path: root/arch/mips/sgi-ip27/ip27-timer.c
2011-05-19Merge branch 'timers-clocksource-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: convert mips to generic i8253 clocksource clocksource: convert x86 to generic i8253 clocksource clocksource: convert footbridge to generic i8253 clocksource clocksource: add common i8253 PIT clocksource blackfin: convert to clocksource_register_hz mips: convert to clocksource_register_hz/khz sparc: convert to clocksource_register_hz/khz alpha: convert to clocksource_register_hz microblaze: convert to clocksource_register_hz/khz ia64: convert to clocksource_register_hz/khz x86: Convert remaining x86 clocksources to clocksource_register_hz/khz Make clocksource name const
2011-05-19MIPS: IP27: Remove pointless switch statement.Ralf Baechle
2011-05-14Merge branch 'consolidate-clksrc-i8253' of ↵Thomas Gleixner
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource Conflicts: arch/ia64/kernel/cyclone.c arch/mips/kernel/i8253.c arch/x86/kernel/i8253.c Reason: Resolve conflicts so further cleanups do not conflict further Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29MIPS: Convert the irq functions to the new namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25MIPS: IP27: Convert to new irq_chip functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2203/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-02-21mips: convert to clocksource_register_hz/khzJohn Stultz
This converts the mips clocksources to use clocksource_register_hz/khz CC: Ralf Baechle <ralf@linux-mips.org> CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com>
2009-11-02MIPS: Add IRQF_TIMER flag for timer interruptsWu Zhangjin
Along the lines of d6c585a4342a2ff627a29f9aea77c5ed4cd76023, add IRQF_TIMER flag for all timer interrupts This ensures that timer interrupts won't be disabled on suspend and not threaded for PREEMPT_RT. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-10-15MIPS: IP27: Switch over to RTC class driverThomas Bogendoerfer
This patchset removes some dead code and creates a platform device for the RTC class driver. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-05[MIPS] IP27: Fix clockevent setupThomas Bogendoerfer
Fix breakage introduced by converting hub_rt to clockevent. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] ip27-timer: fix unsigned irq < 0Roel Kluin
Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Acked-By: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-03-12[MIPS] Fix loads of section missmatchesRalf Baechle
2007-11-02[MIPS] IP27: Fix build error.Ralf Baechle
2007-10-29[MIPS] IP27: Fix slice logic to work for arbitrary number of slices.Ralf Baechle
2007-10-22[MIPS] time: SMP/NUMA-proofing of IP27 HUB RT timer code.Ralf Baechle
2007-10-18[MIPS] IP27: Convert to clock_event_device.Ralf Baechle
This separates the tick timer stuff from the generic MIPS time.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] IP27: Add clocksource driversRalf Baechle
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Use generic NTP code for all MIPS platformsRalf Baechle
2007-02-18[MIPS] IP27: Fix warning.Ralf Baechle
2007-02-06[MIPS] use name instead of typename for each irq_chipAtsushi Nemoto
The "typename" field was obsoleted by the "name" field. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-06[MIPS] Compile __do_IRQ() when really neededFranck Bui-Huu
__do_IRQ() is needed only by irq handlers that can't use default handlers defined in kernel/irq/chip.c. For others platforms there's no need to compile this function since it won't be used. For those platforms this patch defines GENERIC_HARDIRQS_NO__DO_IRQ symbol which is used exactly for this purpose. Futhermore for platforms which do not use __do_IRQ(), end() method which is part of the 'irq_chip' structure is not used. This patch simply removes this method in this case. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] mips HPT cleanup: make clocksource_mips publicAtsushi Nemoto
Make clocksource_mips public and get rid of mips_hpt_read, mips_hpt_mask. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] use generic_handle_irq, handle_level_irq, handle_percpu_irqAtsushi Nemoto
Further incorporation of generic irq framework. Replacing __do_IRQ() by proper flow handler would make the irq handling path a bit simpler and faster. * use generic_handle_irq() instead of __do_IRQ(). * use handle_level_irq for obvious level-type irq chips. * use handle_percpu_irq for irqs marked as IRQ_PER_CPU. * setup .eoi routine for irq chips possibly used with handle_percpu_irq. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] IRQ cleanupsAtsushi Nemoto
