __cpuinit -- so if we remove the __cpuinit from
the arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
related content into no-ops as early as possible, since that will get
rid of these warnings. In any case, they are temporary and harmless.
Here, we remove all the MIPS __cpuinit from C code and __CPUINIT
from asm files. MIPS is interesting in this respect, because there
are also uasm users hiding behind their own renamed versions of the
__cpuinit macros.
[1] https://lkml.org/lkml/2013/5/20/589
[ralf@linux-mips.org: Folded in Paul's followup fix.]
Patchwork: https://patchwork.linux-mips.org/patch/5494/
Patchwork: https://patchwork.linux-mips.org/patch/5495/
Patchwork: https://patchwork.linux-mips.org/patch/5509/
Then <asm-generic/topology.h> will define cpp macro as default definition
for pcibus_to_node resulting in:
CC arch/mips/pci/pci-ip27.o
arch/mips/pci/pci-ip27.c:220:7: error: expected identifier or ‘(’ before ‘void’
arch/mips/pci/pci-ip27.c:220:12: error: expected ‘)’ before ‘(’ token
make[1]: *** [arch/mips/pci/pci-ip27.o] Error 1
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Fixups are executed once the pci-device is found which is during boot
process so __init seems fine as long as the platform does not support
hotplug.
However it is possible to remove the PCI bus at run time and have it
rediscovered again via "echo 1 > /sys/bus/pci/rescan" and this will call
the fixups again.
[ralf@linux-mips.org: Made piixirqmap[] in malta_piix_func0_fixup()
__initdata.]
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Some architectures (alpha, mips, powerpc) have an arch-specific
"pci_probe_only" flag. Others use PCI_PROBE_ONLY in pci_flags for
the same purpose. This moves mips to the pci_flags approach so
generic code can use the same test across all architectures.
CC: Ralf Baechle <ralf@linux-mips.org>
CC: linux-mips@linux-mips.org
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Or else we get lots of variations on this:
arch/mips/pci/pci.c:330: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL'
scattered throughout the build.
Some of the were relying into smp.h being dragged in by another header
which of course is fragile. <asm/cpu-info.h> uses smp_processor_id()
only in macros and including smp.h there leads to an include loop, so
don't change cpu-info.h.
Use the generic pci_swizzle_interrupt_pin() instead of arch-specific code.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
pcibios_map_irq is no way of returning an error but on IP27 an interrupt
is possibly not routable when running out of resources. So do the
interrupt routing at pcibios_enable_device time.
Declare pci_probe_only, etc. in asm-mips/pci.h file. This will fix
some sparse warnings.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
- fix PCI interrupt assignment by emulating ioc3 interrupt pin register
- use pci_probe_only mode
- select correct page size in bridge
- remove no longer needed ioc3_sio_init() code
[Ralf: Fix for 64kB or larger pagesizes]
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
This is to break the code of people who think they are supposed to scribble
into the pci device structure - it's off limits.
infrastructure for it.
Let it rip!
