path: root/arch/mips/sgi-ip27/ip27-smp.c
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-03-29remove references to cpu_*_map in arch/Rusty Russell
This has been obsolescent for a while; time for the final push. In adjacent context, replaced old cpus_* with cpumask_*. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net> (arch/sparc) Acked-by: Chris Metcalf <cmetcalf@tilera.com> (arch/tile) Cc: user-mode-linux-devel@lists.sourceforge.net Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-arm-kernel@lists.infradead.org Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: sparclinux@vger.kernel.org
2009-09-30MIPS: SMP: Fix build.Ralf Baechle
commit 48a048fed82a8e5fdd8618574f6d3de1a0d67a50 Author: Rusty Russell <rusty@rustcorp.com.au> Date: Thu Sep 24 09:34:44 2009 -0600 apparently only passed the "looks good" level of QA ;-) Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-24cpumask: arch_send_call_function_ipi_mask: mipsRusty Russell
We're weaning the core code off handing cpumask's around on-stack. This introduces arch_send_call_function_ipi_mask(), and by defining it, the old arch_send_call_function_ipi is defined by the core code. We also take the chance to wean the implementations off the obsolescent for_each_cpu_mask(): making send_ipi_mask take the pointer seemed the most natural way to ensure all implementations used for_each_cpu. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-30trivial: Fix misspelling of firmwareNick Andrew
Fix misspelling of firmware. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-12-13cpumask: centralize cpu_online_map and cpu_possible_mapRusty Russell
Impact: cleanup Each SMP arch defines these themselves. Move them to a central location. Twists: 1) Some archs (m32, parisc, s390) set possible_map to all 1, so we add a CONFIG_INIT_ALL_POSSIBLE for this rather than break them. 2) mips and sparc32 '#define cpu_possible_map phys_cpu_present_map'. Those archs simply have phys_cpu_present_map replaced everywhere. 3) Alpha defined cpu_possible_map to cpu_present_map; this is tricky so I just manipulate them both in sync. 4) IA64, cris and m32r have gratuitous 'extern cpumask_t cpu_possible_map' declarations. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Tested-by: Tony Luck <tony.luck@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Mike Travis <travis@sgi.com> Cc: ink@jurassic.park.msu.ru Cc: rmk@arm.linux.org.uk Cc: starvik@axis.com Cc: tony.luck@intel.com Cc: takata@linux-m32r.org Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: paulus@samba.org Cc: schwidefsky@de.ibm.com Cc: lethal@linux-sh.org Cc: wli@holomorphy.com Cc: davem@davemloft.net Cc: jdike@addtoit.com Cc: mingo@redhat.com
2008-06-05[MIPS] IP27: Fix clockevent setupThomas Bogendoerfer
Fix breakage introduced by converting hub_rt to clockevent. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] SMP: Call platform methods via ops structure.Ralf Baechle
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Remove IP27 specific structures from struct cpuinfo_mipsRalf Baechle
2007-08-27[MIPS] SMP: Scatter __cpuinit over the code as needed.Ralf Baechle
MIPS doesn't do CPU hotplugging yet but since many of the functions don't even have an __init let's fix this right. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] IP27: Fix modpost warning.Ralf Baechle
MODPOST vmlinux.o WARNING: vmlinux.o(.text+0x3180): Section mismatch: reference to .init.text:per_cpu_init (between 'prom_init_secondary' and 'alloc_cpupda') Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-27[MIPS] SMP: Fix initialization order bug.Ralf Baechle
A recent change requires cpu_possible_map to be initialized before smp_sched_init() but most MIPS platforms were initializing their processors in the prom_prepare_cpus callback of smp_prepare_cpus. The simple fix of calling prom_prepare_cpus from one of the earlier SMP initialization hooks doesn't work well either since IPIs may require init_IRQ() to have completed, so bit the bullet and split prom_prepare_cpus into two initialization functions, plat_smp_setup which is called early from setup_arch and plat_prepare_cpus called where prom_prepare_cpus used to be called. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-01-12[PATCH] mips: task_thread_info()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Replace the complicated and broken attempt to clean interrupt byRalf Baechle
something simple - doesn't need to be fast, after all. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29It's unwise to disable all interrupts of the boot node ;-)Ralf Baechle