This is a big irq cleanup patch. * Use set_irq_chip() to register irq_chip. * Initialize .mask, .unmask, .mask_ack field. Functions for these method are already exist in most case. * Do not initialize .startup, .shutdown, .enable, .disable fields if default routines provided by irq_chip_set_defaults() were suitable. * Remove redundant irq_desc initializations. * Remove unnecessary local_irq_save/local_irq_restore, spin_lock. With this cleanup, it would be easy to switch to slightly lightwait irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ(). Though whole this patch is quite large, changes in each irq_chip are not quite simple. Please review and test on your platform. Thanks. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-06[MIPS] Make irq number allocator generally available for fixing EV64120.Ralf Baechle
2006-10-31[MIPS] Fixup migration to GENERIC_TIMEAtsushi Nemoto
Since we already moved to GENERIC_TIME, we should implement alternatives of old do_gettimeoffset routines to get sub-jiffies resolution from gettimeofday(). This patch includes: * MIPS clocksource support (based on works by Manish Lachwani). * remove unused gettimeoffset routines and related codes. * remove unised 64bit do_div64_32(). * simplify mips_hpt_init. (no argument needed, __init tag) * simplify c0_hpt_timer_init. (no need to write to c0_count) * remove some hpt_init routines. * mips_hpt_mask variable to specify bitmask of hpt value. * convert jmr3927_do_gettimeoffset to jmr3927_hpt_read. * convert ip27_do_gettimeoffset to ip27_hpt_read. * convert bcm1480_do_gettimeoffset to bcm1480_hpt_read. * simplify sb1250 hpt functions. (no need to subtract and shift) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-10-01[PATCH] kill wall_jiffiesAtsushi Nemoto
With 2.6.18-rc4-mm2, now wall_jiffies will always be the same as jiffies. So we can kill wall_jiffies completely. This is just a cleanup and logically should not change any real behavior except for one thing: RTC updating code in (old) ppc and xtensa use a condition "jiffies - wall_jiffies == 1". This condition is never met so I suppose it is just a bug. I just remove that condition only instead of kill the whole "if" block. [heiko.carstens@de.ibm.com: s390 build fix and cleanup] Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] simplify update_times (avoid jiffies/jiffies_64 aliasing problem)Atsushi Nemoto
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390 timer interrupt handler with this change. Currently update_times() calculates ticks by "jiffies - wall_jiffies", but callers of do_timer() should know how many ticks to update. Passing ticks get rid of this redundant calculation. Also there are another redundancy pointed out by Martin Schwidefsky. This cleanup make a barrier added by 5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes it. As a bonus, this cleanup make wall_jiffies can be removed easily, since now wall_jiffies is always synced with jiffies. (This patch does not really remove wall_jiffies. It would be another cleanup patch) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] IP27: Reformatting.Ralf Baechle
2006-07-13[MIPS] IP27: Invoke setup_irq for timer interrupt so proc stats will be shown.Ralf Baechle
2006-07-13[MIPS] IP27: irq_chip startup method returns unsigned int.Ralf Baechle
2006-07-13[MIPS] IP27: struct irq_desc member handler was renamed to chip.Ralf Baechle
2006-07-13[MIPS] Eleminate interrupt migration helper use.Ralf Baechle
> #define hw_interrupt_type irq_chip > typedef struct irq_chip hw_irq_controller; > #define no_irq_type no_irq_chip > typedef struct irq_desc irq_desc_t; Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-02[PATCH] irq-flags: MIPS: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[MIPS] IP27: Fix collision with hardcoded interrupt number.Ralf Baechle
2006-04-27[MIPS] Fix ip27 build.Atsushi Nemoto
2005-09-07[PATCH] NTP: ntp-helper functionsjohn stultz
This patch cleans up a commonly repeated set of changes to the NTP state variables by adding two helper inline functions: ntp_clear(): Clears the ntp state variables ntp_synced(): Returns 1 if the system is synced with a time server. This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc, sparc64. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
